YACS::ENGINE::InGate Class Reference
#include <InGate.hxx>
Inheritance diagram for YACS::ENGINE::InGate:
Collaboration diagram for YACS::ENGINE::InGate:
 InGate (Node *node)
virtual ~InGate ()
void exNotifyFromPrecursor (OutGate *fromgate)
 Notify this port that an upstream node connected by a control flow link is finished. More...
std::list< std::pair< OutGate *, bool > > & edMapOutGate ()
void edAppendPrecursor (OutGate *fromgate)
void edRemovePrecursor (OutGate *fromgate)
int getNumberOfBackLinks () const
void edDisconnectAllLinksToMe ()
void exNotifyFailed ()
 Notify this port that an upstream node connected by a control flow link has failed. More...
void exNotifyDisabled ()
 Notify this port that an upstream node connected by a control flow link has been disabled. More...
void exReset ()
bool exIsReady () const
std::list< OutGate * > getBackLinks ()
void setPrecursorDone (OutGate *fromgate)
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
Static Protected Attributes
static const char NAME [] ="InGate"
static int _total = 0
std::list< std::pair< OutGate *, bool > > _backLinks
Friends
class Bloc
class Node
 Port (Node *node)
Node * _node
int _id
Definition at line 35 of file InGate.hxx.
◆ InGate()
InGate::InGate ( Node *  node)
Definition at line 33 of file InGate.cxx.
33 :Port(node)
34{
35}
Port(Node *node)
Definition: Port.cxx:34
◆ ~InGate()
InGate::~InGate ( )
Definition at line 37 of file InGate.cxx.
38{
39}
◆ edAppendPrecursor()
void InGate::edAppendPrecursor ( OutGate *  fromgate)
Definition at line 99 of file InGate.cxx.
100{
101 list< pair<OutGate *, bool> >::iterator iter(std::find_if(_backLinks.begin(),_backLinks.end(),ItemCmp(from)));
102 if(iter!=_backLinks.end())
103 (*iter).second=false;
104 else
105 _backLinks.push_back(pair<OutGate *, bool>(from,false));
106}
Definition: InGate.hxx:42
References _backLinks.
Referenced by YACS::ENGINE::OutGate::edAddInGate().
◆ edDisconnectAllLinksToMe()
void InGate::edDisconnectAllLinksToMe ( )
Definition at line 46 of file InGate.cxx.
47{
48 for(list< std::pair<OutGate *, bool> >::iterator iter=_backLinks.begin();iter!=_backLinks.end();iter++)
49 ((*iter).first)->edRemoveInGate(this,false);
50 _backLinks.clear();
51}
Referenced by YACS::ENGINE::Node::edDisconnectAllLinksWithMe().
◆ edMapOutGate()
std::list< std::pair< OutGate *, bool > > & YACS::ENGINE::InGate::edMapOutGate ( )
Definition at line 48 of file InGate.hxx.
48{ return _backLinks; }
Referenced by YACS::ENGINE::CFDirectionVisTraits< false >::getNexts().
◆ edRemovePrecursor()
void InGate::edRemovePrecursor ( OutGate *  fromgate)
Definition at line 108 of file InGate.cxx.
109{
110 list< pair<OutGate *, bool> >::iterator iter(std::find_if(_backLinks.begin(),_backLinks.end(),ItemCmp(from)));
111 if(iter!=_backLinks.end())
112 _backLinks.erase(iter);
113}
Referenced by YACS::ENGINE::OutGate::edRemoveInGate(), and YACS::ENGINE::OutGate::edRemoveInGateOneWay().
◆ exIsReady()
◆ exNotifyDisabled()
void InGate::exNotifyDisabled ( )
Definition at line 93 of file InGate.cxx.
94{
95 if(_node)
97}
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, and YACS::ENGINE::Node::exDisabledState().
◆ exNotifyFailed()
void InGate::exNotifyFailed ( )
Definition at line 83 of file InGate.cxx.
84{
85 if(_node)
87}
virtual void exFailedState()
Notify this node that its execution has failed.
Definition: Node.cxx:219
References YACS::ENGINE::Port::_node, and YACS::ENGINE::Node::exFailedState().
◆ exNotifyFromPrecursor()
void InGate::exNotifyFromPrecursor ( OutGate *  from)
Calls the node's gate method : Node::exUpdateState
Called by OutGate::exNotifyDone
Definition at line 68 of file InGate.cxx.
69{
70 DEBTRACE("InGate::exNotifyFromPrecursor");
71 list< pair<OutGate *, bool> >::iterator iter(std::find_if(_backLinks.begin(),_backLinks.end(),ItemCmp(from)));
72 if(iter==_backLinks.end())
73 throw YACS::Exception("InGate::exNotifyFromPrecursor : precursor not found !");
74 (*iter).second=true;
75 if(exIsReady())
77}
bool exIsReady() const
Definition: InGate.cxx:126
virtual void exUpdateState()
Update the node state.
Definition: Node.cxx:206
References _backLinks, YACS::ENGINE::Port::_node, DEBTRACE, exIsReady(), and YACS::ENGINE::Node::exUpdateState().
Referenced by YACS::ENGINE::ElementaryNode::getReadyTasks().
◆ exReset()
void InGate::exReset ( )
Definition at line 120 of file InGate.cxx.
121{
122 for(list< std::pair<OutGate *, bool> >::iterator iter=_backLinks.begin();iter!=_backLinks.end();iter++)
123 (*iter).second=false;
124}
Referenced by YACS::ENGINE::Node::init(), and YACS::ENGINE::ElementaryNode::initCommonPartWithoutStateManagement().
◆ getBackLinks()
string InGate::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::Port.
Definition at line 41 of file InGate.cxx.
42{
43 return NAME;
44}
static const char NAME[]
Definition: InGate.hxx:40
References NAME.
◆ getNumberOfBackLinks()
int InGate::getNumberOfBackLinks ( ) const
Definition at line 115 of file InGate.cxx.
116{
117 return _backLinks.size();
118}
◆ setPrecursorDone()
void InGate::setPrecursorDone ( OutGate *  fromgate)
Definition at line 142 of file InGate.cxx.
143{
144 list< std::pair<OutGate *, bool> >::iterator iter(std::find_if(_backLinks.begin(),_backLinks.end(),ItemCmp(from)));
145 if(iter!=_backLinks.end())
146 (*iter).second=true;
147 else
148 throw YACS::Exception("InGate::setPrecursorDone : precursor not found !");
149}
Referenced by YACS::ENGINE::graphParser::onEnd(), and YACS::ENGINE::Node::resetState().
◆ typeName()
virtual std::string YACS::ENGINE::InGate::typeName ( )
Definition at line 59 of file InGate.hxx.
59{return "YACS__ENGINE__InGate";}
◆ Bloc
friend class Bloc
friend
Definition at line 37 of file InGate.hxx.
◆ Node
friend class Node
friend
Definition at line 38 of file InGate.hxx.
◆ _backLinks
std::list< std::pair<OutGate *, bool> > YACS::ENGINE::InGate::_backLinks
◆ NAME
const char InGate::NAME ="InGate"
staticprotected
Definition at line 40 of file InGate.hxx.
Referenced by getNameOfTypeOfCurrentInstance().
