YACS::ENGINE::InPropertyPort Class Reference
class for Input Property Ports More...
#include <InPropertyPort.hxx>
Inheritance diagram for YACS::ENGINE::InPropertyPort:
Collaboration diagram for YACS::ENGINE::InPropertyPort:
virtual ~InPropertyPort ()
virtual InPropertyPort * getPublicRepresentant ()
virtual void exNewPropertyValue (const std::string &name, const std::string &value)
virtual void exSaveInit ()
virtual void exRestoreInit ()
virtual InPropertyPort * clone (Node *newHelder) const
virtual void * get () const
virtual void put (YACS::ENGINE::Any *data)
void releaseData () override
virtual ~InputPort ()
bool edIsInitialized () const
 soon deprecated More...
template<class T >
void edInit (T value)
void edInit (Any *value)
virtual void exSaveInit ()=0
virtual bool isEmpty ()
virtual void releaseData ()=0
virtual std::string dump ()
bool canBeNull () const
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
bool isBackLinked () const
virtual ~InPort ()
Static Public Attributes
static const char NAME [] ="InPropertyPort"
 InPropertyPort (const InPropertyPort &other, Node *newHelder)
 InPropertyPort (const std::string &name, Node *node, TypeCode *type, bool canBeNull=false)
void releaseDataUnsafe ()
virtual ~DataPort ()
 Port (Node *node)
YACS::ENGINE::Any * _property_data
YACS::ENGINE::Any * _init_property_data
Any * _initValue
std::string _stringRef
bool _canBeNull
TypeCode * _type
Node * _node
int _id
Friends
class Runtime
class OutPort
class Node
static int _total = 0
Definition at line 37 of file InPropertyPort.hxx.
◆ ~InPropertyPort()
InPropertyPort::~InPropertyPort ( )
Definition at line 47 of file InPropertyPort.cxx.
47{}
◆ InPropertyPort() [1/2]
InPropertyPort::InPropertyPort ( const InPropertyPort &  other,
Node *  newHelder
Definition at line 32 of file InPropertyPort.cxx.
33 : InputPort(other, newHelder),
34 DataPort(other, newHelder),
35 Port(other, newHelder),
37{}
Definition: DataPort.cxx:41
InputPort(const InputPort &other, Node *newHelder)
Definition: InputPort.cxx:36
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ InPropertyPort() [2/2]
InPropertyPort::InPropertyPort ( const std::string &  name,
Node *  node,
TypeCode *  type,
bool  canBeNull = false
Definition at line 39 of file InPropertyPort.cxx.
40 : InputPort(name, node, type, canBeNull),
41 DataPort(name, node, type),
42 Port(node),
44{
45}
bool canBeNull() const
Definition: InputPort.cxx:174
◆ clone()
InPropertyPort * InPropertyPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::InputPort.
Definition at line 75 of file InPropertyPort.cxx.
76{
77 return new InPropertyPort(*this,newHelder);
78}
InPropertyPort(const InPropertyPort &other, Node *newHelder)
References InPropertyPort().
◆ exNewPropertyValue()
void InPropertyPort::exNewPropertyValue ( const std::string &  name,
const std::string &  value
Definition at line 55 of file InPropertyPort.cxx.
56{
57 DEBTRACE("Adding new Property to the node " << name << " " << value);
58 _node->setProperty(name, value);
59}
virtual void setProperty(const std::string &name, const std::string &value)
Definition: Node.cxx:491
Node * _node
Definition: Port.hxx:55
References YACS::ENGINE::Port::_node, DEBTRACE, and YACS::ENGINE::Node::setProperty().
Referenced by put().
◆ exRestoreInit()
void InPropertyPort::exRestoreInit ( )
Definition at line 68 of file InPropertyPort.cxx.
References _init_property_data, and _property_data.
◆ exSaveInit()
void InPropertyPort::exSaveInit ( )
Definition at line 62 of file InPropertyPort.cxx.
◆ get()
void * InPropertyPort::get ( ) const
Definition at line 81 of file InPropertyPort.cxx.
82{
83 return (void*) _property_data;
84}
References _property_data.
string InPropertyPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 49 of file InPropertyPort.cxx.
50{
51 return NAME;
52}
References NAME.
◆ getPublicRepresentant()
virtual InPropertyPort * YACS::ENGINE::InPropertyPort::getPublicRepresentant ( )
returns the final physical port behind 'this'.
Reimplemented from YACS::ENGINE::InputPort.
Definition at line 53 of file InPropertyPort.hxx.
53{ return this; }
◆ put() [1/2]
void InPropertyPort::put ( const void *  data)
Definition at line 87 of file InPropertyPort.cxx.
88{
89 put((YACS::ENGINE::Any *)data);
90}
Definition: Any.hxx:79
References put().
◆ put() [2/2]
void InPropertyPort::put ( YACS::ENGINE::Any *  data)
Definition at line 100 of file InPropertyPort.cxx.
101{
102 // Add new properties to the node
103 YACS::ENGINE::SequenceAny * seq_data = static_cast<YACS::ENGINE::SequenceAny*>(data);
104 for (int i = 0; i < seq_data->size(); i++)
105 {
106 std::string key = ((*seq_data)[i]["name"])->getStringValue();
107 std::string value = ((*seq_data)[i]["value"])->getStringValue();
108 exNewPropertyValue(key, value);
109 }
111 _property_data = data;
113 DEBTRACE("value ref count: " << _property_data->getRefCnt());
114}
virtual void exNewPropertyValue(const std::string &name, const std::string &value)
unsigned int getRefCnt() const
Definition: RefCounter.hxx:32
unsigned int size() const
Definition: Any.hxx:209
References _property_data, DEBTRACE, exNewPropertyValue(), YACS::ENGINE::RefCounter::getRefCnt(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::RefCounter::incrRef(), releaseData(), and YACS::ENGINE::SequenceAny::size().
◆ releaseData()
void InPropertyPort::releaseData ( )
overridevirtual
Definition at line 92 of file InPropertyPort.cxx.
93{
96 _property_data = nullptr;
97}
References _property_data, and YACS::ENGINE::RefCounter::decrRef().
◆ typeName()
virtual std::string YACS::ENGINE::InPropertyPort::typeName ( )
Definition at line 55 of file InPropertyPort.hxx.
55{return "YACS__ENGINE__InPropertyPort";}
◆ Node
friend class Node
friend
Definition at line 41 of file InPropertyPort.hxx.
◆ OutPort
friend class OutPort
friend
Definition at line 40 of file InPropertyPort.hxx.
◆ Runtime
friend class Runtime
friend
Definition at line 39 of file InPropertyPort.hxx.
◆ _init_property_data
YACS::ENGINE::Any* YACS::ENGINE::InPropertyPort::_init_property_data
Definition at line 70 of file InPropertyPort.hxx.
Referenced by exRestoreInit(), and exSaveInit().
◆ _property_data
YACS::ENGINE::Any* YACS::ENGINE::InPropertyPort::_property_data
Definition at line 69 of file InPropertyPort.hxx.
Referenced by exRestoreInit(), exSaveInit(), get(), put(), and releaseData().
◆ NAME
const char InPropertyPort::NAME ="InPropertyPort"
