YACS::ENGINE::Logger Class Reference
Class for logging error messages. More...
#include <Logger.hxx>
Collaboration diagram for YACS::ENGINE::Logger:
 Logger (const std::string &name)
virtual ~Logger ()
virtual const std::string & getName ()
virtual void log (int level, const std::string &message, const char *filename, int line)
virtual void error (const std::string &message, const char *filename, int line)
virtual void fatal (const std::string &message, const char *filename, int line)
virtual void warning (const std::string &message, const char *filename, int line)
virtual LogRecord * makeRecord (const std::string &name, int level, const std::string &message, const char *filename, int line)
virtual void handle (LogRecord *record)
virtual void reset ()
virtual std::string getStr ()
virtual bool isEmpty ()
virtual bool hasErrors ()
std::vector< LogRecord * > _records
Definition at line 37 of file Logger.hxx.
◆ Logger()
Logger::Logger ( const std::string &  name)
Definition at line 30 of file Logger.cxx.
30 :_name(name)
31{
32}
std::string _name
Definition: Logger.hxx:54
◆ ~Logger()
Logger::~Logger ( )
Definition at line 34 of file Logger.cxx.
35{
36 reset();
37}
virtual void reset()
Definition: Logger.cxx:75
References reset().
◆ error()
void Logger::error ( const std::string &  message,
const char *  filename,
int  line
Definition at line 50 of file Logger.cxx.
51{
52 log(LogRecord::ERROR,message,filename,line);
53}
static const LogLevel ERROR
Definition: LogRecord.hxx:37
virtual void log(int level, const std::string &message, const char *filename, int line)
Definition: Logger.cxx:44
References YACS::ENGINE::LogRecord::ERROR, and log().
Referenced by YACS::parser::logError().
◆ fatal()
void Logger::fatal ( const std::string &  message,
int  line
Definition at line 55 of file Logger.cxx.
56{
57 log(LogRecord::FATAL,message,filename,line);
58}
static const LogLevel FATAL
Definition: LogRecord.hxx:36
References YACS::ENGINE::LogRecord::FATAL, and log().
Referenced by YACS::YACSLoader::load().
◆ getName()
const std::string & Logger::getName ( )
Definition at line 39 of file Logger.cxx.
40{
41 return _name;
42}
References _name.
Referenced by log().
◆ getStr()
std::string Logger::getStr ( )
Definition at line 85 of file Logger.cxx.
86{
87 std::vector<LogRecord*>::iterator it;
88 std::string msg;
89 for( it = _records.begin(); it != _records.end(); it++)
90 {
91 msg=msg + (*it)->getStr() + '\n';
92 }
93 return msg;
94}
Definition: Logger.hxx:55
References _records.
Referenced by YACS::ENGINE::ProcCataLoader::loadCata(), YACS::HMI::GenericGui::loadSchema(), main(), YACS::HMI::GenericGui::onImportSchema(), YACS::HMI::GenericGui::onImportSupervSchema(), YACS::HMI::GenericGui::onLoadAndRunSchema(), YACS::HMI::EditionProc::synchronize(), and YACS::HMI::BatchJobsListDialog::userOK().
◆ handle()
void Logger::handle ( LogRecord *  record)
Definition at line 70 of file Logger.cxx.
71{
72 _records.push_back(record);
73}
◆ hasErrors()
bool Logger::hasErrors ( )
Definition at line 101 of file Logger.cxx.
102{
103 bool ret=false;
104 std::vector<LogRecord*>::iterator it;
105 for( it = _records.begin(); it != _records.end(); it++)
106 {
107 if((*it)->_level > LogRecord::WARNING)
108 {
109 ret=true;
110 break;
111 }
112 }
113 return ret;
114}
static const LogLevel WARNING
Definition: LogRecord.hxx:38
References _records, and YACS::ENGINE::LogRecord::WARNING.
Referenced by main().
◆ isEmpty()
◆ log()
void Logger::log ( int  level,
int  line
Definition at line 44 of file Logger.cxx.
45{
46 LogRecord* record=makeRecord(getName(),level,message,filename,line);
47 handle(record);
48}
Class for logging record.
Definition: LogRecord.hxx:33
virtual void handle(LogRecord *record)
Definition: Logger.cxx:70
virtual const std::string & getName()
Definition: Logger.cxx:39
virtual LogRecord * makeRecord(const std::string &name, int level, const std::string &message, const char *filename, int line)
Definition: Logger.cxx:65
References getName(), handle(), and makeRecord().
Referenced by error(), fatal(), gui.Appli.Browser::view_log(), and warning().
◆ makeRecord()
LogRecord * Logger::makeRecord ( const std::string &  name,
int  level,
int  line
Definition at line 65 of file Logger.cxx.
66{
67 return new LogRecord(name,level,message,filename,line);
68}
◆ reset()
void Logger::reset ( )
Definition at line 75 of file Logger.cxx.
76{
77 std::vector<LogRecord*>::iterator it;
78 for( it = _records.begin(); it != _records.end(); it++)
79 {
80 delete (*it);
81 }
82 _records.clear();
83}
Referenced by gui.graph.grid::findPath(), and ~Logger().
◆ warning()
void Logger::warning ( const std::string &  message,
int  line
Definition at line 60 of file Logger.cxx.
61{
62 log(LogRecord::WARNING,message,filename,line);
63}
References log(), and YACS::ENGINE::LogRecord::WARNING.
◆ _name
std::string YACS::ENGINE::Logger::_name
Definition at line 54 of file Logger.hxx.
Referenced by getName().
◆ _records
std::vector<LogRecord*> YACS::ENGINE::Logger::_records
Definition at line 55 of file Logger.hxx.
Referenced by getStr(), handle(), hasErrors(), isEmpty(), and reset().
