SalomeHPContainer.hxx
20#ifndef __SALOMEHPCONTAINER_HXX__
21#define __SALOMEHPCONTAINER_HXX__
28#include "Mutex.hxx"
29#include <string>
30#include <vector>
31#include <map>
32#include <mutex>
33#include <SALOMEconfig.h>
34#include CORBA_CLIENT_HEADER(SALOME_Component)
35#include CORBA_CLIENT_HEADER(SALOME_ContainerManager)
36
37namespace YACS
38{
39 namespace ENGINE
40 {
41 class Task;
42 class SalomeComponent;
43
45 {
46 public:
49 //HP specific part
50 void assignPG(const PlayGround *pg) override;
51 void setSizeOfPool(int sz);
52 int getSizeOfPool() const;
53 std::size_t getNumberOfFreePlace() const;
54 void allocateFor(const std::vector<const Task *>& nodes);
55 void release(const Task *node) override;
57 void lock() { _lock.lock(); }
59 void unLock() { _lock.unlock(); }
60 //
61 std::string getKind() const;
62 std::string getDiscreminantStrOfThis(const Task *askingNode) const;
63 bool isAlreadyStarted(const Task *askingNode) const;
64 void start(const Task *askingNode) ;
65 void shutdown(int level);
66 std::string getPlacementId(const Task *askingNode) const;
67 std::string getFullPlacementId(const Task *askingNode) const;
68 Container *clone() const;
69 Container *cloneAlways() const;
70 void setProperty(const std::string& name,const std::string& value);
71 std::string getProperty(const std::string& name) const;
72 void clearProperties();
73 void addComponentName(const std::string& name);
74 std::map<std::string,std::string> getProperties() const;
75 std::map<std::string,std::string> getResourceProperties(const std::string& name) const;
76 void checkCapabilityToDealWith(const ComponentInstance *inst) const ;
77 std::vector<std::string> getKernelContainerNames() const;
78 int getNumberOfCoresPerWorker() const;
79 //
80#ifndef SWIG
81 std::size_t locateTask(const Task *askingNode) const { return _launchModeType.locateTask(askingNode); }
82 const SalomeContainerTools &getContainerInfo() const { return _sct; }
83 std::vector<std::string> getComponentNames() const { return _componentNames; }
84 int getShutdownLev() const { return _shutdownLevel; }
85 SalomeContainerMonoHelper *getHelperOfTask(const Task *node) { return _launchModeType.getHelperOfTask(node); }
86 const SalomeContainerMonoHelper *getHelperOfTask(const Task *node) const { return _launchModeType.getHelperOfTask(node); }
87#endif
88 public:
89 static const char KIND[];
90 protected:
91#ifndef SWIG
93#endif
94 protected:
95 std::mutex _lock;
98 std::vector<std::string> _componentNames;
99 //
101 std::string _initScript;
102 };
103 }
104}
105
106#endif
#define YACSRUNTIMESALOME_EXPORT
SalomeContainerMonoHelper * getHelperOfTask(const Task *node)
void unLock()
For thread safety for concurrent load operation on same Container.
void lock()
std::vector< std::string > _componentNames
std::vector< std::string > getComponentNames() const
const SalomeContainerMonoHelper * getHelperOfTask(const Task *node) const
const SalomeContainerTools & getContainerInfo() const
SalomeHPContainerVectOfHelper _launchModeType
