serverParsers.hxx
20#ifndef _SERVERPARSERS_HXX_
21#define _SERVERPARSERS_HXX_
23#include "ServerNode.hxx"
24
27
28namespace YACS
29{
30
31static std::string t22[]={"ref","node","component","componentinstance",""};
32
33template <class T=YACS::ENGINE::ServerNode*>
35{
37
38 virtual void onStart(const XML_Char* el, const XML_Char** attr);
39 virtual void onEnd(const char *el,parser* child)
40 {
41 DEBTRACE( "servertypeParser::onEnd: " << el )
42 std::string element(el);
43 if(element == "kind")this->kind(((stringtypeParser*)child)->post());
44 else if(element == "loadcontainer") loadcontainer(((stringtypeParser*)child)->post());
45 //else if(element == "loadcontainerinstance") containerinstance(((stringtypeParser*)child)->post());
46 else if(element == "script") script(((codetypeParser*)child)->post());
47 else if(element == "node") node(((stringtypeParser*)child)->post());
48 else if(element == "method") method(((stringtypeParser*)child)->post());
49 else if(element == "load") load(((loadtypeParser*)child)->post());
50 else if(element == "property")this->property(((propertytypeParser*)child)->post());
51 else if(element == "inport") this->inport(((inporttypeParser<myinport>*)child)->post());
52 else if(element == "outport") this->outport(((outporttypeParser<myoutport>*)child)->post());
53 else if(element == "instream") instream(((inporttypeParser<myinport>*)child)->post());
54 else if(element == "outstream") outstream(((outporttypeParser<myoutport>*)child)->post());
55 }
56
57 /*virtual void containerinstance (const std::string& name)
58 {
59 DEBTRACE( "componentinstance: " << name )
60 if(currentProc->componentInstanceMap.count(name) == 0)
61 throw YACS::Exception("Unknown ComponentInstance: "+name);
62 this->_node=theRuntime->createCompoNode(this->_kind,this->_name);
63 YACS::ENGINE::ComponentInstance* inst=currentProc->componentInstanceMap[name];
64 this->_node->setComponent(inst);
65 }*/
66
67 virtual void loadcontainer (const std::string& name)
68 {
69 DEBTRACE( "server_loadcontainer: " << name )
70 this->_node=(YACS::ENGINE::ServerNode*)theRuntime->createFuncNode("DistPython",this->_name);
71 std::map<std::string,YACS::ENGINE::Container *>::const_iterator it(currentProc->containerMap.find(name));
72 if(it!=currentProc->containerMap.end())
73 {
74 this->_node->setContainer((*it).second);
75 }
76 else
77 {
79 cont->setName(name);
80 this->_node->setContainer(cont);
81 cont->decrRef();
82 }
83 }
84 virtual void script (const myfunc& f)
85 {
86 DEBTRACE( "server_script: " << f._code )
87 this->_node->setScript(f._code);
88 }
89 virtual void node (const std::string& name)
90 {
91 DEBTRACE( "server_node: " << name )
92 std::string fullname = currentProc->names.back()+name;
93 if(currentProc->inlineMap.count(name) != 0)
94 {
95 //ServerNode with absolute name found
97 this->_node =n->createNode(this->_name);
98 }
99 else if(currentProc->inlineMap.count(fullname) != 0)
100 {
101 //ServerNode with relative name found
102 //TODO: must be a short name (possible only in the same context)
104 this->_node =n->createNode(this->_name);
105 }
106 else
107 {
108 throw YACS::Exception("Unknown ServerNode");
109 }
110 }
111
112 virtual void method (const std::string& name)
113 {
114 DEBTRACE( "server_method: " << name )
115 if(this->_node==0)
116 throw YACS::Exception("ServerNode must be completely defined before defining its method");
117 if(name == "")
118 {
119 this->logError("a server name must be a non empty string");
120 return;
121 }
122 this->_node->setFname(name);
123 }
124
125 virtual void load (const loadon& l)
126 {
127 DEBTRACE( "server_load: " << l._container);
128 this->_container=l._container;
129 }
130
131 virtual void instream (const myinport& p)
132 {
133 DEBTRACE( "server_instream" )
134 DEBTRACE( p._type )
135 DEBTRACE( p._name )
136 if(this->_node==0)
137 throw YACS::Exception("ServerNode must be completely defined before defining its ports");
138
139 if(currentProc->typeMap.count(p._type)==0)
140 {
142 if(t==0)
143 {
144 std::string msg="Unknown InStreamPort Type: ";
145 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
146 throw YACS::Exception(msg);
147 }
148 else
149 {
150 currentProc->typeMap[p._type]=t;
151 t->incrRef();
152 }
153 }
156 // Set all properties for this port
157 std::map<std::string, std::string>::const_iterator pt;
158 for(pt=p._props.begin();pt!=p._props.end();pt++)
159 port->setProperty((*pt).first,(*pt).second);
160 }
161 virtual void outstream (const myoutport& p)
162 {
163 DEBTRACE( "server_outstream" )
164 DEBTRACE( p._type )
165 DEBTRACE( p._name )
166 if(this->_node==0)
167 throw YACS::Exception("ServerNode must be completely defined before defining its ports");
168
169 if(currentProc->typeMap.count(p._type)==0)
170 {
172 if(t==0)
173 {
174 std::string msg="Unknown OutStreamPort Type: ";
175 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
176 throw YACS::Exception(msg);
177 }
178 else
179 {
180 currentProc->typeMap[p._type]=t;
181 t->incrRef();
182 }
183 }
186 // Set all properties for this port
187 std::map<std::string, std::string>::const_iterator pt;
188 for(pt=p._props.begin();pt!=p._props.end();pt++)
189 port->setProperty((*pt).first,(*pt).second);
190 }
191 virtual T post()
192 {
193 DEBTRACE( "server_post " << this->_node->getName() )
194 this->mincount("method",1);
195 if(this->_state == "disabled")this->_node->exDisabledState();
196
197 // If the server node has no component instance don't go further return the node
198 if(!this->_node->getComponent())
199 return this->_node;
200
201 // when container is not defined by <load container="xxx"/> but indirectly by <node>xxx</node>
202 // this->_container is not set, and there is no need to setContainer
203 // so stop here and return the node
204 if(this->_node->getComponent()->getContainer())
205 return this->_node;
206
207 //If the component instance is anonymous set the container
208 // with the load directive or with the DefaultContainer
209 if(this->_node->getComponent()->isAnonymous())
210 {
211 if(currentProc->containerMap.count(this->_container) != 0)
212 this->_node->getComponent()->setContainer(currentProc->containerMap[this->_container]);
213 else if(this->_container == "" && currentProc->containerMap.count("DefaultContainer") != 0)
214 {
215 //a default container is defined : use it if supported
216 try
217 {
218 currentProc->containerMap["DefaultContainer"]->checkCapabilityToDealWith(this->_node->getComponent());
219 this->_node->getComponent()->setContainer(currentProc->containerMap["DefaultContainer"]);
220 }
221 catch(YACS::Exception)
222 {}
223 }
224 else
225 std::cerr << "WARNING: Unknown container " << this->_container << " ignored" << std::endl;
226 }
227 return this->_node;
228 }
229};
230
231template <class T> servertypeParser<T> servertypeParser<T>::serverParser;
232
233
234template <class T>
235void servertypeParser<T>::onStart(const XML_Char* el, const XML_Char** attr)
236 {
237 DEBTRACE( "servertypeParser::onStart: " << el )
238 std::string element(el);
240 this->maxcount("kind",1,element);
241 this->maxcount("ref",1,element);
242 this->maxcount("node",1,element);
243 this->maxcount("component",1,element);
244 this->maxcount("componentinstance",1,element);
245 this->maxcount("loadcontainer",1,element);
246 this->maxcount("script",1,element);
247 this->maxcount("method",1,element);
248 this->maxcount("load",1,element);
249 this->maxchoice(t22,1,element);
250 if(element == "kind")pp=&stringtypeParser::stringParser;
251 else if(element == "ref")pp=&stringtypeParser::stringParser;
252 else if(element == "component")pp=&stringtypeParser::stringParser;
253 else if(element == "componentinstance")pp=&stringtypeParser::stringParser;
254 else if(element == "loadcontainer")pp=&stringtypeParser::stringParser;
255 else if(element == "script")pp=&codetypeParser::codeParser;
256 else if(element == "node")pp=&stringtypeParser::stringParser;
257 else if(element == "method")pp=&stringtypeParser::stringParser;
258 else if(element == "load")pp=&loadtypeParser::loadParser;
259 else if(element == "property")pp=&propertytypeParser::propertyParser;
260 else if(element == "inport")pp=&inporttypeParser<>::inportParser;
261 else if(element == "outport")pp=&outporttypeParser<>::outportParser;
262 else if(element == "instream")pp=&inporttypeParser<>::inportParser;
263 else if(element == "outstream")pp=&outporttypeParser<>::outportParser;
264 this->SetUserDataAndPush(pp);
265 pp->init();
266 pp->pre();
267 pp->buildAttr(attr);
268 }
269
270} // end of namespace YACS
271
272#endif
virtual bool setContainer(Container *cont)
void setName(std::string name)
WARNING ! name is used in edition to identify different containers, it is not the runtime name of the...
Definition: Container.hxx:83
virtual void setProperty(const std::string &name, const std::string &value)
Set a new value for a property of the port.
virtual OutputDataStreamPort * edAddOutputDataStreamPort(const std::string &outputPortDSName, TypeCode *type)
virtual InputDataStreamPort * edAddInputDataStreamPort(const std::string &inputPortDSName, TypeCode *type)
ComponentInstance * getComponent()
virtual void setFname(const std::string &fname)
Set the function name to use in node execution.
Definition: InlineNode.cxx:69
virtual void setScript(const std::string &script)
Set the script (as a string) to execute.
Definition: InlineNode.cxx:50
virtual void setContainer(Container *container)
Definition: InlineNode.cxx:105
Definition: Node.hxx:125
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
Definition: Proc.hxx:44
std::map< std::string, InlineNode * > inlineMap
Definition: Proc.hxx:89
virtual Container * createContainer(const std::string &name, const std::string &kind="")
Create a new Container and store it in containerMap.
Definition: Proc.cxx:506
Definition: Proc.hxx:90
std::vector< std::string > names
Definition: Proc.hxx:93
Definition: Proc.hxx:91
virtual InlineFuncNode * createFuncNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:190
Definition: Runtime.cxx:333
virtual std::string getEffectiveKindOfServer() const =0
Definition: TypeCode.hxx:68
Proc * p
Definition: driver.cxx:216
char XML_Char
Definition: parserBase.hxx:37
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
Class for code parser in inline nodes.
Definition: codeParsers.hxx:35
static codetypeParser codeParser
Definition: codeParsers.hxx:36
Class for Inport parser.
Definition: portParsers.hxx:49
Class for loading parser.
static loadtypeParser loadParser
Definition: nodeParsers.hxx:90
Class for Outport parser.
Definition: portParsers.hxx:70
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
void logError(const std::string &reason)
Definition: parserBase.cxx:214
Class for property parser.
virtual void method(const std::string &name)
virtual void node(const std::string &name)
virtual void outstream(const myoutport &p)
static servertypeParser< T > serverParser
virtual void script(const myfunc &f)
virtual void loadcontainer(const std::string &name)
virtual void load(const loadon &l)
virtual void instream(const myinport &p)
Class for string parser.
Definition: dataParsers.hxx:32
Definition: dataParsers.hxx:33
std::string _container
Definition: factory.hxx:122
std::string _code
Definition: factory.hxx:104
std::string _name
Definition: factory.hxx:80
