gui.graph.Graph Class Reference
def __init__ (self, item, parent)
def createGraph (self)
def addLink (self, link)
def addItem (self, item)
def selectItem (self, item)
def layout (self, rankdir)
def clearLinks (self)
def orthoLinks (self)
Public Attributes
 parent
 item
 node
 canvas
 editor
 citems
Definition at line 40 of file graph.py.
◆ __init__()
def gui.graph.Graph.__init__ (   self,
  item,
  parent
Definition at line 41 of file graph.py.
41 def __init__(self,item,parent):
42 self.parent=parent
43 self.item=item
44 self.node=item.node
45 #initial canvas size : 1000x1000
46 self.canvas=MyCanvas(1000,1000)
47 self.editor=GraphViewer(self.canvas,parent,"example",0)
48 self.createGraph()
49 root=self.node.getRootNode()
50 rootItem=Item.adapt(root)
51 CONNECTOR.Connect(rootItem,"selected",self.selectItem,())
52 CONNECTOR.Connect(self.item,"add",self.addItem,())
53 CONNECTOR.Connect(self.item.datalinks,"add",self.addLink,())
54
◆ addItem()
def gui.graph.Graph.addItem (   self,
  item
Definition at line 112 of file graph.py.
112 def addItem(self,item):
113 #print "graph.addItem",item
114 node=CItems.Cell(item.node,self.canvas)
115 self.citems[item.node.ptr()]=node
116 node.show()
117 self.canvas.update()
118
References gui.CItems.LinkItem.canvas, gui.graph.Graph.canvas, and gui.graph.Graph.citems.
◆ addLink()
def gui.graph.Graph.addLink (   self,
  link
Definition at line 93 of file graph.py.
93 def addLink(self,link):
94 print("graph.addLink",link)
95 #CItem for outport
96 nodeS=self.citems[link.pout.getNode().ptr()]
97 nodeE=self.citems[link.pin.getNode().ptr()]
98 po=pi=None
99 for p in nodeS.outports:
100 if p.port == link.pout:
101 po=p
102 break
103 for p in nodeE.inports:
104 if p.port == link.pin:
105 pi=p
106 break
107
108 if pi and po:
109 l=CItems.LinkItem(po,pi,self.canvas)
110 self.canvas.update()
111
◆ clearLinks()
def gui.graph.Graph.clearLinks (   self)
Definition at line 185 of file graph.py.
185 def clearLinks(self):
186 items=list(self.citems.values())
187 for node in items:
188 for port in node.outports:
189 if not hasattr(port,"links"):
190 continue
191 for link in port.links():
192 link.clearPoints()
193 self.canvas.update()
194
◆ createGraph()
def gui.graph.Graph.createGraph (   self)
Definition at line 55 of file graph.py.
55 def createGraph(self):
56 #citems dict helps finding items in canvas from swig proxy
57 #To find an item node make : citems[node.ptr()]
58 citems={}
59 self.citems=citems
60 #pitems dict helps finding items in canvas from swig proxy
61 #To find an item port make : pitems[port.ptr()]
62 pitems={}
63
64 y=0
65 lnode=self.node.edGetDirectDescendants()
66 for n in lnode:
67 c=CItems.Cell(n,self.canvas)
68 citems[n.ptr()]=c
69 c.show()
70
71 for k,n in list(citems.items()):
72 for p in n.inports:
73 pitems[p.port.ptr()]=p
74 for p in n.outports:
75 pitems[p.port.ptr()]=p
76
77 for pout,pin in self.node.getSetOfInternalLinks():
78 if pout.getNode().getFather() != self.node and pin.getNode().getFather() != self.node:
79 continue
80 po=pitems.get(pout.ptr())
81 pi=pitems.get(pin.ptr())
82 if pi and po:
83 CItems.LinkItem(po,pi,self.canvas)
84
85 for n in lnode:
86 itemup=citems[n.ptr()]
87 for ndown in n.getOutNodes():
88 itemdown=citems[ndown.ptr()]
89 CItems.ControlLinkItem(itemup.outgate,itemdown.ingate,self.canvas)
90
91 self.layout("LR")
92
◆ layout()
def gui.graph.Graph.layout (   self,
  rankdir
Compute graph layout with graphviz package
Definition at line 123 of file graph.py.
123 def layout(self,rankdir):
124 """Compute graph layout with graphviz package"""
125 G=pygraphviz.AGraph(strict=False,directed=True)
126 G.graph_attr["rankdir"]=rankdir
127 G.graph_attr["dpi"]="72"
128 dpi=72.
129 aspect=dpi/72
130 for k,n in list(self.citems.items()):
131 #k is node address (YACS)
132 #n is item in canvas
133 G.add_node(k)
134
135 for pout,pin in self.node.getSetOfInternalLinks():
136 if pout.getNode().ptr() not in self.citems :
137 continue
138 if pin.getNode().ptr() not in self.citems:
139 continue
140 G.add_edge(pout.getNode().ptr(),pin.getNode().ptr())
141
142 for k,n in list(self.citems.items()):
143 for ndown in n.node.getOutNodes():
144 G.add_edge(n.node.ptr(),ndown.ptr())
145
146 #By default graphviz uses 96.0 pixel per inch (dpi=96.0)
147 for n in G.nodes():
148 item=self.citems[int(n)]
149 h=item.height()/dpi #height in inch
150 w=item.width()/dpi #width in inch
151 n.attr['height']=str(h)
152 n.attr['width']=str(w)
153 n.attr['fixedsize']="true"
154 n.attr['shape']="box"
155 #n.attr['label']=item.node.getName()
156
157 G.layout(prog='dot') # use dot
158 #G.write("layout.dot")
159 #G.draw("layout.png")
160
161 graph_attr=dict(attrs(G))
162 bbox=graph_attr["bb"]
163 x1,y1,x2,y2=eval(bbox)
164 h=self.canvas.height()
165 w=self.canvas.width()
166 h2=max(h,y2-y1+100)
167 w2=max(w,x2-x1+100)
168 if h2 > h or w2 > w:
169 self.canvas.resize(w2,h2)
170
171 for n in G:
172 pos=n.attr['pos'] #position is given in points (72 points par inch, so 1 point = dpi/72=1.34)
173 x,y=eval(pos)
174 x=aspect*x
175 y=aspect*y
176 item=self.citems[int(n)]
177 x0=item.x()
178 y0=item.y()
179 x=x-x0
180 y=y-y0
181 item.moveBy(x,y)
182
183 self.canvas.update()
184
def attrs(g, t=gv.AGRAPH)
Definition: graph.py:265
References gui.graph.attrs(), gui.CItems.LinkItem.canvas, gui.graph.Graph.canvas, gui.graph.Graph.citems, gui.cataitems.ItemNode.node, gui.cataitems.ItemComposedNode.node, gui.CItems.ControlItem.node, gui.CItems.PortItem.node, gui.CItems.Cell.node, gui.graph.Graph.node, gui.GraphViewer.PortItem.node, gui.Items.ItemComposedNode.node, gui.Items.ItemNode.node, YACS::servertypeParser< T >.node(), YACS::servicetypeParser< T >.node(), YACS::looptypeParser< ENGINE::OptimizerLoop * >.node(), YACS::looptypeParser< ENGINE::WhileLoop * >.node(), YACS::looptypeParser< PseudoComposedNode * >.node(), YACS::looptypeParser< ENGINE::ForLoop * >.node(), YACS::looptypeParser< ENGINE::DynParaLoop * >.node(), YACS::looptypeParser< T >.node(), YACS::casetypeParser.node(), YACS::bloctypeParser< YACS::ENGINE::Proc * >.node(), and YACS::bloctypeParser< T >.node().
◆ orthoLinks()
def gui.graph.Graph.orthoLinks (   self)
Definition at line 195 of file graph.py.
195 def orthoLinks(self):
196 items=list(self.citems.values())
197 g=grid(items)
198 for node in items:
199 for port in node.outports:
200 if not hasattr(port,"links"):
201 continue
202 for link in port.links():
203 #clear all intermediate points of the link
204 link.clearPoints()
205 #if isinstance(link,CItems.ControlLinkItem):
206 # print port.port.getNode().getName() +"->"+link.toPort.port.getNode().getName()
207 #else:
208 # print port.port.getNode().getName() +":"+port.port.getName()+"->"+link.toPort.port.getNode().getName()+":"+link.toPort.port.getName()
209 #print (port.x(),port.y()),(link.toPort.x(),link.toPort.y())
210 x0,y0=port.x()+5,port.y()
211 while g.get((x0,y0)).blocked:
212 x0=x0+1
213 x1,y1=link.toPort.x()-5,link.toPort.y()
214 while g.get((x1,y1)).blocked:
215 x1=x1-1
216 path=g.findPath((x0,y0),(x1,y1))
217 #print path
218 if len(path)==1:
219 if port.y() == link.toPort.y():
220 #near ports face to face
221 continue
222 else:
223 x,y=path[0]
224 path=[(x,port.y()),(x,link.toPort.y())]
225 elif len(path)==2:
226 x1,y1=path[0]
227 x2,y2=path[1]
228 if x1 == x2:
229 #vertical line
230 path=[(x1,port.y()),(x1,link.toPort.y())]
231 else:
232 #horizontal line
233 if port.y() == link.toPort.y():
234 #near ports face to face
235 continue
236 else:
237 #transform it into a vertical line
238 x=(x1+x2)/2
239 path=[(x,port.y()),(x,link.toPort.y())]
240
241 #adjust the first point to the same y as port
242 x0,y0=path[0]
243 x1,y1=path[1]
244 if y0==y1:
245 #remove first point and adjust second one
246 del path[0]
247 x0=x1
248 path[0]=x0,port.y()
249 #adjust the last point to the same y as link.toPort
250 x0,y0=path[-1]
251 x1,y1=path[-2]
252 if y0==y1:
253 #remove last point and adjust new last one
254 del path[-1]
255 x0=x1
256 path[-1]=x0,link.toPort.y()
257 #print path
258
259 #add intermediate points
260 for x,y in path:
261 line=link.lines[-1]
262 link.splitLine(line,x,y)
263 self.canvas.update()
264
◆ selectItem()
def gui.graph.Graph.selectItem (   self,
  item
Definition at line 119 of file graph.py.
119 def selectItem(self,item):
120 #print "graph.selectItem",item
121 self.editor.selectItem(item)
122
References gui.graph.Graph.editor, and gui.graph.Graph.selectItem().
Referenced by gui.Tree.Tree.additem(), and gui.graph.Graph.selectItem().
◆ canvas
◆ citems
◆ editor
Definition at line 47 of file graph.py.
Referenced by gui.graph.Graph.selectItem().
◆ item
◆ node
◆ parent
gui.graph.Graph.parent
Definition at line 42 of file graph.py.
Referenced by gui.Appli.Runner.run().
