YACS::ENGINE::PlayGround Class Reference
#include <PlayGround.hxx>
Inheritance diagram for YACS::ENGINE::PlayGround:
Collaboration diagram for YACS::ENGINE::PlayGround:
 PlayGround (const std::vector< std::pair< std::string, int > > &defOfRes)
 PlayGround ()
std::string printSelf () const
void loadFromKernelCatalog ()
std::vector< std::pair< std::string, int > > getData () const
void setData (const std::vector< std::pair< std::string, int > > &defOfRes)
int getNumberOfCoresAvailable () const
int getMaxNumberOfContainersCanBeHostedWithoutOverlap (int nbCoresPerCont) const
std::vector< int > computeOffsets () const
std::vector< YACS::BASES::AutoRefCnt< PartDefinition > > partition (const std::vector< std::pair< const PartDefinition *, const ComplexWeight * > > &parts, const std::vector< int > &nbCoresPerShot) const
int fromWorkerIdToResId (int workerId, int nbProcPerNode) const
std::string deduceMachineFrom (int workerId, int nbProcPerNode) const
int getNumberOfWorkers (int nbCoresPerWorker) const
void highlightOnIds (const std::vector< int > &coreIds, std::vector< bool > &v) const
std::vector< bool > getFetchedCores (int nbCoresPerWorker) const
std::vector< std::size_t > getWorkerIdsFullyFetchedBy (int nbCoresPerComp, const std::vector< bool > &coreFlags) const
std::size_t getNumberOfFreePlace (int nbCoresPerCont) const
std::vector< std::size_t > allocateFor (std::size_t nbOfPlacesToTake, int nbCoresPerCont) const
void release (std::size_t workerId, int nbCoresPerCont) const
std::mutex & getLocker () const
void printMe () const
void incrRef () const
bool decrRef () const
static std::vector< int > BuildVectOfIdsFromVecBool (const std::vector< bool > &v)
static std::vector< int > GetIdsMatching (const std::vector< bool > &bigArr, const std::vector< bool > &pat)
std::vector< std::pair< const ComplexWeight *, int > > bigToTiny (const std::vector< std::pair< const ComplexWeight *, int > > &weights, std::map< int, int > &saveOrder) const
std::vector< std::vector< int > > backToOriginalOrder (const std::vector< std::vector< int > > &disorderVec, const std::map< int, int > &saveOrder) const
int getCriticalPath (const std::vector< std::pair< const ComplexWeight *, int > > &weights, const std::vector< int > &maxNbOfCores) const
std::vector< std::vector< int > > splitIntoParts (const std::vector< int > &coreIds, const std::vector< std::pair< const ComplexWeight *, int > > &weights) const
std::vector< int > takePlace (int maxNbOfCoresToAlloc, int nbCoresPerShot, std::vector< bool > &distributionOfCores, bool lastOne=false) const
void checkCoherentInfo () const
 ~PlayGround ()
std::mutex _locker
std::vector< Resource > _data
 RefCounter ()
virtual ~RefCounter ()
unsigned int _cnt
Definition at line 76 of file PlayGround.hxx.
◆ PlayGround() [1/2]
YACS::ENGINE::PlayGround::PlayGround ( const std::vector< std::pair< std::string, int > > &  defOfRes)
Definition at line 79 of file PlayGround.hxx.
79:_data(defOfRes.begin(),defOfRes.end()) { checkCoherentInfo(); }
void checkCoherentInfo() const
Definition: PlayGround.cxx:157
Definition: PlayGround.hxx:115
◆ PlayGround() [2/2]
YACS::ENGINE::PlayGround::PlayGround ( )
Definition at line 80 of file PlayGround.hxx.
80{ }
◆ ~PlayGround()
PlayGround::~PlayGround ( )
Definition at line 584 of file PlayGround.cxx.
585{
586}
◆ allocateFor()
std::vector< std::size_t > PlayGround::allocateFor ( std::size_t  nbOfPlacesToTake,
int  nbCoresPerCont
Definition at line 194 of file PlayGround.cxx.
195{
196 std::vector<std::size_t> ret;
197 std::size_t nbOfPlacesToTakeCpy(nbOfPlacesToTake),offset(0);
198 for(const auto& res : _data)
199 {
200 std::vector<std::size_t> contIdsInRes(res.allocateFor(nbOfPlacesToTakeCpy,nbCoresPerCont));
201 std::for_each(contIdsInRes.begin(),contIdsInRes.end(),[offset](std::size_t& val) { val += offset; });
202 ret.insert(ret.end(),contIdsInRes.begin(),contIdsInRes.end());
203 offset += static_cast<std::size_t>(res.nbCores()/nbCoresPerCont);
204 }
205 if( ( nbOfPlacesToTakeCpy!=0 ) || ( ret.size()!=nbOfPlacesToTake ) )
206 throw Exception("PlayGround::allocateFor : internal error ! Promised place is not existing !");
207 return ret;
208}
References _data.
◆ backToOriginalOrder()
std::vector< std::vector< int > > PlayGround::backToOriginalOrder ( const std::vector< std::vector< int > > &  disorderVec,
const std::map< int, int > &  saveOrder
Definition at line 451 of file PlayGround.cxx.
452{
453 std::vector< std::vector<int> > ret;
454 std::size_t sz(disorderVec.size());
455 if (disorderVec.size()!=saveOrder.size())
456 throw Exception("PlayGround::backToOriginalOrder : incoherent vector size !");
457 for (int i=0; i<sz; i++)
458 ret.push_back(disorderVec[saveOrder.at(i)]);
459 return ret;
460}
References yacsorb.CORBAEngineTest::i.
Referenced by splitIntoParts().
◆ bigToTiny()
std::vector< std::pair< const ComplexWeight *, int > > PlayGround::bigToTiny ( const std::vector< std::pair< const ComplexWeight *, int > > &  weights,
Definition at line 427 of file PlayGround.cxx.
428{
429 int maxCoresPerShot(0), rankMax(0);
430 int i(0);
431 std::vector< std::pair <const ComplexWeight *, int> > ret;
432 std::size_t sz(weights.size());
433 while (ret.size()<sz)
434 {
435 for(std::vector<std::pair <const ComplexWeight *, int> >::const_iterator it=weights.begin();it!=weights.end();it++,i++)
436 {
437 if ((maxCoresPerShot<(*it).second) && (saveOrder.find(i)==saveOrder.end()))
438 {
439 maxCoresPerShot=(*it).second;
440 rankMax=i;
441 }
442 }
443 ret.push_back(std::pair <const ComplexWeight *, int>(weights[rankMax].first,weights[rankMax].second));
444 saveOrder[rankMax]=ret.size()-1;
445 maxCoresPerShot=0;
446 i=0;
447 }
448 return ret;
449}
◆ BuildVectOfIdsFromVecBool()
std::vector< int > PlayGround::BuildVectOfIdsFromVecBool ( const std::vector< bool > &  v)
Definition at line 234 of file PlayGround.cxx.
235{
236 std::size_t sz(std::count(v.begin(),v.end(),true)),i(0);
237 std::vector<int> ret(sz);
238 std::vector<bool>::const_iterator it(v.begin());
239 while(i<sz)
240 {
241 it=std::find(it,v.end(),true);
242 ret[i++]=std::distance(v.begin(),it);
243 it++;
244 }
245 return ret;
246}
def distance(node, new_node)
Definition: graph.py:275
References gui.graph::distance(), and yacsorb.CORBAEngineTest::i.
Referenced by partition(), and YACS::ENGINE::PartDefinition::stashPart().
◆ checkCoherentInfo()
void PlayGround::checkCoherentInfo ( ) const
Definition at line 157 of file PlayGround.cxx.
158{
159 std::set<std::string> s;
160 for(auto it : _data)
161 {
162 s.insert(it.name());
163 if(it.nbCores()<0)
164 throw Exception("Presence of negative int value !");
165 }
166 if(s.size()!=_data.size())
167 throw Exception("host names entries must be different each other !");
168}
References _data.
Referenced by setData().
◆ computeOffsets()
std::vector< int > PlayGround::computeOffsets ( ) const
Definition at line 148 of file PlayGround.cxx.
149{
150 std::size_t sz(_data.size()),i(0);
151 std::vector<int> ret(sz+1); ret[0]=0;
152 for(auto it=_data.begin();it!=_data.end();it++,i++)
153 ret[i+1]=ret[i]+it->nbCores();
154 return ret;
155}
References _data, and yacsorb.CORBAEngineTest::i.
Referenced by takePlace().
◆ deduceMachineFrom()
std::string PlayGround::deduceMachineFrom ( int  workerId,
int  nbProcPerNode
you must garantee coherence between PlayGround::deduceMachineFrom, PlayGround::getNumberOfWorkers, and PartDefinition::computeWorkerIdsCovered
Definition at line 570 of file PlayGround.cxx.
571{
572 int zePos(fromWorkerIdToResId(workerId,nbProcPerNode));
573 return _data[zePos].name();
574}
int fromWorkerIdToResId(int workerId, int nbProcPerNode) const
Definition: PlayGround.cxx:553
References _data, and fromWorkerIdToResId().
Referenced by YACS::ENGINE::SalomeContainerToolsDecorator::getParameters().
◆ fromWorkerIdToResId()
int PlayGround::fromWorkerIdToResId ( int  workerId,
int  nbProcPerNode
Definition at line 553 of file PlayGround.cxx.
554{
555 std::size_t sz2(_data.size());
556 std::vector<int> deltas(sz2+1); deltas[0]=0;
557 for(std::size_t i=0;i<sz2;i++)
558 deltas[i+1]=deltas[i]+(_data[i].nbCores())/nbProcPerNode;
559 int zePos(0);
560 while(zePos<sz2 && (workerId<deltas[zePos] || workerId>=deltas[zePos+1]))
561 zePos++;
562 if(zePos==sz2)
563 zePos=workerId%sz2;
564 return zePos;
565}
Referenced by deduceMachineFrom().
◆ getCriticalPath()
int PlayGround::getCriticalPath ( const std::vector< std::pair< const ComplexWeight *, int > > &  weights,
const std::vector< int > &  maxNbOfCores
Definition at line 462 of file PlayGround.cxx.
463{
464 double maxWeight(0.);
465 double pathWeight(0.);
466 int rankMaxPath(-1);
467 if ((weights.size()!=nbOfCoresAllocated.size()) || (weights.size()==0))
468 throw Exception("PlayGround::getCriticalPath : internal error !");
469 int i=0;
470 for(std::vector<std::pair <const ComplexWeight *, int> >::const_iterator it=weights.begin();it!=weights.end();it++,i++)
471 {
472 if (nbOfCoresAllocated[i]==0)
473 throw Exception("PlayGround::getCriticalPath : nbOfCoresAllocated is null! error !");
474 if (!(*it).first->isDefaultValue())
475 {
476 pathWeight=(*it).first->calculateTotalLength(nbOfCoresAllocated[i]);
477 if (pathWeight > maxWeight)
478 {
479 maxWeight=pathWeight;
480 rankMaxPath=i;
481 }
482 }
483 }
484 return rankMaxPath;
485}
◆ getData()
std::vector< std::pair< std::string, int > > YACS::ENGINE::PlayGround::getData ( ) const
Definition at line 83 of file PlayGround.hxx.
83{ return std::vector< std::pair<std::string,int> >(ResourceIterator(&_data,0),ResourceIterator(&_data,_data.size())); }
◆ getFetchedCores()
std::vector< bool > YACS::ENGINE::PlayGround::getFetchedCores ( int  nbCoresPerWorker) const
◆ GetIdsMatching()
std::vector< int > PlayGround::GetIdsMatching ( const std::vector< bool > &  bigArr,
const std::vector< bool > &  pat
Definition at line 170 of file PlayGround.cxx.
171{
172 std::vector<int> ret;
173 std::size_t szp(pat.size());
174 std::size_t sz(bigArr.size()/szp);
175 for(std::size_t i=0;i<sz;i++)
176 {
177 std::vector<bool> t(bigArr.begin()+i*szp,bigArr.begin()+(i+1)*szp);
178 if(t==pat)
179 ret.push_back(i);
180 }
181 return ret;
182}
References yacsorb.CORBAEngineTest::i, and gui.Appli::t.
Referenced by partition().
◆ getLocker()
std::mutex & YACS::ENGINE::PlayGround::getLocker ( ) const
Definition at line 101 of file PlayGround.hxx.
101{ return _locker; }
◆ getMaxNumberOfContainersCanBeHostedWithoutOverlap()
int PlayGround::getMaxNumberOfContainersCanBeHostedWithoutOverlap ( int  nbCoresPerCont) const
Definition at line 138 of file PlayGround.cxx.
139{
140 if(nbCoresPerCont<1)
141 throw Exception("PlayGround::getMaxNumberOfContainersCanBeHostedWithoutOverlap : invalid nbCoresPerCont. Must be >=1 !");
142 int ret(0);
143 for(auto it : _data)
144 ret+=it.nbCores()/nbCoresPerCont;
145 return ret;
146}
References _data.
Referenced by getNumberOfWorkers().
◆ getNumberOfCoresAvailable()
int PlayGround::getNumberOfCoresAvailable ( ) const
Definition at line 130 of file PlayGround.cxx.
131{
132 int ret(0);
133 for(auto it : _data)
134 ret+=it.nbCores();
135 return ret;
136}
References _data.
Referenced by YACS::ENGINE::PartDefinition::BuildFrom(), YACS::ENGINE::Bloc::fitToPlayGround(), highlightOnIds(), partition(), and splitIntoParts().
◆ getNumberOfFreePlace()
std::size_t PlayGround::getNumberOfFreePlace ( int  nbCoresPerCont) const
Definition at line 184 of file PlayGround.cxx.
185{
186 std::size_t ret(0);
187 for(auto res : _data)
188 {
189 ret += res.getNumberOfFreePlace(nbCoresPerCont);
190 }
191 return ret;
192}
References _data.
Referenced by YACS::ENGINE::SalomeHPContainer::getNumberOfFreePlace().
◆ getNumberOfWorkers()
int PlayGround::getNumberOfWorkers ( int  nbCoresPerWorker) const
◆ getWorkerIdsFullyFetchedBy()
std::vector< std::size_t > PlayGround::getWorkerIdsFullyFetchedBy ( int  nbCoresPerComp,
const std::vector< bool > &  coreFlags
follow getMaxNumberOfContainersCanBeHostedWithoutOverlap method
Definition at line 280 of file PlayGround.cxx.
281{
282 std::size_t posBg(0),posWorker(0);
283 std::vector<std::size_t> ret;
284 for(auto it : _data)
285 {
286 int nbWorker(it.nbCores()/nbCoresPerComp);
287 for(int j=0;j<nbWorker;j++,posWorker++)
288 {
289 std::vector<bool>::const_iterator it2(std::find(coreFlags.begin()+posBg+j*nbCoresPerComp,coreFlags.begin()+posBg+(j+1)*nbCoresPerComp,false));
290 if(it2==coreFlags.begin()+posBg+(j+1)*nbCoresPerComp)
291 ret.push_back(posWorker);
292 }
293 posBg+=it.nbCores();
294 }
295 return ret;
296}
References _data.
◆ highlightOnIds()
void PlayGround::highlightOnIds ( const std::vector< int > &  coreIds,
Definition at line 248 of file PlayGround.cxx.
249{
250 if(v.size()!=getNumberOfCoresAvailable())
251 throw Exception("PlayGround::highlightOnIds : oops ! invalid size !");
252 for(std::vector<int>::const_iterator it=coreIds.begin();it!=coreIds.end();it++)
253 v[*it]=true;
254}
int getNumberOfCoresAvailable() const
Definition: PlayGround.cxx:130
References getNumberOfCoresAvailable().
◆ loadFromKernelCatalog()
void PlayGround::loadFromKernelCatalog ( )
Definition at line 115 of file PlayGround.cxx.
116{
117 Runtime *r(getRuntime());
118 if(!r)
119 throw Exception("PlayGround::loadFromKernelCatalog : no runtime !");
120 std::vector< std::pair<std::string,int> > data(r->getCatalogOfComputeNodes());
121 setData(data);
122}
void setData(const std::vector< std::pair< std::string, int > > &defOfRes)
Definition: PlayGround.cxx:124
Definition: Runtime.cxx:61
References YACS::ENGINE::getRuntime(), testCppPluginInvokation::r, and setData().
◆ partition()
std::vector< YACS::BASES::AutoRefCnt< PartDefinition > > PlayGround::partition ( const std::vector< std::pair< const PartDefinition *, const ComplexWeight * > > &  parts,
const std::vector< int > &  nbCoresPerShot
Definition at line 298 of file PlayGround.cxx.
299{
300 std::size_t sz(parts.size()),szs(getNumberOfCoresAvailable());
301 if (sz!=nbCoresPerShot.size())
302 throw Exception("PlayGround::partition : incoherent vector size !");
303 if(sz==0)
304 return std::vector< YACS::BASES::AutoRefCnt<PartDefinition> >();
305 if(sz==1)
306 {
307 const PartDefinition *pd(parts[0].first);
308 if(!pd)
309 throw Exception("Presence of null pointer as part def 0 !");
311 std::vector< YACS::BASES::AutoRefCnt<PartDefinition> > ret2(1,ret);
312 return ret2;
313 }
314 if(sz>31)
315 throw Exception("PlayGround::partition : not implemented yet for more than 31 ! You need to pay for it :)");
316 std::vector<bool> zeArr(szs*sz,false);
317 std::size_t i(0);
318 for(std::vector< std::pair<const PartDefinition *, const ComplexWeight *> >::const_iterator it=parts.begin();it!=parts.end();it++,i++)
319 {
320 const PartDefinition *pd((*it).first);
321 if(!pd)
322 throw Exception("Presence of null pointer as part def !");
323 if(pd->getPlayGround()!=this)
324 throw Exception("Presence of non homogeneous playground !");
325 std::vector<bool> bs(pd->getCoresOn()); // tab of length nbCores, with True or False for each Core
326 for(std::size_t j=0;j<szs;j++)
327 zeArr[j*sz+i]=bs[j]; // remplis une table avec les valeurs de bs. La table est [nb part] * [nb cores]
328 }
329 std::vector< std::vector<int> > retIds(sz);
330 for(std::size_t i=0;i<szs;i++)
331 {
332 std::vector<bool> code(zeArr.begin()+i*sz,zeArr.begin()+(i+1)*sz);// vecteur contenant le true/false d'un coeur pour ttes les partitions
333 std::vector<int> locIds(GetIdsMatching(zeArr,code)); // liste des coeurs qui peuvent correspondre au pattern code
334 std::vector<int> partsIds(BuildVectOfIdsFromVecBool(code));// pour chaque partition retourne l'id de la premiere partition à true
335 if(partsIds.empty())
336 continue;
337 std::vector<std::pair <const ComplexWeight *, int> > wg;
338 for(std::vector<int>::const_iterator it=partsIds.begin();it!=partsIds.end();it++)
339 {
340 wg.push_back(std::pair <const ComplexWeight *, int> (parts[*it].second, nbCoresPerShot[*it]));
341 }
342 std::vector< std::vector<int> > ress(splitIntoParts(locIds,wg));
343 std::size_t k(0);
344 for(std::vector<int>::const_iterator it=partsIds.begin();it!=partsIds.end();it++,k++)
345 {
346 retIds[*it].insert(retIds[*it].end(),ress[k].begin(),ress[k].end());
347 }
348 }
349 //
350 std::vector< YACS::BASES::AutoRefCnt<PartDefinition> > ret(sz);
351 for(std::size_t i=0;i<sz;i++)
352 {
353 std::set<int> s(retIds[i].begin(),retIds[i].end());
354 std::vector<int> v(s.begin(),s.end());
355 ret[i]=PartDefinition::BuildFrom(this,v);
356 }
357 return ret;
358}
static YACS::BASES::AutoRefCnt< PartDefinition > BuildFrom(const PlayGround *pg, const std::vector< int > &coreIds)
Definition: PlayGround.cxx:612
static std::vector< int > GetIdsMatching(const std::vector< bool > &bigArr, const std::vector< bool > &pat)
Definition: PlayGround.cxx:170
static std::vector< int > BuildVectOfIdsFromVecBool(const std::vector< bool > &v)
Definition: PlayGround.cxx:234
std::vector< std::vector< int > > splitIntoParts(const std::vector< int > &coreIds, const std::vector< std::pair< const ComplexWeight *, int > > &weights) const
Definition: PlayGround.cxx:360
References YACS::ENGINE::PartDefinition::BuildFrom(), BuildVectOfIdsFromVecBool(), YACS::ENGINE::PartDefinition::copy(), YACS::ENGINE::PartDefinition::getCoresOn(), GetIdsMatching(), getNumberOfCoresAvailable(), YACS::ENGINE::PartDefinition::getPlayGround(), yacsorb.CORBAEngineTest::i, and splitIntoParts().
Referenced by YACS::ENGINE::ForkBlocPoint::partitionRegardingDPL().
◆ printMe()
void PlayGround::printMe ( ) const
Definition at line 225 of file PlayGround.cxx.
226{
227 for(auto it : _data)
228 {
229 it.printSelf(std::cout);
230 std::cout << std::endl;
231 }
232}
References _data.
◆ printSelf()
std::string PlayGround::printSelf ( ) const
Definition at line 102 of file PlayGround.cxx.
103{
104 std::ostringstream oss;
105 std::size_t sz(0);
106 for(auto it : _data)
107 sz=std::max(sz,it.name().length());
108 for(auto it : _data)
109 {
110 oss << " - " << std::setw(10) << it.name() << " : " << it.nbCores() << std::endl;
111 }
112 return oss.str();
113}
References _data.
◆ release()
void PlayGround::release ( std::size_t  workerId,
int  nbCoresPerCont
Definition at line 210 of file PlayGround.cxx.
211{
212 std::size_t offset(0);
213 for(const auto& res : _data)
214 {
215 std::size_t nbOfWorker(static_cast<std::size_t>(res.nbCores()/nbCoresPerCont));
216 std::size_t minId(offset),maxId(offset+nbOfWorker);
217 if(workerId>=minId && workerId<maxId)
218 {
219 res.release(workerId-minId,nbCoresPerCont);
220 break;
221 }
222 }
223}
References _data.
Referenced by YACS::ENGINE::SalomeHPContainer::release().
◆ setData()
void PlayGround::setData ( const std::vector< std::pair< std::string, int > > &  defOfRes)
Definition at line 124 of file PlayGround.cxx.
125{
126 _data=std::vector<Resource>(defOfRes.begin(),defOfRes.end());
128}
References _data, and checkCoherentInfo().
Referenced by loadFromKernelCatalog().
◆ splitIntoParts()
std::vector< std::vector< int > > PlayGround::splitIntoParts ( const std::vector< int > &  coreIds,
Definition at line 360 of file PlayGround.cxx.
361{
362 std::size_t sz(weights.size());
363 if(sz==0)
364 return std::vector< std::vector<int> >();
365 std::vector< std::vector<int> > ret;
366 std::vector< std::vector<int> > disorderRet(sz);
367 std::vector<bool> zeArr(getNumberOfCoresAvailable(),false);
368 highlightOnIds(coreIds,zeArr);
369 int nbOfCoresToSplit(coreIds.size());
370 int totalSpace(coreIds.size());
371 int remainingSpace(totalSpace);
372 std::vector<int> nbOfCoresAllocated(sz);
373 std::vector<int> nbCoresPerShot(sz,-1);
374 // first every other branchs take its minimal part of the cake
375 // and remove branch without valid weight
376 int i(0);
377 std::map<int,int> saveOrder;
378 const std::vector< std::pair <const ComplexWeight *, int> > sortedWeights(bigToTiny(weights, saveOrder));
379 for(std::vector<std::pair <const ComplexWeight *, int> >::const_iterator it=sortedWeights.begin();it!=sortedWeights.end();it++,i++)
380 {
381 nbCoresPerShot[i]=(*it).second;
382 if ((*it).first->isUnsetLoopWeight())
383 {
384 nbOfCoresAllocated[i]=nbCoresPerShot[i]; // branch with only elementary nodes
385 }
386 else if (!(*it).first->hasValidLoopWeight())
387 {
388 nbOfCoresAllocated[i]=std::max((int)((double)totalSpace/(double)(sz)), nbCoresPerShot[i]); // branch with undefined weight, takes his part proportionnally to the number of branchs
389 }
390 else
391 {
392 nbOfCoresAllocated[i]=nbCoresPerShot[i];
393 }
394 }
395 remainingSpace-=std::accumulate(nbOfCoresAllocated.begin(), nbOfCoresAllocated.end(), 0);
396 //get critical path (between path with loopWeight)
397 int criticalPathRank=getCriticalPath(sortedWeights, nbOfCoresAllocated);
398 if (criticalPathRank!=-1)
399 {
400 // add cores to critical path while enough cores are availables
401 while (remainingSpace >= nbCoresPerShot[criticalPathRank])
402 {
403 nbOfCoresAllocated[criticalPathRank]+=nbCoresPerShot[criticalPathRank];
404 remainingSpace-=nbCoresPerShot[criticalPathRank];
405 criticalPathRank=getCriticalPath(sortedWeights, nbOfCoresAllocated);
406 }
407 //fill other paths with remaining cores (if possible) (reuse fromBigToTiny here?)
408 // and takePlace
409 int coresToAdd;
410 int j(0);
411 for(std::vector<int>::iterator it=nbOfCoresAllocated.begin();it!=nbOfCoresAllocated.end();it++,j++)
412 {
413 coresToAdd=((int)(remainingSpace/nbCoresPerShot[j]))*nbCoresPerShot[j];
414 *it+=coresToAdd;
415 remainingSpace-=coresToAdd;
416 }
417 }
418 int k(0);
419 for(std::vector<int>::iterator it=nbOfCoresAllocated.begin();it!=nbOfCoresAllocated.end();it++,k++)
420 {
421 disorderRet[k]=takePlace(*it,nbCoresPerShot[k],zeArr,k==(sz-1));
422 }
423 ret=backToOriginalOrder(disorderRet, saveOrder);
424 return ret;
425}
int getCriticalPath(const std::vector< std::pair< const ComplexWeight *, int > > &weights, const std::vector< int > &maxNbOfCores) const
Definition: PlayGround.cxx:462
std::vector< std::pair< const ComplexWeight *, int > > bigToTiny(const std::vector< std::pair< const ComplexWeight *, int > > &weights, std::map< int, int > &saveOrder) const
Definition: PlayGround.cxx:427
void highlightOnIds(const std::vector< int > &coreIds, std::vector< bool > &v) const
Definition: PlayGround.cxx:248
std::vector< int > takePlace(int maxNbOfCoresToAlloc, int nbCoresPerShot, std::vector< bool > &distributionOfCores, bool lastOne=false) const
Definition: PlayGround.cxx:487
std::vector< std::vector< int > > backToOriginalOrder(const std::vector< std::vector< int > > &disorderVec, const std::map< int, int > &saveOrder) const
Definition: PlayGround.cxx:451
References backToOriginalOrder(), bigToTiny(), getCriticalPath(), getNumberOfCoresAvailable(), highlightOnIds(), yacsorb.CORBAEngineTest::i, and takePlace().
◆ takePlace()
std::vector< int > PlayGround::takePlace ( int  maxNbOfCoresToAlloc,
int  nbCoresPerShot,
std::vector< bool > &  distributionOfCores,
bool  lastOne = false
Definition at line 487 of file PlayGround.cxx.
488{
489 if(maxNbOfCoresToAlloc<1)
490 throw Exception("PlayGround::takePlace : internal error ! no space to alloc !");
491 int tmpMaxNbOfCoresToAlloc(maxNbOfCoresToAlloc);
492 if(lastOne)
493 tmpMaxNbOfCoresToAlloc=std::max(tmpMaxNbOfCoresToAlloc,(int)std::count(distributionOfCores.begin(),distributionOfCores.end(),true));
494 std::vector<int> ret;
495 std::vector<int> offsets(computeOffsets());
496 int nbFullItem(0);
497 std::size_t sz(offsets.size()-1);
498 for(std::size_t i=0;i<sz && tmpMaxNbOfCoresToAlloc>=nbCoresPerShot;i++)
499 {
500 int d(offsets[i+1]-offsets[i]);
501 if(nbCoresPerShot>d)
502 continue;
503 std::vector<bool> target(nbCoresPerShot,true);
504 for(int j=0;j<=d-nbCoresPerShot && tmpMaxNbOfCoresToAlloc>=nbCoresPerShot;)
505 {
506 std::vector<bool> t(distributionOfCores.begin()+offsets[i]+j,distributionOfCores.begin()+offsets[i]+j+nbCoresPerShot);
507 if(t==target)
508 {
509 nbFullItem++;
510 tmpMaxNbOfCoresToAlloc-=nbCoresPerShot;
511 std::fill(distributionOfCores.begin()+offsets[i]+j,distributionOfCores.begin()+offsets[i]+j+nbCoresPerShot,false);
512 for(int k=offsets[i]+j;k<offsets[i]+j+nbCoresPerShot;k++)
513 ret.push_back(k);
514 j+=nbCoresPerShot;
515 }
516 else
517 j++;
518 }
519 }
520 if(nbFullItem>0)
521 return ret;
522 if(nbCoresPerShot<=1)
523 throw Exception("PlayGround::takePlace : internal error !");
524 // not enough contiguous place. Find the first wider contiguous place
525 for(int kk=std::min(nbCoresPerShot-1,tmpMaxNbOfCoresToAlloc);kk>=1;kk--)
526 {
527 for(std::size_t i=0;i<sz && tmpMaxNbOfCoresToAlloc>=kk;i++)
528 {
529 int d(offsets[i+1]-offsets[i]);
530 if(kk>d)
531 continue;
532 std::vector<bool> target(kk,true);
533 for(int j=0;j<=d-kk && tmpMaxNbOfCoresToAlloc>=kk;)
534 {
535 std::vector<bool> t(distributionOfCores.begin()+offsets[i]+j,distributionOfCores.begin()+offsets[i]+j+kk);
536 if(t==target)
537 {
538 nbFullItem++;
539 tmpMaxNbOfCoresToAlloc-=kk;
540 std::fill(distributionOfCores.begin()+offsets[i]+j,distributionOfCores.begin()+offsets[i]+j+kk,false);
541 for(int k=offsets[i]+j;k<offsets[i]+j+kk;k++)
542 ret.push_back(k);
543 return ret;
544 }
545 else
546 j++;
547 }
548 }
549 }
550 throw Exception("PlayGround::takePlace : internal error ! All cores are occupied !");
551}
std::vector< int > computeOffsets() const
Definition: PlayGround.cxx:148
References computeOffsets(), yacsorb.CORBAEngineTest::i, and gui.Appli::t.
◆ _data
◆ _locker
std::mutex YACS::ENGINE::PlayGround::_locker
mutableprivate
Definition at line 114 of file PlayGround.hxx.
