YACS::ENGINE::SalomeHPComponent Class Reference
#include <SalomeHPComponent.hxx>
Inheritance diagram for YACS::ENGINE::SalomeHPComponent:
Collaboration diagram for YACS::ENGINE::SalomeHPComponent:
 SalomeHPComponent (const std::string &name)
 SalomeHPComponent (const SalomeHPComponent &other)
virtual ~SalomeHPComponent ()
virtual void load (Task *askingNode)
 Load the component. More...
virtual void unload (Task *askingNode)
 Unload the component. More...
virtual bool isLoaded (Task *askingNode) const
 Is the component instance already loaded ? More...
virtual bool setContainer (Container *cont)
virtual ServiceNode * createNode (const std::string &name)
 Create a ServiceNode with this component instance and no input or output port. More...
virtual ComponentInstance * clone () const
 Clone the component instance. More...
virtual ComponentInstance * cloneAlways () const
virtual std::string getFileRepr () const
 For dump in file. More...
virtual CORBA::Object_ptr getCompoPtr ()
virtual std::string getKind () const
 Return the component kind. More...
virtual std::string getKindForNode () const
- Public Member Functions inherited from YACS::ENGINE::ComponentInstance
 ComponentInstance (const std::string &name)
 ComponentInstance (const ComponentInstance &other)
const std::string & getCompoName () const
const std::string & getInstanceName () const
virtual void setAnonymous (bool anon)
virtual bool isAnonymous ()
int getNumId () const
Container * getContainer () const
virtual void load (Task *askingNode)=0
 Load the component instance. More...
virtual void unload (Task *askingNode)=0
 Unload the component instance. More...
virtual bool isLoaded (Task *askingNode) const =0
 Indicate if the component instance is loaded (true) or not. More...
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
bool isAttachedOnCloning () const
virtual ServiceNode * createNode (const std::string &name)=0
virtual ComponentInstance * clone () const =0
virtual ComponentInstance * cloneAlways () const =0
- Public Member Functions inherited from YACS::ENGINE::PropertyInterface
virtual ~PropertyInterface ()
 Get a property value given its name. More...
std::map< std::string, std::string > getProperties () const
void incrRef () const
bool decrRef () const
Static Public Attributes
static const char KIND [] ="HPSalome"
- Static Public Attributes inherited from YACS::ENGINE::ComponentInstance
static const char KIND [] =""
CORBA::Object_var _objComponent
- Protected Attributes inherited from YACS::ENGINE::ComponentInstance
std::string _compoName
 WARNING : _compoName identify only the component type. More...
std::string _instanceName
 WARNING : _InstanceName has a strong semantic. It discriminates ComponentInstance instances each other. More...
int _numId
Container * _container
bool _isAttachedOnCloning
bool _anonymous
- Protected Attributes inherited from YACS::ENGINE::PropertyInterface
unsigned int _cnt
- Protected Member Functions inherited from YACS::ENGINE::ComponentInstance
virtual ~ComponentInstance ()
 RefCounter ()
virtual ~RefCounter ()
- Static Protected Attributes inherited from YACS::ENGINE::ComponentInstance
static const char NULL_FILE_REPR [] ="No repr specified for ComponentInstance"
static int _total = 0
Definition at line 31 of file SalomeHPComponent.hxx.
◆ SalomeHPComponent() [1/2]
SalomeHPComponent::SalomeHPComponent ( const std::string &  name)
Definition at line 44 of file SalomeHPComponent.cxx.
44 : ComponentInstance(name)
45{
46 _objComponent=CORBA::Object::_nil();
47}
ComponentInstance(const std::string &name)
References _objComponent.
Referenced by clone(), and cloneAlways().
◆ SalomeHPComponent() [2/2]
SalomeHPComponent::SalomeHPComponent ( const SalomeHPComponent &  other)
Definition at line 49 of file SalomeHPComponent.cxx.
49 :ComponentInstance(other)
50{
51 _objComponent=CORBA::Object::_nil();
52}
◆ ~SalomeHPComponent()
SalomeHPComponent::~SalomeHPComponent ( )
Definition at line 54 of file SalomeHPComponent.cxx.
55{
56}
◆ clone()
ComponentInstance * SalomeHPComponent::clone ( ) const
Implements YACS::ENGINE::ComponentInstance.
Definition at line 119 of file SalomeHPComponent.cxx.
120{
122 {
123 incrRef();
124 return (ComponentInstance*) (this);
125 }
126 else
127 return new SalomeHPComponent(*this);
128}
SalomeHPComponent(const std::string &name)
References YACS::ENGINE::ComponentInstance::_isAttachedOnCloning, YACS::ENGINE::RefCounter::incrRef(), and SalomeHPComponent().
◆ cloneAlways()
ComponentInstance * SalomeHPComponent::cloneAlways ( ) const
Definition at line 130 of file SalomeHPComponent.cxx.
131{
132 return new SalomeHPComponent(*this);
133}
References SalomeHPComponent().
◆ createNode()
ServiceNode * SalomeHPComponent::createNode ( const std::string &  name)
a new SalomeNode node
Definition at line 111 of file SalomeHPComponent.cxx.
112{
113 SalomeNode* node(new SalomeNode(name));
114 node->setComponent(this);
115 return node;
116}
Class for Salome component Service Node.
Definition: CORBANode.hxx:68
References YACS::ENGINE::ServiceNode::setComponent().
◆ getCompoPtr()
virtual CORBA::Object_ptr YACS::ENGINE::SalomeHPComponent::getCompoPtr ( )
Definition at line 45 of file SalomeHPComponent.hxx.
45{return CORBA::Object::_duplicate(_objComponent);}
◆ getFileRepr()
std::string SalomeHPComponent::getFileRepr ( ) const
For dump in file.
Reimplemented from YACS::ENGINE::ComponentInstance.
Definition at line 135 of file SalomeHPComponent.cxx.
136{
137 ostringstream stream;
138 stream << "<component>" << getCompoName() << "</component>";
139 return stream.str();
140}
References YACS::ENGINE::ComponentInstance::getCompoName().
◆ getKind()
std::string SalomeHPComponent::getKind ( ) const
A runtime can provide several implementations of a component instance. Each implementation has a different kind. A ComponentInstance can be associated to a ServiceNode is they have the same kind.
Definition at line 58 of file SalomeHPComponent.cxx.
59{
60 return KIND;
61}
References KIND.
◆ getKindForNode()
std::string SalomeHPComponent::getKindForNode ( ) const
Definition at line 63 of file SalomeHPComponent.cxx.
64{
66}
References YACS::ENGINE::SalomeComponent::KIND.
◆ isLoaded()
bool SalomeHPComponent::isLoaded ( Task *  askingNode) const
Definition at line 76 of file SalomeHPComponent.cxx.
77{
78 return false;
79}
◆ load()
void SalomeHPComponent::load ( Task *  askingNode)
Load the component.
Definition at line 83 of file SalomeHPComponent.cxx.
84{
85 if(_container)
86 {
87 SalomeHPContainer *salomeContainer(dynamic_cast<SalomeHPContainer *>(_container));
88 if(salomeContainer)
89 {
91 _objComponent=tmpCont->loadComponent(askingNode);
92 return ;
93 }
94 throw Exception("Unrecognized type of Container ! Only Salome and HPSalome container are supported by the Salome components !");
95 }
96 else
97 throw Exception("No container on HP component ! Impossible to load !");
98}
static SalomeContainerTmpForHP * BuildFrom(const SalomeHPContainer *cont, const Task *askingNode)
References YACS::ENGINE::ComponentInstance::_container, _objComponent, and YACS::ENGINE::SalomeContainerTmpForHP::BuildFrom().
◆ setContainer()
bool SalomeHPComponent::setContainer ( Container *  cont)
Definition at line 142 of file SalomeHPComponent.cxx.
143{
144 if(!dynamic_cast<SalomeHPContainer *>(cont))
145 throw Exception("SalomeHPComponent::setContainer : a Salome HP component must be attached to a Salome HP container !");
147 {
148 if(_container)
150 return true;
151 }
152 else
153 return false;
154}
virtual bool setContainer(Container *cont)
virtual void addComponentName(const std::string &name)=0
References YACS::ENGINE::ComponentInstance::_compoName, YACS::ENGINE::ComponentInstance::_container, YACS::ENGINE::Container::addComponentName(), and YACS::ENGINE::ComponentInstance::setContainer().
◆ shutdown()
void SalomeHPComponent::shutdown ( int  level)
Definition at line 156 of file SalomeHPComponent.cxx.
157{
158 DEBTRACE("SalomeHPComponent::shutdown " << level);
159 if(_container)
160 _container->shutdown(level);
161}
virtual void shutdown(int level)=0
References YACS::ENGINE::ComponentInstance::_container, DEBTRACE, and YACS::ENGINE::Container::shutdown().
◆ unload()
void SalomeHPComponent::unload ( Task *  askingNode)
Definition at line 69 of file SalomeHPComponent.cxx.
70{
71 //Not implemented
72 std::cerr << "SalomeHPComponent::unload : not implemented " << std::endl;
73}
◆ _objComponent
CORBA::Object_var YACS::ENGINE::SalomeHPComponent::_objComponent
Definition at line 52 of file SalomeHPComponent.hxx.
Referenced by load(), and SalomeHPComponent().
◆ KIND
const char SalomeHPComponent::KIND ="HPSalome"
