YACS::YACSLoader Class Reference
#include <parsers.hxx>
Inheritance diagram for YACS::YACSLoader:
Collaboration diagram for YACS::YACSLoader:
 YACSLoader ()
virtual ~YACSLoader ()
virtual YACS::ENGINE::Proc * load (const char *filename)
void registerProcCataLoader ()
std::map< std::string, parser * > _defaultParsersMap
Definition at line 35 of file parsers.hxx.
◆ YACSLoader()
YACS::YACSLoader::YACSLoader ( )
Definition at line 51 of file parsers.cxx.
52{
53 _defaultParsersMap.clear();
55}
Definition: parsers.hxx:44
Definition: Runtime.cxx:61
Definition: parsers.cxx:40
References _defaultParsersMap, YACS::ENGINE::getRuntime(), and theRuntime.
Referenced by main().
◆ ~YACSLoader()
YACS::YACSLoader::~YACSLoader ( )
Definition at line 146 of file parsers.cxx.
147{
148}
◆ load()
ENGINE::Proc * YACS::YACSLoader::load ( const char *  filename)
Reimplemented in YACS::HMI::YACSGuiLoader.
Definition at line 63 of file parsers.cxx.
64{
65 DEBTRACE("YACSLoader::load: " << file);
68 xmlSAXHandler baseHandler =
69 {
70 0, // internal_subset,
71 0, // isStandalone
72 0, // hasInternalSubset
73 0, // hasExternalSubset
74 0, // resolveEntity
75 0, // getEntity
76 0, // entityDecl
77 0, // notationDecl
78 0, // attributeDecl
79 0, // elementDecl
80 0, // unparsedEntityDecl
81 0, // setDocumentLocator
82 parser::start_document, // startDocument
83 parser::end_document, // endDocument
84 parser::start_element, // startElement
85 parser::end_element, // endElement
86 0, // reference
87 parser::characters, // characters
88 0, // ignorableWhitespace
89 0, // processingInstruction
90 parser::comment, // comment
91 parser::warning, // warning
92 parser::error, // error
93 parser::fatal_error, // fatalError
94 0, // getParameterEntity
95 parser::cdata_block, // cdataBlock
96 0 // externalSubset
97 };
98
99 FILE* fin=fopen(file,"r");
100 if (! fin)
101 {
102 std::cerr << "Couldn't open schema file" << std::endl;
103 throw std::invalid_argument("Couldn't open schema file");
104 }
105
106 saxContext = xmlCreateFileParserCtxt(file);
107
108 if (!saxContext)
109 {
110 std::cerr << "Couldn't allocate memory for parser" << std::endl;
111 throw Exception("Couldn't allocate memory for parser");
112 }
113 saxContext->sax = &baseHandler;
115 if ( !_defaultParsersMap.empty() )
117 else
119
121 currentProc = 0;
122
123 try
124 {
125 if ( xmlParseDocument(saxContext) == -1 )
126 {
127 if(!currentProc)
128 throw Exception("Basic error during parsing.");
129 YACS::ENGINE::Logger* logger = currentProc->getLogger("parser");
130 logger->fatal( saxContext->lastError.message, file, saxContext->input->line );
131 }
132 saxContext = 0;
133 return currentProc;
134 }
135 catch(Exception& e)
136 {
137 if(!currentProc)
138 throw e;
139 YACS::ENGINE::Logger* logger = currentProc->getLogger("parser");
140 logger->fatal(e.what(), file, saxContext->input->line);
141 saxContext = 0;
142 return currentProc;
143 }
144}
Class for logging error messages.
Definition: Logger.hxx:38
virtual void fatal(const std::string &message, const char *filename, int line)
Definition: Logger.cxx:55
virtual Logger * getLogger(const std::string &name)
Definition: Proc.cxx:431
Definition: parserBase.cxx:30
_xmlParserCtxt * saxContext
Definition: parserBase.cxx:31
static void XMLCALL start_element(void *data, const xmlChar *name, const xmlChar **p)
Definition: parserBase.cxx:237
static void XMLCALL warning(void *data, const char *fmt,...)
Definition: parserBase.cxx:284
virtual void init()
Definition: parserBase.cxx:86
Definition: parserBase.cxx:55
static std::stack< parser * > _stackParser
Definition: parserBase.hxx:42
static void XMLCALL fatal_error(void *data, const char *fmt,...)
Definition: parserBase.cxx:322
static void XMLCALL end_document(void *data)
Definition: parserBase.cxx:231
static void XMLCALL comment(void *data, const xmlChar *value)
Definition: parserBase.cxx:268
static parser main_parser
Definition: parserBase.hxx:41
static void XMLCALL error(void *data, const char *fmt,...)
Definition: parserBase.cxx:303
static void XMLCALL cdata_block(void *data, const xmlChar *value, int len)
Definition: parserBase.cxx:275
static void XMLCALL end_element(void *data, const xmlChar *name)
Definition: parserBase.cxx:247
std::string _file
Definition: parserBase.hxx:96
static void XMLCALL start_document(void *data)
Definition: parserBase.cxx:225
static void XMLCALL characters(void *data, const xmlChar *ch, int len)
Definition: parserBase.cxx:259
void setDefaultMap(std::map< std::string, parser * > *)
Definition: rootParser.cxx:61
static roottypeParser rootParser
Definition: rootParser.hxx:32
References _defaultParsersMap, YACS::parser::_file, YACS::parser::_stackParser, YACS::parser::cdata_block(), YACS::parser::characters(), YACS::parser::comment(), currentProc, DEBTRACE, YACS::parser::end_document(), YACS::parser::end_element(), YACS::parser::error(), YACS::ENGINE::Logger::fatal(), YACS::parser::fatal_error(), YACS::ENGINE::Proc::getLogger(), YACS::parser::init(), YACS::parser::main_parser, YACS::roottypeParser::rootParser, saxContext, YACS::roottypeParser::setDefaultMap(), YACS::parser::SetUserDataAndPush(), YACS::parser::start_document(), YACS::parser::start_element(), YACS::parser::warning(), and YACS::Exception::what().
Referenced by YACS::HMI::YACSGuiLoader::load(), and YACS::ENGINE::ProcCataLoader::loadCata().
◆ registerProcCataLoader()
void YACS::YACSLoader::registerProcCataLoader ( )
Definition at line 57 of file parsers.cxx.
58{
60 theRuntime->setCatalogLoaderFactory("proc",factory);
61}
virtual void setCatalogLoaderFactory(const std::string &name, CatalogLoader *factory)
Add a catalog loader factory to the map _catalogLoaderFactoryMap under the name name.
Definition: Runtime.cxx:305
References YACS::ENGINE::Runtime::setCatalogLoaderFactory(), and theRuntime.
Referenced by YACS::HMI::GenericGui::GenericGui().
◆ _defaultParsersMap
std::map<std::string,parser*> YACS::YACSLoader::_defaultParsersMap
