YACS::ENGINE::OutputPort4DS2DF Class Reference
#include <Loop.hxx>
Inheritance diagram for YACS::ENGINE::OutputPort4DS2DF:
Collaboration diagram for YACS::ENGINE::OutputPort4DS2DF:
 OutputPort4DS2DF (DSToDFForLoop *node, TypeCode *type)
void getAllRepresented (std::set< OutPort * > &represented) const
void put (const void *data)
OutputPort * clone (Node *newHelder) const
void put (Any *data)
 ~OutputPort4DS2DF ()
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual std::string dump ()
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
Any * _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
Definition at line 79 of file Loop.hxx.
◆ OutputPort4DS2DF()
OutputPort4DS2DF::OutputPort4DS2DF ( DSToDFForLoop *  node,
TypeCode *  type
Definition at line 156 of file Loop.cxx.
156 :
157 OutputPort("", node, type),
158 DataPort("", node, type),
159 Port(node),_data(0)
160{
161}
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
◆ ~OutputPort4DS2DF()
OutputPort4DS2DF::~OutputPort4DS2DF ( )
Definition at line 189 of file Loop.cxx.
190{
191 if(_data)
192 _data->decrRef();
193}
References _data, and YACS::ENGINE::RefCounter::decrRef().
◆ clone()
OutputPort * OutputPort4DS2DF::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 176 of file Loop.cxx.
177{
178 throw Exception("OutputPort4DS2DF::clone : Internal error");
179}
◆ getAllRepresented()
void OutputPort4DS2DF::getAllRepresented ( std::set< OutPort * > &  represented) const
Reimplemented from YACS::ENGINE::OutPort.
Definition at line 163 of file Loop.cxx.
164{
165 set<OutPort *> setO=_node->getInputDataStreamPort("")->edSetOutPort();
166 for(set<OutPort *>::iterator iter=setO.begin();iter!=setO.end();iter++)
167 (*iter)->getAllRepresented(represented);
168}
virtual std::set< OutPort * > edSetOutPort() const
Returns physical backlinks NOT user backlinks.
Definition: InPort.cxx:65
virtual InputDataStreamPort * getInputDataStreamPort(const std::string &name) const =0
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, YACS::ENGINE::InPort::edSetOutPort(), and YACS::ENGINE::Node::getInputDataStreamPort().
◆ put() [1/2]
void OutputPort4DS2DF::put ( Any *  data)
Definition at line 181 of file Loop.cxx.
182{
183 if(_data)
184 _data->decrRef();
185 _data=data;
186 _data->incrRef();
187}
References _data, YACS::ENGINE::RefCounter::decrRef(), and YACS::ENGINE::RefCounter::incrRef().
◆ put() [2/2]
void OutputPort4DS2DF::put ( const void *  data)
Reimplemented from YACS::ENGINE::OutputPort.
Definition at line 170 of file Loop.cxx.
171{
172 put((Any *)data);
173 OutputPort::put(data);
174}
Definition: Any.hxx:79
void put(const void *data)
Definition: Loop.cxx:170
Definition: OutputPort.cxx:66
References put(), and YACS::ENGINE::OutputPort::put().
Referenced by put().
◆ _data
Any* YACS::ENGINE::OutputPort4DS2DF::_data
Definition at line 89 of file Loop.hxx.
Referenced by put(), and ~OutputPort4DS2DF().
