YACS::ENGINE::DataStreamPort Class Reference
#include <DataStreamPort.hxx>
Inheritance diagram for YACS::ENGINE::DataStreamPort:
Collaboration diagram for YACS::ENGINE::DataStreamPort:
 Set a new value for a property of the port. More...
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
Static Public Attributes
static const char NAME [] ="DataStreamPort"
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
 DataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 33 of file DataStreamPort.hxx.
◆ DataStreamPort() [1/2]
DataStreamPort::DataStreamPort ( const DataStreamPort &  other,
Node *  newHelder
Definition at line 28 of file DataStreamPort.cxx.
28 :DataPort(other,newHelder),Port(other,newHelder),_propertyMap(other._propertyMap)
29{
30}
Definition: DataPort.cxx:41
std::map< std::string, std::string > _propertyMap
Port(Node *node)
Definition: Port.cxx:34
◆ DataStreamPort() [2/2]
DataStreamPort::DataStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 32 of file DataStreamPort.cxx.
32 :DataPort(name,node,type),Port(node)
33{
34}
◆ ~DataStreamPort()
DataStreamPort::~DataStreamPort ( )
Definition at line 36 of file DataStreamPort.cxx.
37{
38}
string DataStreamPort::getNameOfTypeOfCurrentInstance ( ) const
◆ getProperties()
std::map< std::string, std::string > YACS::ENGINE::DataStreamPort::getProperties ( ) const
◆ getProperty()
std::string DataStreamPort::getProperty ( const std::string &  name)
name: the name property
the value property
Definition at line 60 of file DataStreamPort.cxx.
61{
62 return _propertyMap[name];
63}
References _propertyMap.
◆ getTypeOfChannel()
TypeOfChannel YACS::ENGINE::DataStreamPort::getTypeOfChannel ( ) const
returns type of channel the port will use for data exchange on runtime : DATAFLOW or DATASTREAM.
Implements YACS::ENGINE::DataPort.
Definition at line 43 of file DataStreamPort.hxx.
43{ return DATASTREAM; }
References YACS::ENGINE::DATASTREAM.
◆ initPortProperties()
void DataStreamPort::initPortProperties ( )
This method is called before the execution of the parent node. It is not used when the user sets properties
Definition at line 84 of file DataStreamPort.cxx.
85{
86}
◆ setProperties()
void DataStreamPort::setProperties ( std::map< std::string, std::string >  properties)
properties: a map containing the values of properties
Definition at line 69 of file DataStreamPort.cxx.
70{
71 _propertyMap.clear();
72 std::map<std::string,std::string>::iterator it;
73 for (it = properties.begin(); it != properties.end(); ++it)
74 {
75 setProperty((*it).first, (*it).second); // setProperty virtual and derived
76 }
77}
virtual void setProperty(const std::string &name, const std::string &value)
References _propertyMap, and setProperty().
Referenced by YACS::HMI::CommandSetDSPortProperties::localExecute(), YACS::HMI::CommandSetLinkProperties::localExecute(), YACS::HMI::CommandSetDSPortProperties::localReverse(), and YACS::HMI::CommandSetLinkProperties::localReverse().
◆ setProperty()
void DataStreamPort::setProperty ( const std::string &  name,
const std::string &  value
◆ typeName()
virtual std::string YACS::ENGINE::DataStreamPort::typeName ( )
Reimplemented from YACS::ENGINE::DataPort.
Reimplemented in YACS::ENGINE::InputDataStreamPort, and YACS::ENGINE::OutputDataStreamPort.
Definition at line 50 of file DataStreamPort.hxx.
50{return "YACS__ENGINE__DataStreamPort";}
◆ _propertyMap
std::map<std::string,std::string> YACS::ENGINE::DataStreamPort::_propertyMap
Definition at line 40 of file DataStreamPort.hxx.
Referenced by getProperty(), setProperties(), and setProperty().
◆ NAME
const char DataStreamPort::NAME ="DataStreamPort"
Definition at line 36 of file DataStreamPort.hxx.
Referenced by getNameOfTypeOfCurrentInstance().
