YACS::ENGINE::ComponentInstance Class Referenceabstract
Base class for all component instances. More...
#include <ComponentInstance.hxx>
Inheritance diagram for YACS::ENGINE::ComponentInstance:
Collaboration diagram for YACS::ENGINE::ComponentInstance:
 ComponentInstance (const std::string &name)
 ComponentInstance (const ComponentInstance &other)
const std::string & getCompoName () const
const std::string & getInstanceName () const
virtual void setAnonymous (bool anon)
virtual bool isAnonymous ()
int getNumId () const
virtual bool setContainer (Container *cont)
Container * getContainer () const
virtual void load (Task *askingNode)=0
 Load the component instance. More...
virtual void unload (Task *askingNode)=0
 Unload the component instance. More...
virtual bool isLoaded (Task *askingNode) const =0
 Indicate if the component instance is loaded (true) or not. More...
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
bool isAttachedOnCloning () const
virtual std::string getFileRepr () const
 For dump in file. More...
virtual ServiceNode * createNode (const std::string &name)=0
virtual ComponentInstance * clone () const =0
virtual ComponentInstance * cloneAlways () const =0
virtual std::string getKind () const
 Return the component kind. More...
virtual std::string getKindForNode () const
- Public Member Functions inherited from YACS::ENGINE::PropertyInterface
virtual ~PropertyInterface ()
 Get a property value given its name. More...
std::map< std::string, std::string > getProperties () const
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] =""
virtual ~ComponentInstance ()
 RefCounter ()
virtual ~RefCounter ()
std::string _compoName
 WARNING : _compoName identify only the component type. More...
std::string _instanceName
 WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each other. More...
int _numId
Container * _container
bool _isAttachedOnCloning
bool _anonymous
- Protected Attributes inherited from YACS::ENGINE::PropertyInterface
unsigned int _cnt
Static Protected Attributes
static const char NULL_FILE_REPR [] ="No repr specified for ComponentInstance"
static int _total = 0
This is an abstract class that must be specialized in runtime. Specialized classes must provide implementation for loading of a component (load method) unloading (unload method) and an information method (isLoaded) about the state of the component
A component instance is used by one or more ServiceNode to execute services of this component instance
See also
ServiceNode
Definition at line 38 of file ComponentInstance.hxx.
◆ ~ComponentInstance()
ComponentInstance::~ComponentInstance ( )
Definition at line 87 of file ComponentInstance.cxx.
References _container, and YACS::ENGINE::RefCounter::decrRef().
◆ ComponentInstance() [1/2]
ComponentInstance::ComponentInstance ( const std::string &  name)
Definition at line 66 of file ComponentInstance.cxx.
67{
68 _numId = _total++;
69 stringstream instName;
70 instName << _compoName << "_" << _numId;
71 _instanceName = instName.str();
72}
WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each othe...
References _compoName, _instanceName, _numId, and _total.
◆ ComponentInstance() [2/2]
ComponentInstance::ComponentInstance ( const ComponentInstance &  other)
Definition at line 74 of file ComponentInstance.cxx.
74 :_compoName(other._compoName),
75 _container(0),
77 _anonymous(true)
78{
79 _numId = _total++;
80 stringstream instName;
81 instName << _compoName << "_" << _numId;
82 _instanceName = instName.str();
83 if(other._container)
85}
virtual Container * clone() const =0
WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method
References _compoName, _container, _instanceName, _numId, _total, and YACS::ENGINE::Container::clone().
◆ attachOnCloning()
void ComponentInstance::attachOnCloning ( ) const
By calling this method the current container 'this' is not destined to be deeply copied on clone call.
Definition at line 96 of file ComponentInstance.cxx.
97{
99}
References _isAttachedOnCloning.
◆ clone()
◆ cloneAlways()
◆ createNode()
virtual ServiceNode * YACS::ENGINE::ComponentInstance::createNode ( const std::string &  name)
pure virtual
◆ dettachOnCloning()
void ComponentInstance::dettachOnCloning ( ) const
By calling this method the current container 'this' will be deeply copied on clone call.
Definition at line 110 of file ComponentInstance.cxx.
111{
113}
◆ getCompoName()
◆ getContainer()
◆ getFileRepr()
std::string ComponentInstance::getFileRepr ( ) const
◆ getInstanceName()
◆ getKind()
string ComponentInstance::getKind ( ) const
A runtime can provide several implementations of a component instance. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode is they have the same kind.
Reimplemented in YACS::ENGINE::CORBAComponent, YACS::ENGINE::CppComponent, YACS::ENGINE::SalomeComponent, YACS::ENGINE::SalomeHPComponent, and YACS::ENGINE::SalomePythonComponent.
Definition at line 126 of file ComponentInstance.cxx.
127{
128 return KIND;
129}
References KIND.
Referenced by YACS::ENGINE::CppContainer::checkCapabilityToDealWith(), YACS::ENGINE::SalomeContainer::checkCapabilityToDealWith(), and YACS::ENGINE::SalomeHPContainer::checkCapabilityToDealWith().
◆ getKindForNode()
std::string ComponentInstance::getKindForNode ( ) const
◆ getNumId()
int YACS::ENGINE::ComponentInstance::getNumId ( ) const
Definition at line 50 of file ComponentInstance.hxx.
50{ return _numId; }
Referenced by YACS::HMI::SubjectComponent::getKey().
◆ isAnonymous()
◆ isAttachedOnCloning()
bool ComponentInstance::isAttachedOnCloning ( ) const
Definition at line 115 of file ComponentInstance.cxx.
116{
118}
◆ isLoaded()
virtual bool YACS::ENGINE::ComponentInstance::isLoaded ( Task *  askingNode) const
pure virtual
◆ load()
virtual void YACS::ENGINE::ComponentInstance::load ( Task *  askingNode)
pure virtual
◆ setAnonymous()
virtual void YACS::ENGINE::ComponentInstance::setAnonymous ( bool  anon)
Definition at line 48 of file ComponentInstance.hxx.
48{ _anonymous = anon; };
Referenced by YACS::ENGINE::Proc::addComponentInstance().
◆ setContainer()
bool ComponentInstance::setContainer ( Container *  cont)
◆ setName()
void YACS::ENGINE::ComponentInstance::setName ( const std::string &  name)
◆ shutdown()
void ComponentInstance::shutdown ( int  level)
Reimplemented in YACS::ENGINE::SalomeComponent, and YACS::ENGINE::SalomeHPComponent.
Definition at line 136 of file ComponentInstance.cxx.
137{
138}
Referenced by YACS::ENGINE::SalomeNode::shutdown().
◆ unload()
virtual void YACS::ENGINE::ComponentInstance::unload ( Task *  askingNode)
pure virtual
◆ _anonymous
bool YACS::ENGINE::ComponentInstance::_anonymous
Definition at line 81 of file ComponentInstance.hxx.
◆ _compoName
std::string YACS::ENGINE::ComponentInstance::_compoName
◆ _container
◆ _instanceName
std::string YACS::ENGINE::ComponentInstance::_instanceName
Definition at line 74 of file ComponentInstance.hxx.
Referenced by ComponentInstance().
◆ _isAttachedOnCloning
◆ _numId
int YACS::ENGINE::ComponentInstance::_numId
Definition at line 75 of file ComponentInstance.hxx.
◆ _total
int ComponentInstance::_total = 0
staticprotected
Definition at line 80 of file ComponentInstance.hxx.
◆ KIND
const char ComponentInstance::KIND =""
Definition at line 68 of file ComponentInstance.hxx.
Referenced by getKind(), and getKindForNode().
◆ NULL_FILE_REPR
const char ComponentInstance::NULL_FILE_REPR ="No repr specified for ComponentInstance"
staticprotected
Definition at line 79 of file ComponentInstance.hxx.
Referenced by getFileRepr().
