YACS::ENGINE::OutputCalStreamPort Class Reference
Class for Output Calcium DataStream Ports. More...
#include <CalStreamPort.hxx>
Inheritance diagram for YACS::ENGINE::OutputCalStreamPort:
Collaboration diagram for YACS::ENGINE::OutputCalStreamPort:
 OutputCalStreamPort (const std::string &name, Node *node, TypeCode *type)
 OutputCalStreamPort (const OutputCalStreamPort &other, Node *newHelder)
virtual ~OutputCalStreamPort ()
void setDepend (const std::string &depend)
void setLevel (const std::string &schema)
std::string getDepend ()
int getLevel ()
void setSchema (const std::string &schema)
std::string getSchema ()
void setProperty (const std::string &name, const std::string &value)
 Set a new value for a property of the port. More...
virtual bool addInPort (InPort *inPort)
OutputCalStreamPort * clone (Node *newHelder) const
virtual int removeInPort (InPort *inPort, bool forward)
- Public Member Functions inherited from YACS::ENGINE::OutputDataStreamPort
 OutputDataStreamPort (const OutputDataStreamPort &other, Node *newHelder)
 OutputDataStreamPort (const std::string &name, Node *node, TypeCode *type)
virtual ~OutputDataStreamPort ()
virtual OutputDataStreamPort * clone (Node *newHelder) const
virtual bool edAddInputDataStreamPort (InputDataStreamPort *port)
int edRemoveInputDataStreamPort (InputDataStreamPort *inPort, bool forward)
- Public Member Functions inherited from YACS::ENGINE::DataStreamPort
 Set the values of all properties of the port. More...
 Get the value of a property of the port. More...
std::map< std::string, std::string > getProperties () const
virtual void initPortProperties ()
 Initialize port properties at the start of calculation phase. More...
virtual ~DataStreamPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
Static Public Attributes
static const char NAME [] ="OutputCalStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::OutputDataStreamPort
static const char NAME [] ="OutputDataStreamPort"
- Static Public Attributes inherited from YACS::ENGINE::DataStreamPort
static const char NAME [] ="DataStreamPort"
std::string _depend
std::string _schema
int _level
double _delta
- Protected Attributes inherited from YACS::ENGINE::OutputDataStreamPort
std::set< InputDataStreamPort * > _setOfInputDataStreamPort
- Protected Attributes inherited from YACS::ENGINE::DataStreamPort
TypeCode * _type
Node * _node
int _id
- Protected Member Functions inherited from YACS::ENGINE::DataStreamPort
 DataStreamPort (const DataStreamPort &other, Node *newHelder)
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 82 of file CalStreamPort.hxx.
◆ OutputCalStreamPort() [1/2]
OutputCalStreamPort::OutputCalStreamPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 214 of file CalStreamPort.cxx.
214 :
215 OutputDataStreamPort(name, node, type),
216 DataPort(name, node, type),
217 Port(node),_depend("TIME_DEPENDENCY"),_schema("TI_SCHEM"),_level(-1)
218{
219}
Definition: DataPort.cxx:41
OutputDataStreamPort(const OutputDataStreamPort &other, Node *newHelder)
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ OutputCalStreamPort() [2/2]
OutputCalStreamPort::OutputCalStreamPort ( const OutputCalStreamPort &  other,
Node *  newHelder
Definition at line 221 of file CalStreamPort.cxx.
221 :
222 OutputDataStreamPort(other,newHelder),
223 DataPort(other,newHelder),
224 Port(other,newHelder),
225 _depend(other._depend),_schema(other._schema),_level(other._level)
226{
227}
◆ ~OutputCalStreamPort()
OutputCalStreamPort::~OutputCalStreamPort ( )
Definition at line 229 of file CalStreamPort.cxx.
230{
231}
◆ addInPort()
bool OutputCalStreamPort::addInPort ( InPort *  inPort)
Reimplemented from YACS::ENGINE::OutputDataStreamPort.
Definition at line 281 of file CalStreamPort.cxx.
282{
283 DEBTRACE("OutputCalStreamPort::addInPort " << InputCalStreamPort::NAME );
285 {
286 string what="not compatible type of port requested during building of link FROM ";
287 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
288 throw Exception(what);
289 }
290
291 InputCalStreamPort* port=static_cast<InputCalStreamPort*>(inPort);
292 if(port->getDepend() != _depend)
293 {
294 std::string what= "incompatible DependencyType properties: "+_depend+" != "+ port->getDepend();
295 throw Exception(what);
296 }
297 bool ret;
298 ret= edAddInputDataStreamPort(port);
299 return ret;
300}
Definition: DataPort.cxx:56
Class for Input Calcium DataStream Ports.
virtual bool edAddInputDataStreamPort(InputDataStreamPort *port)
References _depend, DEBTRACE, YACS::ENGINE::OutputDataStreamPort::edAddInputDataStreamPort(), YACS::ENGINE::InputCalStreamPort::getDepend(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InputCalStreamPort::NAME, and NAME.
◆ clone()
OutputCalStreamPort * OutputCalStreamPort::clone ( Node *  newHelder) const
Definition at line 276 of file CalStreamPort.cxx.
277{
278 return new OutputCalStreamPort(*this,newHelder);
279}
OutputCalStreamPort(const std::string &name, Node *node, TypeCode *type)
References OutputCalStreamPort().
◆ getDepend()
std::string YACS::ENGINE::OutputCalStreamPort::getDepend ( )
Definition at line 91 of file CalStreamPort.hxx.
91{return _depend;};
References _depend.
◆ getLevel()
int YACS::ENGINE::OutputCalStreamPort::getLevel ( )
Definition at line 92 of file CalStreamPort.hxx.
92{return _level;};
References _level.
std::string OutputCalStreamPort::getNameOfTypeOfCurrentInstance ( ) const
Definition at line 271 of file CalStreamPort.cxx.
272{
273 return NAME;
274}
References NAME.
◆ getSchema()
std::string YACS::ENGINE::OutputCalStreamPort::getSchema ( )
Definition at line 94 of file CalStreamPort.hxx.
94{return _schema;};
References _schema.
◆ removeInPort()
int OutputCalStreamPort::removeInPort ( InPort *  inPort,
bool  forward
Definition at line 303 of file CalStreamPort.cxx.
304{
305 DEBTRACE("OutputCalStreamPort::removeInPort");
307 {
308 string what="not compatible type of port requested during destruction of for link FROM ";
309 what+=NAME; what+=" TO "; what+=inPort->getNameOfTypeOfCurrentInstance();
310 throw Exception(what);
311 }
312 return edRemoveInputDataStreamPort(static_cast<InputDataStreamPort *>(inPort),forward);
313}
int edRemoveInputDataStreamPort(InputDataStreamPort *inPort, bool forward)
References DEBTRACE, YACS::ENGINE::OutputDataStreamPort::edRemoveInputDataStreamPort(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::InputCalStreamPort::NAME, and NAME.
◆ setDepend()
void OutputCalStreamPort::setDepend ( const std::string &  depend)
Definition at line 233 of file CalStreamPort.cxx.
234{
235 DEBTRACE("OutputCalStreamPort::setDepend: " << edGetNumberOfOutLinks());
236 if(edGetNumberOfOutLinks() > 0)
237 {
238 throw Exception("Can not modify DependencyType property on a connected port");
239 }
240 if(depend != "TIME_DEPENDENCY" && depend != "ITERATION_DEPENDENCY")
241 {
242 throw Exception("DependencyType property must be TIME_DEPENDENCY or ITERATION_DEPENDENCY");
243 }
244 _depend=depend;
245}
virtual int edGetNumberOfOutLinks() const
Definition: OutPort.cxx:50
References _depend, DEBTRACE, and YACS::ENGINE::OutPort::edGetNumberOfOutLinks().
Referenced by setProperty().
◆ setLevel()
void OutputCalStreamPort::setLevel ( const std::string &  schema)
Definition at line 255 of file CalStreamPort.cxx.
256{
257 _level =atoi(level.c_str());
258}
References _level.
◆ setProperty()
void OutputCalStreamPort::setProperty ( const std::string &  name,
const std::string &  value
name: the name property
value: the value property
Reimplemented from YACS::ENGINE::DataStreamPort.
Definition at line 260 of file CalStreamPort.cxx.
261{
262 if(name == "DependencyType")
263 setDepend(value);
264 else if(name == "DateCalSchem")
265 setSchema(value);
266 else if(name == "StorageLevel")
267 setLevel(value);
269}
virtual void setProperty(const std::string &name, const std::string &value)
void setSchema(const std::string &schema)
void setDepend(const std::string &depend)
void setLevel(const std::string &schema)
References setDepend(), setLevel(), YACS::ENGINE::DataStreamPort::setProperty(), and setSchema().
◆ setSchema()
void OutputCalStreamPort::setSchema ( const std::string &  schema)
Definition at line 247 of file CalStreamPort.cxx.
248{
249 if(schema != "TI_SCHEM" && schema != "TF_SCHEM" && schema != "ALPHA_SCHEM")
250 {
251 throw Exception("DateCalSchem property must be TI_SCHEM, TF_SCHEM or ALPHA_SCHEM");
252 }
253 _schema=schema;
254}
References _schema.
◆ _delta
double YACS::ENGINE::OutputCalStreamPort::_delta
Definition at line 104 of file CalStreamPort.hxx.
◆ _depend
std::string YACS::ENGINE::OutputCalStreamPort::_depend
Definition at line 101 of file CalStreamPort.hxx.
Referenced by addInPort(), getDepend(), and setDepend().
◆ _level
int YACS::ENGINE::OutputCalStreamPort::_level
Definition at line 103 of file CalStreamPort.hxx.
Referenced by getLevel(), and setLevel().
◆ _schema
std::string YACS::ENGINE::OutputCalStreamPort::_schema
Definition at line 102 of file CalStreamPort.hxx.
Referenced by getSchema(), and setSchema().
◆ NAME
const char OutputCalStreamPort::NAME ="OutputCalStreamPort"
Definition at line 85 of file CalStreamPort.hxx.
Referenced by addInPort(), getNameOfTypeOfCurrentInstance(), and removeInPort().
