YACS::ENGINE::FakeNodeForSwitch Class Reference
#include <Switch.hxx>
Inheritance diagram for YACS::ENGINE::FakeNodeForSwitch:
Collaboration diagram for YACS::ENGINE::FakeNodeForSwitch:
 FakeNodeForSwitch (Switch *sw, bool normalFinish, bool internalError=false)
 FakeNodeForSwitch (const FakeNodeForSwitch &other)
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void exForwardFailed ()
void exForwardFinished ()
void execute ()
void aborted ()
void finished ()
Switch * _sw
bool _normalFinish
bool _internalError
Friends
class Switch
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 66 of file Switch.hxx.
◆ FakeNodeForSwitch() [1/2]
FakeNodeForSwitch::FakeNodeForSwitch ( Switch *  sw,
bool  normalFinish,
bool  internalError = false
Definition at line 230 of file Switch.cxx.
230 :ElementaryNode("thisIsAFakeNode"),
231 _sw(sw),
232 _normalFinish(normalFinish),
233 _internalError(internalError)
234{
237}
Definition: Node.hxx:90
friend class ElementaryNode
Definition: Node.hxx:80
ComposedNode * getFather() const
Definition: Node.hxx:127
Definition: Node.hxx:91
@ TOACTIVATE
Definition: define.hxx:40
References YACS::ENGINE::Node::_father, YACS::ENGINE::Node::_state, _sw, YACS::ENGINE::Node::getFather(), and YACS::TOACTIVATE.
Referenced by simpleClone().
◆ FakeNodeForSwitch() [2/2]
FakeNodeForSwitch::FakeNodeForSwitch ( const FakeNodeForSwitch &  other)
Definition at line 239 of file Switch.cxx.
239 :ElementaryNode(other),_sw(0),
240 _normalFinish(false),
241 _internalError(true)
242{
243}
◆ aborted()
void FakeNodeForSwitch::aborted ( )
privatevirtual
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 266 of file Switch.cxx.
267{
270 else
272}
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
@ INTERNALERR
Definition: define.hxx:49
@ ERROR
Definition: define.hxx:52
References _internalError, YACS::ENGINE::Node::_state, _sw, YACS::ERROR, YACS::INTERNALERR, and YACS::ENGINE::Node::setState().
◆ execute()
void FakeNodeForSwitch::execute ( )
privatevirtual
Implements YACS::ENGINE::Task.
Definition at line 260 of file Switch.cxx.
261{
262 if(!_normalFinish)
263 throw Exception("");//only to trigger ABORT on Executor
264}
References _normalFinish.
◆ exForwardFailed()
void FakeNodeForSwitch::exForwardFailed ( )
privatevirtual
Called typically by Bloc to notify failure on potentially next nodes on the same scope of 'this'
Reimplemented from YACS::ENGINE::Node.
Definition at line 250 of file Switch.cxx.
251{
253}
virtual void exForwardFailed()
Definition: Node.cxx:378
References _sw, and YACS::ENGINE::Node::exForwardFailed().
◆ exForwardFinished()
void FakeNodeForSwitch::exForwardFinished ( )
privatevirtual
Called typically by Bloc to activate potentially next nodes on the same scope of 'this'
Definition at line 255 of file Switch.cxx.
256{
258}
virtual void exForwardFinished()
Definition: Node.cxx:386
References _sw, and YACS::ENGINE::Node::exForwardFinished().
◆ finished()
void FakeNodeForSwitch::finished ( )
privatevirtual
Definition at line 274 of file Switch.cxx.
275{
277}
@ DONE
Definition: define.hxx:43
References _sw, YACS::DONE, and YACS::ENGINE::Node::setState().
◆ simpleClone()
Node * FakeNodeForSwitch::simpleClone ( ComposedNode *  father,
bool  editionOnly
privatevirtual
Definition at line 245 of file Switch.cxx.
246{
247 return new FakeNodeForSwitch(*this);
248}
FakeNodeForSwitch(Switch *sw, bool normalFinish, bool internalError=false)
Definition: Switch.cxx:230
References FakeNodeForSwitch().
◆ Switch
friend class Switch
friend
Definition at line 68 of file Switch.hxx.
◆ _internalError
bool YACS::ENGINE::FakeNodeForSwitch::_internalError
Definition at line 72 of file Switch.hxx.
Referenced by aborted().
◆ _normalFinish
bool YACS::ENGINE::FakeNodeForSwitch::_normalFinish
Definition at line 71 of file Switch.hxx.
Referenced by execute().
◆ _sw
Switch* YACS::ENGINE::FakeNodeForSwitch::_sw
Definition at line 70 of file Switch.hxx.
Referenced by aborted(), exForwardFailed(), exForwardFinished(), FakeNodeForSwitch(), and finished().
