DataStreamPort.cxx
20#include "DataStreamPort.hxx"
21#include <iostream>
23using namespace YACS::ENGINE;
24using namespace std;
26const char DataStreamPort::NAME[]="DataStreamPort";
27
28DataStreamPort::DataStreamPort(const DataStreamPort& other, Node *newHelder):DataPort(other,newHelder),Port(other,newHelder),_propertyMap(other._propertyMap)
29{
30}
31
32DataStreamPort::DataStreamPort(const std::string& name, Node *node, TypeCode* type):DataPort(name,node,type),Port(node)
33{
34}
35
37{
38}
39
41{
42 return NAME;
43}
44
46
50void DataStreamPort::setProperty(const std::string& name, const std::string& value)
51{
52 _propertyMap[name]=value;
53}
54
56
60std::string DataStreamPort::getProperty(const std::string& name)
61{
62 return _propertyMap[name];
63}
64
66
69void DataStreamPort::setProperties(std::map<std::string,std::string> properties)
70{
71 _propertyMap.clear();
72 std::map<std::string,std::string>::iterator it;
73 for (it = properties.begin(); it != properties.end(); ++it)
74 {
75 setProperty((*it).first, (*it).second); // setProperty virtual and derived
76 }
77}
78
80
85{
86}
DataStreamPort(const DataStreamPort &other, Node *newHelder)
virtual std::string getProperty(const std::string &name)
Get the value of a property of the port.
std::map< std::string, std::string > _propertyMap
virtual void setProperties(std::map< std::string, std::string > properties)
Set the values of all properties of the port.
virtual void initPortProperties()
Initialize port properties at the start of calculation phase.
virtual void setProperty(const std::string &name, const std::string &value)
Set a new value for a property of the port.
Base class for all nodes.
Definition: Node.hxx:70
Base class for all ports.
Definition: Port.hxx:43
Definition: TypeCode.hxx:68
