YACS::ENGINE::LinkInfo Class Reference
Class that deal with list of semantics links for high level analysis. More...
#include <LinkInfo.hxx>
Collaboration diagram for YACS::ENGINE::LinkInfo:
 LinkInfo (unsigned char level)
void clearAll ()
void startCollapseTransac ()
void endCollapseTransac ()
void setPointOfView (ComposedNode *pov)
void pushInfoLink (OutPort *semStart, InPort *end, InfoReason reason)
void pushWarnLink (OutPort *semStart, InPort *end, WarnReason reason)
void pushErrLink (OutPort *semStart, InPort *end, ErrReason reason)
void pushErrSwitch (CollectorSwOutPort *collector)
void pushUselessCFLink (Node *start, Node *end)
void takeDecision () const
std::string getGlobalRepr () const
std::string getInfoRepr () const
std::string getWarnRepr () const
std::string getErrRepr () const
bool areWarningsOrErrors () const
unsigned getNumberOfInfoLinks (InfoReason reason) const
unsigned getNumberOfWarnLinksGrp (WarnReason reason) const
unsigned getNumberOfErrLinks (ErrReason reason) const
std::set< std::pair< Node *, Node * > > getInfoUselessLinks () const
std::pair< OutPort *, InPort * > getInfoLink (unsigned id, InfoReason reason) const
std::vector< std::pair< OutPort *, InPort * > > getWarnLink (unsigned id, WarnReason reason) const
std::pair< OutPort *, InPort * > getErrLink (unsigned id, ErrReason reason) const
Static Public Attributes
static const unsigned char ALL_STOP_ASAP = 1
static const unsigned char ALL_DONT_STOP = 2
static const unsigned char WARN_ONLY_DONT_STOP = 3
static std::string getStringReprOfI (InfoReason reason)
static std::string getStringReprOfW (WarnReason reason)
static std::string getStringReprOfE (ErrReason reason)
static std::string printThereIsAre (unsigned val, const std::string &other)
ComposedNode * _pov
unsigned int _level
unsigned char _levelOfInfo
std::vector< InPort * > _unsetInPort
std::vector< InPort * > _onlyBackDefined
std::set< std::pair< Node *, Node * > > _uselessLinks
std::map< InfoReason, std::vector< std::pair< OutPort *, InPort * > > > _infos
std::map< WarnReason, std::vector< std::vector< std::pair< OutPort *, InPort * > > > > _collapse
std::map< ErrReason, std::vector< std::pair< OutPort *, InPort * > > > _errors
std::vector< CollectorSwOutPort * > _errorsOnSwitchCases
Definition at line 82 of file LinkInfo.hxx.
◆ LinkInfo()
LinkInfo::LinkInfo ( unsigned char  level)
Definition at line 32 of file LinkInfo.cxx.
32 :_levelOfInfo(level),_level(0)
33{
34}
unsigned int _level
Definition: LinkInfo.hxx:86
Definition: LinkInfo.hxx:87
◆ areWarningsOrErrors()
bool LinkInfo::areWarningsOrErrors ( ) const
Definition at line 199 of file LinkInfo.cxx.
200{
201 return (getNumberOfWarnLinksGrp(W_ALL)!=0) || (getNumberOfErrLinks(E_ALL)!=0) || !_unsetInPort.empty() || !_onlyBackDefined.empty();
202}
Definition: LinkInfo.hxx:89
unsigned getNumberOfErrLinks(ErrReason reason) const
Definition: LinkInfo.cxx:246
Definition: LinkInfo.hxx:88
unsigned getNumberOfWarnLinksGrp(WarnReason reason) const
Definition: LinkInfo.cxx:229
References _onlyBackDefined, _unsetInPort, YACS::ENGINE::E_ALL, getNumberOfErrLinks(), getNumberOfWarnLinksGrp(), and YACS::ENGINE::W_ALL.
Referenced by endCollapseTransac(), main(), YACS::HMI::GenericGui::onRunLoadedSchema(), and YACS::HMI::EditionProc::synchronize().
◆ clearAll()
void LinkInfo::clearAll ( )
Definition at line 36 of file LinkInfo.cxx.
37{
38 _level=0;
39 _unsetInPort.clear();
40 _onlyBackDefined.clear();
41 _uselessLinks.clear();
42 _infos.clear();
43 _collapse.clear();
44 _errors.clear();
46}
Definition: LinkInfo.hxx:90
Definition: LinkInfo.hxx:93
Definition: LinkInfo.hxx:91
Definition: LinkInfo.hxx:92
Definition: LinkInfo.hxx:94
References _collapse, _errors, _errorsOnSwitchCases, _infos, _level, _onlyBackDefined, _unsetInPort, and _uselessLinks.
Referenced by YACS::ENGINE::ComposedNode::checkConsistency().
◆ endCollapseTransac()
void LinkInfo::endCollapseTransac ( )
Definition at line 53 of file LinkInfo.cxx.
54{
55 if(--_level==0)
56 {
59 throw Exception(getGlobalRepr());
62 throw Exception(getErrRepr());
63 }
64}
Definition: LinkInfo.hxx:128
Definition: LinkInfo.hxx:126
std::string getGlobalRepr() const
Definition: LinkInfo.cxx:118
bool areWarningsOrErrors() const
Definition: LinkInfo.cxx:199
std::string getErrRepr() const
Definition: LinkInfo.cxx:182
References _level, _levelOfInfo, ALL_STOP_ASAP, areWarningsOrErrors(), getErrRepr(), getGlobalRepr(), getNumberOfWarnLinksGrp(), YACS::ENGINE::W_ALL, and WARN_ONLY_DONT_STOP.
Referenced by YACS::ENGINE::Bloc::verdictForCollapses().
◆ getErrLink()
std::pair< OutPort *, InPort * > LinkInfo::getErrLink ( unsigned  id,
ErrReason  reason
Definition at line 291 of file LinkInfo.cxx.
292{
293 if(reason==E_NEVER_SET_INPUTPORT)
294 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), _unsetInPort[id] );
295 else if(reason==E_ONLY_BACKWARD_DEFINED)
296 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), _onlyBackDefined[id] );
297 else
298 {
299 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_errors.find(reason);
300 if(iter!=_errors.end())
301 return (*iter).second[id];
302 else
303 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), reinterpret_cast<InPort *>(0) );
304 }
305}
@ E_NEVER_SET_INPUTPORT
Definition: LinkInfo.hxx:69
@ E_ONLY_BACKWARD_DEFINED
Definition: LinkInfo.hxx:70
References _errors, _onlyBackDefined, _unsetInPort, YACS::ENGINE::E_NEVER_SET_INPUTPORT, and YACS::ENGINE::E_ONLY_BACKWARD_DEFINED.
◆ getErrRepr()
std::string LinkInfo::getErrRepr ( ) const
Definition at line 182 of file LinkInfo.cxx.
183{
184 vector<InPort *>::const_iterator iter;
185 ostringstream stream;
186 for(iter=_unsetInPort.begin();iter!=_unsetInPort.end();iter++)
187 stream << getStringReprOfE(E_NEVER_SET_INPUTPORT) << "\"" << _pov->getInPortName(*iter) << "\"." << endl;
188 for(iter=_onlyBackDefined.begin();iter!=_onlyBackDefined.end();iter++)
189 stream << getStringReprOfE(E_ONLY_BACKWARD_DEFINED) << "\"" << _pov->getInPortName(*iter) << "\"." << endl;
190 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter2;
191 for(iter2=_errors.begin();iter2!=_errors.end();iter2++)
192 for(vector< pair<OutPort *,InPort *> >::const_iterator iter3=(*iter2).second.begin();iter3!=(*iter2).second.end();iter3++)
193 stream << getStringReprOfE((*iter2).first) << " between \"" <<_pov->getOutPortName((*iter3).first) << "\" and \"" << _pov->getInPortName((*iter3).second) << endl;
194 for(vector<CollectorSwOutPort *>::const_iterator iter3=_errorsOnSwitchCases.begin();iter3!=_errorsOnSwitchCases.end();iter3++)
195 (*iter3)->getHumanReprOfIncompleteCases(stream);
196 return stream.str();
197}
std::string getOutPortName(const OutPort *) const
std::string getInPortName(const InPort *) const
Get the input port name.
ComposedNode * _pov
Definition: LinkInfo.hxx:85
static std::string getStringReprOfE(ErrReason reason)
Definition: LinkInfo.cxx:364
References _errors, _errorsOnSwitchCases, _onlyBackDefined, _pov, _unsetInPort, YACS::ENGINE::E_NEVER_SET_INPUTPORT, YACS::ENGINE::E_ONLY_BACKWARD_DEFINED, YACS::ENGINE::ComposedNode::getInPortName(), YACS::ENGINE::ComposedNode::getOutPortName(), and getStringReprOfE().
Referenced by endCollapseTransac(), getGlobalRepr(), pushErrLink(), pushErrSwitch(), and takeDecision().
◆ getGlobalRepr()
std::string LinkInfo::getGlobalRepr ( ) const
Definition at line 118 of file LinkInfo.cxx.
119{
120 ostringstream retS; retS << GLOBAL_MESSAGE1;
121 retS << printThereIsAre(getNumberOfErrLinks(E_ALL),"error") << ".\n";
122 retS << printThereIsAre(getNumberOfWarnLinksGrp(W_ALL),"warning") << ".\n";
123 retS << printThereIsAre(getNumberOfInfoLinks(I_ALL),"info") << ".\n";
125 {
126 retS << "****** ERRORS ******" << endl;
127 retS << getErrRepr() << endl;
128 }
130 {
131 retS << "****** WARNINGS ******" << endl;
132 retS << getWarnRepr() << endl;
133 }
135 {
136 retS << "****** INFO ******" << endl;
137 retS << getInfoRepr() << endl;
138 }
139 return retS.str();
140}
static const char GLOBAL_MESSAGE1[]
Definition: LinkInfo.cxx:28
static std::string printThereIsAre(unsigned val, const std::string &other)
Definition: LinkInfo.cxx:389
unsigned getNumberOfInfoLinks(InfoReason reason) const
Definition: LinkInfo.cxx:207
std::string getInfoRepr() const
Definition: LinkInfo.cxx:142
std::string getWarnRepr() const
Definition: LinkInfo.cxx:163
References YACS::ENGINE::E_ALL, getErrRepr(), getInfoRepr(), getNumberOfErrLinks(), getNumberOfInfoLinks(), getNumberOfWarnLinksGrp(), getWarnRepr(), GLOBAL_MESSAGE1, YACS::ENGINE::I_ALL, printThereIsAre(), and YACS::ENGINE::W_ALL.
Referenced by endCollapseTransac(), main(), and YACS::HMI::EditionProc::synchronize().
◆ getInfoLink()
std::pair< OutPort *, InPort * > LinkInfo::getInfoLink ( unsigned  id,
InfoReason  reason
Definition at line 271 of file LinkInfo.cxx.
272{
273 if(reason==I_CF_USELESS)
274 return pair<OutPort *, InPort *>();
275 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.find(reason);
276 if(iter!=_infos.end())
277 return (*iter).second[id];
278 else
279 return pair<OutPort *, InPort *>( reinterpret_cast<OutPort *>(0), reinterpret_cast<InPort *>(0) );
280}
References _infos, and YACS::ENGINE::I_CF_USELESS.
◆ getInfoRepr()
std::string LinkInfo::getInfoRepr ( ) const
Definition at line 142 of file LinkInfo.cxx.
143{
144 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter;
145 ostringstream stream;
146 for(iter=_infos.begin();iter!=_infos.end();iter++)
147 {
148 for(vector< pair<OutPort *,InPort *> >::const_iterator iter2=(*iter).second.begin();iter2!=(*iter).second.end();iter2++)
149 {
150 stream << getStringReprOfI((*iter).first) << " between \"" << _pov->getOutPortName((*iter2).first);
151 stream << "\" and \"" << _pov->getInPortName((*iter2).second) << "\"." << endl;
152 }
153 }
154 set< pair<Node *, Node *> >::const_iterator iter3;
155 for(iter3=_uselessLinks.begin();iter3!=_uselessLinks.end();iter3++)
156 {
157 stream << "Useless CF link between \"" << _pov->getChildName((*iter3).first);
158 stream << "\" and \"" << _pov->getChildName((*iter3).second) << "\"." << endl;
159 }
160 return stream.str();
161}
static std::string getStringReprOfI(InfoReason reason)
Definition: LinkInfo.cxx:307
References _infos, _pov, _uselessLinks, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getInPortName(), YACS::ENGINE::ComposedNode::getOutPortName(), and getStringReprOfI().
Referenced by getGlobalRepr().
◆ getInfoUselessLinks()
std::set< std::pair< Node *, Node * > > LinkInfo::getInfoUselessLinks ( ) const
Definition at line 266 of file LinkInfo.cxx.
267{
268 return _uselessLinks;
269}
References _uselessLinks.
Referenced by YACS::ENGINE::Bloc::removeRecursivelyRedundantCL().
◆ getNumberOfErrLinks()
unsigned LinkInfo::getNumberOfErrLinks ( ErrReason  reason) const
Definition at line 246 of file LinkInfo.cxx.
247{
248 if(reason==E_ALL)
249 return _errors.size()+_onlyBackDefined.size()+_unsetInPort.size()+_errorsOnSwitchCases.size();
250 else if(reason==E_NEVER_SET_INPUTPORT)
251 return _unsetInPort.size();
252 else if(reason==E_ONLY_BACKWARD_DEFINED)
253 return _onlyBackDefined.size();
254 else if(reason==E_UNCOMPLETE_SW)
255 return _errorsOnSwitchCases.size();
256 else
257 {
258 map<ErrReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_errors.find(reason);
259 if(iter!=_errors.end())
260 return (*iter).second.size();
261 else
262 return 0;
263 }
264}
References _errors, _errorsOnSwitchCases, _onlyBackDefined, _unsetInPort, YACS::ENGINE::E_ALL, YACS::ENGINE::E_NEVER_SET_INPUTPORT, YACS::ENGINE::E_ONLY_BACKWARD_DEFINED, and YACS::ENGINE::E_UNCOMPLETE_SW.
Referenced by areWarningsOrErrors(), and getGlobalRepr().
◆ getNumberOfInfoLinks()
unsigned LinkInfo::getNumberOfInfoLinks ( InfoReason  reason) const
If 'reason'==I_ALL returns nummmber of types of links info whereas it returns number of info per type.
Definition at line 207 of file LinkInfo.cxx.
208{
209 if(reason==I_ALL)
210 {
211 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.begin();
212 unsigned val=0;
213 for(;iter!=_infos.end();iter++)
214 val+=(*iter).second.size();
215 return val+_uselessLinks.size();
216 }
217 if(reason==I_CF_USELESS)
218 return _uselessLinks.size();
219 else
220 {
221 map<InfoReason, vector< pair<OutPort *,InPort *> > >::const_iterator iter=_infos.find(reason);
222 if(iter!=_infos.end())
223 return (*iter).second.size();
224 else
225 return 0;
226 }
227}
References _infos, _uselessLinks, YACS::ENGINE::I_ALL, and YACS::ENGINE::I_CF_USELESS.
◆ getNumberOfWarnLinksGrp()
unsigned LinkInfo::getNumberOfWarnLinksGrp ( WarnReason  reason) const
Definition at line 229 of file LinkInfo.cxx.
230{
231 unsigned ret=0;
232 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter;
233 if(reason==W_ALL)
234 {
235 for(iter=_collapse.begin();iter!=_collapse.end();iter++)
236 ret+=(*iter).second.size();
237 return ret;
238 }
239 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter2=_collapse.find(reason);
240 if(iter2!=_collapse.end())
241 return (*iter2).second.size();
242 else
243 return 0;
244}
References _collapse, and YACS::ENGINE::W_ALL.
Referenced by areWarningsOrErrors(), endCollapseTransac(), and getGlobalRepr().
◆ getStringReprOfE()
std::string LinkInfo::getStringReprOfE ( ErrReason  reason)
staticprotected
Definition at line 364 of file LinkInfo.cxx.
365{
366 string ret;
367 if(reason==E_NEVER_SET_INPUTPORT)
368 return "Never set InPort ";
369 if(reason==E_ONLY_BACKWARD_DEFINED)
370 return "Never set InPort only back defined ";
371 switch(reason)
372 {
374 ret="DS unestablishable";
375 break;
376 case E_COLLAPSE_DFDS:
377 ret="DF/DS collapse";
378 break;
379 case E_COLLAPSE_DS:
380 ret="Inter DS collapse";
381 break;
383 ret="Unpredictable fed";
384 }
385 ret+=" "; ret+=LINK_REPR;
386 return ret;
387}
static const char LINK_REPR[]
@ E_UNPREDICTABLE_FED
Definition: LinkInfo.hxx:74
@ E_DS_LINK_UNESTABLISHABLE
Definition: LinkInfo.hxx:71
References YACS::ENGINE::E_COLLAPSE_DFDS, YACS::ENGINE::E_COLLAPSE_DS, YACS::ENGINE::E_DS_LINK_UNESTABLISHABLE, YACS::ENGINE::E_NEVER_SET_INPUTPORT, YACS::ENGINE::E_ONLY_BACKWARD_DEFINED, YACS::ENGINE::E_UNPREDICTABLE_FED, and LINK_REPR.
Referenced by getErrRepr().
◆ getStringReprOfI()
std::string LinkInfo::getStringReprOfI ( InfoReason  reason)
staticprotected
Definition at line 307 of file LinkInfo.cxx.
308{
309 string ret;
310 switch(reason)
311 {
312 case I_USELESS:
313 ret="Useless DF";
314 break;
315 case I_BACK:
316 ret="Back";
317 break;
318 case I_BACK_USELESS:
319 ret="Back and useless";
320 break;
321 case I_BACK_CRAZY:
322 ret+="Crazy back";
323 break;
324 case I_DFDS:
325 ret+="DF/DS";
326 }
327 ret+=" "; ret+=LINK_REPR;
328 return ret;
329}
References YACS::ENGINE::I_BACK, YACS::ENGINE::I_BACK_CRAZY, YACS::ENGINE::I_BACK_USELESS, YACS::ENGINE::I_DFDS, YACS::ENGINE::I_USELESS, and LINK_REPR.
Referenced by getInfoRepr().
◆ getStringReprOfW()
std::string LinkInfo::getStringReprOfW ( WarnReason  reason)
staticprotected
Definition at line 331 of file LinkInfo.cxx.
332{
333 string ret;
334 switch(reason)
335 {
336 case W_COLLAPSE:
337 ret="Collapse";
338 break;
340 ret="Collapse and useless";
341 break;
342 case W_COLLAPSE_EL:
343 ret="Collapse on ElementaryNode";
344 break;
346 ret+="Collapse on ElementaryNode and useless";
347 break;
348 case W_BACK_COLLAPSE:
349 ret+="Back collapse";
350 break;
352 ret+="Back collapse and useless";
353 break;
355 ret+="Back collapse on ElementaryNode";
356 break;
358 ret+="Back collapse and useless on ElementaryNode";
359 }
360 ret+=" "; ret+=LINK_REPR;
361 return ret;
362}
@ W_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:59
@ W_BACK_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:61
@ W_BACK_COLLAPSE_EL
Definition: LinkInfo.hxx:62
@ W_BACK_COLLAPSE_EL_AND_USELESS
Definition: LinkInfo.hxx:63
@ W_COLLAPSE_AND_USELESS
Definition: LinkInfo.hxx:57
References LINK_REPR, YACS::ENGINE::W_BACK_COLLAPSE, YACS::ENGINE::W_BACK_COLLAPSE_AND_USELESS, YACS::ENGINE::W_BACK_COLLAPSE_EL, YACS::ENGINE::W_BACK_COLLAPSE_EL_AND_USELESS, YACS::ENGINE::W_COLLAPSE, YACS::ENGINE::W_COLLAPSE_AND_USELESS, YACS::ENGINE::W_COLLAPSE_EL, and YACS::ENGINE::W_COLLAPSE_EL_AND_USELESS.
Referenced by getWarnRepr().
◆ getWarnLink()
std::vector< std::pair< OutPort *, InPort * > > LinkInfo::getWarnLink ( unsigned  id,
WarnReason  reason
Definition at line 282 of file LinkInfo.cxx.
283{
284 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter=_collapse.find(reason);
285 if(iter!=_collapse.end())
286 return (*iter).second[id];
287 else
288 return vector< pair<OutPort *, InPort *> >();
289}
References _collapse.
◆ getWarnRepr()
std::string LinkInfo::getWarnRepr ( ) const
Definition at line 163 of file LinkInfo.cxx.
164{
165 map<WarnReason, vector< vector< pair<OutPort *,InPort *> > > >::const_iterator iter;
166 ostringstream stream;
167 unsigned i=0;
168 for(iter=_collapse.begin();iter!=_collapse.end();iter++)
169 {
170 stream << getStringReprOfW((*iter).first) << " for group containing following group links: ";
171 vector< vector< pair<OutPort *,InPort *> > >::const_iterator iter2=(*iter).second.begin();
172 for(;iter2!=(*iter).second.end();iter2++)
173 {
174 stream << " Group # " << i++ << " : " << endl;
175 for(vector< pair<OutPort *,InPort *> >::const_iterator iter3=(*iter2).begin();iter3!=(*iter2).end();iter3++)
176 stream << " \"" << _pov->getOutPortName((*iter3).first) << "\" and \"" << _pov->getInPortName((*iter3).second) << endl;
177 }
178 }
179 return stream.str();
180}
static std::string getStringReprOfW(WarnReason reason)
Definition: LinkInfo.cxx:331
References _collapse, _pov, YACS::ENGINE::ComposedNode::getInPortName(), YACS::ENGINE::ComposedNode::getOutPortName(), getStringReprOfW(), and yacsorb.CORBAEngineTest::i.
◆ printThereIsAre()
std::string LinkInfo::printThereIsAre ( unsigned  val,
const std::string &  other
staticprotected
Definition at line 389 of file LinkInfo.cxx.
390{
391 ostringstream ret;
392 ret << "There ";
393 if(val==0)
394 ret << "are no";
395 else if(val==1)
396 ret << "is one";
397 else
398 ret << "are " << val;
399 ret << " " << other;
400 if(val==0 || val>1)
401 ret << "s";
402 return ret.str();
403}
◆ pushErrLink()
◆ pushErrSwitch()
void LinkInfo::pushErrSwitch ( CollectorSwOutPort *  collector)
◆ pushInfoLink()
void LinkInfo::pushInfoLink ( OutPort *  semStart,
InPort *  end,
InfoReason  reason
◆ pushUselessCFLink()
void LinkInfo::pushUselessCFLink ( Node *  start,
Node *  end
Definition at line 107 of file LinkInfo.cxx.
108{
109 _uselessLinks.insert(pair<Node *,Node *>(start,end));
110}
Referenced by YACS::ENGINE::Bloc::findUselessLinksIn(), and YACS::ENGINE::Bloc::performCFComputationsOnlyOneLevel().
◆ pushWarnLink()
void LinkInfo::pushWarnLink ( OutPort *  semStart,
InPort *  end,
WarnReason  reason
Definition at line 76 of file LinkInfo.cxx.
77{
78 if(_collapse[reason].empty())
79 _collapse[reason].push_back(vector< pair<OutPort *,InPort *> >());
80 else
81 if(_collapse[reason].back()[0].second!=end)
82 _collapse[reason].push_back(vector< pair<OutPort *,InPort *> >());
83 _collapse[reason].back().push_back(pair<OutPort *,InPort *>(semStart,end));
84}
Referenced by YACS::ENGINE::ComposedNode::checkCFLinks(), YACS::ENGINE::ComposedNode::solveObviousOrDelegateCFLinks(), YACS::ENGINE::Bloc::verdictForCollapses(), and YACS::ENGINE::Bloc::verdictForOkAndUseless1().
◆ setPointOfView()
void LinkInfo::setPointOfView ( ComposedNode *  pov)
Definition at line 66 of file LinkInfo.cxx.
67{
68 _pov=pov;
69}
References _pov.
◆ startCollapseTransac()
void LinkInfo::startCollapseTransac ( )
Definition at line 48 of file LinkInfo.cxx.
49{
50 _level++;
51}
References _level.
◆ takeDecision()
void LinkInfo::takeDecision ( ) const
Definition at line 112 of file LinkInfo.cxx.
113{
114 if(!_errors.empty())
115 throw Exception(getErrRepr());
116}
References _errors, and getErrRepr().
◆ _collapse
std::map<WarnReason, std::vector< std::vector< std::pair<OutPort *,InPort *> > > > YACS::ENGINE::LinkInfo::_collapse
◆ _errors
std::map<ErrReason, std::vector< std::pair<OutPort *,InPort *> > > YACS::ENGINE::LinkInfo::_errors
◆ _errorsOnSwitchCases
std::vector<CollectorSwOutPort *> YACS::ENGINE::LinkInfo::_errorsOnSwitchCases
Definition at line 94 of file LinkInfo.hxx.
Referenced by clearAll(), getErrRepr(), getNumberOfErrLinks(), and pushErrSwitch().
◆ _infos
std::map<InfoReason, std::vector< std::pair<OutPort *,InPort *> > > YACS::ENGINE::LinkInfo::_infos
Definition at line 91 of file LinkInfo.hxx.
Referenced by clearAll(), getInfoLink(), getInfoRepr(), getNumberOfInfoLinks(), and pushInfoLink().
◆ _level
unsigned int YACS::ENGINE::LinkInfo::_level
◆ _levelOfInfo
unsigned char YACS::ENGINE::LinkInfo::_levelOfInfo
Definition at line 87 of file LinkInfo.hxx.
Referenced by endCollapseTransac(), pushErrLink(), and pushErrSwitch().
◆ _onlyBackDefined
std::vector<InPort *> YACS::ENGINE::LinkInfo::_onlyBackDefined
◆ _pov
ComposedNode* YACS::ENGINE::LinkInfo::_pov
Definition at line 85 of file LinkInfo.hxx.
Referenced by getErrRepr(), getInfoRepr(), getWarnRepr(), and setPointOfView().
◆ _unsetInPort
std::vector<InPort *> YACS::ENGINE::LinkInfo::_unsetInPort
◆ _uselessLinks
std::set< std::pair<Node *, Node *> > YACS::ENGINE::LinkInfo::_uselessLinks
◆ ALL_DONT_STOP
const unsigned char YACS::ENGINE::LinkInfo::ALL_DONT_STOP = 2
Definition at line 127 of file LinkInfo.hxx.
◆ ALL_STOP_ASAP
const unsigned char YACS::ENGINE::LinkInfo::ALL_STOP_ASAP = 1
◆ WARN_ONLY_DONT_STOP
const unsigned char YACS::ENGINE::LinkInfo::WARN_ONLY_DONT_STOP = 3
Definition at line 128 of file LinkInfo.hxx.
