graph.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20import sys
21import pilot
22from . import Item
23from qt import *
24from qtcanvas import *
25from .GraphViewer import GraphViewer
26from . import Editor
27from . import CItems
28import pygraphviz
29from pygraphviz import graphviz as gv
30import traceback
31from . import CONNECTOR
32import bisect
33
35 def customEvent(self,event):
36 object=event.data()
37 object.customEvent(event)
38 self.update()
39
40class Graph:
41 def __init__(self,item,parent):
42 self.parent=parent
43 self.item=item
44 self.node=item.node
45 #initial canvas size : 1000x1000
46 self.canvas=MyCanvas(1000,1000)
47 self.editor=GraphViewer(self.canvas,parent,"example",0)
48 self.createGraph()
49 root=self.node.getRootNode()
50 rootItem=Item.adapt(root)
51 CONNECTOR.Connect(rootItem,"selected",self.selectItem,())
52 CONNECTOR.Connect(self.item,"add",self.addItem,())
53 CONNECTOR.Connect(self.item.datalinks,"add",self.addLink,())
54
55 def createGraph(self):
56 #citems dict helps finding items in canvas from swig proxy
57 #To find an item node make : citems[node.ptr()]
58 citems={}
59 self.citems=citems
60 #pitems dict helps finding items in canvas from swig proxy
61 #To find an item port make : pitems[port.ptr()]
62 pitems={}
63
64 y=0
65 lnode=self.node.edGetDirectDescendants()
66 for n in lnode:
67 c=CItems.Cell(n,self.canvas)
68 citems[n.ptr()]=c
69 c.show()
70
71 for k,n in list(citems.items()):
72 for p in n.inports:
73 pitems[p.port.ptr()]=p
74 for p in n.outports:
75 pitems[p.port.ptr()]=p
76
77 for pout,pin in self.node.getSetOfInternalLinks():
78 if pout.getNode().getFather() != self.node and pin.getNode().getFather() != self.node:
79 continue
80 po=pitems.get(pout.ptr())
81 pi=pitems.get(pin.ptr())
82 if pi and po:
83 CItems.LinkItem(po,pi,self.canvas)
84
85 for n in lnode:
86 itemup=citems[n.ptr()]
87 for ndown in n.getOutNodes():
88 itemdown=citems[ndown.ptr()]
89 CItems.ControlLinkItem(itemup.outgate,itemdown.ingate,self.canvas)
90
91 self.layout("LR")
92
93 def addLink(self,link):
94 print("graph.addLink",link)
95 #CItem for outport
96 nodeS=self.citems[link.pout.getNode().ptr()]
97 nodeE=self.citems[link.pin.getNode().ptr()]
98 po=pi=None
99 for p in nodeS.outports:
100 if p.port == link.pout:
101 po=p
102 break
103 for p in nodeE.inports:
104 if p.port == link.pin:
105 pi=p
106 break
107
108 if pi and po:
109 l=CItems.LinkItem(po,pi,self.canvas)
110 self.canvas.update()
111
112 def addItem(self,item):
113 #print "graph.addItem",item
114 node=CItems.Cell(item.node,self.canvas)
115 self.citems[item.node.ptr()]=node
116 node.show()
117 self.canvas.update()
118
119 def selectItem(self,item):
120 #print "graph.selectItem",item
121 self.editor.selectItem(item)
122
123 def layout(self,rankdir):
124 """Compute graph layout with graphviz package"""
125 G=pygraphviz.AGraph(strict=False,directed=True)
126 G.graph_attr["rankdir"]=rankdir
127 G.graph_attr["dpi"]="72"
128 dpi=72.
129 aspect=dpi/72
130 for k,n in list(self.citems.items()):
131 #k is node address (YACS)
132 #n is item in canvas
133 G.add_node(k)
134
135 for pout,pin in self.node.getSetOfInternalLinks():
136 if pout.getNode().ptr() not in self.citems :
137 continue
138 if pin.getNode().ptr() not in self.citems:
139 continue
140 G.add_edge(pout.getNode().ptr(),pin.getNode().ptr())
141
142 for k,n in list(self.citems.items()):
143 for ndown in n.node.getOutNodes():
144 G.add_edge(n.node.ptr(),ndown.ptr())
145
146 #By default graphviz uses 96.0 pixel per inch (dpi=96.0)
147 for n in G.nodes():
148 item=self.citems[int(n)]
149 h=item.height()/dpi #height in inch
150 w=item.width()/dpi #width in inch
151 n.attr['height']=str(h)
152 n.attr['width']=str(w)
153 n.attr['fixedsize']="true"
154 n.attr['shape']="box"
155 #n.attr['label']=item.node.getName()
156
157 G.layout(prog='dot') # use dot
158 #G.write("layout.dot")
159 #G.draw("layout.png")
160
161 graph_attr=dict(attrs(G))
162 bbox=graph_attr["bb"]
163 x1,y1,x2,y2=eval(bbox)
164 h=self.canvas.height()
165 w=self.canvas.width()
166 h2=max(h,y2-y1+100)
167 w2=max(w,x2-x1+100)
168 if h2 > h or w2 > w:
169 self.canvas.resize(w2,h2)
170
171 for n in G:
172 pos=n.attr['pos'] #position is given in points (72 points par inch, so 1 point = dpi/72=1.34)
173 x,y=eval(pos)
174 x=aspect*x
175 y=aspect*y
176 item=self.citems[int(n)]
177 x0=item.x()
178 y0=item.y()
179 x=x-x0
180 y=y-y0
181 item.moveBy(x,y)
182
183 self.canvas.update()
184
185 def clearLinks(self):
186 items=list(self.citems.values())
187 for node in items:
188 for port in node.outports:
189 if not hasattr(port,"links"):
190 continue
191 for link in port.links():
192 link.clearPoints()
193 self.canvas.update()
194
195 def orthoLinks(self):
196 items=list(self.citems.values())
197 g=grid(items)
198 for node in items:
199 for port in node.outports:
200 if not hasattr(port,"links"):
201 continue
202 for link in port.links():
203 #clear all intermediate points of the link
204 link.clearPoints()
205 #if isinstance(link,CItems.ControlLinkItem):
206 # print port.port.getNode().getName() +"->"+link.toPort.port.getNode().getName()
207 #else:
208 # print port.port.getNode().getName() +":"+port.port.getName()+"->"+link.toPort.port.getNode().getName()+":"+link.toPort.port.getName()
209 #print (port.x(),port.y()),(link.toPort.x(),link.toPort.y())
210 x0,y0=port.x()+5,port.y()
211 while g.get((x0,y0)).blocked:
212 x0=x0+1
213 x1,y1=link.toPort.x()-5,link.toPort.y()
214 while g.get((x1,y1)).blocked:
215 x1=x1-1
216 path=g.findPath((x0,y0),(x1,y1))
217 #print path
218 if len(path)==1:
219 if port.y() == link.toPort.y():
220 #near ports face to face
221 continue
222 else:
223 x,y=path[0]
224 path=[(x,port.y()),(x,link.toPort.y())]
225 elif len(path)==2:
226 x1,y1=path[0]
227 x2,y2=path[1]
228 if x1 == x2:
229 #vertical line
230 path=[(x1,port.y()),(x1,link.toPort.y())]
231 else:
232 #horizontal line
233 if port.y() == link.toPort.y():
234 #near ports face to face
235 continue
236 else:
237 #transform it into a vertical line
238 x=(x1+x2)/2
239 path=[(x,port.y()),(x,link.toPort.y())]
240
241 #adjust the first point to the same y as port
242 x0,y0=path[0]
243 x1,y1=path[1]
244 if y0==y1:
245 #remove first point and adjust second one
246 del path[0]
247 x0=x1
248 path[0]=x0,port.y()
249 #adjust the last point to the same y as link.toPort
250 x0,y0=path[-1]
251 x1,y1=path[-2]
252 if y0==y1:
253 #remove last point and adjust new last one
254 del path[-1]
255 x0=x1
256 path[-1]=x0,link.toPort.y()
257 #print path
258
259 #add intermediate points
260 for x,y in path:
261 line=link.lines[-1]
262 link.splitLine(line,x,y)
263 self.canvas.update()
264
265def attrs(g,t=gv.AGRAPH):
266 ah=None
267 while 1:
268 ah=gv.agnxtattr(g.handle,t,ah)
269 value=gv.agxget(g.handle,ah)
270 yield gv.agattrname(ah),value
271
272def h(x,y,destx,desty):
273 return abs(destx-x)+abs(desty-y)
274
275def distance(node,new_node):
276 x,y=node.coord
277 x1,y1=new_node.coord
278 d= abs(x1-x)+abs(y1-y)
279 if node.parent != None:
280 x0,y0=node.parent.coord
281 if (x1-x)*(y0-y)-(y1-y)*(x0-x) != 0:
282 #corner add some cost to penalize
283 d=d+1
284 return d
285
286class node:
287 def __init__(self,coord,index):
288 self.coord=coord
289 self.index=index
290 self.blocked=0
291 self.total=0
293 self.parent=None
294 self.open=0
295 self.close=0
296
297class grid:
298 def __init__(self,graph):
299 self.graph=graph
300 xs=set()
301 ys=set()
302 xmargin=5
303 ymargin=5
304 for n in graph:
305 h=n.height()
306 w=n.width()
307 x=n.x()
308 y=n.y()
309 xs.add(x-xmargin)
310 xs.add(x+w+xmargin)
311 ys.add(y-ymargin)
312 ys.add(y+h+ymargin)
313
314 xs=list(xs)
315 xs.sort()
316 x0=xs[0]-36
317 xs.insert(0,x0)
318 x0=xs[-1]+36
319 xs.append(x0)
320
321 ys=list(ys)
322 ys.sort()
323 y0=ys[0]-36
324 ys.insert(0,y0)
325 y0=ys[-1]+36
326 ys.append(y0)
327
328 self.xs=xs
329 self.ys=ys
330 self.cols=[]
331 for w in range(len(xs)-1):
332 col=[]
333 x=(xs[w]+xs[w+1])/2
334 for h in range(len(ys)-1):
335 y=(ys[h]+ys[h+1])/2
336 col.append(node((x,y),(w,h)))
337 self.cols.append(col)
338
339 for n in graph:
340 h=n.height()
341 w=n.width()
342 x=n.x()
343 y=n.y()
344 l1,l2=bisect.bisect_left(ys,y-ymargin),bisect.bisect_left(ys,y+h+ymargin)
345 i1,i2=bisect.bisect_left(xs,x-xmargin),bisect.bisect_left(xs,x+w+xmargin)
346 for c in self.cols[i1:i2]:
347 for e in c[l1:l2]:
348 e.blocked=1
349
350 #for col in self.cols:
351 # print [e.coord +(e.blocked,) for e in col]
352
353 def reset(self):
354 for c in self.cols:
355 for n in c:
356 n.open=n.close=0
357 n.total= n.path_cost=0
358 n.parent=None
359
360 def get(self,coord):
361 x,y=coord
362 col= bisect.bisect_left(self.xs,x)-1
363 if col < 0 or col >= len(self.cols):
364 return None
365 col=self.cols[col]
366 row=bisect.bisect_left(self.ys,y)-1
367 if row < 0 or row >= len(col):
368 return None
369 return col[row]
370
371 def getPath(self,node):
372 path=[node.coord]
373 parent=node.parent
374 while parent:
375 prev=node
376 node=parent
377 parent=node.parent
378 if parent:
379 #if points are aligned don't keep the middle point
380 x,y=node.coord
381 x0,y0=prev.coord
382 x1,y1=parent.coord
383 if (x1-x)*(y0-y)-(y1-y)*(x0-x) == 0:
384 continue
385 path.append(node.coord)
386 path.reverse()
387 return path
388
389 def neighbours(self,node):
390 col,row=node.index
391 l=[]
392 steps=((0, +1), (+1, 0), (0, -1), (-1, 0 ))
393 for step in steps:
394 c=col+step[0]
395 r=row+step[1]
396 if c < 0 or c >=len(self.cols):
397 continue
398 co=self.cols[c]
399 if r <0 or r >= len(co):
400 continue
401 n=co[r]
402 if n.blocked:
403 continue
404 l.append(n)
405 return l
406
407 def findPath(self,fromLoc,toLoc):
408 """Find shortest path from fromLoc to toLoc"""
409 self.reset()
410 self.open=[]
411 fromNode=self.get(fromLoc)
412 self.open.append((fromNode.total,fromNode))
413 toNode=self.get(toLoc)
414 if toNode.blocked:
415 print("toNode is blocked")
416 return []
417 destx,desty=toNode.coord
418 while self.open:
419 #if open is not void, take the best node (the first one)
420 t,node=self.open.pop(0)
421 node.close=1
422 if node == toNode:
423 #got toLoc
424 return self.getPath(node)
425
426 for new_node in self.neighbours(node):
427 if new_node.close :
428 continue
429 x,y =new_node.coord
430 path_cost=node.path_cost+distance(node,new_node)
431 total=path_cost+h(x,y,destx,desty)
432 if new_node.open :
433 #the node is already in open
434 if total < new_node.total:
435 self.open.remove((new_node.total,new_node))
436 new_node.path_cost=path_cost
437 new_node.parent=node
438 new_node.total=total
439 bisect.insort(self.open,(new_node.total,new_node))
440 else:
441 #the node is not yet in open
442 new_node.path_cost=path_cost
443 new_node.parent=node
444 new_node.total=total
445 bisect.insort(self.open,(new_node.total,new_node))
446 new_node.open=1
447
448 return []
449
def addLink(self, link)
Definition: graph.py:93
def addItem(self, item)
Definition: graph.py:112
Definition: graph.py:195
Definition: graph.py:185
def __init__(self, item, parent)
Definition: graph.py:41
def selectItem(self, item)
Definition: graph.py:119
Definition: graph.py:55
def layout(self, rankdir)
Definition: graph.py:123
def customEvent(self, event)
Definition: graph.py:35
def getPath(self, node)
Definition: graph.py:371
def reset(self)
Definition: graph.py:353
def findPath(self, fromLoc, toLoc)
Definition: graph.py:407
def neighbours(self, node)
Definition: graph.py:389
def get(self, coord)
Definition: graph.py:360
def __init__(self, graph)
Definition: graph.py:298
def __init__(self, coord, index)
Definition: graph.py:287
def distance(node, new_node)
Definition: graph.py:275
def h(x, y, destx, desty)
Definition: graph.py:272
def attrs(g, t=gv.AGRAPH)
Definition: graph.py:265
