StudyPorts.cxx
20#include "StudyPorts.hxx"
21#include "TypeCode.hxx"
22#include "Node.hxx"
23#include "Proc.hxx"
24#include "ComponentInstance.hxx"
25#include "SalomeComponent.hxx"
26#include "RuntimeSALOME.hxx"
27
28#include "SALOMEDS_Attributes.hh"
29#include "SALOME_KernelServices.hxx"
30
31#include <iostream>
32#include <iomanip>
33#include <cstdlib>
34
35//#define _DEVDEBUG_
36#include "YacsTrace.hxx"
37
38
39namespace YACS
40{
41namespace ENGINE
42{
43
52OutputStudyPort::OutputStudyPort(const std::string& name, Node* node, TypeCode* type)
53 : OutputXmlPort(name, node, type),
54 DataPort(name, node, type),
55 Port(node)
56{
57}
58
60 : OutputXmlPort(other,newHelder),
61 DataPort(other,newHelder),
62 Port(other,newHelder),_storeData(other._storeData)
63{
64}
65
67{
68 return new OutputStudyPort(*this,newHelder);
69}
70
71void OutputStudyPort::setData(const std::string& data)
72{
73 _storeData = data;
74 DEBTRACE( "OutputStudyPort::setData " << _storeData );
75 modified();
76}
77
79{
80 DEBTRACE("OutputStudyPort::getData " << _storeData);
81 return _storeData;
82}
83
84void OutputStudyPort::putIOR(const std::string& ior)
85{
86 DEBTRACE("OutputStudyPort::putIOR " << ior);
87 if(ior.substr(0,7) == "<value>")
88 {
89 put(ior.c_str());
90 }
91 else
92 {
93 int tk=edGetType()->kind();
94 std::string value;
95 switch(tk)
96 {
97 case Double:
98 value="<value><double>"+ior+"</double></value>";
99 break;
100 case Int:
101 value="<value><int>"+ior+"</int></value>";
102 break;
103 case String:
104 value="<value><string>"+ior+"</string></value>";
105 break;
106 case Bool:
107 value="<value><boolean>"+ior+"</boolean></value>";
108 break;
109 case Objref:
110 value="<value><objref>"+ior+"</objref></value>";
111 break;
112 case Sequence:
113 case Array:
114 case Struct:
115 default:
116 break;
117 }
118 put(value.c_str());
119 }
120}
121
123{
124 DEBTRACE( "OutputStudyPort::dump " << _storeData );
125 DEBTRACE( "OutputStudyPort::dump " << _data );
126 //return "<value><string>"+_storeData+"</string></value>";
127 return _data;
128}
129
131{
132 return getData();
133}
135{
136 return getData();
137}
138
140{
141 std::string data = getData();
142 DEBTRACE("data: " << data );
143 //try an id
144 SALOMEDS::SObject_var aSO = KERNEL::getStudyServant()->FindObjectID(data.c_str());
145 if(CORBA::is_nil(aSO))
146 {
147 //try a path
148 aSO=KERNEL::getStudyServant()->FindObjectByPath(data.c_str());
149 if(CORBA::is_nil(aSO))
150 {
151 std::stringstream msg;
152 msg << "Execution problem: no id or path: " << data << " in study";
153 throw Exception(msg.str());
154 }
155 }
156
157 CORBA::String_var path=KERNEL::getStudyServant()->GetObjectPath(aSO);
158 DEBTRACE(path);
159 CORBA::String_var id=aSO->GetID();
160 DEBTRACE(id);
161 //CORBA::Object_var sobj=aSO->GetObject();
162
163 SALOMEDS::GenericAttribute_var aGAttr;
164 CORBA::String_var value;
165
166 if(edGetType()->kind()==Objref)
167 {
168 if ( aSO->FindAttribute( aGAttr, "AttributeIOR" ) )
169 {
170 SALOMEDS::AttributeIOR_var anAttr = SALOMEDS::AttributeIOR::_narrow( aGAttr );
171 value=anAttr->Value();
172 putIOR((const char*)value);
173 }
174 else
175 {
176 //Problem !!!
177 std::string error="Execution problem: no AttributeIOR in study object: ";
178 error=error+data;
179 throw Exception(error);
180 }
181 }
182 else if(edGetType()->kind()==Double )
183 {
184 if ( aSO->FindAttribute( aGAttr, "AttributeReal" ) )
185 {
186 SALOMEDS::AttributeReal_var anAttr = SALOMEDS::AttributeReal::_narrow( aGAttr );
187 CORBA::Double d=anAttr->Value();
188 std::stringstream msg;
189 msg << "<value><double>" << std::setprecision(16) << d << "</double></value>";
190 put(msg.str().c_str());
191 }
192 else
193 {
194 std::string error="Execution problem: no AttributeReal in study object: ";
195 throw Exception(error+data);
196 }
197 }
198 else if(edGetType()->kind()== Int)
199 {
200 if ( aSO->FindAttribute( aGAttr, "AttributeInteger" ) )
201 {
202 SALOMEDS::AttributeInteger_var anAttr = SALOMEDS::AttributeInteger::_narrow( aGAttr );
203 CORBA::Long l=anAttr->Value();
204 std::stringstream msg;
205 msg << "<value><int>" << l << "</int></value>";
206 put(msg.str().c_str());
207 }
208 else
209 {
210 std::string error="Execution problem: no AttributeInteger in study object: ";
211 throw Exception(error+data);
212 }
213 }
214 else
215 {
216 if ( aSO->FindAttribute( aGAttr, "AttributeComment" ) )
217 {
218 SALOMEDS::AttributeComment_var anAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
219 value=anAttr->Value();
220 DEBTRACE(value);
221 putIOR((const char*)value);
222 }
223 else
224 {
225 std::string error="Execution problem: no AttributeComment in study object: ";
226 throw Exception(error+data);
227 }
228 }
229}
230
231
232
233
234SALOMEDS::SObject_ptr findOrCreateSoWithName(SALOMEDS::StudyBuilder_ptr builder,
235 SALOMEDS::SObject_ptr sobj, const std::string& name)
236{
237 SALOMEDS::ChildIterator_var anIterator= KERNEL::getStudyServant()->NewChildIterator(sobj);
238 SALOMEDS::GenericAttribute_var anAttr;
239 SALOMEDS::AttributeName_var namAttr ;
240 SALOMEDS::SObject_var result=SALOMEDS::SObject::_nil();
241
242 for (; anIterator->More(); anIterator->Next())
243 {
244 SALOMEDS::SObject_var anObj=anIterator->Value();
245 if(anObj->FindAttribute(anAttr, "AttributeName"))
246 {
247 namAttr = SALOMEDS::AttributeName::_narrow( anAttr );
248 CORBA::String_var value=namAttr->Value();
249 if(name == (const char*)value)
250 {
251 result=anObj;
252 break;
253 }
254 }
255 }
256 if(CORBA::is_nil(result))
257 {
258 //create it
259 result = builder->NewObject( sobj );
260 anAttr=builder->FindOrCreateAttribute(result,"AttributeName");
261 namAttr = SALOMEDS::AttributeName::_narrow( anAttr );
262 namAttr->SetValue(name.c_str());
263 }
264 return result._retn();
265}
266
275InputStudyPort::InputStudyPort(const std::string& name, Node* node, TypeCode* type)
276 : InputXmlPort(name, node, type),
277 DataPort(name, node, type),
278 Port(node)
279{
280}
281
283 : InputXmlPort(other,newHelder),
284 DataPort(other,newHelder),
285 Port(other,newHelder),_storeData(other._storeData)
286{
287}
288
290{
291 return new InputStudyPort(*this,newHelder);
292}
293
294void InputStudyPort::setData(const std::string& data)
295{
296 _storeData = data;
297 DEBTRACE( "InputStudyPort::setData " << _storeData );
298 modified();
299}
300
302{
303 DEBTRACE("InputStudyPort::getData " << _storeData);
304 return _storeData;
305}
306
308{
309 switch(edGetType()->kind())
310 {
311 case Objref:
312 return splitXML(_data);
313 default:
314 return _data;
315 }
316}
317
318std::string InputStudyPort::splitXML(const std::string& s)
319{
320 // <value><tag>content</tag></value>
321 std::string::size_type begin = s.find_first_of("<"); // <value>
322 begin = s.find_first_of(">",begin); // end of <value>
323 begin = s.find_first_of("<",begin); // beginning of <tag>
324 begin = s.find_first_of(">",begin); // end of <tag>
325 begin = s.find_first_not_of("> ",begin); // beginning of content
326 std::string::size_type last = s.find_first_of("<",begin); // beginning of </tag>
327 return s.substr(begin,last-begin);
328}
329
331{
332 DEBTRACE( "InputStudyPort::dump " << _storeData );
333 DEBTRACE( "InputStudyPort::dump " << _data );
334 //return "<value><string>"+_storeData+"</string></value>";
335 return _data;
336}
338{
339 return getData();
340}
342{
343 return getData();
344}
345
346void InputStudyPort::putDataInStudy(SALOMEDS::StudyBuilder_var aBuilder)
347{
348 SALOMEDS::GenericAttribute_var aGAttr;
349 SALOMEDS::SObject_var aSO ;
350 SALOMEDS::AttributeName_var anAttr ;
351 SALOMEDS::AttributeIOR_var iorAttr ;
352 SALOMEDS::SComponent_var aFather;
353
354 std::string data = getData();
355 DEBTRACE("data: " << data );
356 //try to find an existing id (i:j:k...)
357 aSO = KERNEL::getStudyServant()->FindObjectID(data.c_str());
358 if(CORBA::is_nil(aSO))
359 {
360 // the id does not exist. Try to create it by id
361 aSO=KERNEL::getStudyServant()->CreateObjectID(data.c_str());
362 if(!CORBA::is_nil(aSO))
363 {
364 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeName");
365 anAttr = SALOMEDS::AttributeName::_narrow( aGAttr );
366 anAttr->SetValue(getName().c_str());
367 }
368 }
369
370 if(CORBA::is_nil(aSO))
371 {
372 //try to publish the object with a given path
373 std::string name; // the component instance name
374 std::string objname; // the object name (eventually with "/")
375 std::string::size_type begin = data.find_first_not_of("/");
376 std::string::size_type pos=data.find_first_of("/", begin);
377 if (pos != std::string::npos)
378 {
379 name=data.substr(begin,pos-begin);
380 objname=data.substr(pos+1);
381 }
382 else
383 {
384 name=data.substr(begin);
385 objname="";
386 }
387 std::string pname="/"+name;
388 DEBTRACE(pname);
389 DEBTRACE(objname);
390
391 Proc* proc=getNode()->getProc();
392 if(proc->componentInstanceMap.count(name)!=0)
393 {
394 // There is a component instance with this name. Is it a Salome component or not ?
395 ComponentInstance* compo=proc->componentInstanceMap[name];
396 if(SalomeComponent* scompo=dynamic_cast<SalomeComponent*>(compo))
397 {
398 //It's a Salome component, make it the right way : component name, component instance reference, ...
399 CORBA::Object_var compovar= scompo->getCompoPtr();
400 SALOMEDS::Driver_var aDriver = SALOMEDS::Driver::_narrow(compovar);
401 if ( !CORBA::is_nil( aDriver ) )
402 {
403 //It's a Salome component that implements the Driver interface. Use it to publish in study
404 CORBA::ORB_ptr orb;
405 CORBA::Object_var anObject;
406 try
407 {
409 anObject=orb->string_to_object(getIOR().c_str());
410 }
411 catch ( ... )
412 {
413 std::cerr << "Execution problem: can not get the object to publish" << std::endl;
414 return;
415 }
416 if ( aDriver->CanPublishInStudy( anObject ) )
417 {
418 //It's fine use the driver to publish
419 SALOMEDS::SObject_var aTmpSO; // initialized to nil
420 try
421 {
422 aTmpSO = aDriver->PublishInStudy(aTmpSO, anObject,objname.c_str() );
423 return;
424 }
425 catch ( ... )
426 {
427 std::cerr << "Execution problem: error in PublishInStudy" << std::endl;
428 return;
429 }
430 }
431 }
432 }
433 }
434
435 // Does component entry exist ?
436 aSO=KERNEL::getStudyServant()->FindObjectByPath(pname.c_str());
437 if(CORBA::is_nil(aSO))
438 {
439 // We have not been able to publish the object with Salome Driver, make it the light way
440 aFather=aBuilder->NewComponent(name.c_str());
441 if(CORBA::is_nil(aFather))
442 {
443 std::cerr << "Execution problem: can not create component: " + name << std::endl;
444 return;
445 }
446 aGAttr=aBuilder->FindOrCreateAttribute(aFather,"AttributeName");
447 anAttr = SALOMEDS::AttributeName::_narrow( aGAttr );
448 anAttr->SetValue(name.c_str());
449 aSO=KERNEL::getStudyServant()->FindObjectByPath(pname.c_str());
450 }
451
452 begin=data.find_first_not_of("/",pos);
453 while (begin != std::string::npos)
454 {
455 pos = data.find_first_of("/", begin);
456 if (pos != std::string::npos)
457 name=data.substr(begin,pos-begin);
458 else
459 name=data.substr(begin);
460 aSO=findOrCreateSoWithName(aBuilder,aSO,name);
461 begin=data.find_first_not_of("/",pos);
462 }
463 }
464
465 if(CORBA::is_nil(aSO))
466 {
467 std::cerr << "Execution problem: can not create id or path: " + data + " in study" << std::endl;
468 return;
469 }
470
471 std::string value;
472 SALOMEDS::AttributeComment_var commentAttr ;
473 SALOMEDS::AttributeReal_var realAttr ;
474 SALOMEDS::AttributeInteger_var intAttr ;
475 SALOMEDS::AttributeString_var stringAttr ;
476 double d;
477 long v;
478 switch(edGetType()->kind())
479 {
480 case Objref:
481 value=getIOR();
482 DEBTRACE(value);
483 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeIOR");
484 iorAttr = SALOMEDS::AttributeIOR::_narrow( aGAttr );
485 iorAttr->SetValue(value.c_str());
486 break;
487 case Double:
488 value=splitXML(dump());
489 DEBTRACE(value);
490 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeReal");
491 realAttr = SALOMEDS::AttributeReal::_narrow( aGAttr );
492 d=atof(value.c_str());
493 realAttr->SetValue(d);
494 break;
495 case Int:
496 value=splitXML(dump());
497 DEBTRACE(value);
498 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeInteger");
499 intAttr = SALOMEDS::AttributeInteger::_narrow( aGAttr );
500 v=atol(value.c_str());
501 intAttr->SetValue(v);
502 break;
503 case String:
504 case Bool:
505 value=splitXML(dump());
506 DEBTRACE(value);
507 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeComment");
508 commentAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
509 commentAttr->SetValue(value.c_str());
510 break;
511 default:
512 value=dump();
513 DEBTRACE(value);
514 aGAttr=aBuilder->FindOrCreateAttribute(aSO,"AttributeComment");
515 commentAttr = SALOMEDS::AttributeComment::_narrow( aGAttr );
516 commentAttr->SetValue(value.c_str());
517 }
518}
519
520} //end namespace ENGINE
521} //end namespace YACS
TypeCode * edGetType() const
Definition: DataPort.hxx:53
std::string getName() const
Definition: DataPort.hxx:55
Base class for Input Ports.
Definition: InputPort.hxx:44
Class for Study input Ports.
Definition: StudyPorts.hxx:51
virtual std::string getPyObj()
Definition: StudyPorts.cxx:337
virtual void putDataInStudy(SALOMEDS::StudyBuilder_var aBuilder)
Definition: StudyPorts.cxx:346
InputStudyPort(const std::string &name, Node *node, TypeCode *type)
Definition: StudyPorts.cxx:275
virtual std::string dump()
Definition: StudyPorts.cxx:330
virtual std::string getIOR()
Definition: StudyPorts.cxx:307
InputPort * clone(Node *newHelder) const
Definition: StudyPorts.cxx:289
Definition: StudyPorts.cxx:341
void setData(const std::string &data)
Definition: StudyPorts.cxx:294
virtual std::string splitXML(const std::string &s)
Definition: StudyPorts.cxx:318
Class for XML Input Ports.
Definition: XMLPorts.hxx:38
Base class for all nodes.
Definition: Node.hxx:70
virtual Proc * getProc()
Definition: Node.cxx:401
Class for Study output Ports.
Definition: StudyPorts.hxx:33
OutputStudyPort(const std::string &name, Node *node, TypeCode *type)
Definition: StudyPorts.cxx:52
Definition: StudyPorts.cxx:71
Definition: StudyPorts.cxx:130
Definition: StudyPorts.cxx:134
OutputPort * clone(Node *newHelder) const
Definition: StudyPorts.cxx:66
virtual void putIOR(const std::string &ior)
Definition: StudyPorts.cxx:84
Definition: StudyPorts.cxx:122
Class for XML Output Ports.
Definition: XMLPorts.hxx:68
Definition: XMLPorts.cxx:137
Base class for all ports.
Definition: Port.hxx:43
void modified()
Definition: Port.cxx:53
Node * getNode() const
Definition: Port.hxx:46
Definition: Proc.hxx:44
std::map< std::string, ComponentInstance * > componentInstanceMap
Definition: Proc.hxx:92
CORBA::ORB_ptr getOrb() const
Class for Salome component instance.
Definition: TypeCode.hxx:68
DynType kind() const
Definition: TypeCode.cxx:47
SALOMEDS::SObject_ptr findOrCreateSoWithName(SALOMEDS::StudyBuilder_ptr builder, SALOMEDS::SObject_ptr sobj, const std::string &name)
Definition: StudyPorts.cxx:234
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
