YACS::ENGINE::DataFlowPort Class Reference
#include <DataFlowPort.hxx>
Inheritance diagram for YACS::ENGINE::DataFlowPort:
Collaboration diagram for YACS::ENGINE::DataFlowPort:
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
Static Public Attributes
virtual ~DataPort ()
 Port (Node *node)
TypeCode * _type
Node * _node
int _id
static int _total = 0
Definition at line 32 of file DataFlowPort.hxx.
◆ DataFlowPort() [1/2]
DataFlowPort::DataFlowPort ( const DataFlowPort &  other,
Node *  newHelder
Definition at line 27 of file DataFlowPort.cxx.
27 :DataPort(other,newHelder),Port(other,newHelder)
28{
29}
Definition: DataPort.cxx:41
Port(Node *node)
Definition: Port.cxx:34
◆ DataFlowPort() [2/2]
DataFlowPort::DataFlowPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 31 of file DataFlowPort.cxx.
31 :DataPort(name,node,type),Port(node)
32{
33}
◆ ~DataFlowPort()
DataFlowPort::~DataFlowPort ( )
Definition at line 35 of file DataFlowPort.cxx.
36{
37}
string DataFlowPort::getNameOfTypeOfCurrentInstance ( ) const
Reimplemented from YACS::ENGINE::Port.
Reimplemented in YACS::ENGINE::InPropertyPort, YACS::ENGINE::InputPort, and YACS::ENGINE::OutputPort.
Definition at line 39 of file DataFlowPort.cxx.
40{
41 return NAME;
42}
static const char NAME[]
References NAME.
◆ getTypeOfChannel()
TypeOfChannel YACS::ENGINE::DataFlowPort::getTypeOfChannel ( ) const
returns type of channel the port will use for data exchange on runtime : DATAFLOW or DATASTREAM.
Implements YACS::ENGINE::DataPort.
Definition at line 41 of file DataFlowPort.hxx.
41{ return DATAFLOW; }
References YACS::ENGINE::DATAFLOW.
◆ typeName()
◆ valFromStr()
void DataFlowPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented in YACS::ENGINE::InputCorbaPort, YACS::ENGINE::OutputCorbaPort, YACS::ENGINE::InputPyPort, YACS::ENGINE::OutputPyPort, YACS::ENGINE::InputXmlPort, and YACS::ENGINE::OutputXmlPort.
Definition at line 61 of file DataFlowPort.cxx.
62{
63}
◆ valToStr()
std::string DataFlowPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 50 of file DataFlowPort.cxx.
51{
52 return "no display conversion available";
53}
◆ NAME
const char DataFlowPort::NAME ="DataFlowPort"
Definition at line 35 of file DataFlowPort.hxx.
Referenced by getNameOfTypeOfCurrentInstance().
