CalStreamPort.hxx
20#ifndef __CALSTREAMPORT_HXX__
21#define __CALSTREAMPORT_HXX__
23#include "yacsconfig.h"
24#ifdef DSC_PORTS
25#include "DSC_Engines.hh"
26#endif
27
30
31namespace YACS
32{
33 namespace ENGINE
34 {
41 {
42 public:
43 static const char NAME[];
44 InputCalStreamPort(const std::string& name, Node *node, TypeCode* type);
45 InputCalStreamPort(const InputCalStreamPort& other, Node *newHelder);
46 virtual ~InputCalStreamPort();
47 void setProperty(const std::string& name, const std::string& value);
48 std::string getNameOfTypeOfCurrentInstance() const;
49 InputCalStreamPort * clone(Node *newHelder) const;
50#ifdef DSC_PORTS
51 virtual void initPortProperties();
52#endif
53 void setSchema(const std::string& value);
54 std::string getSchema(){return _schema;};
55 void setLevel(const std::string& value);
56 int getLevel(){return _level;};
57 void setDepend(const std::string& value);
58 std::string getDepend(){return _depend;};
59 void setDelta(const std::string& value);
60 double getDelta(){return _delta;};
61 void setAlpha(const std::string& value);
62 double getAlpha(){return _alpha;};
63 void setInterp(const std::string& value);
64 std::string getInterp(){return _interp;};
65 void setExtrap(const std::string& value);
66 std::string getExtrap(){return _extrap;};
67 protected:
68 std::string _depend;
69 std::string _schema;
70 std::string _interp;
71 std::string _extrap;
72 int _level;
73 double _delta;
74 double _alpha;
75 };
76
83 {
84 public:
85 static const char NAME[];
86 OutputCalStreamPort(const std::string& name, Node *node, TypeCode* type);
87 OutputCalStreamPort(const OutputCalStreamPort& other, Node *newHelder);
88 virtual ~OutputCalStreamPort();
89 void setDepend(const std::string& depend);
90 void setLevel(const std::string& schema);
91 std::string getDepend(){return _depend;};
92 int getLevel(){return _level;};
93 void setSchema(const std::string& schema);
94 std::string getSchema(){return _schema;};
95 void setProperty(const std::string& name, const std::string& value);
96 virtual bool addInPort(InPort *inPort) ;
97 std::string getNameOfTypeOfCurrentInstance() const;
98 OutputCalStreamPort * clone(Node *newHelder) const;
99 virtual int removeInPort(InPort *inPort, bool forward) ;
100 protected:
101 std::string _depend;
102 std::string _schema;
104 double _delta;
105 };
106 }
107}
108
109#endif
Initialize port properties at the start of calculation phase.
Class for Input Calcium DataStream Ports.
void setSchema(const std::string &value)
void setProperty(const std::string &name, const std::string &value)
Set a new value for a property of the port.
void setLevel(const std::string &value)
void setDepend(const std::string &value)
InputCalStreamPort(const std::string &name, Node *node, TypeCode *type)
void setAlpha(const std::string &value)
void setExtrap(const std::string &value)
void setDelta(const std::string &value)
void setInterp(const std::string &value)
Base class for all nodes.
Definition: Node.hxx:70
Class for Output Calcium DataStream Ports.
void setSchema(const std::string &schema)
void setDepend(const std::string &depend)
OutputCalStreamPort(const std::string &name, Node *node, TypeCode *type)
void setLevel(const std::string &schema)
Definition: TypeCode.hxx:68
