yacsSrv.cxx
20#include <Python.h>
21#include <yacs.hh>
22#include "RuntimeSALOME.hxx"
23#include "Proc.hxx"
24#include "Exception.hxx"
25#include "Executor.hxx"
26#include "Dispatcher.hxx"
27#include "parsers.hxx"
28
29#include <iostream>
30#include <sstream>
31#include <set>
32
33//#define _DEVDEBUG_
34#include "YacsTrace.hxx"
35
36using namespace std;
37
39CORBA::ORB_ptr orb;
40YACS_ORB::YACS_Gen_var myyacsref;
41
43{
44public:
45 void dispatch(YACS::ENGINE::Node* object, const std::string& event)
46 {
47 std::cerr << "dispatch " << object->getNumId() << std::endl;
48 typedef std::set<YACS_ORB::Observer_ptr>::iterator jt;
49 std::pair<int,std::string> key(object->getNumId(),event);
50 for(jt iter=_observers[key].begin();iter!=_observers[key].end();iter++)
51 {
52 (*iter)->notifyObserver((CORBA::Long)object->getNumId(),event.c_str());
53 }
54 }
55
56 void addObserver(YACS_ORB::Observer_ptr observer,int numid, const std::string& event)
57 {
58 _observers[std::pair<int,std::string>(numid,event)].insert(YACS_ORB::Observer::_duplicate(observer));
59 // printObservers();
60 }
61protected:
62 std::map< std::pair<int,std::string> , std::set<YACS_ORB::Observer_ptr> > _observers;
63};
64
65class Yacs_i : public POA_YACS_ORB::YACS_Gen,
66 public PortableServer::RefCountServantBase
67{
68public:
69 inline Yacs_i() {}
70 virtual ~Yacs_i() {}
71 YACS_ORB::Proc_ptr Load(const char* xmlFile);
72 void Run(YACS_ORB::Proc_ptr p);
73 void addObserver(YACS_ORB::Observer_ptr observer, CORBA::Long numid,const char* event);
74};
75
76class Proc_i : public POA_YACS_ORB::Proc,
77 public PortableServer::RefCountServantBase
78{
79public:
81 virtual ~Proc_i() {};
82 virtual void RunW();
83 CORBA::Long getState(CORBA::Long numid);
84 char * getXMLState(CORBA::Long numid);
85 void getIds(YACS_ORB::longArray_out numids,YACS_ORB::stringArray_out names);
86protected:
89};
90
92{
94}
95
96CORBA::Long Proc_i::getState(CORBA::Long numid)
97{
98 if(YACS::ENGINE::Node::idMap.count(numid) == 0)
99 {
100 std::cerr << "Unknown node id " << numid << std::endl;
101 return (CORBA::Long)-1;
102 }
104 CORBA::Long state=node->getEffectiveState();
105 return state;
106}
107
108char * Proc_i::getXMLState(CORBA::Long numid)
109{
110 if(YACS::ENGINE::Node::idMap.count(numid) == 0)
111 {
112 std::cerr << "Unknown node id " << numid << std::endl;
113 return "<state>unknown</state>";
114 }
116 std::stringstream msg;
117 msg << "<state>" << node->getEffectiveState() << "</state>";
118 msg << "<name>" << node->getQualifiedName() << "</name>";
119 msg << "<id>" << numid << "</id>";
120 return CORBA::string_dup(msg.str().c_str());
121}
122
123void Proc_i::getIds(YACS_ORB::longArray_out numids,YACS_ORB::stringArray_out names)
124{
125 std::list<YACS::ENGINE::Node *> nodes=_proc->getAllRecursiveNodes();
126 int len=nodes.size();
129 names->length(len);
130 numids->length(len);
131 int i=0;
132 for(list<YACS::ENGINE::Node *>::const_iterator iter=nodes.begin();iter!=nodes.end();iter++,i++)
133 {
134 (*names)[i]=CORBA::string_dup((*iter)->getQualifiedName().c_str());
135 (*numids)[i]=(*iter)->getNumId();
136 }
137}
138
139YACS_ORB::Proc_ptr Yacs_i::Load(const char* xmlFile)
140{
141 YACS::ENGINE::Proc* proc=loader->load(xmlFile);
142 Proc_i* p=new Proc_i(proc);
143 YACS_ORB::Proc_ptr pp = p->_this();
144 return pp;
145}
146
147void Yacs_i::addObserver(YACS_ORB::Observer_ptr observer, CORBA::Long numid,const char* event)
148{
150}
151
152void Yacs_i::Run(YACS_ORB::Proc_ptr p)
153{
154 Proc_i *servant=dynamic_cast<Proc_i *> (PortableServer::POA::_the_root_poa()->reference_to_servant(p));
155 servant->RunW();
156}
157
158static CORBA::Boolean bindObjectToName(CORBA::ORB_ptr, CORBA::Object_ptr,const char*);
159static ostream& operator<<(ostream& os, const CORBA::Exception& e);
160
161int main(int argc, char** argv)
162{
165 MyDispatcher* disp=new MyDispatcher();
167
168 try
169 {
170 orb = CORBA::ORB_init(argc, argv);
171
172 {
173 CORBA::Object_var obj = orb->resolve_initial_references("RootPOA");
174 PortableServer::POA_var root_poa = PortableServer::POA::_narrow(obj);
175 // POA manager
176 PortableServer::POAManager_var poa_man = root_poa->the_POAManager();
177 poa_man->activate();
178
179 // Create and activate servant
180 Yacs_i* myyacs = new Yacs_i();
181 // Obtain a reference to the object, and print it out as a
182 // stringified IOR.
183 obj = myyacs->_this();
184 CORBA::String_var sior(orb->object_to_string(obj));
185 DEBTRACE("'" << (char*)sior << "'");
186 myyacsref = YACS_ORB::YACS_Gen::_narrow(obj);
187
188 if( !bindObjectToName(orb, myyacsref,"Yacs") ) return 1;
189
190 // Decrement the reference count of the object implementation, so
191 // that it will be properly cleaned up when the POA has determined
192 // that it is no longer needed.
193 myyacs->_remove_ref();
194 }
195 orb->run();
196 }
197 catch(CORBA::SystemException&) {
198 DEBTRACE("Caught CORBA::SystemException.");
199 }
200 catch(CORBA::Exception& ex) {
201 DEBTRACE("Caught CORBA::Exception." << ex);
202 }
203 catch(omniORB::fatalException& fe) {
204 DEBTRACE("Caught omniORB::fatalException:");
205 DEBTRACE(" file: " << fe.file());
206 DEBTRACE(" line: " << fe.line());
207 DEBTRACE(" mesg: " << fe.errmsg());
208 }
209 catch(...) {
210 DEBTRACE("Caught unknown exception." );
211 }
212
213 return 0;
214}
215
216
218
219static CORBA::Boolean
220bindObjectToName(CORBA::ORB_ptr orb, CORBA::Object_ptr objref,const char *name)
221{
222 CosNaming::NamingContext_var rootContext;
223
224 try {
225 // Obtain a reference to the root context of the Name service:
226 CORBA::Object_var obj;
227 obj = orb->resolve_initial_references("NameService");
228
229 // Narrow the reference returned.
230 rootContext = CosNaming::NamingContext::_narrow(obj);
231 if( CORBA::is_nil(rootContext) ) {
232 DEBTRACE("Failed to narrow the root naming context.");
233 return 0;
234 }
235 }
236 catch(CORBA::ORB::InvalidName& ex) {
237 // This should not happen!
238 DEBTRACE("Service required is invalid [does not exist]." );
239 return 0;
240 }
241
242 try {
243 // Bind a context called "test" to the root context:
244
245 CosNaming::Name contextName;
246 contextName.length(1);
247 contextName[0].id = (const char*) "test"; // string copied
248 contextName[0].kind = (const char*) "my_context"; // string copied
249 // Note on kind: The kind field is used to indicate the type
250 // of the object. This is to avoid conventions such as that used
251 // by files (name.type -- e.g. test.ps = postscript etc.)
252
253 CosNaming::NamingContext_var testContext;
254 try {
255 // Bind the context to root.
256 testContext = rootContext->bind_new_context(contextName);
257 }
258 catch(CosNaming::NamingContext::AlreadyBound& ex) {
259 // If the context already exists, this exception will be raised.
260 // In this case, just resolve the name and assign testContext
261 // to the object returned:
262 CORBA::Object_var obj;
263 obj = rootContext->resolve(contextName);
264 testContext = CosNaming::NamingContext::_narrow(obj);
265 if( CORBA::is_nil(testContext) ) {
266 DEBTRACE("Failed to narrow naming context.");
267 return 0;
268 }
269 }
270
271 // Bind objref with name name to the testContext:
272 CosNaming::Name objectName;
273 objectName.length(1);
274 objectName[0].id = name; // string copied
275 objectName[0].kind = (const char*) "Object"; // string copied
276
277 try {
278 testContext->bind(objectName, objref);
279 }
280 catch(CosNaming::NamingContext::AlreadyBound& ex) {
281 testContext->rebind(objectName, objref);
282 }
283 }
284 catch(CORBA::COMM_FAILURE& ex) {
285 DEBTRACE("Caught system exception COMM_FAILURE -- unable to contact the "
286 << "naming service.");
287 return 0;
288 }
289 catch(CORBA::SystemException&) {
290 DEBTRACE("Caught a CORBA::SystemException while using the naming service.");
291 return 0;
292 }
293
294 return 1;
295}
296
297static ostream& operator<<(ostream& os, const CORBA::Exception& e)
298{
299 CORBA::Any tmp;
300 tmp<<= e;
301 CORBA::TypeCode_var tc = tmp.type();
302 const char *p = tc->name();
303 if ( *p != '\0' ) {
304 os<<p;
305 }
306 else {
307 os << tc->id();
308 }
309 return os;
310}
void dispatch(YACS::ENGINE::Node *object, const std::string &event)
Definition: yacsSrv.cxx:45
std::map< std::pair< int, std::string >, std::set< YACS_ORB::Observer_ptr > > _observers
Definition: yacsSrv.cxx:62
void addObserver(YACS_ORB::Observer_ptr observer, int numid, const std::string &event)
Definition: yacsSrv.cxx:56
Definition: yacsSrv.cxx:108
void getIds(YACS_ORB::longArray_out numids, YACS_ORB::stringArray_out names)
Definition: yacsSrv.cxx:123
YACS::ENGINE::Proc * _proc
Definition: yacsSrv.cxx:88
Proc_i(YACS::ENGINE::Proc *p)
Definition: yacsSrv.cxx:80
Definition: yacsSrv.cxx:96
YACS::ENGINE::Executor _executor
Definition: yacsSrv.cxx:87
virtual void RunW()
Definition: yacsSrv.cxx:91
virtual ~Proc_i()
Definition: yacsSrv.cxx:81
std::list< Node * > getAllRecursiveNodes()
Get all children nodes elementary and composed including this node.
Base class for dispatcher in observer pattern.
Definition: Dispatcher.hxx:74
static Dispatcher * getDispatcher()
Definition: Dispatcher.cxx:55
static void setDispatcher(Dispatcher *dispatcher)
Definition: Dispatcher.cxx:64
Threaded Executor.
Definition: Executor.hxx:63
void RunW(Scheduler *graph, int debug=0, bool fromScratch=true)
Definition: Executor.cxx:1833
Base class for all nodes.
Definition: Node.hxx:70
static std::map< int, Node * > idMap
Definition: Node.hxx:188
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
Definition: Proc.hxx:44
static void setRuntime(long flags=UsePython+UseCorba+UseXml+UseCpp+UseSalome, int argc=0, char *argv[]=NULL)
YACS_ORB::Proc_ptr Load(const char *xmlFile)
Definition: yacsSrv.cxx:139
Definition: yacsSrv.cxx:152
Yacs_i()
Definition: yacsSrv.cxx:69
void addObserver(YACS_ORB::Observer_ptr observer, CORBA::Long numid, const char *event)
Definition: yacsSrv.cxx:147
virtual ~Yacs_i()
Definition: yacsSrv.cxx:70
Proc * p
Definition: driver.cxx:216
sequence< string > stringArray
Definition: yacsgui.idl:33
sequence< long > longArray
Definition: yacsgui.idl:34
Definition: yacsSrv.cxx:161
CORBA::ORB_ptr orb
Definition: yacsSrv.cxx:39
static CORBA::Boolean bindObjectToName(CORBA::ORB_ptr, CORBA::Object_ptr, const char *)
Definition: yacsSrv.cxx:220
Definition: yacsSrv.cxx:40
static ostream & operator<<(ostream &os, const CORBA::Exception &e)
Definition: yacsSrv.cxx:297
YACS::YACSLoader::YACSLoader * loader
Definition: yacsSrv.cxx:38
