YACS::ENGINE::OutPort Class Referenceabstract
#include <OutPort.hxx>
Inheritance diagram for YACS::ENGINE::OutPort:
Collaboration diagram for YACS::ENGINE::OutPort:
virtual ~OutPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 36 of file OutPort.hxx.
◆ OutPort() [1/2]
OutPort::OutPort ( const OutPort &  other,
Node *  newHelder
Definition at line 29 of file OutPort.cxx.
29 :DataPort(other,newHelder),Port(other,newHelder)
30{
31}
Definition: DataPort.cxx:41
Port(Node *node)
Definition: Port.cxx:34
◆ OutPort() [2/2]
OutPort::OutPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 33 of file OutPort.cxx.
33 :DataPort(name,node,type),Port(node)
34{
35}
◆ ~OutPort()
OutPort::~OutPort ( )
Definition at line 37 of file OutPort.cxx.
38{
39}
◆ addInPort()
◆ calculateHistoryOfLinkWith()
std::vector< DataPort * > OutPort::calculateHistoryOfLinkWith ( InPort *  end)
Definition at line 55 of file OutPort.cxx.
56{
57 if(!isAlreadyLinkedWith(end))
58 throw Exception("ComposedNode::edRemoveLink : unexisting link");
59 vector<DataPort *> ret;
61 list<ComposedNode *> allAscendanceOfNodeStart=getNode()->getAllAscendanceOf(lwstCmnAnctr);
62 list<ComposedNode *> allAscendanceOfNodeEnd=end->getNode()->getAllAscendanceOf(lwstCmnAnctr);
63
64 // --- Part of test if the link from 'start' to 'end' really exist particulary all eventually intermediate ports created
65
66 ComposedNode *iterS=getNode()->getFather();
67 pair<OutPort *,OutPort *> currentPortO(this,this);
68 ret.push_back(currentPortO.first);
69 while(iterS!=lwstCmnAnctr)
70 {
71 iterS->getDelegateOf(currentPortO, end, allAscendanceOfNodeEnd);
72 if(currentPortO.first!=ret.back())
73 ret.push_back(currentPortO.first);
74 iterS=iterS->_father;
75 }
76 iterS=end->getNode()->getFather();
77 InPort *currentPortI=end;
78 int i=0;
79 while(iterS!=lwstCmnAnctr)
80 {
81 vector<DataPort *>::iterator iter2;
82 iterS->getDelegateOf(currentPortI, this, allAscendanceOfNodeStart);
83 if(currentPortI!=ret.back())
84 {
85 i++;
86 ret.push_back(currentPortI);
87 }
88 iterS=iterS->_father;
89 }
90 vector<DataPort *>::iterator iter=ret.end(); iter-=i;
91 reverse(iter,ret.end());
92 return ret;
93}
virtual void getDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
static ComposedNode * getLowestCommonAncestor(Node *node1, Node *node2)
Retrieves the lowest common ancestor of 2 nodes.
ComposedNode * _father
Definition: Node.hxx:90
ComposedNode * getFather() const
Definition: Node.hxx:127
std::list< ComposedNode * > getAllAscendanceOf(ComposedNode *levelToStop=0) const
Definition: Node.cxx:317
virtual bool isAlreadyLinkedWith(InPort *withp) const =0
Node * getNode() const
Definition: Port.hxx:46
References YACS::ENGINE::Node::_father, YACS::ENGINE::Node::getAllAscendanceOf(), YACS::ENGINE::ComposedNode::getDelegateOf(), YACS::ENGINE::Node::getFather(), YACS::ENGINE::ComposedNode::getLowestCommonAncestor(), YACS::ENGINE::Port::getNode(), yacsorb.CORBAEngineTest::i, and isAlreadyLinkedWith().
◆ checkConsistency()
void OutPort::checkConsistency ( LinkInfo &  info) const
Reimplemented in YACS::ENGINE::CollectorSwOutPort.
Definition at line 41 of file OutPort.cxx.
42{
43}
◆ edGetNumberOfOutLinks()
int OutPort::edGetNumberOfOutLinks ( ) const
◆ edSetInPort()
virtual std::set< InPort * > YACS::ENGINE::OutPort::edSetInPort ( ) const
pure virtual
◆ getAllRepresented()
void OutPort::getAllRepresented ( std::set< OutPort * > &  represented) const
◆ isAlreadyLinkedWith()
◆ removeInPort()
◆ typeName()
virtual std::string YACS::ENGINE::OutPort::typeName ( )
