YACS::ENGINE::OutputXmlPort Class Reference
Class for XML Output Ports. More...
#include <XMLPorts.hxx>
Inheritance diagram for YACS::ENGINE::OutputXmlPort:
Collaboration diagram for YACS::ENGINE::OutputXmlPort:
 OutputXmlPort (const std::string &name, Node *node, TypeCode *type)
 OutputXmlPort (const OutputXmlPort &other, Node *newHelder)
void put (const char *data)
virtual const char * get () const
OutputPort * clone (Node *newHelder) const
virtual std::string dump ()
- Public Member Functions inherited from YACS::ENGINE::OutputPort
virtual ~OutputPort ()
bool isAlreadyInSet (InputPort *inputPort) const
bool isConnected () const
int removeInPort (InPort *inPort, bool forward)
virtual bool edAddInputPort (InputPort *phyPort)
virtual bool edAddInPropertyPort (InPropertyPort *phyPort)
virtual int edRemoveInputPort (InputPort *inputPort, bool forward)
bool addInPort (InPort *inPort)
virtual void exInit ()
 Check validity of output port. Nothing on base class. More...
virtual OutputPort * clone (Node *newHelder) const =0
virtual ~DataFlowPort ()
TypeCode * edGetType () const
std::string getName () const
virtual ~Port ()
Node * getNode () const
int getNumId () const
void modified ()
virtual ~OutPort ()
std::string _data
- Protected Attributes inherited from YACS::ENGINE::OutputPort
std::set< InputPort * > _setOfInputPort
TypeCode * _type
Node * _node
int _id
- Static Public Attributes inherited from YACS::ENGINE::OutputPort
static const char NAME [] ="OutputPort"
- Protected Member Functions inherited from YACS::ENGINE::OutputPort
 OutputPort (const OutputPort &other, Node *newHelder)
 OutputPort (const std::string &name, Node *node, TypeCode *type)
const std::set< InputPort * > & getSetOfPhyLinks () const
 Returns physical links linked to this. Contrary to edSetInPort that returns semantic links. More...
virtual ~DataPort ()
 Port (Node *node)
static int _total = 0
See also
XmlNode
Definition at line 67 of file XMLPorts.hxx.
◆ OutputXmlPort() [1/2]
OutputXmlPort::OutputXmlPort ( const std::string &  name,
Node *  node,
TypeCode *  type
Definition at line 122 of file XMLPorts.cxx.
123 : OutputPort(name, node, type), DataPort(name, node, type), Port(node)
124{
125}
Definition: DataPort.cxx:41
OutputPort(const OutputPort &other, Node *newHelder)
Definition: OutputPort.cxx:38
Port(Node *node)
Definition: Port.cxx:34
Referenced by clone().
◆ OutputXmlPort() [2/2]
OutputXmlPort::OutputXmlPort ( const OutputXmlPort &  other,
Node *  newHelder
Definition at line 127 of file XMLPorts.cxx.
127 :OutputPort(other,newHelder),DataPort(other,newHelder),
128 Port(other,newHelder),_data(other._data)
129{
130}
◆ clone()
OutputPort * OutputXmlPort::clone ( Node *  newHelder) const
Implements YACS::ENGINE::OutputPort.
Definition at line 150 of file XMLPorts.cxx.
151{
152 return new OutputXmlPort(*this,newHelder);
153}
OutputXmlPort(const std::string &name, Node *node, TypeCode *type)
Definition: XMLPorts.cxx:122
References OutputXmlPort().
◆ dump()
std::string OutputXmlPort::dump ( )
Reimplemented from YACS::ENGINE::OutputPort.
Reimplemented in YACS::ENGINE::OutputPresetPort, and YACS::ENGINE::OutputStudyPort.
Definition at line 155 of file XMLPorts.cxx.
156{
157 return _data;
158}
References _data.
◆ get()
const char * OutputXmlPort::get ( ) const
Definition at line 132 of file XMLPorts.cxx.
133{
134 return _data.c_str();
135}
References _data.
◆ put() [1/2]
void OutputXmlPort::put ( const char *  data)
Definition at line 142 of file XMLPorts.cxx.
143{
144 DEBTRACE(data);
145 InputPort *p;
146 _data=data;
147 OutputPort::put(data);
148}
Base class for Input Ports.
Definition: InputPort.hxx:44
Definition: OutputPort.cxx:66
Proc * p
Definition: driver.cxx:216
References _data, DEBTRACE, p, and YACS::ENGINE::OutputPort::put().
◆ put() [2/2]
void OutputXmlPort::put ( const void *  data)
Definition at line 137 of file XMLPorts.cxx.
138{
139 put((const char*)data);
140}
Definition: XMLPorts.cxx:137
References put().
Referenced by YACS::ENGINE::PresetNode::execute(), YACS::ENGINE::OutputStudyPort::getDataFromStudy(), put(), and YACS::ENGINE::OutputStudyPort::putIOR().
◆ valFromStr()
void OutputXmlPort::valFromStr ( std::string  valstr)
Allows to set data from a string representation used in user interface.
Implemented in derived classes, depending on runtime, to set the data from its user interface representation. Typical use, a Python string representation that can be used in edition or restitution.
Reimplemented from YACS::ENGINE::DataFlowPort.
Definition at line 165 of file XMLPorts.cxx.
166{
167 _data = valstr;
168}
References _data.
◆ valToStr()
std::string OutputXmlPort::valToStr ( )
Gives a string representation of the data, for user interfaces.
Implemented in derived classes, depending on runtime, to provide the data representation for user interfaces. Typical use, a Python string representation that can be used in edition or restitution.
Definition at line 160 of file XMLPorts.cxx.
161{
162 return _data;
163}
References _data.
◆ _data
std::string YACS::ENGINE::OutputXmlPort::_data
Definition at line 80 of file XMLPorts.hxx.
Referenced by YACS::ENGINE::OutputStudyPort::dump(), dump(), get(), put(), valFromStr(), and valToStr().
