YACS::ENGINE::InputCalStreamPort Class Reference
Class for Input Calcium DataStream Ports. More...
#include <CalStreamPort.hxx>
Inheritance diagram for YACS::ENGINE::InputCalStreamPort:
Collaboration diagram for YACS::ENGINE::InputCalStreamPort:
 InputCalStreamPort (const std::string &name, Node *node, TypeCode *type)
 InputCalStreamPort (const InputCalStreamPort &other, Node *newHelder)
virtual ~InputCalStreamPort ()
void setProperty (const std::string &name, const std::string &value)
 Set a new value for a property of the port. More...
InputCalStreamPort * clone (Node *newHelder) const
void setSchema (const std::string &value)
std::string getSchema ()
void setLevel (const std::string &value)
int getLevel ()
void setDepend (const std::string &value)
std::string getDepend ()
void setDelta (const std::string &value)
double getDelta ()
void setAlpha (const std::string &value)
double getAlpha ()
void setInterp (const std::string &value)
std::string getInterp ()
void setExtrap (const std::string &value)
std::string getExtrap ()
- Public Member Functions inherited from YACS::ENGINE::InputDataStreamPort
 InputDataStreamPort (const InputDataStreamPort &other, Node *newHelder)
 InputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~InputDataStreamPort ()
virtual InputDataStreamPort * clone (Node *newHelder) const
virtual void edAddOutputDataStreamPort (OutputDataStreamPort *port)
std::set< OutputDataStreamPort * > getConnectedOutputDataStreamPort ()
- Public Member Functions inherited from YACS::ENGINE::DataStreamPort
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Static Public Attributes
static const char NAME [] ="InputCalStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::InputDataStreamPort
static const char NAME [] ="InputDataStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::DataStreamPort
static const char NAME [] ="DataStreamPort"
std::string _depend
std::string _schema
std::string _interp
std::string _extrap
int _level
double _delta
double _alpha
- Protected Attributes inherited from YACS::ENGINE::InputDataStreamPort
std::set< OutputDataStreamPort * > _setOfOutputDataStreamPort
- Protected Attributes inherited from YACS::ENGINE::DataStreamPort
TypeCode * _type
Node * _node
int _id
- Protected Member Functions inherited from YACS::ENGINE::DataStreamPort
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 40 of file CalStreamPort.hxx.
◆ InputCalStreamPort() [1/2]
InputCalStreamPort::InputCalStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 34 of file CalStreamPort.cxx.
34 :
35 InputDataStreamPort(name, node, type),
36 DataPort(name, node, type),
37 Port(node),_depend("TIME_DEPENDENCY"),_schema("TI_SCHEM"),_delta(-1.),_level(-1),_alpha(0.),
38 _interp("L1_SCHEM"),_extrap("UNDEFINED_EXTRA_SCHEM")
39{
40}
Definition: DataPort.cxx:41
InputDataStreamPort(const InputDataStreamPort &other, Node *newHelder)
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InputCalStreamPort() [2/2]
InputCalStreamPort::InputCalStreamPort ( const InputCalStreamPort &  other,
Node *  newHelder
Definition at line 41 of file CalStreamPort.cxx.
41 :
42 InputDataStreamPort(other,newHelder),
43 DataPort(other,newHelder),
44 Port(other,newHelder),_depend(other._depend),_schema(other._schema),_delta(other._delta),_level(other._level),
45 _alpha(other._alpha),_interp(other._interp),_extrap(other._extrap)
46{
47}
◆ ~InputCalStreamPort()
InputCalStreamPort::~InputCalStreamPort ( )
Definition at line 49 of file CalStreamPort.cxx.
50{
51}
◆ clone()
InputCalStreamPort * InputCalStreamPort::clone ( Node *  newHelder) const
Reimplemented from YACS::ENGINE::InputDataStreamPort.
Definition at line 207 of file CalStreamPort.cxx.
208{
209 return new InputCalStreamPort(*this,newHelder);
210}
InputCalStreamPort(const std::string &name, Node *node, TypeCode *type)
References InputCalStreamPort().
◆ getAlpha()
double YACS::ENGINE::InputCalStreamPort::getAlpha ( )
Definition at line 62 of file CalStreamPort.hxx.
62{return _alpha;};
References _alpha.
◆ getDelta()
double YACS::ENGINE::InputCalStreamPort::getDelta ( )
Definition at line 60 of file CalStreamPort.hxx.
60{return _delta;};
References _delta.
◆ getDepend()
std::string YACS::ENGINE::InputCalStreamPort::getDepend ( )
Definition at line 58 of file CalStreamPort.hxx.
58{return _depend;};
References _depend.
Referenced by YACS::ENGINE::OutputCalStreamPort::addInPort().
◆ getExtrap()
std::string YACS::ENGINE::InputCalStreamPort::getExtrap ( )
Definition at line 66 of file CalStreamPort.hxx.
66{return _extrap;};
References _extrap.
◆ getInterp()
std::string YACS::ENGINE::InputCalStreamPort::getInterp ( )
Definition at line 64 of file CalStreamPort.hxx.
64{return _interp;};
References _interp.
◆ getLevel()
int YACS::ENGINE::InputCalStreamPort::getLevel ( )
Definition at line 56 of file CalStreamPort.hxx.
56{return _level;};
References _level.
std::string InputCalStreamPort::getNameOfTypeOfCurrentInstance ( ) const
Definition at line 202 of file CalStreamPort.cxx.
203{
204 return NAME;
205}
References NAME.
◆ getSchema()
std::string YACS::ENGINE::InputCalStreamPort::getSchema ( )
Definition at line 54 of file CalStreamPort.hxx.
54{return _schema;};
References _schema.
◆ setAlpha()
void InputCalStreamPort::setAlpha ( const std::string &  value)
Definition at line 84 of file CalStreamPort.cxx.
85{
86 std::istringstream iss(value);
87 double temp;
88 if (!(iss >> temp)||temp<0. || temp >1.)
89 throw Exception("Alpha property must be a float > 0 and < 1");
90 _alpha=temp;
91}
References _alpha.
Referenced by setProperty().
◆ setDelta()
void InputCalStreamPort::setDelta ( const std::string &  value)
Definition at line 92 of file CalStreamPort.cxx.
93{
94 std::istringstream iss(value);
95 double temp;
96 if (!(iss >> temp)||temp<0. || temp >1.)
97 throw Exception("DeltaT property must be > 0 and < 1");
98 _delta=temp;
99}
References _delta.
◆ setDepend()
void InputCalStreamPort::setDepend ( const std::string &  value)
Definition at line 53 of file CalStreamPort.cxx.
54{
55 DEBTRACE("InputCalStreamPort::setDepend: " << edGetNumberOfLinks());
56 if(edGetNumberOfLinks() > 0)
57 {
58 throw Exception("Can not modify DependencyType property on a connected port");
59 }
60 if(depend != "TIME_DEPENDENCY" && depend != "ITERATION_DEPENDENCY")
61 {
62 throw Exception("DependencyType property must be TIME_DEPENDENCY or ITERATION_DEPENDENCY");
63 }
64 _depend=depend;
65}
virtual int edGetNumberOfLinks() const
Returns number of physical backlinks NOT number of user backlinks.
Definition: InPort.cxx:45
References _depend, DEBTRACE, and YACS::ENGINE::InPort::edGetNumberOfLinks().
◆ setExtrap()
void InputCalStreamPort::setExtrap ( const std::string &  value)
Definition at line 108 of file CalStreamPort.cxx.
109{
110 if(value != "E0_SCHEM" && value != "E1_SCHEM")
111 {
112 throw Exception("ExtrapolationSchem property must be E0_SCHEM or E1_SCHEM");
113 }
114 _extrap=value;
115}
References _extrap.
◆ setInterp()
void InputCalStreamPort::setInterp ( const std::string &  value)
Definition at line 100 of file CalStreamPort.cxx.
101{
102 if(value != "L0_SCHEM" && value != "L1_SCHEM")
103 {
104 throw Exception("InterpolationSchem property must be L0_SCHEM or L1_SCHEM");
105 }
106 _interp=value;
107}
References _interp.
◆ setLevel()
void InputCalStreamPort::setLevel ( const std::string &  value)
Definition at line 75 of file CalStreamPort.cxx.
76{
77 DEBTRACE("InputCalStreamPort::setLevel: " << value);
78 std::istringstream iss(value);
79 int temp;
80 if (!(iss >> temp)|| temp<1)
81 throw Exception("StorageLevel property must be an integer > 0");
82 _level=temp;
83}
References _level, and DEBTRACE.
◆ setProperty()
void InputCalStreamPort::setProperty ( const std::string &  name,
name: the name property
value: the value property
Reimplemented from YACS::ENGINE::DataStreamPort.
Definition at line 117 of file CalStreamPort.cxx.
118{
119 DEBTRACE("InputCalStreamPort::setProperty: " << name << " " << value);
120 if(name == "DependencyType")
121 setDepend(value);
122 else if(name == "DateCalSchem")
123 setSchema(value);
124 else if(name == "StorageLevel")
125 setLevel(value);
126 else if(name == "Alpha")
127 setAlpha(value);
128 else if(name == "DeltaT")
129 setDelta(value);
130 else if(name == "InterpolationSchem")
131 setInterp(value);
132 else if(name == "ExtrapolationSchem")
133 setExtrap(value);
135}
virtual void setProperty(const std::string &name, const std::string &value)
void setSchema(const std::string &value)
void setLevel(const std::string &value)
void setDepend(const std::string &value)
void setAlpha(const std::string &value)
void setExtrap(const std::string &value)
void setDelta(const std::string &value)
void setInterp(const std::string &value)
References DEBTRACE, setAlpha(), setDelta(), setDepend(), setExtrap(), setInterp(), setLevel(), YACS::ENGINE::DataStreamPort::setProperty(), and setSchema().
◆ setSchema()
void InputCalStreamPort::setSchema ( const std::string &  value)
Definition at line 67 of file CalStreamPort.cxx.
68{
69 if(schema != "TI_SCHEM" && schema != "TF_SCHEM" && schema != "ALPHA_SCHEM")
70 {
71 throw Exception("DateCalSchem property must be TI_SCHEM, TF_SCHEM or ALPHA_SCHEM");
72 }
73 _schema=schema;
74}
References _schema.
◆ _alpha
double YACS::ENGINE::InputCalStreamPort::_alpha
Definition at line 74 of file CalStreamPort.hxx.
Referenced by getAlpha(), and setAlpha().
◆ _delta
double YACS::ENGINE::InputCalStreamPort::_delta
Definition at line 73 of file CalStreamPort.hxx.
Referenced by getDelta(), and setDelta().
◆ _depend
std::string YACS::ENGINE::InputCalStreamPort::_depend
Definition at line 68 of file CalStreamPort.hxx.
Referenced by getDepend(), and setDepend().
◆ _extrap
std::string YACS::ENGINE::InputCalStreamPort::_extrap
Definition at line 71 of file CalStreamPort.hxx.
Referenced by getExtrap(), and setExtrap().
◆ _interp
std::string YACS::ENGINE::InputCalStreamPort::_interp
Definition at line 70 of file CalStreamPort.hxx.
Referenced by getInterp(), and setInterp().
◆ _level
int YACS::ENGINE::InputCalStreamPort::_level
Definition at line 72 of file CalStreamPort.hxx.
Referenced by getLevel(), and setLevel().
◆ _schema
std::string YACS::ENGINE::InputCalStreamPort::_schema
Definition at line 69 of file CalStreamPort.hxx.
Referenced by getSchema(), and setSchema().
◆ NAME
const char InputCalStreamPort::NAME ="InputCalStreamPort"
