YACS::ENGINE::Switch Class Reference
Control node that emulates the C switch. More...
#include <Switch.hxx>
Inheritance diagram for YACS::ENGINE::Switch:
Collaboration diagram for YACS::ENGINE::Switch:
 Switch (const Switch &other, ComposedNode *father, bool editionOnly)
 Switch (const std::string &name)
 ~Switch ()
void exUpdateState ()
void init (bool start=true)
Node * edSetDefaultNode (Node *DISOWNnode)
Node * edReleaseDefaultNode ()
Node * edReleaseCase (int caseId)
Node * edGetNode (int caseId)
Node * edSetNode (int caseId, Node *DISOWNnode)
void edChangeCase (int oldCase, int newCase)
 Change the case of a node. More...
virtual bool edAddChild (Node *DISOWNnode)
int getMaxCase ()
std::list< Node * > edGetDirectDescendants () const
InputPort * edGetConditionPort ()
void writeDot (std::ostream &os) const
void edRemoveChild (Node *node)
 Remove a child node. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
YACS::StatesForNode getEffectiveState () const
YACS::StatesForNode getEffectiveState (const Node *node) const
 Return the effective state of a node in the context of this switch (its father) More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
Node * getChildByShortName (const std::string &name) const
std::string getMyQualifiedName (const Node *directSon) const
std::string getCaseId (const Node *node) const
int getRankOfNode (Node *node) const
 Get the progress weight of the graph. More...
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Static Public Attributes
static const char DEFAULT_NODE_NAME [] ="default"
static const char SELECTOR_INPUTPORT_NAME [] ="select"
static const int ID_FOR_DEFAULT_NODE =-1973012217
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
YACS::Event updateStateOnFinishedEventFrom (Node *node)
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * > > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * > > &bw, LinkInfo &info) const
void checkNoCyclePassingThrough (Node *node)
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
AnyInputPort _condition
std::map< int, Node * > _mapOfNode
FakeNodeForSwitch * _undispatchableNotificationNode
std::map< InPort *, CollectorSwOutPort * > _outPortsCollector
std::vector< CollectorSwOutPort * > _alreadyExistingCollectors
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
int getNbOfCases () const
static std::string getRepresentationOfCase (int i)
Friends
class FakeNodeForSwitch
class CollectorSwOutPort
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Definition at line 84 of file Switch.hxx.
◆ Switch() [1/2]
Switch::Switch ( const Switch &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 285 of file Switch.cxx.
285 :StaticDefinedComposedNode(other,father),_condition(other._condition,this),
287{
288 for(map<int,Node *>::const_iterator iter=other._mapOfNode.begin();iter!=other._mapOfNode.end();iter++)
289 _mapOfNode[(*iter).first]=(*iter).second->clone(this,editionOnly);
290 if(!editionOnly)
291 for(map<InPort *, CollectorSwOutPort * >::const_iterator iter2=other._outPortsCollector.begin();iter2!=other._outPortsCollector.end();iter2++)
292 {
293 CollectorSwOutPort *newCol=new CollectorSwOutPort(*((*iter2).second),this);
294 _alreadyExistingCollectors.push_back(newCol);
295 }
296}
Definition: Switch.hxx:97
Definition: Switch.hxx:94
friend class CollectorSwOutPort
Definition: Switch.hxx:87
Definition: Switch.hxx:96
Definition: Switch.hxx:93
Definition: Switch.hxx:95
References _alreadyExistingCollectors, _mapOfNode, _outPortsCollector, and CollectorSwOutPort.
◆ Switch() [2/2]
Switch::Switch ( const std::string &  name)
Definition at line 298 of file Switch.cxx.
299{
300}
static YACS::ENGINE::TypeCode * _tc_int
Definition: Runtime.hxx:137
static const char SELECTOR_INPUTPORT_NAME[]
Definition: Switch.hxx:90
◆ ~Switch()
Switch::~Switch ( )
Definition at line 302 of file Switch.cxx.
303{
305
306 for(map< int , Node * >::iterator iter=_mapOfNode.begin();iter!=_mapOfNode.end();iter++)
307 delete (*iter).second;
308 for(map<InPort *, CollectorSwOutPort * >::iterator iter2=_outPortsCollector.begin();iter2!=_outPortsCollector.end();iter2++)
309 delete (*iter2).second;
310 for(vector<CollectorSwOutPort *>::iterator iter3=_alreadyExistingCollectors.begin();iter3!=_alreadyExistingCollectors.end();iter3++)
311 delete (*iter3);
312}
References _alreadyExistingCollectors, _mapOfNode, _outPortsCollector, and _undispatchableNotificationNode.
◆ accept()
void Switch::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ComposedNode.
Definition at line 838 of file Switch.cxx.
839{
840 visitor->visitSwitch(this);
841}
virtual void visitSwitch(Switch *node)=0
References YACS::ENGINE::Visitor::visitSwitch().
◆ buildDelegateOf()
void Switch::buildDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
InPort *  finalTarget,
const std::list< ComposedNode * > &  pointsOfView
Definition at line 701 of file Switch.cxx.
702{
703 map<InPort *, CollectorSwOutPort * >::iterator result=_outPortsCollector.find(finalTarget);
704 CollectorSwOutPort *newCollector;
705 if(result!=_outPortsCollector.end())
706 newCollector=(*result).second;
707 else
708 {
709 newCollector=new CollectorSwOutPort(this,finalTarget);
710 newCollector->edSetType((port.first)->edGetType());
711 _outPortsCollector[finalTarget]=newCollector;
712 }
713 newCollector->addPotentialProducerForMaster(port.first);
714 port.second=newCollector;
715 port.first=newCollector;
716}
void addPotentialProducerForMaster(OutPort *port)
Definition: Switch.cxx:137
void edSetType(TypeCode *type)
Definition: DataPort.cxx:47
References _outPortsCollector, YACS::ENGINE::CollectorSwOutPort::addPotentialProducerForMaster(), CollectorSwOutPort, and YACS::ENGINE::DataPort::edSetType().
◆ checkCFLinks()
void Switch::checkCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
startsIf different of 0, must aggregate at leat 1 element.
end:
alreadyFedin/out parameter. Indicates if 'end' ports is already and surely set or fed by an another port.
directionIf true : forward direction else backward direction.
info: informations collectedduring the check
Definition at line 661 of file Switch.cxx.
662{
663 map<InPort *, CollectorSwOutPort * >::const_iterator iter=_outPortsCollector.find(end);
664 if(iter!=_outPortsCollector.end())
665 {
666 set<OutPort *> represented;
667 (*iter).second->getAllRepresented(represented);
668 list<OutPort *> others;
669 for(list<OutPort *>::const_iterator iter2=starts.begin();iter2!=starts.end();iter2++)
670 if(represented.find(*iter2)==represented.end())
671 others.push_back(*iter2);
672 if(others.empty())
673 alreadyFed=FED_ST;
674 else
675 StaticDefinedComposedNode::checkCFLinks(others,end,alreadyFed,direction,info);//should never happend;
676 }
677 else
678 StaticDefinedComposedNode::checkCFLinks(starts,end,alreadyFed,direction,info);
679}
virtual void checkCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
References _outPortsCollector, YACS::ENGINE::ComposedNode::checkCFLinks(), and YACS::ENGINE::ComposedNode::FED_ST.
◆ checkControlDependancy()
void Switch::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * > > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * > > &  bw,
LinkInfo &  info
Definition at line 681 of file Switch.cxx.
686{
687 throw Exception("Switch::checkControlDependancy : a link was dectected between 2 cases of a switch. Impossible !");
688}
◆ checkLinkPossibility()
void Switch::checkLinkPossibility ( OutPort *  start,
const std::list< ComposedNode * > &  pointsOfViewStart,
InPort *  end,
const std::list< ComposedNode * > &  pointsOfViewEnd
Definition at line 695 of file Switch.cxx.
697{
698 throw Exception("Switch::checkLinkPossibility : A link between 2 different cases of a same Switch requested -> Impossible");
699}
◆ checkNoCyclePassingThrough()
void Switch::checkNoCyclePassingThrough ( Node *  node)
Implements YACS::ENGINE::ComposedNode.
Definition at line 690 of file Switch.cxx.
691{
692 throw Exception("Switch::checkNoCyclePassingThrough : uncorrect control flow link relative to switch");
693}
◆ edAddChild()
bool Switch::edAddChild ( Node *  DISOWNnode)
Definition at line 633 of file Switch.cxx.
634{
635 int aCase = getMaxCase() + 1;
636 DEBTRACE(aCase);
637 bool ret = edSetNode(aCase, node);
638 DEBTRACE(ret);
639 return ret;
640}
Node * edSetNode(int caseId, Node *DISOWNnode)
Definition: Switch.cxx:541
References DEBTRACE, edSetNode(), and getMaxCase().
◆ edChangeCase()
void Switch::edChangeCase ( int  oldCase,
int  newCase
oldCase: the case value to change
newCase: the new value to set raise an exception if the old case does not exist or if the new case already exists
Definition at line 575 of file Switch.cxx.
576{
577 std::map< int , Node * >::iterator iter=_mapOfNode.find(oldCase);
578 if(iter==_mapOfNode.end())
579 {
580 //the case does not exists
581 throw Exception("Switch::edChangeCase : case does not exist");
582 }
583 iter=_mapOfNode.find(newCase);
584 if(iter != _mapOfNode.end())
585 {
586 //the new case exists
587 throw Exception("Switch::edChangeCase : new case exists");
588 }
589 Node* node=_mapOfNode[oldCase];
590 _mapOfNode.erase(oldCase);
591 _mapOfNode[newCase]=node;
592 modified();
593}
Base class for all nodes.
Definition: Node.hxx:70
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References _mapOfNode, and YACS::ENGINE::Node::modified().
Referenced by YACS::HMI::CommandSetSwitchCase::localExecute(), and YACS::HMI::CommandSetSwitchCase::localReverse().
◆ edGetConditionPort()
◆ edGetDirectDescendants()
list< Node * > Switch::edGetDirectDescendants ( ) const
Definition at line 393 of file Switch.cxx.
394{
395 list<Node *> ret;
396 for(map< int , Node * >::const_iterator iter=_mapOfNode.begin();iter!=_mapOfNode.end();iter++)
397 if((*iter).second)
398 ret.push_back((*iter).second);
399 return ret;
400}
References _mapOfNode.
Referenced by getProgressWeight().
◆ edGetNode()
Node * Switch::edGetNode ( int  caseId)
◆ edReleaseCase()
Node * Switch::edReleaseCase ( int  caseId)
Definition at line 509 of file Switch.cxx.
510{
511 map< int , Node * >::iterator iter=_mapOfNode.find(caseId);
512 if(iter==_mapOfNode.end())
513 {
514 string what("Switch::edReleaseCase : the case # "); what+=getRepresentationOfCase(caseId); what+=" is not set yet.";
515 throw Exception(what);
516 }
517 else
518 {
519 Node *ret=(*iter).second;
521 _mapOfNode.erase(iter);
522 modified();
523 return ret;
524 }
525}
virtual void edRemoveChild(Node *node)
static std::string getRepresentationOfCase(int i)
Definition: Switch.cxx:761
References _mapOfNode, YACS::ENGINE::ComposedNode::edRemoveChild(), getRepresentationOfCase(), and YACS::ENGINE::Node::modified().
Referenced by edReleaseDefaultNode(), and edRemoveChild().
◆ edReleaseDefaultNode()
Node * Switch::edReleaseDefaultNode ( )
Definition at line 504 of file Switch.cxx.
505{
507}
Node * edReleaseCase(int caseId)
Definition: Switch.cxx:509
Definition: Switch.hxx:91
References edReleaseCase(), and ID_FOR_DEFAULT_NODE.
◆ edRemoveChild()
void Switch::edRemoveChild ( Node *  node)
Definition at line 432 of file Switch.cxx.
433{
434 map< int , Node * >::iterator iter=_mapOfNode.begin();
435 for(;iter!=_mapOfNode.end();iter++)
436 if(node==(*iter).second)
437 {
438 edReleaseCase((*iter).first);
439 return;
440 }
441 ostringstream what; what << "Switch::edRemoveChild : node with name " << node->getName() << " is not a direct child of Switch node " << _name;
442 throw Exception(what.str());
443}
std::string _name
Definition: Node.hxx:89
Definition: Node.hxx:125
References _mapOfNode, YACS::ENGINE::Node::_name, edReleaseCase(), and YACS::ENGINE::Node::getName().
◆ edSetDefaultNode()
Node * Switch::edSetDefaultNode ( Node *  DISOWNnode)
Definition at line 499 of file Switch.cxx.
500{
501 return edSetNode(ID_FOR_DEFAULT_NODE,node);
502}
References edSetNode(), and ID_FOR_DEFAULT_NODE.
Referenced by YACS::switchtypeParser::default_().
◆ edSetNode()
Node * Switch::edSetNode ( int  caseId,
Node *  node
caseId: the case ID chosen to place 'node'
node: the node for the specified 'caseId'
: If an old node with id equal to 'caseId' exists before, this old node is returned so that to be deallocated. 0 is returned if caseId is a new ID. WARNING : 'node' is held by 'this' after call, whereas returned node is no more held.
Definition at line 541 of file Switch.cxx.
542{
543 if(!node)
544 throw Exception("Switch::edSetNode : null node cannot be set as a case in switch node");
545 if(node->_father!=0)
546 throw Exception("Switch::edSetNode : node already held by another father");
548 node->_father=this;
549 map< int , Node * >::iterator iter=_mapOfNode.find(caseId);
550 if(iter==_mapOfNode.end())
551 {
552 _mapOfNode[caseId]=node;
553 modified();
554 return 0;
555 }
556 else
557 {
558 if(node!=(*iter).second)
559 {
560 Node *ret=(*iter).second;
561 (*iter).second=node;
562 modified();
563 return ret;
564 }
565 }
566 return 0;
567}
void checkNoCrossHierachyWith(Node *node) const
Definition: Node.hxx:90
References YACS::ENGINE::Node::_father, _mapOfNode, YACS::ENGINE::ComposedNode::checkNoCrossHierachyWith(), and YACS::ENGINE::Node::modified().
Referenced by YACS::switchtypeParser::case_(), edAddChild(), and edSetDefaultNode().
◆ exUpdateState()
void Switch::exUpdateState ( )
Update the node state.
: Update the '_state' attribute. Typically called by 'this->_inGate' when 'this->_inGate' is ready.
Called by InGate::exNotifyFromPrecursor
Reimplemented from YACS::ENGINE::Node.
Definition at line 319 of file Switch.cxx.
320{
321 DEBTRACE("Switch::exUpdateState " << _state);
323 return;
324 if(_inGate.exIsReady())
325 {
327 if(_condition.isEmpty())
329 else
330 {
331 map< int , Node * >::iterator iter=_mapOfNode.find(_condition.getIntValue());
332 if(iter==_mapOfNode.end())
333 {
335 if(iter==_mapOfNode.end())
336 {
337 bool normalFinish=getAllOutPortsLeavingCurrentScope().empty();
340 }
341 else
342 ((*iter).second)->exUpdateState();
343 }
344 else
345 ((*iter).second)->exUpdateState();
346 }
347 }
348}
std::set< OutPort * > getAllOutPortsLeavingCurrentScope() const
bool exIsReady() const
Definition: InGate.cxx:126
InGate _inGate
Definition: Node.hxx:86
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
Definition: Node.hxx:91
friend class FakeNodeForSwitch
Definition: Switch.hxx:86
@ ACTIVATED
Definition: define.hxx:41
@ DISABLED
Definition: define.hxx:50
References _condition, YACS::ENGINE::Node::_inGate, _mapOfNode, YACS::ENGINE::Node::_state, _undispatchableNotificationNode, YACS::ACTIVATED, DEBTRACE, YACS::DISABLED, YACS::ENGINE::InGate::exIsReady(), FakeNodeForSwitch, YACS::ENGINE::ComposedNode::getAllOutPortsLeavingCurrentScope(), YACS::ENGINE::AnyInputPort::getIntValue(), ID_FOR_DEFAULT_NODE, YACS::ENGINE::AnyInputPort::isEmpty(), and YACS::ENGINE::Node::setState().
◆ getAllInPortsComingFromOutsideOfCurrentScope()
std::set< InPort * > Switch::getAllInPortsComingFromOutsideOfCurrentScope ( ) const
List all input ports of 'this' so that, for each it exists at least 1 link coming from outside to it.
Definition at line 648 of file Switch.cxx.
649{
651 set<OutPort *> temp2=_condition.edSetOutPort();
652 for(set<OutPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
653 if(!isInMyDescendance((*iter3)->getNode()))
654 {
655 ret.insert((InPort *)&_condition);
656 break;
657 }
658 return ret;
659}
std::set< InPort * > getAllInPortsComingFromOutsideOfCurrentScope() const
Node * isInMyDescendance(Node *nodeToTest) const
virtual std::set< OutPort * > edSetOutPort() const
Returns physical backlinks NOT user backlinks.
Definition: InPort.cxx:65
References _condition, YACS::ENGINE::InPort::edSetOutPort(), YACS::ENGINE::ComposedNode::getAllInPortsComingFromOutsideOfCurrentScope(), and YACS::ENGINE::ComposedNode::isInMyDescendance().
◆ getCaseId()
std::string Switch::getCaseId ( const Node *  node) const
Definition at line 819 of file Switch.cxx.
820{
821 const char sep='_';
822 map<int, Node*>::const_iterator iter;
823 for (iter = _mapOfNode.begin(); iter != _mapOfNode.end(); iter++)
824 if (iter->second == node)
825 {
826 stringstream a;
827 if (iter->first == Switch::ID_FOR_DEFAULT_NODE)
828 a << DEFAULT_NODE_NAME << sep;
829 else if (iter->first <0)
830 a << "m" << -iter->first << sep;
831 else a << "p" << iter->first << sep;
832 return a.str();
833 }
834 string what("node "); what+= node->getName() ; what+=" is not a child of node "; what += getName();
835 throw Exception(what);
836}
std::string getName() const
static const char DEFAULT_NODE_NAME[]
Definition: Switch.hxx:89
References _mapOfNode, gui.CONNECTOR::a, DEFAULT_NODE_NAME, YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getName(), and ID_FOR_DEFAULT_NODE.
Referenced by getMyQualifiedName().
◆ getChildByShortName()
Node * Switch::getChildByShortName ( const std::string &  name) const
Definition at line 477 of file Switch.cxx.
478{
479 if(name==DEFAULT_NODE_NAME)
480 {
481 map< int , Node * >::const_iterator iter=_mapOfNode.find(ID_FOR_DEFAULT_NODE);
482 if(iter!=_mapOfNode.end())
483 return (Node *)((*iter).second);
484 else
485 {
486 string what("Switch::getChildByShortName : no default node defined for switch of name "); what+=getName();
487 throw Exception(what);
488 }
489 }
490 for(map< int , Node * >::const_iterator iter=_mapOfNode.begin();iter!=_mapOfNode.end();iter++)
491 {
492 if(name==((*iter).second)->getQualifiedName())
493 return (*iter).second;
494 }
495 string what("node "); what+= name ; what+=" is not a child of node switch "; what += getName();
496 throw Exception(what);
497}
References _mapOfNode, DEFAULT_NODE_NAME, YACS::ENGINE::ComposedNode::getName(), and ID_FOR_DEFAULT_NODE.
◆ getDelegateOf()
void Switch::getDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
Definition at line 718 of file Switch.cxx.
719{
720 map<InPort *, CollectorSwOutPort * >::iterator iter=_outPortsCollector.find(finalTarget);
721 if(iter==_outPortsCollector.end())
722 {
723 string what("Switch::getDelegateOf : not exported OuputPort with name "); what+=(port.first)->getName(); what+=" for target inport of name ";
724 what+=finalTarget->getName();
725 throw Exception(what);
726 }
727 ((*iter).second)->checkManagementOfPort(port.first);
728 port.second=(*iter).second;
729 port.first=(*iter).second;
730}
Definition: DataPort.hxx:55
References _outPortsCollector, YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::DataPort::getName().
◆ getEffectiveState() [1/2]
YACS::StatesForNode Switch::getEffectiveState ( ) const
Return the node state in the context of its father.
the effective node state
The node state is stored in a private attribute _state. This state is relative to its father state : a node with a TOACTIVATE state with a father node in a READY state is not to activate. Its effective state is only READY. This method returns the effective state of the node taking into account that of its father.
Definition at line 790 of file Switch.cxx.
791{
793}
virtual YACS::StatesForNode getEffectiveState() const
Definition: Node.cxx:538
References YACS::ENGINE::Node::getEffectiveState().
◆ getEffectiveState() [2/2]
YACS::StatesForNode Switch::getEffectiveState ( const Node *  node) const
nodethe node which effective state is queried
Definition at line 778 of file Switch.cxx.
779{
781 if(effectiveState==YACS::READY)
782 return YACS::READY;
783 if(effectiveState==YACS::TOACTIVATE)
784 return YACS::READY;
785 if(effectiveState==YACS::DISABLED)
786 return YACS::DISABLED;
787
788 return node->getState();
789}
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
StatesForNode
Definition: define.hxx:34
@ READY
Definition: define.hxx:37
@ TOACTIVATE
Definition: define.hxx:40
References YACS::DISABLED, YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::Node::getState(), YACS::READY, and YACS::TOACTIVATE.
◆ getInputPort()
InputPort * Switch::getInputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getOutputPort, this method is NOT recursive and so the leaf of type ElementaryNode aggregating this InputPort is directly invoked.
Definition at line 470 of file Switch.cxx.
471{
473 return (InputPort *)&_condition;
475}
InputPort * getInputPort(const std::string &name) const
Base class for Input Ports.
Definition: InputPort.hxx:44
References _condition, YACS::ENGINE::ComposedNode::getInputPort(), and SELECTOR_INPUTPORT_NAME.
◆ getLocalInputPorts()
std::list< InputPort * > Switch::getLocalInputPorts ( ) const
Definition at line 453 of file Switch.cxx.
454{
455 list<InputPort *> ret=StaticDefinedComposedNode::getLocalInputPorts();
456 ret.push_back((InputPort *)&_condition);
457 return ret;
458}
std::list< InputPort * > getLocalInputPorts() const
References _condition, and YACS::ENGINE::ComposedNode::getLocalInputPorts().
◆ getMaxCase()
int Switch::getMaxCase ( )
Definition at line 595 of file Switch.cxx.
596{
597 int aCase = 0;
598 map<int, Node*>::const_iterator it = _mapOfNode.begin();
599 for(; it != _mapOfNode.end(); ++it)
600 if ((*it).first > aCase)
601 aCase = (*it).first;
602 return aCase;
603}
Referenced by edAddChild().
◆ getMaxLevelOfParallelism()
int Switch::getMaxLevelOfParallelism ( ) const
Definition at line 407 of file Switch.cxx.
408{
409 int ret(0);
410 for(std::map< int , Node * >::const_iterator it=_mapOfNode.begin();it!=_mapOfNode.end();it++)
411 ret=std::max(ret,((*it).second)->getMaxLevelOfParallelism());
412 return ret;
413}
◆ getMyQualifiedName()
std::string Switch::getMyQualifiedName ( const Node *  directSon) const
Definition at line 812 of file Switch.cxx.
813{
814 string id=getCaseId(directSon);
815 id+=directSon->getName();
816 return id;
817}
std::string getCaseId(const Node *node) const
Definition: Switch.cxx:819
References getCaseId(), and YACS::ENGINE::Node::getName().
◆ getNbOfCases()
int Switch::getNbOfCases ( ) const
Definition at line 747 of file Switch.cxx.
748{
749 return _mapOfNode.size();
750}
◆ getNumberOfInputPorts()
int Switch::getNumberOfInputPorts ( ) const
◆ getOutPort()
OutPort * Switch::getOutPort ( const std::string &  name) const
: Contrary to getOutputPort method, this method returns the output port at highest level, possible. That is to say in some ComposedNode, like ForEachLoop or Switch, an outport inside 'this' is seen differently than the true outport.
Definition at line 459 of file Switch.cxx.
460{
461 for(map<InPort *, CollectorSwOutPort * >::const_iterator iter=_outPortsCollector.begin();iter!=_outPortsCollector.end();iter++)
462 if(name==(*iter).second->getName())
463 return (*iter).second;
464 for(vector<CollectorSwOutPort *>::const_iterator iter2=_alreadyExistingCollectors.begin();iter2!=_alreadyExistingCollectors.end();iter2++)
465 if(name==(*iter2)->getName())
466 return *iter2;
468}
OutPort * getOutPort(const std::string &name) const
References _alreadyExistingCollectors, _outPortsCollector, and YACS::ENGINE::ComposedNode::getOutPort().
Referenced by YACS::ENGINE::CollectorSwOutPort::CollectorSwOutPort().
◆ getProgressWeight()
list< ProgressWeight > Switch::getProgressWeight ( ) const
Only elementary nodes have weight. If the switch node is not done, we add the weight of all his descendants, otherwise only the weight of the used case count.
Definition at line 610 of file Switch.cxx.
611{
612 list<ProgressWeight> ret;
613 list<Node *> setOfNode=edGetDirectDescendants();
614 if (getState() == YACS::DONE)
615 {
616 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
617 {
618 if (getEffectiveState(*iter) == YACS::DONE)
619 ret=(*iter)->getProgressWeight();
620 }
621 }
622 else
623 {
624 for(list<Node *>::const_iterator iter=setOfNode.begin();iter!=setOfNode.end();iter++)
625 {
626 list<ProgressWeight> myCurrentSet=(*iter)->getProgressWeight();
627 ret.insert(ret.end(),myCurrentSet.begin(),myCurrentSet.end());
628 }
629 }
630 return ret;
631}
Definition: Switch.cxx:790
std::list< Node * > edGetDirectDescendants() const
Definition: Switch.cxx:393
@ DONE
Definition: define.hxx:43
References YACS::DONE, edGetDirectDescendants(), getEffectiveState(), and YACS::ENGINE::Node::getState().
◆ getRankOfNode()
◆ getReadyTasks()
void Switch::getReadyTasks ( std::vector< Task * > &  tasks)
Definition at line 367 of file Switch.cxx.
368{
369 /*
370 * To change the way ComposedNode state is handled, uncomment the following line
371 * see Bloc::getReadyTasks
372 */
375 {
376 map< int , Node * >::iterator iter=_mapOfNode.find(_condition.getIntValue());
377 if(iter!=_mapOfNode.end())
378 ((*iter).second)->getReadyTasks(tasks);
379 else
380 {
382 if(iter!=_mapOfNode.end())
383 (*iter).second->getReadyTasks(tasks);//Default Node is returned
384 else
387 else
388 throw Exception("Switch::getReadyTasks : internal error");
389 }
390 }
391}
void getReadyTasks(std::vector< Task * > &tasks)
Definition: Switch.cxx:367
References _condition, _mapOfNode, YACS::ENGINE::Node::_state, _undispatchableNotificationNode, YACS::ACTIVATED, YACS::ENGINE::AnyInputPort::getIntValue(), YACS::ENGINE::ElementaryNode::getReadyTasks(), getReadyTasks(), ID_FOR_DEFAULT_NODE, YACS::ENGINE::Node::setState(), and YACS::TOACTIVATE.
Referenced by getReadyTasks().
◆ getRepresentationOfCase()
string Switch::getRepresentationOfCase ( int  i)
staticprivate
Definition at line 761 of file Switch.cxx.
762{
764 {
765 ostringstream stream;
766 stream << i;
767 return stream.str();
768 }
769 else
770 return DEFAULT_NODE_NAME;
771}
References DEFAULT_NODE_NAME, yacsorb.CORBAEngineTest::i, and ID_FOR_DEFAULT_NODE.
Referenced by YACS::ENGINE::CollectorSwOutPort::addPotentialProducerForMaster(), edReleaseCase(), and YACS::ENGINE::CollectorSwOutPort::getHumanReprOfIncompleteCases().
◆ getSetOfInputPort()
std::list< InputPort * > Switch::getSetOfInputPort ( ) const
Definition at line 445 of file Switch.cxx.
446{
447 list<InputPort *> ret=StaticDefinedComposedNode::getSetOfInputPort();
448 ret.push_back((InputPort *)&_condition);
449 return ret;
450}
References _condition, and YACS::ENGINE::ComposedNode::getSetOfInputPort().
◆ getWeightRegardingDPL()
void Switch::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 415 of file Switch.cxx.
416{
417 ComplexWeight localWeight;
418 for(std::map< int , Node * >::const_iterator it=_mapOfNode.begin();it!=_mapOfNode.end();it++)
419 {
420 ((*it).second)->getWeightRegardingDPL(&localWeight);
421 weight->max(localWeight);
422 localWeight.setToZero();
423 }
424}
void max(ComplexWeight &other)
void getWeightRegardingDPL(ComplexWeight *weight)
Definition: Switch.cxx:415
References _mapOfNode, getWeightRegardingDPL(), YACS::ENGINE::ComplexWeight::max(), and YACS::ENGINE::ComplexWeight::setToZero().
Referenced by getWeightRegardingDPL().
◆ init()
void Switch::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Definition at line 350 of file Switch.cxx.
351{
352 DEBTRACE("Switch::init " << start);
354 int i=0;
355 for(map< int , Node * >::iterator iter=_mapOfNode.begin();iter!=_mapOfNode.end();iter++, i++)
356 {
357 if(!(*iter).second)
358 {
359 ostringstream stream;
360 stream << "Switch::init : initialization failed due to unitialized branch of id " << (*iter).first;
361 throw Exception(stream.str());
362 }
363 ((*iter).second)->init(start);
364 }
365}
void init(bool start=true)
Definition: Switch.cxx:350
References _mapOfNode, DEBTRACE, yacsorb.CORBAEngineTest::i, YACS::ENGINE::ComposedNode::init(), and init().
Referenced by init().
◆ partitionRegardingDPL()
void Switch::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 426 of file Switch.cxx.
427{
428 for(std::map< int , Node * >::const_iterator it=_mapOfNode.begin();it!=_mapOfNode.end();it++)
429 (*it).second->partitionRegardingDPL(pd,zeMap);
430}
◆ releaseDelegateOf()
void Switch::releaseDelegateOf ( OutPort *  portDwn,
OutPort *  portUp,
Definition at line 732 of file Switch.cxx.
733{
734 set<OutPort *> repr;
735 portDwn->getAllRepresented(repr);
736 if(repr.size()==1)
737 {
738 CollectorSwOutPort *portCasted=dynamic_cast<CollectorSwOutPort *>(portUp);
739 if(portCasted->removePotentialProducerForMaster())//normally always true
740 {
741 delete portCasted;
742 _outPortsCollector.erase(finalTarget);
743 }
744 }
745}
virtual void getAllRepresented(std::set< OutPort * > &represented) const
Definition: OutPort.cxx:45
References _outPortsCollector, YACS::ENGINE::OutPort::getAllRepresented(), and YACS::ENGINE::CollectorSwOutPort::removePotentialProducerForMaster().
◆ simpleClone()
Node * Switch::simpleClone ( ComposedNode *  father,
bool  editionOnly = true
Definition at line 314 of file Switch.cxx.
315{
316 return new Switch(*this,father,editionOnly);
317}
friend class Switch
Definition: Node.hxx:73
References YACS::ENGINE::Node::Switch.
◆ typeName()
virtual std::string YACS::ENGINE::Switch::typeName ( )
Definition at line 133 of file Switch.hxx.
133{return "YACS__ENGINE__Switch";}
◆ updateStateOnFinishedEventFrom()
YACS::Event Switch::updateStateOnFinishedEventFrom ( Node *  node)
Definition at line 642 of file Switch.cxx.
643{
645 return YACS::FINISH;//notify to father node that 'this' has becomed finished.
646}
@ FINISH
Definition: define.hxx:59
References YACS::DONE, YACS::FINISH, and YACS::ENGINE::Node::setState().
◆ writeDot()
void Switch::writeDot ( std::ostream &  os) const
Dump to the input stream a dot representation of the node.
os: the input stream
Definition at line 795 of file Switch.cxx.
796{
797 os << " subgraph cluster_" << getId() << " {\n" ;
798 for(map<int,Node*>::const_iterator iter=_mapOfNode.begin();iter!=_mapOfNode.end();iter++)
799 {
800 Node* n=(*iter).second;
801 n->writeDot(os);
802 os << getId() << " -> " << n->getId() << ";\n";
803 }
804 os << "}\n" ;
805 os << getId() << "[fillcolor=\"" ;
807 os << getColorState(state);
808 os << "\" label=\"" << "Switch:" ;
809 os << getQualifiedName() <<"\"];\n";
810}
std::string getColorState(YACS::StatesForNode state) const
Return the color associated to a state.
Definition: Node.cxx:578
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
const std::string getId() const
Definition: Node.cxx:478
References _mapOfNode, YACS::ENGINE::Node::getColorState(), YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::Node::getId(), YACS::ENGINE::Node::getQualifiedName(), gui.Appli::n, and yacsorb.CORBAEngineTest::state.
◆ CollectorSwOutPort
friend
Definition at line 87 of file Switch.hxx.
Referenced by buildDelegateOf(), and Switch().
◆ FakeNodeForSwitch
friend
Definition at line 86 of file Switch.hxx.
Referenced by exUpdateState().
◆ _alreadyExistingCollectors
std::vector<CollectorSwOutPort *> YACS::ENGINE::Switch::_alreadyExistingCollectors
mutableprotected
Definition at line 97 of file Switch.hxx.
Referenced by getOutPort(), Switch(), and ~Switch().
◆ _condition
AnyInputPort YACS::ENGINE::Switch::_condition
◆ _mapOfNode
◆ _outPortsCollector
std::map<InPort *, CollectorSwOutPort * > YACS::ENGINE::Switch::_outPortsCollector
◆ _undispatchableNotificationNode
FakeNodeForSwitch* YACS::ENGINE::Switch::_undispatchableNotificationNode
Definition at line 95 of file Switch.hxx.
Referenced by exUpdateState(), getReadyTasks(), and ~Switch().
◆ DEFAULT_NODE_NAME
const char Switch::DEFAULT_NODE_NAME ="default"
Definition at line 89 of file Switch.hxx.
Referenced by getCaseId(), getChildByShortName(), and getRepresentationOfCase().
◆ ID_FOR_DEFAULT_NODE
◆ SELECTOR_INPUTPORT_NAME
const char Switch::SELECTOR_INPUTPORT_NAME ="select"
Definition at line 90 of file Switch.hxx.
Referenced by getInputPort().
