Appli.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20"""
21"""
22import sys,os
23from qt import *
24from . import Tree
25from . import PanelManager
26from . import BoxManager
27from . import Icons
28from . import Items
29from . import adapt
30from . import Item
31from . import logview
32import pilot
33import threading
34import time
35from . import CONNECTOR
36from . import catalog
37import traceback
38import glob
39
41 def __init__(self,caption,msg):
42 QCustomEvent.__init__(self,8888)
43 self.caption=caption
44 self.msg=msg
45 def process(self,parent):
46 QMessageBox.warning(parent,self.caption,self.msg)
47
48class Runner(threading.Thread):
49 def __init__(self,parent,executor,proc):
50 threading.Thread.__init__(self)
51 self.parent=parent
52 self.executor=executor
53 self.proc=proc
54
55 def run(self):
56 try:
57 self.executor.RunW(self.proc,0)
58 except ValueError as ex:
59 #traceback.print_exc()
60 QApplication.postEvent(self.parent, ErrorEvent('YACS execution error',str(ex)))
61
63 def __init__(self,parent,proc):
64 QVBox.__init__(self,parent)
65 pp=Item.adapt(proc)
66 self.proc=proc
67 self.pproc=pp
68 self.hSplitter = QSplitter(self,"hSplitter")
70 self.objectBrowser.additem(pp)
72 self.panelManager.setRootItem(pp)
74 self.boxManager.setRootItem(pp)
75 self.selected=None
76 self.executor=None
77 self.resume=0
78 self.thr=None
80
81 def view_log(self):
82 self.log.text.setText(self.proc.getLogger("parser").getStr())
83 self.log.show()
84
85 def onDblSelect(self,item):
86 #item is instance of Item.Item
87 pass
88
89 def onSelect(self,item):
90 #item is instance of Item.Item
91 self.selected=item
92
93 def customEvent(self,ev):
94 if ev.type() == 8888:
95 ev.process(self)
96
97 def run(self):
98 if not self.executor:
99 self.executor = pilot.ExecutorSwig()
100 if self.thr and self.thr.isAlive():
101 return
102 #continue execution mode
103 self.executor.setExecMode(0)
104 #execute it in a thread
105 self.thr = Runner(self, self.executor, self.proc)
106 #as a daemon (no need to join)
107 self.thr.setDaemon(1)
108 #start the thread
109 self.thr.start()
110 time.sleep(0.1)
111 self.resume=0
112
113 def susp(self):
114 """Suspend or resume an executing schema"""
115 if not self.executor:
116 return
117 if not self.thr.isAlive():
118 return
119
120 if self.resume:
121 #continue execution mode
122 self.executor.setExecMode(0)
123 #resume it
124 self.executor.resumeCurrentBreakPoint()
125 self.resume=0
126 else:
127 #step by step execution mode
128 self.executor.setExecMode(1)
129 self.resume=1
130
131 def step(self):
132 """Step on a paused schema"""
133 if not self.executor:
134 self.executor = pilot.ExecutorSwig()
135 if not self.thr or not self.thr.isAlive():
136 #start in step by step mode
137 self.executor.setExecMode(1)
138 self.thr = Runner(self, self.executor, self.proc)
139 self.thr.setDaemon(1)
140 self.thr.start()
141 self.resume=1
142 return
143
144 #step by step execution mode
145 self.resume=1
146 self.executor.setExecMode(1)
147 #resume it
148 self.executor.resumeCurrentBreakPoint()
149
150 def stop(self):
151 """Stop the schema"""
152 if not self.executor:
153 return
154 if not self.thr.isAlive():
155 return
156 self.executor.setExecMode(1)
157 self.executor.waitPause()
158 self.executor.resumeCurrentBreakPoint()
159 #self.executor.stopExecution()
160
162 """
163 Appli()
164 Cree la fenetre principale de l'interface utilisateur
165 """
166 def __init__(self):
167 QMainWindow.__init__(self)
168 self.createWidgets()
169 self.initActions()
170 self.initMenus()
171 self.initToolbar()
172 self.initStatusbar()
173 self.initYACS()
174
175 def createWidgets(self):
176 self.tabWidget = QTabWidget(self)
177 self.currentPanel=None
178 self.connect(self.tabWidget, SIGNAL('currentChanged(QWidget *)'),self.handlePanelChanged)
179 self.setCentralWidget(self.tabWidget)
180 self.resize(800,600)
181
182 def handlePanelChanged(self,panel):
183 self.currentPanel=panel
184
185 def initActions(self):
186 self.actions = []
187
188 self.newAct=QAction('New', QIconSet(Icons.get_image("new")), '&New',
189 QKeySequence("CTRL+N"),self)
190 self.newAct.setStatusTip('Open an empty editor window')
191 self.newAct.setWhatsThis( """<b>New</b>"""
192 """<p>An empty editor window will be created.</p>""")
193 self.newAct.connect(self.newAct,SIGNAL('activated()'), self.newProc)
194 self.actions.append(self.newAct)
195
196 self.prefAct=QAction('Preferences',QIconSet(Icons.get_image("configure.png")),'&Preferences...',
197 0, self)
198 self.prefAct.setStatusTip('Set the prefered configuration')
199 self.prefAct.setWhatsThis("""<b>Preferences</b>"""
200 """<p>Set the configuration items of the application"""
201 """ with your prefered values.</p>""")
202 self.prefAct.connect(self.prefAct,SIGNAL('activated()'), self.handlePreferences)
203 self.actions.append(self.prefAct)
204
205 self.runAct=QAction('Run',QIconSet(Icons.get_image("run.png")),'&Run',0,self)
206 self.runAct.connect(self.runAct,SIGNAL('activated()'), self.run)
207 self.runAct.setStatusTip('Run the selected schema')
208 self.actions.append(self.runAct)
209
210 self.suspAct=QAction('Suspend/resume',QIconSet(Icons.get_image("suspend-resume.gif")),'&Suspend/resume',0,self)
211 self.suspAct.connect(self.suspAct,SIGNAL('activated()'), self.susp)
212 self.suspAct.setStatusTip('Suspend/resume the selected schema')
213 self.actions.append(self.suspAct)
214
215 self.stepAct=QAction('Step',QIconSet(Icons.get_image("steps.png")),'&Step',0,self)
216 self.stepAct.connect(self.stepAct,SIGNAL('activated()'), self.step)
217 self.stepAct.setStatusTip('Step the selected schema')
218 self.actions.append(self.stepAct)
219
220 self.stopAct=QAction('Stop',QIconSet(Icons.get_image("kill.png")),'&Stop',0,self)
221 self.stopAct.connect(self.stopAct,SIGNAL('activated()'), self.stop)
222 self.stopAct.setStatusTip('Stop the selected schema')
223 self.actions.append(self.stopAct)
224
225 self.cataToolAct=QAction('Catalog Tool',0,self,"catatool")
226 self.cataToolAct.connect(self.cataToolAct,SIGNAL('activated()'), self.cata_tool)
227 self.actions.append(self.cataToolAct)
228
229 def initMenus(self):
230 menubar = self.menuBar()
231
232 #menu file
233 self.fileMenu=QPopupMenu(self)
234 self.newAct.addTo(self.fileMenu)
235 self.fileMenu.insertItem("&Open", self.openFile)
236 self.fileMenu.insertItem("&Open Salome", self.openSalomeFile)
237 self.loadersMenu = QPopupMenu(self)
238 self.fileMenu.insertItem("Loaders", self.loadersMenu)
239 self.loaders=[]
240 for file in glob.glob("/local/chris/SALOME2/SUPERV/YACS/BR_CC/YACS_SRC/src/pyqt/*loader.py"):
241 d,f=os.path.split(file)
242 name=f[:-9]
243 def call_loader(event,obj=self,file=file):
244 obj.openFileWithLoader(file)
245 self.loaders.append(call_loader)
246 self.loadersMenu.insertItem(name, call_loader)
247 menubar.insertItem('&File',self.fileMenu)
248
249 #menu settings
250 self.settingsMenu = QPopupMenu(self)
251 menubar.insertItem('&Settings', self.settingsMenu)
252 self.settingsMenu.insertTearOffHandle()
253 self.prefAct.addTo(self.settingsMenu)
254
255 #menu Edit
256 self.editMenu = QPopupMenu(self)
257 self.editMenu.insertItem("&Add node", self.addNode)
258 menubar.insertItem('&Edit', self.editMenu)
259
260 #menu Canvas
261 #sous menu layout
262 self.layoutMenu = QPopupMenu(self)
263 self.layoutMenu.insertItem("&Left Right", self.LR)
264 self.layoutMenu.insertItem("Right Left", self.RL)
265 self.layoutMenu.insertItem("Top Bottom", self.TB)
266 self.layoutMenu.insertItem("Bottom Top", self.BT)
267 self.canvasMenu = QPopupMenu(self)
268 self.canvasMenu.insertItem("&Zoom in", self.zoomIn)
269 self.canvasMenu.insertItem("Zoom &out", self.zoomOut)
270 self.canvasMenu.insertItem("Layout", self.layoutMenu)
271 self.canvasMenu.insertItem("Ortholinks", self.orthoLinks)
272 self.canvasMenu.insertItem("Clearlinks", self.clearLinks)
273 self.canvasMenu.insertItem("&Update", self.updateCanvas)
274 menubar.insertItem('&Canvas', self.canvasMenu)
275
276 #menu window
277 self.windowMenu = QPopupMenu(self)
278 self.cataToolAct.addTo(self.windowMenu)
279 self.windowMenu.insertItem("&Log", self.view_log)
280 menubar.insertItem('&Window', self.windowMenu)
281 self.connect(self.windowMenu, SIGNAL('aboutToShow()'), self.handleWindowMenu)
282
283 #menu help
284 self.help=QPopupMenu(self)
285 menubar.insertItem('&Help',self.help)
286 self.help.insertItem('&About',self.about,Qt.Key_F1)
287 self.help.insertItem('About &Qt',self.aboutQt)
288
289 def initYACS(self):
290 import pilot
291 import loader
292 import salomeloader
293 self.runtime= pilot.getRuntime()
294 self.loader = loader.YACSLoader()
295 self.executor = pilot.ExecutorSwig()
296 self.salomeloader=salomeloader.SalomeLoader()
297 self.loader.registerProcCataLoader()
298
299 def openSalomeFile(self):
300 fn = QFileDialog.getOpenFileName(QString.null,QString.null,self)
301 if fn.isEmpty():
302 self.statusBar().message('Loading aborted',2000)
303 return
304 fileName = str(fn)
305 proc=self.salomeloader.load(fileName)
306 logger=proc.getLogger("parser")
307 if logger.hasErrors():
309 self.logFile.text.setText(logger.getStr())
310 self.logFile.show()
311
312 panel=Browser(self.tabWidget,proc)
313 self.currentPanel=panel
314 self.tabWidget.addTab( panel,os.path.basename(fileName))
315 self.tabWidget.showPage(panel)
316
317 def openFile(self):
318 fn = QFileDialog.getOpenFileName(QString.null,QString.null,self)
319 if fn.isEmpty():
320 self.statusBar().message('Loading aborted',2000)
321 return
322 fileName = str(fn)
323 proc=self.loader.load(fileName)
324 logger=proc.getLogger("parser")
325 if logger.hasErrors():
327 self.logFile.text.setText(logger.getStr())
328 self.logFile.show()
329
330 panel=Browser(self.tabWidget,proc)
331 self.currentPanel=panel
332 self.tabWidget.addTab( panel,os.path.basename(fileName))
333 self.tabWidget.showPage(panel)
334
335 def newProc(self):
336 r=pilot.getRuntime()
337 proc=r.createProc("pr")
338 panel=Browser(self.tabWidget,proc)
339 self.currentPanel=panel
340 self.tabWidget.addTab( panel,proc.getName())
341 self.tabWidget.showPage(panel)
342
343 def openFileWithLoader(self,file):
344 d,f=os.path.split(file)
345 sys.path.insert(0,d)
346 module=__import__(os.path.splitext(f)[0])
347 del sys.path[0]
348 loader=module.Loader()
349
350 fn = QFileDialog.getOpenFileName(QString.null,QString.null,self)
351 if fn.isEmpty():
352 self.statusBar().message('Loading aborted',2000)
353 return
354 fileName = str(fn)
355 proc=loader.load(fileName)
356 logger=proc.getLogger("parser")
357 if logger.hasErrors():
359 self.logFile.text.setText(logger.getStr())
360 self.logFile.show()
361
362 panel=Browser(self.tabWidget,proc)
363 self.currentPanel=panel
364 self.tabWidget.addTab( panel,os.path.basename(fileName))
365 self.tabWidget.showPage(panel)
366
367 def cata_tool(self):
369 self.catalogTool.show()
370 return
371
372 def view_log(self):
373 if self.currentPanel:
375
376 def LR(self,*args ):self.rankdir("LR")
377 def RL(self,*args ):self.rankdir("RL")
378 def TB(self,*args ):self.rankdir("TB")
379 def BT(self,*args ):self.rankdir("BT")
380
381 def rankdir(self,orient):
382 if self.currentPanel and self.currentPanel.panelManager.visible:
383 self.currentPanel.panelManager.visible.layout(orient)
384
385 def updateCanvas(self):
386 if self.currentPanel.selected:#item selected
387 if isinstance(self.currentPanel.selected,Items.ItemComposedNode):
388 #can update
389 self.currentPanel.selected.graph.editor.updateCanvas()
390
391 def addNode(self,node):
392 if self.currentPanel and self.currentPanel.selected:#item selected
393 if isinstance(self.currentPanel.selected,Items.ItemComposedNode):
394 #can add node
395 self.currentPanel.selected.addNode(node)
396
397 def zoomIn(self):
398 if self.currentPanel and self.currentPanel.panelManager.visible:
399 if isinstance(self.currentPanel.panelManager.visible,Items.ItemComposedNode):
400 #we can zoom
401 self.currentPanel.panelManager.visible.graph.editor.zoomIn()
402
403 def zoomOut(self):
404 if self.currentPanel and self.currentPanel.panelManager.visible:
405 if isinstance(self.currentPanel.panelManager.visible,Items.ItemComposedNode):
406 #we can unzoom
407 self.currentPanel.panelManager.visible.graph.editor.zoomOut()
408
409 def orthoLinks(self):
410 if self.currentPanel and self.currentPanel.panelManager.visible:
411 if isinstance(self.currentPanel.panelManager.visible,Items.ItemComposedNode):
412 #it is a composed node with a graph
413 self.currentPanel.panelManager.visible.graph.orthoLinks()
414
415 def clearLinks(self):
416 if self.currentPanel and self.currentPanel.panelManager.visible:
417 if isinstance(self.currentPanel.panelManager.visible,Items.ItemComposedNode):
418 #it is a composed node with a graph
419 self.currentPanel.panelManager.visible.graph.clearLinks()
420
422 pass
423
425 pass
426
427 def about(self):
428 QMessageBox.about(self,'YACS browser GUI', 'YACS browser GUI')
429
430 def aboutQt(self):
431 QMessageBox.aboutQt(self,'YACS browser GUI')
432
433 def run(self):
434 if self.currentPanel:
435 self.currentPanel.run()
436
437 def susp(self):
438 if self.currentPanel:
439 self.currentPanel.susp()
440
441 def step(self):
442 if self.currentPanel:
443 self.currentPanel.step()
444
445 def stop(self):
446 if self.currentPanel:
447 self.currentPanel.stop()
448
449 def initToolbar(self):
450 tb = QToolBar(self)
451 self.newAct.addTo(tb)
452 self.runAct.addTo(tb)
453 self.suspAct.addTo(tb)
454 self.stepAct.addTo(tb)
455 self.stopAct.addTo(tb)
456 self.toolbars={}
457 self.toolbars['File']=tb
458
459 def initStatusbar(self):
460 sb = self.statusBar()
461 self.SBfile=QLabel(sb)
462 sb.addWidget(self.SBfile)
463 QWhatsThis.add(self.SBfile,
464 """<p>Partie de la statusbar qui donne le nom"""
465 """du fichier courant. </p>""")
466 self.SBfile.setText("")
467
468
469if __name__ == "__main__":
470 from .Item import Item
471 app = QApplication(sys.argv)
473 t.objectBrowser.additem(Item("item1"))
474 n=t.objectBrowser.additem(Item("item2"))
475 n.additem(Item("item3"))
476 app.setMainWidget(t)
477 t.show()
478 app.exec_loop()
479
480
def LR(self, *args)
Definition: Appli.py:376
def cata_tool(self)
Definition: Appli.py:367
def addNode(self, node)
Definition: Appli.py:391
def step(self)
Definition: Appli.py:441
def initMenus(self)
Definition: Appli.py:229
def TB(self, *args)
Definition: Appli.py:378
def susp(self)
Definition: Appli.py:437
Definition: Appli.py:409
Definition: Appli.py:185
Definition: Appli.py:449
def zoomIn(self)
Definition: Appli.py:397
def handleWindowMenu(self)
Definition: Appli.py:424
def newProc(self)
Definition: Appli.py:335
def initYACS(self)
Definition: Appli.py:289
def openFile(self)
Definition: Appli.py:317
def zoomOut(self)
Definition: Appli.py:403
def handlePreferences(self)
Definition: Appli.py:421
def openFileWithLoader(self, file)
Definition: Appli.py:343
Definition: Appli.py:415
def stop(self)
Definition: Appli.py:445
def RL(self, *args)
Definition: Appli.py:377
def about(self)
Definition: Appli.py:427
def __init__(self)
Definition: Appli.py:166
def BT(self, *args)
Definition: Appli.py:379
Definition: Appli.py:175
Definition: Appli.py:459
def aboutQt(self)
Definition: Appli.py:430
def rankdir(self, orient)
Definition: Appli.py:381
Definition: Appli.py:299
def run(self)
Definition: Appli.py:433
Definition: Appli.py:385
def handlePanelChanged(self, panel)
Definition: Appli.py:182
def view_log(self)
Definition: Appli.py:372
def __init__(self, parent, proc)
Definition: Appli.py:63
def view_log(self)
Definition: Appli.py:81
def onSelect(self, item)
Definition: Appli.py:89
def stop(self)
Definition: Appli.py:150
def onDblSelect(self, item)
Definition: Appli.py:85
def susp(self)
Definition: Appli.py:113
def step(self)
Definition: Appli.py:131
def customEvent(self, ev)
Definition: Appli.py:93
def run(self)
Definition: Appli.py:97
def __init__(self, caption, msg)
def process(self, parent)
def __init__(self, parent, executor, proc)
Definition: Appli.py:49
def run(self)
Definition: Appli.py:55
