YACS::ENGINE::Port Class Reference
Base class for all ports. More...
#include <Port.hxx>
Inheritance diagram for YACS::ENGINE::Port:
Collaboration diagram for YACS::ENGINE::Port:
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
 Port (Node *node)
Node * _node
int _id
Static Protected Attributes
static int _total = 0
Not instanciable class that factorizes all basic data and behaviours relative to the in and out interfaces of all nodes. End-user should neither instanciate a sub-class of 'Port' nor call other methods than accessor.
Definition at line 42 of file Port.hxx.
◆ ~Port()
Port::~Port ( )
Definition at line 44 of file Port.cxx.
45{
46}
◆ Port() [1/2]
Port::Port ( Node *  node)
Definition at line 34 of file Port.cxx.
34 :_node(node)
35{
36 _id = _total++;
37}
static int _total
Definition: Port.hxx:57
Node * _node
Definition: Port.hxx:55
References _id, and _total.
◆ Port() [2/2]
Port::Port ( const Port &  other,
Node *  newHelder
Definition at line 39 of file Port.cxx.
39 :_node(newHelder)
40{
41 _id = _total++;
42}
◆ getNode()
Node * YACS::ENGINE::Port::getNode ( ) const
Definition at line 46 of file Port.hxx.
46{ return _node; }
Referenced by YACS::ENGINE::RuntimeSALOME::adapt(), YACS::ENGINE::CollectorSwOutPort::addPotentialProducerForMaster(), YACS::ENGINE::Bloc::Bloc(), YACS::ENGINE::OutPort::calculateHistoryOfLinkWith(), YACS::HMI::LinkMatrix::cellFrom(), YACS::HMI::LinkMatrix::cellTo(), YACS::ENGINE::ComposedNode::checkCFLinks(), YACS::ENGINE::DynParaLoop::checkCFLinks(), YACS::ENGINE::ForLoop::checkCFLinks(), YACS::ENGINE::Loop::checkCFLinks(), YACS::ENGINE::Bloc::checkControlDependancy(), YACS::ENGINE::StaticDefinedComposedNode::checkControlDependancy(), YACS::ENGINE::DynParaLoop::checkLinkPossibility(), YACS::ENGINE::ForEachLoopGen::checkLinkPossibility(), YACS::ENGINE::OptimizerLoop::checkLinkPossibility(), YACS::ENGINE::ComposedNode::checkLinksCoherenceRegardingControl(), YACS::ENGINE::DynParaLoop::cloneAndPlaceNodesCoherently(), YACS::ENGINE::ComposedNode::edAddDFLink(), YACS::ENGINE::ComposedNode::edAddLink(), YACS::HMI::EditionInputPort::EditionInputPort(), YACS::HMI::EditionOutputPort::EditionOutputPort(), YACS::ENGINE::ConditionInputPort::edNotifyDereferencedBy(), YACS::ENGINE::ConditionInputPort::edNotifyReferencedBy(), YACS::ENGINE::ComposedNode::edRemoveLink(), YACS::ENGINE::ElementaryNode::edRemovePort(), YACS::HMI::SchemaInPortItem::flags(), YACS::HMI::SchemaOutPortItem::flags(), YACS::ENGINE::ForEachLoopGen::getFEDeltaBetween(), YACS::ENGINE::CollectorSwOutPort::getHumanReprOfIncompleteCases(), YACS::ENGINE::ElementaryNode::getInPortName(), YACS::ENGINE::ElementaryNode::getOutPortName(), YACS::ENGINE::OptimizerLoop::initInterceptors(), YACS::HMI::SubjectComposedNode::loadLinks(), YACS::HMI::InPortMenu::popupMenu(), YACS::HMI::OutPortMenu::popupMenu(), YACS::ENGINE::InputStudyPort::putDataInStudy(), YACS::HMI::SubjectNode::restoreLinks(), YACS::HMI::SubjectNode::saveLinks(), YACS::HMI::SchemaInPortItem::SchemaInPortItem(), YACS::HMI::GuiExecutor::setInPortValue(), YACS::HMI::SubjectDataPort::setName(), YACS::HMI::SubjectInputPort::SubjectInputPort(), YACS::HMI::SubjectOutputPort::SubjectOutputPort(), YACS::HMI::SchemaInPortItem::update(), YACS::ENGINE::VisitorSaveSchema::writeSimpleDataLinks(), YACS::ENGINE::VisitorSaveSchema::writeSimpleStreamLinks(), and YACS::HMI::SubjectDataPort::~SubjectDataPort().
◆ getNumId()
int YACS::ENGINE::Port::getNumId ( ) const
◆ modified()
◆ typeName()
◆ _id
int YACS::ENGINE::Port::_id
Definition at line 56 of file Port.hxx.
Referenced by Port().
◆ _node
◆ _total
int Port::_total = 0
staticprotected
Definition at line 57 of file Port.hxx.
◆ NAME
const char Port::NAME ="Port"
staticprotected
Definition at line 58 of file Port.hxx.
Referenced by getNameOfTypeOfCurrentInstance().
