YACS::ENGINE::SalomeContainerTmpForHP Class Reference
#include <SalomeContainerTmpForHP.hxx>
Inheritance diagram for YACS::ENGINE::SalomeContainerTmpForHP:
Collaboration diagram for YACS::ENGINE::SalomeContainerTmpForHP:
 SalomeContainerTmpForHP (const Container &other, const SalomeContainerTools &sct, const SalomeContainerHelper *lmt, const std::vector< std::string > &componentNames, int shutdownLev, const SalomeHPContainer *zeOriginCont, std::size_t pos)
std::string getDiscreminantStrOfThis (const Task *askingNode) const
CORBA::Object_ptr loadComponent (Task *inst)
 Load a component instance in this container. More...
- Public Member Functions inherited from YACS::ENGINE::SalomeContainer
 SalomeContainer ()
 SalomeContainer (const SalomeContainer &other)
 SalomeContainer (const Container &other, const SalomeContainerTools &sct, const SalomeContainerHelper *lmt, const std::vector< std::string > &componentNames, int shutdownLev)
void lock ()
 For thread safety for concurrent load operation on same Container. More...
void unLock ()
std::string getKind () const
bool isAlreadyStarted (const Task *askingNode) const
 Check if the component instance container is already started. More...
Engines::Container_ptr getContainerPtr (const Task *askingNode) const
void start (const Task *askingNode) override
 Start a salome container (true salome container not yacs one) with given ContainerParameters (_params) More...
void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name) override
bool canAcceptImposedResource () override
Container * clone () const
 WARNING ! clone behaviour MUST be in coherence with what is returned by isAttachedOnCloning() method More...
Container * cloneAlways () const
std::string getPlacementId (const Task *askingNode) const
 Get the container placement id for a component instance. More...
std::string getFullPlacementId (const Task *askingNode) const
 Get the container full path for a component instance. More...
void checkCapabilityToDealWith (const ComponentInstance *inst) const
void setProperty (const std::string &name, const std::string &value)
std::string getProperty (const std::string &name) const
void clearProperties ()
void addComponentName (const std::string &name)
void addToResourceList (const std::string &name)
virtual CORBA::Object_ptr loadComponent (Task *inst)
void shutdown (int level)
std::map< std::string, std::string > getResourceProperties (const std::string &name) const
std::map< std::string, std::string > getProperties () const
- Public Member Functions inherited from YACS::ENGINE::Container
virtual std::string getKind () const =0
virtual std::string getDiscreminantStrOfThis (const Task *askingNode) const
virtual bool isAlreadyStarted (const Task *askingNode) const =0
virtual void start (const Task *askingNode)=0
virtual void start (const Task *askingNode, const std::string &resource_name, const std::string &container_name)
virtual bool isUsingPythonCache ()
virtual void usePythonCache (bool v)
virtual std::string getPlacementId (const Task *askingNode) const =0
virtual std::string getFullPlacementId (const Task *askingNode) const =0
virtual void setAttachOnCloningStatus (bool val) const
virtual void attachOnCloning () const
virtual void dettachOnCloning () const
virtual bool isAttachedOnCloning () const
virtual void lock ()=0
virtual void unLock ()=0
virtual Container * clone () const =0
virtual Container * cloneAlways () const =0
virtual bool isSupportingRTODefNbOfComp () const
virtual void checkCapabilityToDealWith (const ComponentInstance *inst) const =0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name) const =0
virtual void clearProperties ()=0
virtual void addComponentName (const std::string &name)=0
virtual std::map< std::string, std::string > getProperties () const =0
virtual std::map< std::string, std::string > getResourceProperties (const std::string &name) const =0
virtual void setProperties (const std::map< std::string, std::string > &properties)
virtual std::string getName () const
void setName (std::string name)
 WARNING ! name is used in edition to identify different containers, it is not the runtime name of the container More...
void setProc (Proc *proc)
Proc * getProc ()
virtual void shutdown (int level)=0
void incrRef () const
bool decrRef () const
static SalomeContainerTmpForHP * BuildFrom (const SalomeHPContainer *cont, const Task *askingNode)
const SalomeHPContainer * _zeOriginCont
std::size_t _pos
- Static Public Attributes inherited from YACS::ENGINE::SalomeContainer
static const char KIND [] ="Salome"
static const char TYPE_PROPERTY_STR [] ="type"
- Static Public Attributes inherited from YACS::ENGINE::Container
static const char KIND_ENTRY [] ="container_kind"
static const char AOC_ENTRY [] ="attached_on_cloning"
static const char USE_PYCACHE_PROPERTY [] ="use_py_cache"
- Protected Member Functions inherited from YACS::ENGINE::SalomeContainer
virtual ~SalomeContainer ()
- Protected Member Functions inherited from YACS::ENGINE::Container
 Container ()
virtual ~Container ()
 RefCounter ()
virtual ~RefCounter ()
- Protected Attributes inherited from YACS::ENGINE::SalomeContainer
YACS::BASES::Mutex _mutex
 thread safety in Salome ??? More...
std::vector< std::string > _componentNames
SalomeContainerHelper * _launchModeType
int _shutdownLevel
SalomeContainerTools _sct
- Protected Attributes inherited from YACS::ENGINE::Container
bool _isAttachedOnCloning
Proc * _proc
unsigned int _cnt
Definition at line 33 of file SalomeContainerTmpForHP.hxx.
◆ SalomeContainerTmpForHP()
YACS::ENGINE::SalomeContainerTmpForHP::SalomeContainerTmpForHP ( const Container &  other,
const SalomeContainerTools &  sct,
const SalomeContainerHelper *  lmt,
const std::vector< std::string > &  componentNames,
int  shutdownLev,
const SalomeHPContainer *  zeOriginCont,
std::size_t  pos
Definition at line 36 of file SalomeContainerTmpForHP.hxx.
38 :SalomeContainer(other,sct,lmt,componentNames,shutdownLev),_zeOriginCont(zeOriginCont),_pos(pos) { }
Referenced by BuildFrom().
◆ BuildFrom()
SalomeContainerTmpForHP * SalomeContainerTmpForHP::BuildFrom ( const SalomeHPContainer *  cont,
const Task *  askingNode
Definition at line 56 of file SalomeContainerTmpForHP.cxx.
57{
58 const SalomeContainerHelper *lmt(0);
59 std::size_t posIn(0);
60 {
62 lmt=cont->getHelperOfTask(askingNode);
63 posIn=cont->locateTask(askingNode);
64 }
65 return new SalomeContainerTmpForHP(*cont,cont->getContainerInfo(),lmt,cont->getComponentNames(),cont->getShutdownLev(),cont,posIn);
66}
SalomeContainerTmpForHP(const Container &other, const SalomeContainerTools &sct, const SalomeContainerHelper *lmt, const std::vector< std::string > &componentNames, int shutdownLev, const SalomeHPContainer *zeOriginCont, std::size_t pos)
SalomeContainerMonoHelper * getHelperOfTask(const Task *node)
std::vector< std::string > getComponentNames() const
const SalomeContainerTools & getContainerInfo() const
std::size_t locateTask(const Task *askingNode) const
References YACS::ENGINE::SalomeHPContainer::getComponentNames(), YACS::ENGINE::SalomeHPContainer::getContainerInfo(), YACS::ENGINE::SalomeHPContainer::getHelperOfTask(), YACS::ENGINE::SalomeHPContainer::getShutdownLev(), YACS::ENGINE::SalomeHPContainer::locateTask(), and SalomeContainerTmpForHP().
Referenced by GetContainerObj(), YACS::ENGINE::SalomeHPContainer::getDiscreminantStrOfThis(), YACS::ENGINE::DistributedPythonNode::load(), and YACS::ENGINE::SalomeHPComponent::load().
◆ getDiscreminantStrOfThis()
std::string YACS::ENGINE::SalomeContainerTmpForHP::getDiscreminantStrOfThis ( const Task *  askingNode) const
Reimplemented from YACS::ENGINE::Container.
Definition at line 39 of file SalomeContainerTmpForHP.hxx.
39{ std::ostringstream oss; oss << _zeOriginCont << "_" << _pos; return oss.str(); }
References _pos, and _zeOriginCont.
◆ loadComponent()
CORBA::Object_ptr SalomeContainerTmpForHP::loadComponent ( Task *  askingNode)
instthe component instance to load
Reimplemented from YACS::ENGINE::SalomeContainer.
Definition at line 28 of file SalomeContainerTmpForHP.cxx.
29{
30 const ComponentInstance *inst(askingNode?askingNode->getComponent():0);
31 if(!inst)
32 throw Exception("SalomeContainerTmpForHP::loadComponent : asking to load a component on the given task whereas this task has no component !");
33 std::string compoName(inst->getCompoName());
34 {
35 YACS::BASES::AutoLocker<Container> alck(this);//To be sure
36 if(!this->isAlreadyStarted(askingNode))
37 this->start(askingNode);
38 }
39 CORBA::Object_ptr objComponent=CORBA::Object::_nil();
40 {
41 YACS::BASES::AutoLocker<Container> alck(this);//To be sure
42 std::string compoName(inst->getCompoName());
43 Engines::Container_var container(_launchModeType->getContainer(askingNode));
44 objComponent=container->find_component_instance(compoName.c_str());
45 if(CORBA::is_nil(objComponent))
46 {
47 char *reason;
48 bool isLoadable(container->load_component_Library(compoName.c_str(), reason));
49 if(isLoadable)
50 objComponent=SalomeContainerTools::CreateComponentInstance(this,container,inst);
51 }
52 }
53 return objComponent;
54}
virtual Engines::Container_var getContainer(const Task *askingNode) const =0
static CORBA::Object_ptr CreateComponentInstance(Container *cont, Engines::Container_ptr contPtr, const ComponentInstance *inst)
bool isAlreadyStarted(const Task *askingNode) const
void start(const Task *askingNode) override
Start a salome container (true salome container not yacs one) with given ContainerParameters (_params...
virtual ComponentInstance * getComponent()=0
References YACS::ENGINE::SalomeContainer::_launchModeType, YACS::ENGINE::SalomeContainerToolsBase::CreateComponentInstance(), YACS::ENGINE::ComponentInstance::getCompoName(), YACS::ENGINE::Task::getComponent(), YACS::ENGINE::SalomeContainerHelper::getContainer(), YACS::ENGINE::SalomeContainer::isAlreadyStarted(), and YACS::ENGINE::SalomeContainer::start().
◆ _pos
std::size_t YACS::ENGINE::SalomeContainerTmpForHP::_pos
Definition at line 44 of file SalomeContainerTmpForHP.hxx.
Referenced by getDiscreminantStrOfThis().
◆ _zeOriginCont
const SalomeHPContainer* YACS::ENGINE::SalomeContainerTmpForHP::_zeOriginCont
Definition at line 43 of file SalomeContainerTmpForHP.hxx.
