SessionCataLoader.cxx
20#include "RuntimeSALOME.hxx"
21#include "SessionCataLoader.hxx"
23#include "ServiceNode.hxx"
24#include "TypeCode.hxx"
26#include <iostream>
27#include <sstream>
28
29//#define _DEVDEBUG_
30#include "YacsTrace.hxx"
31
32#define NEW_KERNEL
33
34using namespace YACS::ENGINE;
35
36SessionCataLoader::SessionCataLoader(const std::string& path):CatalogLoader(path)
37{
38 //path should be a CORBA URI like that : corbaname::machine:port/NameService#Kernel.dir/ModulCatalog.object
39 //or equivalent corbaname
40}
41
42/*
43 In salome catalog, the type names for CALCIUM are : INTEGER, FLOAT,DOUBLE,STRING,BOOLEAN
44 enum DataStreamType {
45 DATASTREAM_UNKNOWN,
46 DATASTREAM_INTEGER,
47 DATASTREAM_FLOAT,
48 DATASTREAM_DOUBLE,
49 DATASTREAM_STRING,
50 DATASTREAM_BOOLEAN
51 } ;
52*/
53#ifndef NEW_KERNEL
54std::map<SALOME_ModuleCatalog::DataStreamType,std::string> datastreamMap;
55#endif
56
58
66void SessionCataLoader::importComponent(Catalog* cata,SALOME_ModuleCatalog::Acomponent_ptr compo)
67{
68 CORBA::String_var componame = compo->componentname();
69
70 DEBTRACE("Implementation type : " << compo->implementation_type());
71#ifdef NEW_KERNEL
72 SALOME_ModuleCatalog::ImplType imptyp=compo->implementation_type();
73 if(imptyp == SALOME_ModuleCatalog::SO)DEBTRACE("Dyn lib");
74 if(imptyp == SALOME_ModuleCatalog::PY)DEBTRACE("Python module");
75 if(imptyp == SALOME_ModuleCatalog::EXE)DEBTRACE("Executable");
76 DEBTRACE("Implementation name : " << compo->implementation_name());
77#endif
78
79 SALOME_ModuleCatalog::ListOfInterfaces_var interfacename_list = compo->GetInterfaceList();
80 if(interfacename_list->length() == 0)
81 return;
82 int found=0;
83 for (int j = 0; j < interfacename_list->length();j++)
84 {
85 DEBTRACE ("Interface : " << interfacename_list[j]);
86 if(strcmp(componame,interfacename_list[j]) == 0)
87 {
88 found=j;
89 break;
90 }
91 }
92 DEBTRACE ("Interface found : " << interfacename_list[found]);
93 ComponentDefinition* compodef=new ComponentDefinition((const char*)componame);
94
95 SALOME_ModuleCatalog::DefinitionInterface_var interface;
96 interface= compo->GetInterface(interfacename_list[found]);
97 SALOME_ModuleCatalog::ListOfInterfaceService services = interface->interfaceservicelist;
98 for (int k = 0; k < services.length(); k++)
99 {
100 DEBTRACE("Service : " << services[k].ServiceName);
101 const char* s=services[k].ServiceName;
102 //create a new service node (prototype)
103 ServiceNode* node=getRuntime()->createCompoNode("Salome",s);
104 node->setRef((const char*)componame);
105 node->setMethod(s);
106 for (int kk=0;kk< services[k].ServiceinParameter.length();kk++)
107 {
108 DEBTRACE("Parameter : " << services[k].ServiceinParameter[kk].Parametername);
109 DEBTRACE("Type : " << services[k].ServiceinParameter[kk].Parametertype);
110 const char* ty=services[k].ServiceinParameter[kk].Parametertype;
111 if(cata->_typeMap.count(ty)==0)
112 {
113 std::stringstream msg;
114 msg << "Type " <<ty <<" does not exist. Service " << s << " of component " << componame << " is not available";
115 _errors=_errors+"\n"+msg.str();
116 std::cerr << msg.str() << std::endl;
117 compodef->_serviceMap[s+std::string("_IS_INVALID")]=0;
118 delete node;
119 node=0;
120 break;
121 }
122 const char* name=services[k].ServiceinParameter[kk].Parametername;
123 node->edAddInputPort(name,cata->_typeMap[ty]);
124 }
125 if(node == 0)continue;
126
127 for (int kk=0;kk< services[k].ServiceoutParameter.length();kk++)
128 {
129 DEBTRACE("Parameter : " << services[k].ServiceoutParameter[kk].Parametername);
130 DEBTRACE("Type : " << services[k].ServiceoutParameter[kk].Parametertype);
131 const char* ty=services[k].ServiceoutParameter[kk].Parametertype;
132 if(cata->_typeMap.count(ty)==0)
133 {
134 std::stringstream msg;
135 msg << "Type " <<ty <<" does not exist. Service " << s << " of component " << componame << " is not available";
136 _errors=_errors+"\n"+msg.str();
137 std::cerr << msg.str() << std::endl;
138 compodef->_serviceMap[s+std::string("_IS_INVALID")]=0;
139 delete node;
140 node=0;
141 break;
142 }
143 const char* name=services[k].ServiceoutParameter[kk].Parametername;
144 node->edAddOutputPort(name,cata->_typeMap[ty]);
145 }
146 if(node == 0)continue;
147
148 for (int kk=0;kk< services[k].ServiceinDataStreamParameter.length();kk++)
149 {
150 DEBTRACE("Parameter : " << services[k].ServiceinDataStreamParameter[kk].Parametername);
151 DEBTRACE("Type : " << services[k].ServiceinDataStreamParameter[kk].Parametertype);
152 DEBTRACE("Dependency : " << services[k].ServiceinDataStreamParameter[kk].Parameterdependency);
153#ifdef NEW_KERNEL
154 const char* ty=services[k].ServiceinDataStreamParameter[kk].Parametertype;
155#else
156 std::string ty=datastreamMap[services[k].ServiceinDataStreamParameter[kk].Parametertype];
157#endif
158 if(cata->_typeMap.count(ty)==0)
159 {
160 std::stringstream msg;
161 msg << "Type " <<ty <<" does not exist. Service " << s << " of component " << componame << " is not available";
162 _errors=_errors+"\n"+msg.str();
163 std::cerr << msg.str() << std::endl;
164 compodef->_serviceMap[s+std::string("_IS_INVALID")]=0;
165 delete node;
166 node=0;
167 break;
168 }
169 const char* name=services[k].ServiceinDataStreamParameter[kk].Parametername;
171 port=node->edAddInputDataStreamPort(name,cata->_typeMap[ty]);
172 }
173 if(node == 0)continue;
174
175 for (int kk=0;kk< services[k].ServiceoutDataStreamParameter.length();kk++)
176 {
177 DEBTRACE("Parameter : " << services[k].ServiceoutDataStreamParameter[kk].Parametername);
178 DEBTRACE("Type : " << services[k].ServiceoutDataStreamParameter[kk].Parametertype);
179 DEBTRACE("Dependency : " << services[k].ServiceoutDataStreamParameter[kk].Parameterdependency);
180#ifdef NEW_KERNEL
181 const char* ty=services[k].ServiceoutDataStreamParameter[kk].Parametertype;
182#else
183 std::string ty=datastreamMap[services[k].ServiceoutDataStreamParameter[kk].Parametertype];
184#endif
185 if(cata->_typeMap.count(ty)==0)
186 {
187 std::stringstream msg;
188 msg << "Type " <<ty <<" does not exist. Service " << s << " of component " << componame << " is not available";
189 _errors=_errors+"\n"+msg.str();
190 std::cerr << msg.str() << std::endl;
191 compodef->_serviceMap[s+std::string("_IS_INVALID")]=0;
192 delete node;
193 node=0;
194 break;
195 }
196 const char* name=services[k].ServiceoutDataStreamParameter[kk].Parametername;
198 port=node->edAddOutputDataStreamPort(name,cata->_typeMap[ty]);
199 // Set all properties for this port
200 /*
201 std::map<std::string, std::string>::const_iterator pt;
202 for(pt=p._props.begin();pt!=p._props.end();pt++)
203 port->setProperty((*pt).first,(*pt).second);
204 */
205 }
206 if(node == 0)continue;
207 compodef->_serviceMap[s]=node;
208 }
209
210 /* Even if a component has no service, put it in the catalog
211 if(compodef->_serviceMap.size() > 0)
212 {
213 cata->_componentMap[(const char*)componame]=compodef;
214 }
215 else
216 {
217 delete compodef;
218 }
219 */
220 cata->_componentMap[(const char*)componame]=compodef;
221}
222
224{
225 DEBTRACE ("SessionCataLoader::~SessionCataLoader");
226}
227
228void SessionCataLoader::loadTypes(Catalog* cata,SALOME_ModuleCatalog::ModuleCatalog_ptr catalog)
229{
231 std::map<std::string,TypeCode*>& typeMap=cata->_typeMap;
232 // Get types list
233 SALOME_ModuleCatalog::ListOfTypeDefinition_var types_list=catalog->GetTypes();
234 for (int i=0; i< types_list->length(); i++)
235 {
236 const char* name=types_list[i].name;
237 DEBTRACE ("type : " << types_list[i].name << " " << types_list[i].kind);
238 if(types_list[i].kind == SALOME_ModuleCatalog::Dble)
239 {
240 r->_tc_double->incrRef();
241 typeMap[name]=r->_tc_double;
242 }
243 else if(types_list[i].kind == SALOME_ModuleCatalog::Int)
244 {
245 r->_tc_int->incrRef();
246 typeMap[name]=r->_tc_int;
247 }
248 else if(types_list[i].kind == SALOME_ModuleCatalog::Bool)
249 {
250 r->_tc_bool->incrRef();
251 typeMap[name]=r->_tc_bool;
252 }
253 else if(types_list[i].kind == SALOME_ModuleCatalog::Str)
254 {
255 r->_tc_string->incrRef();
256 typeMap[name]=r->_tc_string;
257 }
258 else if(types_list[i].kind == SALOME_ModuleCatalog::Seq)
259 {
260 const char* content=types_list[i].content;
261 if ( typeMap.find(content) != typeMap.end() )
262 typeMap[name]=r->createSequenceTc(name,name,typeMap[content]);
263 //else ignored !!
264 }
265 else if(types_list[i].kind == SALOME_ModuleCatalog::Array)
266 {
267 //ignored, for the moment !!
268 }
269 else if(types_list[i].kind == SALOME_ModuleCatalog::Objref)
270 {
271 std::list<TypeCodeObjref *> ltc;
272 const char* id=types_list[i].id;
273 for (int m=0; m< types_list[i].bases.length(); m++)
274 {
275 const char* b_name=types_list[i].bases[m];
276 if(typeMap.find(b_name) != typeMap.end())
277 ltc.push_back((TypeCodeObjref *)typeMap[b_name]);
278 //else ignored !!!
279 }
280 typeMap[name]=r->createInterfaceTc(id,name,ltc);
281 }
282 else if(types_list[i].kind == SALOME_ModuleCatalog::Struc)
283 {
284 TypeCodeStruct* t=r->createStructTc("",name);
285 for (int m=0; m< types_list[i].members.length(); m++)
286 {
287 const char* m_name=types_list[i].members[m].name;
288 const char* m_type=types_list[i].members[m].type;
289 if(typeMap.find(m_type) != typeMap.end())
290 t->addMember(m_name,typeMap[m_type]);
291 //else ignored !!!
292 }
293 typeMap[name]=t;
294 }
295 else
296 {
297 std::cerr << "Unknown kind: " << types_list[i].kind << std::endl;
298 }
299 }
300}
301
303{
304 // Fill the types map with built in types
306 std::map<std::string,TypeCode*>& typeMap=cata->_typeMap;
307
308#ifdef NEW_KERNEL
309 //Add old Calcium data types for KERNEL
310 if(typeMap.count("CALCIUM_double")!=0)
311 {
312 typeMap["DOUBLE"]=typeMap["CALCIUM_double"];
313 typeMap["DOUBLE"]->incrRef();
314 }
315 if(typeMap.count("CALCIUM_real")!=0)
316 {
317 typeMap["FLOAT"]=typeMap["CALCIUM_real"];
318 typeMap["FLOAT"]->incrRef();
319 }
320 if(typeMap.count("CALCIUM_integer")!=0)
321 {
322 typeMap["INTEGER"]=typeMap["CALCIUM_integer"];
323 typeMap["INTEGER"]->incrRef();
324 }
325 if(typeMap.count("CALCIUM_boolean")!=0)
326 {
327 typeMap["BOOLEAN"]=typeMap["CALCIUM_boolean"];
328 typeMap["BOOLEAN"]->incrRef();
329 }
330 if(typeMap.count("CALCIUM_string")!=0)
331 {
332 typeMap["STRING"]=typeMap["CALCIUM_string"];
333 typeMap["STRING"]->incrRef();
334 }
335#endif
336
337 //GEOM
338 /*
339 typeMap["GEOM_Object"]=TypeCode::interfaceTc("IDL:GEOM/GEOM_Object:1.0","GEOM_Object");
340 typeMap["ListOfLong"]=TypeCode::sequenceTc("ListOfLong","ListOfLong",r->_tc_int);
341 typeMap["GEOM_List"]=TypeCode::interfaceTc("IDL:GEOM/GEOM_List:1.0","GEOM_List");
342 typeMap["GEOM_Superv"]=TypeCode::interfaceTc("IDL:GEOM/GEOM_Superv:1.0","GEOM_Superv");
343 typeMap["ListOfGO"]=TypeCode::sequenceTc("ListOfGO","ListOfGO",cata->_typeMap["GEOM_Object"]);
344 typeMap["string_array"]=TypeCode::sequenceTc("string_array","string_array",r->_tc_string);
345 r->_tc_int->incrRef();
346 typeMap["BCErrorType"]=r->_tc_int;
347 typeMap["BCError"]=TypeCode::structTc("","BCError");
348 ((TypeCodeStruct*)typeMap["BCError"])->addMember("incriminated",typeMap["ListOfLong"]);
349 typeMap["BCErrors"]=TypeCode::sequenceTc("BCErrors","BCErrors",typeMap["BCError"]);
350 typeMap["GEOM_Gen"]=TypeCode::interfaceTc("IDL:GEOM/GEOM_Gen:1.0","GEOM_Gen");
351 typeMap["GEOM_Object"]->incrRef();
352 typeMap["GEOM_Shape"]=typeMap["GEOM_Object"];
353 */
354
355 //SMESH
356 /*
357 typeMap["SMESH_Mesh"]=TypeCode::interfaceTc("IDL:Mesh/SMESH_Mesh:1.0","SMESH_Mesh");
358 typeMap["SMESH_Hypothesis"]=TypeCode::interfaceTc("IDL:SMESH/SMESH_Hypothesis:1.0","SMESH_Hypothesis");
359 */
360
361 //MED
362 /*
363 typeMap["MED"]=TypeCode::interfaceTc("IDL:SALOME_MED/MED:1.0","MED");
364 typeMap["FIELD"]=TypeCode::interfaceTc("IDL:SALOME_MED/FIELD:1.0","FIELD");
365 // TODO : FIELDDOUBLE inherits FIELD
366 typeMap["FIELDDOUBLE"]=TypeCode::interfaceTc("IDL:SALOME_MED/FIELDDOUBLE:1.0","FIELDDOUBLE");
367 */
368
369 //COMPONENT
370 /*
371 typeMap["AddComponent"]=TypeCode::interfaceTc("IDL:SuperVisionTest/AddComponent:1.0","AddComponent");
372 typeMap["AddComponent"]->incrRef();
373 typeMap["AddInterface"]=typeMap["AddComponent"];
374 typeMap["SuperVisionTest/Adder"]=TypeCode::interfaceTc("IDL:SuperVisionTest/Adder:1.0","SuperVisionTest/Adder");
375 typeMap["AdditionComponent/Adder"]=TypeCode::interfaceTc("IDL:AdditionComponent/Adder:1.0","AdditionComponent/Adder");
376 typeMap["Syr"]=TypeCode::interfaceTc("IDL:SuperVisionTest/Syr:1.0","Syr");
377 typeMap["ListOfSyr"]=TypeCode::interfaceTc("IDL:SuperVisionTest/ListOfSyr:1.0","ListOfSyr");
378 */
379}
380
382{
383 DEBTRACE("SessionCataLoader::load")
384#ifndef NEW_KERNEL
385 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_UNKNOWN]="CALCIUM_unknown";
386 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_INTEGER]="CALCIUM_integer";
387 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_FLOAT]="CALCIUM_real";
388 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_DOUBLE]="CALCIUM_double";
389 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_BOOLEAN]="CALCIUM_boolean";
390 datastreamMap[SALOME_ModuleCatalog::DATASTREAM_STRING]="CALCIUM_string";
391#endif
392
393 CORBA::ORB_ptr orb = getSALOMERuntime()->getOrb();
394 CORBA::Object_var obj;
395 SALOME_ModuleCatalog::ModuleCatalog_var catalog;
396 obj=orb->string_to_object(_path.c_str());
397 catalog= SALOME_ModuleCatalog::ModuleCatalog::_narrow(obj);
398 _errors="";
399
400 // Get types in catalog
401 loadTypes(cata,catalog);
402 // Get old types
403 loadTypesOld(cata);
404
405 // Get component list
406 SALOME_ModuleCatalog::ListOfComponents_var componentname_list;
407 componentname_list = catalog->GetComponentList();
408 for (int i=0; i<componentname_list->length(); i++)
409 {
410 DEBTRACE ("Component : " << componentname_list[i]);
411 SALOME_ModuleCatalog::Acomponent_var component = catalog->GetComponent(componentname_list[i]);
412 importComponent(cata,component);
413 }
414 cata->setErrors(_errors);
415}
class for YACS catalog loader.
Definition: Catalog.hxx:63
class for YACS catalogs.
Definition: Catalog.hxx:42
void setErrors(const std::string &errors)
Definition: Catalog.hxx:48
std::map< std::string, ComponentDefinition * > _componentMap
Definition: Catalog.hxx:50
std::map< std::string, TypeCode * > _typeMap
Definition: Catalog.hxx:49
Base class for component definition.
std::map< std::string, ServiceNode * > _serviceMap
virtual OutputDataStreamPort * edAddOutputDataStreamPort(const std::string &outputPortDSName, TypeCode *type)
virtual InputPort * edAddInputPort(const std::string &inputPortName, TypeCode *type)
virtual InputDataStreamPort * edAddInputDataStreamPort(const std::string &inputPortDSName, TypeCode *type)
virtual OutputPort * edAddOutputPort(const std::string &outputPortName, TypeCode *type)
CORBA::ORB_ptr getOrb() const
virtual ServiceNode * createCompoNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:205
virtual void setRef(const std::string &ref)
Associate a new component instance to this service node.
virtual void setMethod(const std::string &method)
Definition: ServiceNode.hxx:50
virtual void loadCata(Catalog *cata)
virtual void loadTypesOld(Catalog *cata)
virtual void loadTypes(Catalog *cata, SALOME_ModuleCatalog::ModuleCatalog_ptr catalog)
virtual void importComponent(Catalog *cata, SALOME_ModuleCatalog::Acomponent_ptr compo)
import a SALOME component definition in a YACS catalog
Class for reference objects.
Definition: TypeCode.hxx:126
Class for struct type.
Definition: TypeCode.hxx:228
Definition: Runtime.cxx:61
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
