yacsSrv.cxx File Reference
#include <Python.h>
#include <yacs.hh>
#include "RuntimeSALOME.hxx"
#include "Proc.hxx"
#include "Exception.hxx"
#include "Executor.hxx"
#include "Dispatcher.hxx"
#include "parsers.hxx"
#include <sstream>
#include <set>
Include dependency graph for yacsSrv.cxx:
class  MyDispatcher
class  Yacs_i
class  Proc_i
static CORBA::Boolean bindObjectToName (CORBA::ORB_ptr, CORBA::Object_ptr, const char *)
static ostream & operator<< (ostream &os, const CORBA::Exception &e)
int main (int argc, char **argv)
Variables
YACS::YACSLoader::YACSLoader * loader
CORBA::ORB_ptr orb
YACS_ORB::YACS_Gen_var myyacsref
◆ bindObjectToName()
static CORBA::Boolean bindObjectToName ( CORBA::ORB_ptr  orb,
CORBA::Object_ptr  objref,
const char *  name
Definition at line 220 of file yacsSrv.cxx.
221{
222 CosNaming::NamingContext_var rootContext;
223
224 try {
225 // Obtain a reference to the root context of the Name service:
226 CORBA::Object_var obj;
227 obj = orb->resolve_initial_references("NameService");
228
229 // Narrow the reference returned.
230 rootContext = CosNaming::NamingContext::_narrow(obj);
231 if( CORBA::is_nil(rootContext) ) {
232 DEBTRACE("Failed to narrow the root naming context.");
233 return 0;
234 }
235 }
236 catch(CORBA::ORB::InvalidName& ex) {
237 // This should not happen!
238 DEBTRACE("Service required is invalid [does not exist]." );
239 return 0;
240 }
241
242 try {
243 // Bind a context called "test" to the root context:
244
245 CosNaming::Name contextName;
246 contextName.length(1);
247 contextName[0].id = (const char*) "test"; // string copied
248 contextName[0].kind = (const char*) "my_context"; // string copied
249 // Note on kind: The kind field is used to indicate the type
250 // of the object. This is to avoid conventions such as that used
251 // by files (name.type -- e.g. test.ps = postscript etc.)
252
253 CosNaming::NamingContext_var testContext;
254 try {
255 // Bind the context to root.
256 testContext = rootContext->bind_new_context(contextName);
257 }
258 catch(CosNaming::NamingContext::AlreadyBound& ex) {
259 // If the context already exists, this exception will be raised.
260 // In this case, just resolve the name and assign testContext
261 // to the object returned:
262 CORBA::Object_var obj;
263 obj = rootContext->resolve(contextName);
264 testContext = CosNaming::NamingContext::_narrow(obj);
265 if( CORBA::is_nil(testContext) ) {
266 DEBTRACE("Failed to narrow naming context.");
267 return 0;
268 }
269 }
270
271 // Bind objref with name name to the testContext:
272 CosNaming::Name objectName;
273 objectName.length(1);
274 objectName[0].id = name; // string copied
275 objectName[0].kind = (const char*) "Object"; // string copied
276
277 try {
278 testContext->bind(objectName, objref);
279 }
280 catch(CosNaming::NamingContext::AlreadyBound& ex) {
281 testContext->rebind(objectName, objref);
282 }
283 }
284 catch(CORBA::COMM_FAILURE& ex) {
285 DEBTRACE("Caught system exception COMM_FAILURE -- unable to contact the "
286 << "naming service.");
287 return 0;
288 }
289 catch(CORBA::SystemException&) {
290 DEBTRACE("Caught a CORBA::SystemException while using the naming service.");
291 return 0;
292 }
293
294 return 1;
295}
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
References DEBTRACE, testCppPluginInvokation::ex, and orb.
Referenced by main().
◆ main()
int main ( int  argc,
char **  argv
Definition at line 161 of file yacsSrv.cxx.
162{
165 MyDispatcher* disp=new MyDispatcher();
167
168 try
169 {
170 orb = CORBA::ORB_init(argc, argv);
171
172 {
173 CORBA::Object_var obj = orb->resolve_initial_references("RootPOA");
174 PortableServer::POA_var root_poa = PortableServer::POA::_narrow(obj);
175 // POA manager
176 PortableServer::POAManager_var poa_man = root_poa->the_POAManager();
177 poa_man->activate();
178
179 // Create and activate servant
180 Yacs_i* myyacs = new Yacs_i();
181 // Obtain a reference to the object, and print it out as a
182 // stringified IOR.
183 obj = myyacs->_this();
184 CORBA::String_var sior(orb->object_to_string(obj));
185 DEBTRACE("'" << (char*)sior << "'");
186 myyacsref = YACS_ORB::YACS_Gen::_narrow(obj);
187
188 if( !bindObjectToName(orb, myyacsref,"Yacs") ) return 1;
189
190 // Decrement the reference count of the object implementation, so
191 // that it will be properly cleaned up when the POA has determined
192 // that it is no longer needed.
193 myyacs->_remove_ref();
194 }
195 orb->run();
196 }
197 catch(CORBA::SystemException&) {
198 DEBTRACE("Caught CORBA::SystemException.");
199 }
200 catch(CORBA::Exception& ex) {
201 DEBTRACE("Caught CORBA::Exception." << ex);
202 }
203 catch(omniORB::fatalException& fe) {
204 DEBTRACE("Caught omniORB::fatalException:");
205 DEBTRACE(" file: " << fe.file());
206 DEBTRACE(" line: " << fe.line());
207 DEBTRACE(" mesg: " << fe.errmsg());
208 }
209 catch(...) {
210 DEBTRACE("Caught unknown exception." );
211 }
212
213 return 0;
214}
static void setDispatcher(Dispatcher *dispatcher)
Definition: Dispatcher.cxx:64
static void setRuntime(long flags=UsePython+UseCorba+UseXml+UseCpp+UseSalome, int argc=0, char *argv[]=NULL)
static CORBA::Boolean bindObjectToName(CORBA::ORB_ptr, CORBA::Object_ptr, const char *)
Definition: yacsSrv.cxx:220
Definition: yacsSrv.cxx:40
Definition: yacsSrv.cxx:38
References bindObjectToName(), DEBTRACE, testCppPluginInvokation::ex, loader, myyacsref, orb, YACS::ENGINE::Dispatcher::setDispatcher(), YACS::ENGINE::RuntimeSALOME::setRuntime(), and YACS::YACSLoader::YACSLoader().
◆ operator<<()
static ostream & operator<< ( ostream &  os,
const CORBA::Exception &  e
Definition at line 297 of file yacsSrv.cxx.
298{
299 CORBA::Any tmp;
300 tmp<<= e;
301 CORBA::TypeCode_var tc = tmp.type();
302 const char *p = tc->name();
303 if ( *p != '\0' ) {
304 os<<p;
305 }
306 else {
307 os << tc->id();
308 }
309 return os;
310}
Proc * p
Definition: driver.cxx:216
References p.
Variable Documentation
◆ loader
Definition at line 38 of file yacsSrv.cxx.
Referenced by Yacs_i::Load(), and main().
◆ myyacsref
Definition at line 40 of file yacsSrv.cxx.
◆ orb
