YACS::ENGINE::CollectorSwOutPort Class Reference
#include <Switch.hxx>
Inheritance diagram for YACS::ENGINE::CollectorSwOutPort:
Collaboration diagram for YACS::ENGINE::CollectorSwOutPort:
void getHumanReprOfIncompleteCases (std::ostream &stream) const
virtual ~OutPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool removePotentialProducerForMaster ()
 CollectorSwOutPort (Switch *master, InPort *port)
 CollectorSwOutPort (const CollectorSwOutPort &other, Switch *master)
void addPotentialProducerForMaster (OutPort *port)
bool checkManagementOfPort (OutPort *port)
InPort * _consumer
std::string _className
OutPort * _currentProducer
std::map< int, OutPort * > _potentialProducers
Friends
class Switch
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 37 of file Switch.hxx.
◆ CollectorSwOutPort() [1/2]
CollectorSwOutPort::CollectorSwOutPort ( Switch *  master,
InPort *  port
: 'master' specifies the instance of Switch of which 'this' collects all of these direct or indirect outports going to the same port 'port' (which is out of scope of 'master').
Definition at line 112 of file Switch.cxx.
112 :OutPort("",master,port->edGetType()),
113 DataPort("",master,port->edGetType()),
114 Port(master),
116{
117 _name="Representant_of_";
118 _name+=master->getName();
119 _name+="_for_inport_";
120 _name+=port->getName();
121}
std::string getName() const
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.cxx:41
Definition: DataPort.hxx:55
OutPort(const OutPort &other, Node *newHelder)
Definition: OutPort.cxx:29
Port(Node *node)
Definition: Port.cxx:34
References YACS::ENGINE::DataPort::_name, YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::DataPort::getName().
◆ CollectorSwOutPort() [2/2]
CollectorSwOutPort::CollectorSwOutPort ( const CollectorSwOutPort &  other,
Switch *  master
Definition at line 123 of file Switch.cxx.
123 :OutPort("",master,other.edGetType()),
124 DataPort("",master,other.edGetType()),
125 Port(master),
127{
128 _name=other._name;
129 Switch *othSw=(Switch *)other._node;
130 for(map<int, OutPort *>::const_iterator iter=other._potentialProducers.begin();iter!=other._potentialProducers.end();iter++)
131 {
132 string name=othSw->getOutPortName((*iter).second);
133 _potentialProducers[(*iter).first]=master->getOutPort(name);
134 }
135}
Definition: Switch.hxx:63
std::string getOutPortName(const OutPort *) const
Node * _node
Definition: Port.hxx:55
Definition: Switch.hxx:85
OutPort * getOutPort(const std::string &name) const
Definition: Switch.cxx:459
References YACS::ENGINE::DataPort::_name, YACS::ENGINE::Port::_node, _potentialProducers, YACS::ENGINE::Switch::getOutPort(), and YACS::ENGINE::ComposedNode::getOutPortName().
◆ addInPort()
bool CollectorSwOutPort::addInPort ( InPort *  inPort)
privatevirtual
Implements YACS::ENGINE::OutPort.
Definition at line 83 of file Switch.cxx.
84{
85 bool ret = false;
87 {//a specific link is beeing done
88 ret=_currentProducer->addInPort(inPort);
90 }
91 else//global links asked
92 for(map<int, OutPort *>::iterator iter=_potentialProducers.begin();iter!=_potentialProducers.end();iter++)
93 ret |= (*iter).second->addInPort(inPort);
94 return ret;
95}
virtual bool addInPort(InPort *inPort)=0
References _currentProducer, _potentialProducers, and YACS::ENGINE::OutPort::addInPort().
◆ addPotentialProducerForMaster()
void CollectorSwOutPort::addPotentialProducerForMaster ( OutPort *  port)
Definition at line 137 of file Switch.cxx.
138{
139 int i=((Switch *)_node)->getRankOfNode(port->getNode());
140 map<int, OutPort *>::iterator pt=_potentialProducers.find(i);
141 if(pt==_potentialProducers.end())
142 {
144 _currentProducer=port;
145 }
146 else
147 {
148 _currentProducer=(*pt).second;
149 if(_currentProducer!=port)
150 {
151 string what("CollectorSwOutPort::addPotentialProducerForMaster : In switch node "); what+=_node->getName();
152 what+=" for input named \'"; what+=_consumer->getName(); what+="\' the output "; what+=_currentProducer->getName();
153 what+=" already got out for case of label ";
154 what+=Switch::getRepresentationOfCase((*pt).first);
155 throw Exception(what);
156 }
157 }
159}
Definition: DataPort.cxx:56
Definition: Node.hxx:125
Node * getNode() const
Definition: Port.hxx:46
static std::string getRepresentationOfCase(int i)
Definition: Switch.cxx:761
References _className, _consumer, _currentProducer, YACS::ENGINE::Port::_node, _potentialProducers, YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::Port::getNode(), YACS::ENGINE::Switch::getRepresentationOfCase(), and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::Switch::buildDelegateOf().
◆ checkConsistency()
void CollectorSwOutPort::checkConsistency ( LinkInfo &  info) const
privatevirtual
Called by Switch::checkCFLinks.
Reimplemented from YACS::ENGINE::OutPort.
Definition at line 201 of file Switch.cxx.
202{
203 if(((Switch *)_node)->getNbOfCases()!=_potentialProducers.size())
204 info.pushErrSwitch((CollectorSwOutPort *)this);
205 for(map<int, OutPort *>::const_iterator iter=_potentialProducers.begin();iter!=_potentialProducers.end();iter++)
206 (*iter).second->checkConsistency(info);
207}
void pushErrSwitch(CollectorSwOutPort *collector)
Definition: LinkInfo.cxx:99
References YACS::ENGINE::Port::_node, _potentialProducers, and YACS::ENGINE::LinkInfo::pushErrSwitch().
◆ checkManagementOfPort()
bool CollectorSwOutPort::checkManagementOfPort ( OutPort *  port)
Definition at line 187 of file Switch.cxx.
188{
189 for(map<int, OutPort *>::iterator iter=_potentialProducers.begin();iter!=_potentialProducers.end();iter++)
190 if((*iter).second==port)
191 {
192 _currentProducer=port;
193 return _potentialProducers.size()==1;
194 }
195 throw Exception("CollectorSwOutPort::checkManagementOfPort : unexported port");
196}
References _currentProducer, and _potentialProducers.
◆ edGetNumberOfOutLinks()
int CollectorSwOutPort::edGetNumberOfOutLinks ( ) const
privatevirtual
Definition at line 38 of file Switch.cxx.
39{
40 return 1;
41}
◆ edRemoveAllLinksLinkedWithMe()
void CollectorSwOutPort::edRemoveAllLinksLinkedWithMe ( )
privatevirtual
Implements YACS::ENGINE::DataPort.
Definition at line 63 of file Switch.cxx.
64{
65 map<int, OutPort *>::iterator pt;
66 if(_consumer)
67 for(pt=_potentialProducers.begin();pt!=_potentialProducers.end();pt++)
68 ((*pt).second)->removeInPort(_consumer,true);
69}
int removeInPort(InPort *inPort, bool forward)
Definition: Switch.cxx:97
References _consumer, _potentialProducers, and removeInPort().
◆ edSetInPort()
std::set< InPort * > CollectorSwOutPort::edSetInPort ( ) const
privatevirtual
Definition at line 43 of file Switch.cxx.
44{
45 set<InPort *> ret;
46 if(_consumer)
47 ret.insert(_consumer);
48 return ret;
49}
References _consumer.
◆ getAllRepresented()
void CollectorSwOutPort::getAllRepresented ( std::set< OutPort * > &  represented) const
privatevirtual
Definition at line 76 of file Switch.cxx.
77{
78 map<int, OutPort *>::const_iterator pt;
79 for(pt=_potentialProducers.begin();pt!=_potentialProducers.end();pt++)
80 ((*pt).second)->getAllRepresented(represented);
81}
void getAllRepresented(std::set< OutPort * > &represented) const
References _potentialProducers, and getAllRepresented().
Referenced by getAllRepresented().
◆ getHumanReprOfIncompleteCases()
void CollectorSwOutPort::getHumanReprOfIncompleteCases ( std::ostream &  stream) const
Called by LinkInfo::getErrRepr to have a comprehensible message on throw. When called, typically checkCompletenessOfCases has detected that some potential producers were laking...
Definition at line 213 of file Switch.cxx.
214{
215 set<int> lackingCases;
216 for(map< int ,Node * >::const_iterator iter=((Switch *)_node)->_mapOfNode.begin();iter!=((Switch *)_node)->_mapOfNode.end();iter++)
217 {
218 if(_potentialProducers.find((*iter).first)==_potentialProducers.end())
219 lackingCases.insert((*iter).first);
220 }
221 ostringstream streamForExc;
222 stream << "For link to " << _consumer->getName() << " of node " << _consumer->getNode()->getName()
223 << " the cases of switch node named " << _node->getName()
224 << " do not define links for following cases ids :";
225 for(set<int>::iterator iter=lackingCases.begin();iter!=lackingCases.end();iter++)
226 stream << Switch::getRepresentationOfCase(*iter) << " ";
227 stream << endl;
228}
References _consumer, YACS::ENGINE::Port::_node, _potentialProducers, YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), YACS::ENGINE::Port::getNode(), and YACS::ENGINE::Switch::getRepresentationOfCase().
std::string CollectorSwOutPort::getNameOfTypeOfCurrentInstance ( ) const
privatevirtual
Reimplemented from YACS::ENGINE::DataPort.
Definition at line 58 of file Switch.cxx.
59{
60 return _className;
61}
References _className.
◆ getTypeOfChannel()
TypeOfChannel CollectorSwOutPort::getTypeOfChannel ( ) const
privatevirtual
returns type of channel the port will use for data exchange on runtime : DATAFLOW or DATASTREAM.
Definition at line 71 of file Switch.cxx.
72{
73 return (*(_potentialProducers.begin())).second->getTypeOfChannel();
74}
References _potentialProducers.
◆ isAlreadyLinkedWith()
bool CollectorSwOutPort::isAlreadyLinkedWith ( InPort *  withp) const
privatevirtual
Definition at line 51 of file Switch.cxx.
52{
53 set<InPort *> s;
54 with->getAllRepresentants(s);
55 return s.find(_consumer)!=s.end();
56}
References _consumer, and YACS::ENGINE::InPort::getAllRepresentants().
◆ removeInPort()
int CollectorSwOutPort::removeInPort ( InPort *  inPort,
bool  forward
privatevirtual
Definition at line 97 of file Switch.cxx.
98{
100 {
101 return _currentProducer->removeInPort(inPort,forward);
102 }
103 else
104 throw Exception("CollectorSwOutputPort::edRemoveInputPort : internal error on link removal.");
106}
virtual int removeInPort(InPort *inPort, bool forward)=0
References _currentProducer, and YACS::ENGINE::OutPort::removeInPort().
Referenced by edRemoveAllLinksLinkedWithMe().
◆ removePotentialProducerForMaster()
bool CollectorSwOutPort::removePotentialProducerForMaster ( )
Definition at line 161 of file Switch.cxx.
162{
163 int i;
164 map<int, OutPort *>::iterator result;
165 for(result=_potentialProducers.begin();result!=_potentialProducers.end();result++)
166 if((*result).second==_currentProducer)
167 {
168 i=(*result).first;
169 break;
170 }
171 if(result==_potentialProducers.end())
172 {
173 ostringstream stream; stream << "CollectorSwOutPort::removePotentialProducerForMaster : link from the branch whith id ";
174 stream << i << " not defined";
175 throw Exception(stream.str());
176 }
177 if((*result).second!=_currentProducer)
178 {
179 ostringstream stream; stream << "CollectorSwOutPort::removePotentialProducerForMaster : link from the branch whith id ";
180 stream << i << " defined but the output specified is not compatible";
181 throw Exception(stream.str());
182 }
183 _potentialProducers.erase(result);
184 return _potentialProducers.empty();
185}
References _currentProducer, _potentialProducers, and yacsorb.CORBAEngineTest::i.
Referenced by YACS::ENGINE::Switch::releaseDelegateOf().
◆ Switch
friend class Switch
friend
Definition at line 39 of file Switch.hxx.
◆ _className
std::string YACS::ENGINE::CollectorSwOutPort::_className
Definition at line 61 of file Switch.hxx.
Referenced by addPotentialProducerForMaster(), and getNameOfTypeOfCurrentInstance().
◆ _consumer
InPort* YACS::ENGINE::CollectorSwOutPort::_consumer
◆ _currentProducer
OutPort* YACS::ENGINE::CollectorSwOutPort::_currentProducer
◆ _potentialProducers
