Bloc.cxx
20#include "Bloc.hxx"
21#include "LinkInfo.hxx"
22#include "InputPort.hxx"
24#include "OutputPort.hxx"
26#include "ElementaryNode.hxx"
27#include "Visitor.hxx"
28#include "ForkBlocPoint.hxx"
29#include "SetOfPoints.hxx"
30#include "PlayGround.hxx"
31
32#include <queue>
33#include <iostream>
34#include <numeric>
35
36//#define _DEVDEBUG_
37#include "YacsTrace.hxx"
38
39using namespace YACS::ENGINE;
40using namespace std;
41
48Bloc::Bloc(const Bloc& other, ComposedNode *father, bool editionOnly):StaticDefinedComposedNode(other,father),_fwLinks(0),_bwLinks(0)
49{
50 for(list<Node *>::const_iterator iter=other._setOfNode.begin();iter!=other._setOfNode.end();iter++)
51 _setOfNode.push_back((*iter)->simpleClone(this,editionOnly));
52
53 //CF Linking
54 vector< pair<OutGate *, InGate *> > cfLinksToReproduce=other.getSetOfInternalCFLinks();
55 vector< pair<OutGate *, InGate *> >::iterator iter1=cfLinksToReproduce.begin();
56 for(;iter1!=cfLinksToReproduce.end();iter1++)
57 edAddCFLink(getChildByName(other.getChildName((*iter1).first->getNode())),getChildByName(other.getChildName((*iter1).second->getNode())));
58
59 //Data + DataStream linking
60 vector< pair<OutPort *, InPort *> > linksToReproduce=other.getSetOfInternalLinks();
61 vector< pair<OutPort *, InPort *> >::iterator iter2=linksToReproduce.begin();
62 for(;iter2!=linksToReproduce.end();iter2++)
63 {
64 OutPort* pout = iter2->first;
65 InPort* pin = iter2->second;
66 if(&other == getLowestCommonAncestor(pout->getNode(), pin->getNode()))
67 {
68 edAddLink(getOutPort(other.getPortName(pout)),getInPort(other.getPortName(pin)));
69 }
70 }
71}
72
74
77Bloc::Bloc(const std::string& name):StaticDefinedComposedNode(name),_fwLinks(0),_bwLinks(0)
78{
79}
80
82{
83 for(list<Node *>::iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
84 delete *iter;
85 delete _fwLinks;
86 delete _bwLinks;
87}
88
90
95void Bloc::init(bool start)
96{
97 Node::init(start);
98 for(list<Node *>::iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
99 (*iter)->init(start);
100}
101
103
108{
109 if(_state==YACS::DONE)return true;
110 if(_state==YACS::ERROR)return true;
111 if(_state==YACS::FAILED)return true;
112 if(_state==YACS::DISABLED)return true;
113 return false;
114}
115
117{
118 int ret=0;
119 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
120 ret+=(*iter)->getOutGate()->getNbOfInGatesConnected();
121 return ret;
122}
123
124Node *Bloc::simpleClone(ComposedNode *father, bool editionOnly) const
125{
126 return new Bloc(*this,father,editionOnly);
127}
128
130
133void Bloc::getReadyTasks(std::vector<Task *>& tasks)
134{
135 /*
136 * ComposedNode state goes to ACTIVATED when one of its child has been ACTIVATED
137 * To change this uncomment the following line
138 * Then the father node will go to ACTIVATED state before its child node
139 */
142 for(list<Node *>::iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
143 (*iter)->getReadyTasks(tasks);
144}
145
147
154{
155 if(_state == YACS::DISABLED)return;
156 if(_state == YACS::DONE)return;
157 if(_inGate.exIsReady())
158 {
160 for(list<Node *>::iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
161 if((*iter)->exIsControlReady())
162 (*iter)->exUpdateState();
163 }
164}
165
167
177{
179 {
180 if(node->_father==this)
181 return false;
182 else
183 {
184 string what = "Bloc::edAddChild : node "; what += node->getName();
185 what += " is already grand children of node";
186 throw Exception(what);
187 }
188 }
189
190 if(node->_father)
191 {
192 string what = "Bloc::edAddChild: node is not orphan: "; what += node->getName();
193 throw Exception(what);
194 }
195
197
198 if(isNameAlreadyUsed(node->getName()))
199 {
200 string what("Bloc::edAddChild : name "); what+=node->getName();
201 what+=" already exists in the scope of "; what+=_name;
202 throw Exception(what);
203 }
204
205 node->_father=this;
206 _setOfNode.push_back(node);
207 //should we also set _modified flag for node ??
208 ComposedNode *iter=node->_father;
209 //set the _modified flag so that latter on edUpdateState (eventually called by isValid) refresh state
210 //better call it at end
211 modified();
212 return true;
213}
214
221{
223 list<Node *>::iterator iter=find(_setOfNode.begin(),_setOfNode.end(),node);
224 if(iter!=_setOfNode.end())
225 {
226 _setOfNode.erase(iter);
227 modified();
228 }
229}
230
231std::vector< std::list<Node *> > Bloc::splitIntoIndependantGraph() const
232{
233 std::size_t sz(_setOfNode.size());
234 list<Node *>::const_iterator it=_setOfNode.begin();
235 for(;it!=_setOfNode.end();it++)
236 (*it)->_colour=White;
237 it=_setOfNode.begin();
238 std::vector< list<Node *> > ret;
239 while(it!=_setOfNode.end())
240 {
241 Node *start(*it); start->_colour=Grey;
242 ret.push_back(list<Node *>());
243 list<Node *>& ll(ret.back());
244 std::queue<Node *> fifo; fifo.push(start);
245 while(!fifo.empty())
246 {
247 Node *cur(fifo.front()); fifo.pop();
248 ll.push_back(cur);
249 //
250 OutGate *og(cur->getOutGate());
251 list<InGate *> og2(og->edSetInGate());
252 for(list<InGate *>::const_iterator it2=og2.begin();it2!=og2.end();it2++)
253 {
254 Node *cur2((*it2)->getNode());
255 if(cur2->_colour==White)
256 {
257 cur2->_colour=Grey;
258 fifo.push(cur2);
259 }
260 }
261 //
262 InGate *ig(cur->getInGate());
263 list<OutGate *> bl(ig->getBackLinks());
264 for(list<OutGate *>::const_iterator it3=bl.begin();it3!=bl.end();it3++)
265 {
266 Node *cur3((*it3)->getNode());
267 if(cur3->_colour==White)
268 {
269 cur3->_colour=Grey;
270 fifo.push(cur3);
271 }
272 }
273 }
274 for(it=_setOfNode.begin();it!=_setOfNode.end() && (*it)->_colour!=White;it++);
275 }
276 return ret;
277}
278
279Node *Bloc::getChildByShortName(const std::string& name) const
280{
281 for (list<Node *>::const_iterator iter = _setOfNode.begin(); iter != _setOfNode.end(); iter++)
282 if ((*iter)->getName() == name)
283 return (*iter);
284 string what("node "); what+= name ; what+=" is not a child of Bloc "; what += getName();
285 throw Exception(what);
286}
287
289{
290 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
291 {
292 if((*iter)->_state == YACS::DONE)continue;
293 if((*iter)->_state == YACS::DISABLED)continue;
294 return false;
295 }
296 return true;
297}
298
300{
301 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
302 {
303 if((*iter)->_state == YACS::DONE)continue;
304 if((*iter)->_state == YACS::FAILED)continue;
305 if((*iter)->_state == YACS::DISABLED)continue;
306 if((*iter)->_state == YACS::ERROR)continue;
307 if((*iter)->_state == YACS::INTERNALERR)continue;
308 return false;
309 }
310 return true;
311}
312
313bool Bloc::isNameAlreadyUsed(const std::string& name) const
314{
315 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
316 if((*iter)->getName()==name)
317 return true;
318 return false;
319}
320
321bool insertNodeChildrenInSet(Node *node, std::set<Node *>& nodeSet)
322{
323 bool verdict=true;
324 list<Node *> outNodes=node->getOutNodes();
325 for (list<Node *>::iterator iter=outNodes.begin();iter!=outNodes.end(); iter++)
326 {
327 verdict=(nodeSet.insert(*iter)).second;
328 if (verdict) verdict = insertNodeChildrenInSet((*iter),nodeSet);
329 }
330 return verdict;
331}
332
339{
340 set<Node *> currentNodesToTest;
341 //don't insert node to test in set.
342 //If it is present after insertion of connected nodes we have a loop
343 //collect all connected nodes
344 insertNodeChildrenInSet(node,currentNodesToTest);
345 //try to insert node
346 if(!(currentNodesToTest.insert(node)).second)
347 throw Exception("Cycle has been detected",1);
348}
349
350std::vector< std::pair<OutGate *, InGate *> > Bloc::getSetOfInternalCFLinks() const
351{
352 vector< pair<OutGate *, InGate *> > ret;
353 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
354 {
355 list<InGate *> outCFLinksOfCurNode=(*iter)->_outGate.edSetInGate();
356 for(list<InGate *>::iterator iter2=outCFLinksOfCurNode.begin();iter2!=outCFLinksOfCurNode.end();iter2++)
357 ret.push_back(pair<OutGate *, InGate *>(&(*iter)->_outGate,*iter2));
358 }
359 return ret;
360}
361
371{
372 DEBTRACE("Bloc::updateStateOnFinishedEventFrom: " << node->getName());
373 //ASSERT(node->_father==this)
375 {
377 if(!areAllSubNodesDone())
378 {
380 return YACS::ABORT;
381 }
382 return YACS::FINISH;//notify to father node that 'this' has becomed finished.
383 }
384 //more job to do in 'this' bloc
385 //Conversion exceptions can be thrown so catch them to control errors
386 try
387 {
388 //notify the finished node to propagate to its following nodes
389 node->exForwardFinished();
390 }
391 catch(YACS::Exception& ex)
392 {
393 //The node has failed to propagate. It must be put in error
394 DEBTRACE("Bloc::updateStateOnFinishedEventFrom: " << ex.what());
395 // notify the node it has failed
396 node->exForwardFailed();
398 return YACS::ABORT;
399 }
400 return YACS::NOEVENT;//no notification to father needed because from father point of view nothing happened.
401}
402
404
409{
410 node->exForwardFailed();
412 {
414 if(!areAllSubNodesDone()){
416 return YACS::ABORT;
417 }
418 return YACS::FINISH;//notify to father node that 'this' has becomed finished.
419 }
420 return YACS::NOEVENT;
421}
422
423void Bloc::writeDot(std::ostream &os) const
424{
425 os << " subgraph cluster_" << getId() << " {\n" ;
426 list<Node *>nodes=getChildren();
427 for(list<Node *>::const_iterator iter=nodes.begin();iter!=nodes.end();iter++)
428 {
429 (*iter)->writeDot(os);
430 string p=(*iter)->getId();
431 //not connected node
432 if((*iter)->_inGate._backLinks.size() == 0) os << getId() << " -> " << p << ";\n";
433 list<Node *>outnodes = (*iter)->getOutNodes();
434 for(list<Node *>::const_iterator itout=outnodes.begin();itout!=outnodes.end();itout++)
435 {
436 os << p << " -> " << (*itout)->getId() << ";\n";
437 }
438 }
439 os << "}\n" ;
440 os << getId() << "[fillcolor=\"" ;
442 os << getColorState(state);
443 os << "\" label=\"" << "Bloc:" ;
444 os << getQualifiedName() <<"\"];\n";
445}
446
447void Bloc::accept(Visitor* visitor)
448{
449 visitor->visitBloc(this);
450}
451
457{
458 std::list< AbstractPoint * > pts(analyzeParallelism());
459 ForkBlocPoint fbp(pts,NULL);
460 return fbp.getMaxLevelOfParallelism();
461}
462
463std::list< AbstractPoint * > Bloc::analyzeParallelism() const
464{
465 std::vector< std::list<Node *> > r(splitIntoIndependantGraph());
466 std::list< AbstractPoint * > pts;
467 for(std::vector< std::list<Node *> >::const_iterator it=r.begin();it!=r.end();it++)
468 {
469 SetOfPoints sop(*it);
470 sop.simplify();
471 pts.push_back(sop.getUniqueAndReleaseIt());
472 }
473 return pts;
474}
475
477{
478 std::list< AbstractPoint * > pts(analyzeParallelism());
479 ForkBlocPoint fbp(pts,NULL);
480 fbp.getWeightRegardingDPL(weight);
481}
482
484{
489 std::set< std::pair<Node *, Node *> > linksToKill(info.getInfoUselessLinks());
490 for(std::set< std::pair<Node *, Node *> >::const_iterator it=linksToKill.begin();it!=linksToKill.end();it++)
491 edRemoveCFLink((*it).first,(*it).second);
493}
494
496{
497 if(!pd)
498 throw Exception("Bloc::partitionRegardingDPL : NULL pointer !");
499 std::list< AbstractPoint * > pts(analyzeParallelism());
500 ForkBlocPoint fbp(pts,NULL);
501 fbp.partitionRegardingDPL(pd,zeMap);
502}
503
505{
506 delete _fwLinks;//Normally useless
507 delete _bwLinks;//Normally useless
508 _fwLinks=new map<Node *,set<Node *> >;
509 _bwLinks=new map<Node *,set<Node *> >;
510
511 //a set to store all CF links : used to find fastly if two nodes are connected
512 std::set< std::pair< Node*, Node* > > links;
513
514 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
515 {
516 Node* n1=*iter;
517 std::list<InGate *> ingates=n1->getOutGate()->edSetInGate();
518 for(std::list<InGate *>::const_iterator it2=ingates.begin();it2!=ingates.end();it2++)
519 {
520 //CF link : n1 -> (*it2)->getNode()
521 Node* n2=(*it2)->getNode();
522 links.insert(std::pair< Node*, Node* >(n1,n2));
523 std::set<Node *> bwn1=(*_bwLinks)[n1];
524 std::set<Node *> fwn1=(*_fwLinks)[n1];
525 std::set<Node *> fwn2=(*_fwLinks)[n2];
526 std::set<Node *> bwn2=(*_bwLinks)[n2];
527 std::pair<std::set<Node*>::iterator,bool> ret;
528 for(std::set<Node *>::const_iterator iter2=bwn1.begin();iter2!=bwn1.end();iter2++)
529 {
530 for(std::set<Node *>::const_iterator it3=fwn2.begin();it3!=fwn2.end();it3++)
531 {
532 ret=(*_fwLinks)[*iter2].insert(*it3);
533 if(ret.second==false)
534 {
535 //dependency already exists (*iter2) -> (*it3) : if a direct link exists it's a useless one
536 if(links.find(std::pair< Node*, Node* >(*iter2,*it3)) != links.end())
537 info.pushUselessCFLink(*iter2,*it3);
538 }
539 }
540 ret=(*_fwLinks)[*iter2].insert(n2);
541 if(ret.second==false)
542 {
543 //dependency already exists (*iter2) -> n2 : if a direct link exists it's a useless one
544 if(links.find(std::pair< Node*, Node* >(*iter2,n2)) != links.end())
545 info.pushUselessCFLink(*iter2,n2);
546 }
547 }
548 for(std::set<Node *>::const_iterator it3=fwn2.begin();it3!=fwn2.end();it3++)
549 {
550 ret=(*_fwLinks)[n1].insert(*it3);
551 if(ret.second==false)
552 {
553 //dependency already exists n1 -> *it3 : if a direct link exists it's a useless one
554 if(links.find(std::pair< Node*, Node* >(n1,*it3)) != links.end())
555 info.pushUselessCFLink(n1,*it3);
556 }
557 }
558 ret=(*_fwLinks)[n1].insert(n2);
559 if(ret.second==false)
560 {
561 //dependency already exists n1 -> n2 : it's a useless link
562 info.pushUselessCFLink(n1,n2);
563 }
564
565 for(std::set<Node *>::const_iterator iter2=fwn2.begin();iter2!=fwn2.end();iter2++)
566 {
567 (*_bwLinks)[*iter2].insert(bwn1.begin(),bwn1.end());
568 (*_bwLinks)[*iter2].insert(n1);
569 }
570 (*_bwLinks)[n2].insert(bwn1.begin(),bwn1.end());
571 (*_bwLinks)[n2].insert(n1);
572 }
573 }
574}
575
589{
592}
593
595{
597 delete _fwLinks; _fwLinks=0;
598 delete _bwLinks; _bwLinks=0;
599}
600
614void Bloc::checkControlDependancy(OutPort *start, InPort *end, bool cross,
615 std::map < ComposedNode *, std::list < OutPort * >, SortHierarc >& fw,
616 std::vector<OutPort *>& fwCross,
617 std::map< ComposedNode *, std::list < OutPort *>, SortHierarc >& bw,
618 LinkInfo& info) const
619{
620 if(!cross)
621 {
622 Node *startN=isInMyDescendance(start->getNode());
623 Node *endN=isInMyDescendance(end->getNode());
624 if(startN==endN)
625 bw[(ComposedNode *)this].push_back(start);
626 else if(areLinked(startN,endN,true))
627 fw[(ComposedNode *)this].push_back(start);
628 else
629 if(areLinked(startN,endN,false))
630 bw[(ComposedNode *)this].push_back(start);
631 else
632 info.pushErrLink(start,end,E_UNPREDICTABLE_FED);
633 }
634 else//DFDS detected
636 fwCross.push_back(start);
637 else
639}
640
642
650bool Bloc::areLinked(Node *start, Node *end, bool fw) const
651{
652 set<Node *>& nexts=fw ? (*_fwLinks)[start] : (*_bwLinks)[start];
653 return nexts.find(end)!=nexts.end();
654}
655
657
665{
666 set<Node *>& nexts=(*_fwLinks)[start];
667 set<Node *>& preds=(*_bwLinks)[start];
668 return nexts.find(end)==nexts.end() && preds.find(end)==preds.end();
669}
670
672
679void Bloc::checkCFLinks(const std::list<OutPort *>& starts, InputPort *end, unsigned char& alreadyFed, bool direction, LinkInfo& info) const
680{
681 if(alreadyFed==FREE_ST || alreadyFed==FED_ST)
682 {
683 map<Node *,list <OutPort *> > classPerNodes;
684 for(list< OutPort *>::const_iterator iter1=starts.begin();iter1!=starts.end();iter1++)
685 classPerNodes[isInMyDescendance((*iter1)->getNode())].push_back(*iter1);
686 set<Node *> allNodes;
687 for(map<Node *,list <OutPort *> >::iterator iter2=classPerNodes.begin();iter2!=classPerNodes.end();iter2++)
688 allNodes.insert((*iter2).first);
689 vector<Node *> okAndUseless1,useless2;
690 seekOkAndUseless1(okAndUseless1,allNodes);
691 seekUseless2(useless2,allNodes);//after this point allNodes contains collapses
692 verdictForOkAndUseless1(classPerNodes,end,okAndUseless1,alreadyFed,direction,info);
693 verdictForCollapses(classPerNodes,end,allNodes,alreadyFed,direction,info);
694 verdictForOkAndUseless1(classPerNodes,end,useless2,alreadyFed,direction,info);
695 }
696 else if(alreadyFed==FED_DS_ST)
697 for(list< OutPort *>::const_iterator iter1=starts.begin();iter1!=starts.end();iter1++)
698 info.pushErrLink(*iter1,end,E_COLLAPSE_DFDS);
699}
700
702{
703 for(list<Node *>::const_iterator iter=_setOfNode.begin();iter!=_setOfNode.end();iter++)
704 {
705 (*iter)->_colour=White;
706 (*iter)->getInGate()->exReset();
707 (*iter)->getOutGate()->exReset();
708 }
709}
710
720void Bloc::verdictForOkAndUseless1(const std::map<Node *,std::list <OutPort *> >& pool, InputPort *end,
721 const std::vector<Node *>& candidates, unsigned char& alreadyFed,
722 bool direction, LinkInfo& info)
723{
724 for(vector<Node *>::const_iterator iter=candidates.begin();iter!=candidates.end();iter++)
725 {
726 const list<OutPort *>& mySet=(*pool.find(*iter)).second;
727 if(mySet.size()==1)
728 {
729 if(alreadyFed==FREE_ST)
730 {
731 alreadyFed=FED_ST;//This the final choice. General case !
732 if(!direction)
733 info.pushInfoLink(*(mySet.begin()),end,I_BACK);
734 }
735 else if(alreadyFed==FED_ST)
736 info.pushInfoLink(*(mySet.begin()),end,direction ? I_USELESS : I_BACK_USELESS);//Second or more turn in case of alreadyFed==FREE_ST before call of this method
737 }
738 else
739 {
740 if(dynamic_cast<ElementaryNode *>(*iter))
741 {
742 WarnReason reason;
743 if(alreadyFed==FREE_ST)
744 reason=direction ? W_COLLAPSE_EL : W_BACK_COLLAPSE_EL;
745 else if(alreadyFed==FED_ST)
747 for(list<OutPort *>::const_iterator iter2=mySet.begin();iter2!=mySet.end();iter2++)
748 info.pushWarnLink(*iter2,end,reason);
749 }
750 else
751 ((ComposedNode *)(*iter))->checkCFLinks(mySet,end,alreadyFed,direction,info);//Thanks to recursive model!
752 }
753 }
754}
755
765void Bloc::verdictForCollapses(const std::map<Node *,std::list <OutPort *> >& pool, InputPort *end,
766 const std::set<Node *>& candidates, unsigned char& alreadyFed,
767 bool direction, LinkInfo& info)
768{
770 for(set<Node *>::const_iterator iter=candidates.begin();iter!=candidates.end();iter++)
771 {
772 const list<OutPort *>& mySet=(*pool.find(*iter)).second;
773 if(mySet.size()==1)
774 {
775 if(alreadyFed==FREE_ST)
776 info.pushWarnLink(*(mySet.begin()),end,direction ? W_COLLAPSE : W_BACK_COLLAPSE);
777 else if(alreadyFed==FED_ST)
778 info.pushWarnLink(*(mySet.begin()),end,direction ? W_COLLAPSE_AND_USELESS : W_BACK_COLLAPSE_EL_AND_USELESS);
779 }
780 else
781 {
782 if(dynamic_cast<ElementaryNode *>(*iter))
783 {
784 WarnReason reason;
785 if(alreadyFed==FREE_ST)
786 reason=direction ? W_COLLAPSE_EL : W_BACK_COLLAPSE_EL;
787 else if(alreadyFed==FED_ST)
789 for(list<OutPort *>::const_iterator iter2=mySet.begin();iter2!=mySet.end();iter2++)
790 info.pushWarnLink(*iter2,end,reason);
791 }
792 else
793 {
794 ((ComposedNode *)(*iter))->checkCFLinks(mySet,end,alreadyFed,direction,info);//Thanks to recursive model!
795 WarnReason reason;
796 if(alreadyFed==FREE_ST)
797 reason=direction ? W_COLLAPSE : W_BACK_COLLAPSE;
798 else if(alreadyFed==FED_ST)
800 for(list<OutPort *>::const_iterator iter2=mySet.begin();iter2!=mySet.end();iter2++)
801 info.pushWarnLink(*iter2,end,reason);
802 }
803 }
804 }
805 if(!candidates.empty())
806 if(alreadyFed==FREE_ST)
807 alreadyFed=FED_ST;
808 info.endCollapseTransac();
809}
810
816void Bloc::seekOkAndUseless1(std::vector<Node *>& okAndUseless1, std::set<Node *>& allNodes) const
817{
818 set<Node *>::iterator iter=allNodes.begin();
819 while(iter!=allNodes.end())
820 {
821 set<Node *>& whereToFind=(*_bwLinks)[*iter];
822 std::set<Node *>::iterator iter2;
823 for(iter2=allNodes.begin();iter2!=allNodes.end();iter2++)
824 if((*iter)!=(*iter2))
825 if(whereToFind.find(*iter2)==whereToFind.end())
826 break;
827 if(iter2!=allNodes.end())
828 iter++;
829 else
830 {
831 okAndUseless1.push_back((*iter));
832 allNodes.erase(iter);
833 iter=allNodes.begin();
834 }
835 }
836}
837
842void Bloc::seekUseless2(std::vector<Node *>& useless2, std::set<Node *>& allNodes) const
843{
844 set<Node *>::iterator iter=allNodes.begin();
845 while(iter!=allNodes.end())
846 {
847 set<Node *>& whereToFind=(*_fwLinks)[*iter];
848 std::set<Node *>::iterator iter2;
849 for(iter2=allNodes.begin();iter2!=allNodes.end();iter2++)
850 if((*iter)!=(*iter2))
851 if(whereToFind.find(*iter2)==whereToFind.end())
852 break;
853 if(iter2!=allNodes.end())
854 {
855 iter++;
856 }
857 else
858 {
859 useless2.push_back((*iter));
860 allNodes.erase(iter);
861 iter=allNodes.begin();
862 }
863 }
864}
865
869void Bloc::updateWithNewFind(const std::vector<Node *>& path, std::map<Node *, std::set<Node *> >& fastFinder)
870{
871 if(path.size()>=3)
872 {
873 vector<Node *>::const_iterator iter=path.begin(); iter++;
874 vector<Node *>::const_iterator iter2=path.end(); iter2-=1;
875 for(;iter!=iter2;iter++)
876 fastFinder[*iter].insert(*(iter+1));
877 }
878}
879
883void Bloc::findUselessLinksIn(const std::list< std::vector<Node *> >& res , LinkInfo& info)
884{
885 unsigned maxSize=0;
886 list< vector<Node *> >::const_iterator whereToPeerAt;
887 for(list< vector<Node *> >::const_iterator iter=res.begin();iter!=res.end();iter++)
888 if((*iter).size()>maxSize)
889 {
890 maxSize=(*iter).size();
891 whereToPeerAt=iter;
892 }
893 //
894 if(maxSize>1)
895 {
896 vector<Node *>::const_iterator iter2=(*whereToPeerAt).begin();
897 map<Node *,bool>::iterator iter4;
898 set<Node *> searcher(iter2+1,(*whereToPeerAt).end());//to boost research
899 for(;iter2!=((*whereToPeerAt).end()-2);iter2++)
900 {
901 list< pair<InGate *,bool> >& nexts=(*iter2)->getOutGate()->edMapInGate();
902 for(list< pair<InGate *,bool> >::iterator iter4=nexts.begin();iter4!=nexts.end();iter4++)
903 if((*iter4).first->getNode()!=*(iter2+1))
904 if(searcher.find((*iter4).first->getNode())!=searcher.end())
905 info.pushUselessCFLink(*iter2,(*iter4).first->getNode());
906 searcher.erase(*iter2);
907 }
908 }
909}
bool insertNodeChildrenInSet(Node *node, std::set< Node * > &nodeSet)
Definition: Bloc.cxx:321
Definition: Bloc.hxx:36
void removeRecursivelyRedundantCL()
Definition: Bloc.cxx:483
Node * getChildByShortName(const std::string &name) const
Definition: Bloc.cxx:279
void checkCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
Check control flow links.
Definition: Bloc.cxx:679
std::list< Node * > _setOfNode
Definition: Bloc.hxx:38
int getNumberOfCFLinks() const
Definition: Bloc.cxx:116
void checkControlDependancy(OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
Definition: Bloc.cxx:614
virtual ~Bloc()
Definition: Bloc.cxx:81
bool areLinked(Node *start, Node *end, bool fw) const
Check if two nodes are linked.
Definition: Bloc.cxx:650
void checkNoCyclePassingThrough(Node *node)
Definition: Bloc.cxx:338
bool isNameAlreadyUsed(const std::string &name) const
Definition: Bloc.cxx:313
void accept(Visitor *visitor)
Definition: Bloc.cxx:447
std::vector< std::list< Node * > > splitIntoIndependantGraph() const
Definition: Bloc.cxx:231
std::list< AbstractPoint * > analyzeParallelism() const
Definition: Bloc.cxx:463
Node * simpleClone(ComposedNode *father, bool editionOnly=true) const
Definition: Bloc.cxx:124
bool isFinished()
Indicate if the bloc execution is finished.
Definition: Bloc.cxx:107
std::vector< std::pair< OutGate *, InGate * > > getSetOfInternalCFLinks() const
Definition: Bloc.cxx:350
bool areAllSubNodesFinished() const
Definition: Bloc.cxx:299
std::list< Node * > getChildren() const
Definition: Bloc.hxx:57
void seekOkAndUseless1(std::vector< Node * > &okAndUseless1, std::set< Node * > &allNodes) const
Definition: Bloc.cxx:816
void performCFComputationsOnlyOneLevel(LinkInfo &info) const
Definition: Bloc.cxx:504
static void updateWithNewFind(const std::vector< Node * > &path, std::map< Node *, std::set< Node * > > &fastFinder)
Definition: Bloc.cxx:869
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)
Definition: Bloc.cxx:495
static void verdictForOkAndUseless1(const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::vector< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
Definition: Bloc.cxx:720
static void verdictForCollapses(const std::map< Node *, std::list< OutPort * > > &pool, InputPort *end, const std::set< Node * > &candidates, unsigned char &alreadyFed, bool direction, LinkInfo &info)
Definition: Bloc.cxx:765
YACS::Event updateStateOnFinishedEventFrom(Node *node)
Definition: Bloc.cxx:370
std::map< Node *, std::set< Node * > > * _bwLinks
For internal calculations.
Definition: Bloc.hxx:42
bool areAllSubNodesDone() const
Definition: Bloc.cxx:288
int getMaxLevelOfParallelism() const
Definition: Bloc.cxx:456
bool arePossiblyRunnableAtSameTime(Node *start, Node *end) const
Check if two nodes can run in parallel.
Definition: Bloc.cxx:664
void getWeightRegardingDPL(ComplexWeight *weight)
Definition: Bloc.cxx:476
void init(bool start=true)
Initialize the bloc.
Definition: Bloc.cxx:95
YACS::Event updateStateOnFailedEventFrom(Node *node, const Executor *execInst)
Notify this bloc that a node has failed.
Definition: Bloc.cxx:408
std::map< Node *, std::set< Node * > > * _fwLinks
Definition: Bloc.hxx:40
bool edAddChild(Node *DISOWNnode)
Add a child node to the bloc.
Definition: Bloc.cxx:176
static void findUselessLinksIn(const std::list< std::vector< Node * > > &res, LinkInfo &info)
Definition: Bloc.cxx:883
void performCFComputations(LinkInfo &info) const
Definition: Bloc.cxx:588
void seekUseless2(std::vector< Node * > &useless2, std::set< Node * > &allNodes) const
Definition: Bloc.cxx:842
void initComputation() const
Definition: Bloc.cxx:701
void exUpdateState()
Update the bloc state.
Definition: Bloc.cxx:153
void getReadyTasks(std::vector< Task * > &tasks)
Collect all nodes that are ready to execute.
Definition: Bloc.cxx:133
void edRemoveChild(Node *node)
Definition: Bloc.cxx:220
virtual void writeDot(std::ostream &os) const
Dump to the input stream a dot representation of the node.
Definition: Bloc.cxx:423
void destructCFComputations(LinkInfo &info) const
destroy recursively all results of initial computations.
Definition: Bloc.cxx:594
static const unsigned char FREE_ST
OutPort * getOutPort(const std::string &name) const
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks() const
void checkNoCrossHierachyWith(Node *node) const
std::string getName() const
void edRemoveCFLink(Node *nodeS, Node *nodeE)
Remove a controlflow link.
virtual void edRemoveChild(Node *node)
Remove a child node.
bool isNodeAlreadyAggregated(const Node *node) const
Check that Node 'node' is already a direct son of this.
std::string getPortName(const PORT *port) const
virtual void removeRecursivelyRedundantCL()
virtual void performCFComputations(LinkInfo &info) const
perform recursively all CF computations.
static const unsigned char FED_ST
static const unsigned char FED_DS_ST
bool edAddCFLink(Node *nodeS, Node *nodeE)
Add a controlflow link between two nodes.
bool edAddLink(OutPort *start, InPort *end)
Add a dataflow link between two data ports.
virtual void destructCFComputations(LinkInfo &info) const
Node * isInMyDescendance(Node *nodeToTest) const
Returns the parent of a node that is the direct child of this node.
static ComposedNode * getLowestCommonAncestor(Node *node1, Node *node2)
Retrieves the lowest common ancestor of 2 nodes.
Threaded Executor.
Definition: Executor.hxx:63
void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap) const
std::list< OutGate * > getBackLinks()
Definition: InGate.cxx:134
bool exIsReady() const
Definition: InGate.cxx:126
Base class for Input Ports.
Definition: InputPort.hxx:44
Class that deal with list of semantics links for high level analysis.
Definition: LinkInfo.hxx:83
void pushErrLink(OutPort *semStart, InPort *end, ErrReason reason)
Definition: LinkInfo.cxx:86
void pushInfoLink(OutPort *semStart, InPort *end, InfoReason reason)
Definition: LinkInfo.cxx:71
void pushUselessCFLink(Node *start, Node *end)
Definition: LinkInfo.cxx:107
std::set< std::pair< Node *, Node * > > getInfoUselessLinks() const
Definition: LinkInfo.cxx:266
void pushWarnLink(OutPort *semStart, InPort *end, WarnReason reason)
Definition: LinkInfo.cxx:76
Base class for all nodes.
Definition: Node.hxx:70
std::string _name
Definition: Node.hxx:89
virtual void exForwardFinished()
Definition: Node.cxx:386
ComposedNode * _father
Definition: Node.hxx:90
std::string getColorState(YACS::StatesForNode state) const
Return the color associated to a state.
Definition: Node.cxx:578
InGate _inGate
Definition: Node.hxx:86
Definition: Node.hxx:125
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
std::list< Node * > getOutNodes() const
Definition: Node.cxx:185
const std::string getId() const
Definition: Node.cxx:478
YACS::Colour _colour
Definition: Node.hxx:84
virtual void init(bool start=true)
Definition: Node.cxx:102
OutGate * getOutGate()
Definition: Node.hxx:124
InGate * getInGate()
Definition: Node.hxx:123
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
InPort * getInPort(const std::string &name) const
Definition: Node.cxx:239
virtual void exForwardFailed()
Definition: Node.cxx:378
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
YACS::StatesForNode _state
Definition: Node.hxx:91
std::list< InGate * > edSetInGate() const
Definition: OutGate.cxx:112
Node * getNode() const
Definition: Port.hxx:46
AbstractPoint * getUniqueAndReleaseIt() const
virtual void visitBloc(Bloc *node)=0
Proc * p
Definition: driver.cxx:216
@ E_UNPREDICTABLE_FED
Definition: LinkInfo.hxx:74
@ E_DS_LINK_UNESTABLISHABLE
Definition: LinkInfo.hxx:71
@ W_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:59
@ W_BACK_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:61
@ W_BACK_COLLAPSE_EL
Definition: LinkInfo.hxx:62
@ W_BACK_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:63
@ W_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:57
Event
Definition: define.hxx:56
@ ABORT
Definition: define.hxx:60
@ NOEVENT
Definition: define.hxx:57
@ FINISH
Definition: define.hxx:59
@ White
Definition: define.hxx:28
@ Grey
Definition: define.hxx:29
StatesForNode
Definition: define.hxx:34
@ FAILED
Definition: define.hxx:51
@ ACTIVATED
Definition: define.hxx:41
@ INTERNALERR
Definition: define.hxx:49
@ DONE
Definition: define.hxx:43
@ TOACTIVATE
Definition: define.hxx:40
@ DISABLED
Definition: define.hxx:50
@ ERROR
Definition: define.hxx:52
