Items.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20import sys
21import pilot
22import SALOMERuntime
23from . import Item
24from . import adapt
25from qt import *
26from qtcanvas import *
27from . import Editor
28from . import CItems
29import pygraphviz
30import traceback
31from . import CONNECTOR
32from . import graph
33from . import panels
34
36 def __init__(self,pin,pout):
37 Item.Item.__init__(self)
38 self.pin=pin
39 self.pout=pout
40 self.labellabel= pout.getNode().getName()+":"+pout.getName()+"->"+pin.getNode().getName()+":"+pin.getName()
41
42 def getIconName(self):
43 return "datalink.png"
44
46 def __init__(self,pin,pout):
47 Item.Item.__init__(self)
48 self.pin=pin
49 self.pout=pout
50 self.labellabel= pout.getNode().getName()+":"+pout.getName()+"->"+pin.getNode().getName()+":"+pin.getName()
51
52 def getIconName(self):
53 return "streamlink.png"
54
56 def __init__(self,nodeup,nodedown):
57 Item.Item.__init__(self)
58 self.nodedown=nodedown
59 self.nodeup=nodeup
60 self.labellabel= nodeup.getName()+"->"+nodedown.getName()
61
62 def getIconName(self):
63 return "controllink.png"
64
66 """Item for all control links of a composed node"""
67 def __init__(self,item):
68 Item.Item.__init__(self)
69 self.item=item
70 self.labellabel="Control Links"
71
72 def getIconName(self):
73 return "folder"
74 def isExpandable(self):
75 return True
76
77 def getChildren(self):
78 sublist=[]
79 for n in self.item.node.edGetDirectDescendants():
80 for p in n.getOutNodes():
81 sublist.append(ControlLinkItem(n,p))
82 return sublist
83
84 def addLink(self,link):
85 CONNECTOR.Emit(self,"add",link)
86
88 """Item for all data links of a composed node"""
89 def __init__(self,item):
90 Item.Item.__init__(self)
91 self.item=item
92 self.labellabel="Data Links"
93
94 def getIconName(self):
95 return "folder"
96 def isExpandable(self):
97 return True
98
99 def getChildren(self):
100 sublist=[]
101 for pout,pin in self.item.node.getSetOfInternalLinks():
102 if pout.getNode().getFather() != self.item.node and pin.getNode().getFather() != self.item.node:
103 continue
104 if isinstance(pin,pilot_InputDataStreamPort):
105 sublist.append(StreamLinkItem(pin,pout))
106 else:
107 sublist.append(DataLinkItem(pin,pout))
108 #for pout,pin in self.item.node.getSetOfLinksLeavingCurrentScope():
109 # sublist.append(DataLinkItem(pin,pout))
110 #for pin,pout in self.item.node.getSetOfLinksComingInCurrentScope():
111 # sublist.append(DataLinkItem(pin,pout))
112 return sublist
113
114 def addLink(self,link):
115 CONNECTOR.Emit(self,"add",link)
116
118 """Item pour les noeuds composes"""
119 n=0
120 def __init__(self,node):
121 #node is an instance of YACS::ENGINE::ComposedNode
122 Item.Item.__init__(self)
123 self.node=node
124 self.graph=None
125 self.labellabel=node.getName()
128
129 def isExpandable(self):
130 return True
131
132 def getChildren(self):
133 #liste des noeuds fils
134 liste=self.node.edGetDirectDescendants()
135 #On les adapte en item avant de les retourner
136 sublist=[]
137 for n in liste:
138 try:
139 sublist.append(Item.adapt(n))
140 except:
141 #print n
142 #traceback.print_exc()
143 raise
144 sublist.append(self.datalinks)
145 sublist.append(self.controllinks)
146 return sublist
147
148 def dblselected(self):
149 #print "ItemComposedNode dblselected"
150 root=self.node.getRootNode()
151 rootItem=Item.adapt(root)
152 if not self.emittingemitting:
154 CONNECTOR.Emit(rootItem,"dblselected",self)
155 self.emittingemitting=0
156
157 def selected(self):
158 #print "ItemComposedNode selected"
159 root=self.node.getRootNode()
160 rootItem=Item.adapt(root)
161 if not self.emittingemitting:
162 self.emittingemitting=1
163 CONNECTOR.Emit(rootItem,"selected",self)
164 self.emittingemitting=0
165
166 def getIconName(self):
167 return "green-los"
168
169 def panel(self,parent):
170 """Retourne un tab widget pour browser/editer la proc"""
171 tabWidget = QTabWidget( parent )
172 for name,method in self.panels:
173 tabWidget.addTab( method(self,tabWidget), name )
174 return tabWidget
175
176 def addNode(self,service):
177 print("Composed.addNode",service)
178 #add node service in the parent self which is a ComposedNode
179 new_node=service.clone(None)
180 ItemComposedNode.n=ItemComposedNode.n+1
181 name=service.getName()+"_%d" % ItemComposedNode.n
182 new_node.setName(name)
183 self.node.edAddChild(new_node)
184 item=Item.adapt(new_node)
185 CONNECTOR.Emit(self,"add",item)
186
187 def panel1(self,parent):
188 qvbox=QVBox(parent)
189 self.graph=graph.Graph(self,qvbox)
190 return qvbox
191
192 def layout(self,rankdir):
193 if self.graph:
194 self.graph.layout(rankdir)
195
196 panels=[("Panel1",panel1)]
197
198 def addLink(self,link):
199 print("Composed.addLink",link)
200 if isinstance(link,DataLinkItem):
201 self.datalinks.addLink(link)
202 elif isinstance(link,StreamLinkItem):
203 self.datalinks.addLink(link)
204 else:
205 self.controllinks.addLink(link)
206
207
209 def box(self,parent):
210 return panels.PanelForLoop(parent,self)
211
212 def addNode(self,service):
213 new_node=service.clone(None)
214 ItemComposedNode.n=ItemComposedNode.n+1
215 name=service.getName()+"_%d" % ItemComposedNode.n
216 new_node.setName(name)
217 #replace the old node (if it exists) with the new one
218 nodes=self.node.edGetDirectDescendants()
219 if nodes:
220 old_item=Item.adapt(nodes[0])
221 CONNECTOR.Emit(old_item,"remove")
222 self.node.edSetNode(new_node)
223 item=Item.adapt(new_node)
224 CONNECTOR.Emit(self,"add",item)
225 CONNECTOR.Emit(self,"changed")
226
228 pass
229
230class ItemForEach(ItemForLoop):
231 pass
232
234 def addNode(self,service):
235 return
236
237class ItemProc(ItemComposedNode):
238 """Item pour la procedure"""
239 def connecting(self,item):
240 print("ItemProc.connecting",item)
241 self._connecting=item
242
244 """Item pour les ports """
245 panels=[]
246 def __init__(self,port,root=None):
247 Item.Item.__init__(self)
248 self.port=port
249 self.labellabel=port.getName()
250 if root:
251 self.root=root
252 elif self.port.getNode().getFather():
253 root=self.port.getNode().getRootNode()
254 self.root=Item.adapt(root)
255 else:
256 self.root=None
257
258 def selected(self):
259 #print "ItemPort selected"
260 if not self.root:
261 return
262 if not self.emittingemitting:
264 CONNECTOR.Emit(self.root,"selected",self)
265 self.emittingemitting=0
266
267 def getIconName(self):
268 return "port.png"
269
270 def panel(self,parent):
271 """Retourne un tab widget pour browser/editer l'item"""
272 tabWidget = QTabWidget( parent )
273 for name,method in self.panels:
274 tabWidget.addTab( method(self,tabWidget), name )
275 return tabWidget
276 box=panel
277
278 def link(self,other):
279 print("ItemPort.link:",self,other)
280
281 def connect(self):
282 print("ItemPort.connect:")
283 self.root.connecting(self)
284
286 def getIconName(self):
287 return "inport.png"
288
289 def panel1(self,parent):
290 return panels.PanelInPort(parent,self)
291
292 panels=[("Panel1",panel1)]
293
295 def getIconName(self):
296 return "outport.png"
297
298 def panel1(self,parent):
299 return panels.PanelOutPort(parent,self)
300
301 panels=[("Panel1",panel1)]
302
303 def link(self,other):
304 nodeS=self.port.getNode()
305 nodeE=other.port.getNode()
306 father=nodeS.getFather()
307 if father != nodeE.getFather():
308 #not same father : do nothing for the moment
309 return
310 try:
311 #cflink=nodeS.getOutGate().isAlreadyInSet(nodeE.getInGate())
312 cflink= nodeE.getInGate() in nodeS.getOutGate().edSetInGate()
313 father.edAddDFLink(self.port,other.port)
314 l=DataLinkItem(other.port,self.port)
315 fitem=Item.adapt(father)
316 fitem.addLink(l)
317 if not cflink:
318 #add also a control flow link
319 fitem.addLink(ControlLinkItem(nodeS,nodeE))
320 except ValueError as ex:
321 traceback.print_exc()
322 QMessageBox.warning(None,"YACS error",str(ex))
323 return
324
326 def getIconName(self):
327 return "instream.png"
328
330 def getIconName(self):
331 return "outstream.png"
332
333 def link(self,other):
334 father=self.port.getNode().getFather()
335 if father != other.port.getNode().getFather():
336 #not same father : not for the moment
337 return
338 try:
339 father.edAddLink(self.port,other.port)
340 l=StreamLinkItem(other.port,self.port)
341 fitem=Item.adapt(father)
342 fitem.addLink(l)
343 except ValueError as ex:
344 traceback.print_exc()
345 QMessageBox.warning(None,"YACS error",str(ex))
346 return
347
349 """Item for InGate"""
350 def __init__(self,port):
351 Item.Item.__init__(self)
352 self.portport=port
354 """Item for OutGate"""
355 def __init__(self,port):
356 Item.Item.__init__(self)
357 self.portport=port
358
360 """Item pour les noeuds elementaires
361 Il n a pas de fils
362 """
363 #attr donnant la liste des panels du noeud (nom,method)
364 panels=[]
365 def __init__(self,node):
366 Item.Item.__init__(self)
367 self.node=node
368 self.labellabel=node.getName()
369 self.fatherfather=Item.adapt(node.getFather())
370
371 def selected(self):
372 #print "ItemNode selected"
373 root=self.node.getRootNode()
374 rootItem=Item.adapt(root)
375 if not self.emittingemitting:
377 #for those that have subscribed to item level
378 CONNECTOR.Emit(self,"selected",self)
379 #for those that have subscribed to rootItem level
380 CONNECTOR.Emit(rootItem,"selected",self)
381 self.emittingemitting=0
382
383 def isExpandable(self):
384 return True
385
386 def getChildren(self):
387 sublist=[]
388 for n in self.node.getSetOfInputPort():
389 sublist.append(Item.adapt(n))
390 for n in self.node.getSetOfOutputPort():
391 sublist.append(Item.adapt(n))
392 for n in self.node.getSetOfInputDataStreamPort():
393 sublist.append(Item.adapt(n))
394 for n in self.node.getSetOfOutputDataStreamPort():
395 sublist.append(Item.adapt(n))
396 return sublist
397
398 def panel(self,parent):
399 """Retourne un tab widget pour browser/editer l'item"""
400 tabWidget = QTabWidget( parent )
401 for name,method in self.panels:
402 tabWidget.addTab( method(self,tabWidget), name )
403 return tabWidget
404 box=panel
405
407
408 def panel1(self,parent):
409 return panels.PanelScript(parent,self)
410
411 panels=[("Panel1",panel1)]
412
413 def getIconName(self):
414 return "green-ball"
415
417 def panel1(self,parent):
418 return panels.PanelFunc(parent,self)
419
420 panels=[("Panel1",panel1)]
421
422 def getIconName(self):
423 return "green-ball"
424
425 def FuncChanged(self, newText ):
426 self.myFunc=str(newText)
427
429 def panel1(self,parent):
430 """Retourne un widget pour browser/editer l'item"""
431 self.myName=self.node.getName()
432
433 qvbox=QVBox(parent)
434 qvbox.layout().setAlignment(Qt.AlignTop|Qt.AlignLeft)
435 qvbox.setSpacing( 5 )
436
437 row0=QHBox(qvbox)
438 label=QLabel("Name: ",row0)
439 self.lined0 = QLineEdit(self.node.getName(),row0)
440 qvbox.connect( self.lined0, SIGNAL("textChanged(const QString &)"), self.NameChanged )
441 qvbox.connect( self.lined0, SIGNAL("returnPressed()"), self.NameReturn )
442 QToolTip.add( self.lined0, "Node name" )
443
444 row1=QHBox(qvbox)
445 label1=QLabel("Ref: ",row1)
446 self.lined1 = QLineEdit(row1)
447 if self.node.getComponent():
448 self.lined1.setText(self.node.getComponent().getName())
449 else:
450 self.lined1.setText("NO_COMPONENT_NAME")
451
452 row2=QHBox(qvbox)
453 label2=QLabel("Method: ",row2)
454 self.lined2 = QLineEdit(row2)
455 self.lined2.setText(self.node.getMethod())
456
457 row3=QHBox(qvbox)
458 but1=QPushButton( "Save", row3 )
459 but2=QPushButton( "Cancel", row3 )
460 qvbox.connect( but1, SIGNAL("clicked()"), self.handleSave )
461 qvbox.connect( but2, SIGNAL("clicked()"), self.handleCancel )
462
463 return qvbox
464
465 panels=[("Panel1",panel1)]
466
467 def NameChanged(self, newText ):
468 self.myName=str(newText)
469
470 def NameReturn(self):
471 pass
472
473 def getIconName(self):
474 return "green-square"
475
476 def handleSave(self):
477 self.node.setRef(str(self.lined1.text()))
478 self.node.setMethod(str(self.lined2.text()))
479 def handleCancel(self):
480 self.lined0.setText(self.node.getName())
481 self.lined1.setText(self.node.getComponent().getName())
482 self.lined2.setText(self.node.getMethod())
483
484def adapt_Proc_to_Item(obj, protocol, alternate):
485 return ItemProc(obj)
486
487def adapt_Node_to_Item(obj, protocol, alternate):
488 return ItemNode(obj)
489
490def adapt_ComposedNode_to_Item(obj, protocol, alternate):
491 return ItemComposedNode(obj)
492
493def adapt_ForLoop_to_Item(obj, protocol, alternate):
494 return ItemForLoop(obj)
495
496def adapt_Switch_to_Item(obj, protocol, alternate):
497 return ItemSwitch(obj)
498
499def adapt_While_to_Item(obj, protocol, alternate):
500 return ItemWhile(obj)
501
502def adapt_ForEach_to_Item(obj, protocol, alternate):
503 return ItemForEach(obj)
504
505def adapt_InlineFuncNode_to_Item(obj, protocol, alternate):
506 return ItemFuncNode(obj)
507
508def adapt_InlineScriptNode_to_Item(obj, protocol, alternate):
509 return ItemScriptNode(obj)
510
511def adapt_ServiceNode_to_Item(obj, protocol, alternate):
512 return ItemService(obj)
513
514def adapt_Port_to_Item(obj, protocol, alternate):
515 return ItemPort(obj)
516
517def adapt_InPort_to_Item(obj, protocol, alternate):
518 return ItemInPort(obj)
519
520def adapt_OutPort_to_Item(obj, protocol, alternate):
521 return ItemOutPort(obj)
522
523def adapt_InStream_to_Item(obj, protocol, alternate):
524 return ItemInStream(obj)
525
526def adapt_OutStream_to_Item(obj, protocol, alternate):
527 return ItemOutStream(obj)
528
529def adapt_InGate_to_Item(obj, protocol, alternate):
530 return ItemInGate(obj)
531
532def adapt_OutGate_to_Item(obj, protocol, alternate):
533 return ItemOutGate(obj)
534
535if hasattr(pilot,"ProcPtr"):
536 #SWIG 1.3.24
537 adapt.registerAdapterFactory(pilot.ProcPtr, Item.Item, adapt_Proc_to_Item)
538 adapt.registerAdapterFactory(pilot.BlocPtr, Item.Item, adapt_ComposedNode_to_Item)
539 adapt.registerAdapterFactory(pilot.ForLoopPtr, Item.Item, adapt_ComposedNode_to_Item)
540 adapt.registerAdapterFactory(pilot.WhileLoopPtr, Item.Item, adapt_ComposedNode_to_Item)
541 adapt.registerAdapterFactory(pilot.ForEachLoopPtr, Item.Item, adapt_ComposedNode_to_Item)
542 adapt.registerAdapterFactory(pilot.SwitchPtr, Item.Item, adapt_ComposedNode_to_Item)
543 adapt.registerAdapterFactory(pilot.ComposedNodePtr, Item.Item, adapt_ComposedNode_to_Item)
544
545 adapt.registerAdapterFactory(pilot.ServiceNodePtr, Item.Item, adapt_ServiceNode_to_Item)
546 #adapt.registerAdapterFactory(pilot.ServiceNodeNodePtr, Item.Item, adapt_Node_to_Item)
547 adapt.registerAdapterFactory(pilot.InlineNodePtr, Item.Item, adapt_InlineScriptNode_to_Item)
548 adapt.registerAdapterFactory(pilot.InlineFuncNodePtr, Item.Item, adapt_InlineFuncNode_to_Item)
549 adapt.registerAdapterFactory(pilot.NodePtr, Item.Item, adapt_Node_to_Item)
550
551 adapt.registerAdapterFactory(pilot.OutputPortPtr, Item.Item, adapt_OutPort_to_Item)
552 adapt.registerAdapterFactory(pilot.InputPortPtr, Item.Item, adapt_InPort_to_Item)
553 adapt.registerAdapterFactory(pilot.OutputDataStreamPortPtr, Item.Item, adapt_OutStream_to_Item)
554 adapt.registerAdapterFactory(pilot.InputDataStreamPortPtr, Item.Item, adapt_InStream_to_Item)
555
556 pilot_InputDataStreamPort=pilot.InputDataStreamPortPtr
557
558else:
559 #SWIG 1.3.29
560 adapt.registerAdapterFactory(pilot.Proc, Item.Item, adapt_Proc_to_Item)
561 adapt.registerAdapterFactory(SALOMERuntime.SalomeProc, Item.Item, adapt_Proc_to_Item)
562 adapt.registerAdapterFactory(pilot.Bloc, Item.Item, adapt_ComposedNode_to_Item)
563 adapt.registerAdapterFactory(pilot.ForLoop, Item.Item, adapt_ForLoop_to_Item)
564
565 adapt.registerAdapterFactory(pilot.WhileLoop, Item.Item, adapt_While_to_Item)
566 adapt.registerAdapterFactory(pilot.ForEachLoop, Item.Item, adapt_ForEach_to_Item)
567 adapt.registerAdapterFactory(pilot.Switch, Item.Item, adapt_Switch_to_Item)
568 adapt.registerAdapterFactory(pilot.ComposedNode, Item.Item, adapt_ComposedNode_to_Item)
569
570 adapt.registerAdapterFactory(pilot.ServiceNode, Item.Item, adapt_ServiceNode_to_Item)
571 adapt.registerAdapterFactory(SALOMERuntime.CORBANode, Item.Item, adapt_ServiceNode_to_Item)
572 adapt.registerAdapterFactory(SALOMERuntime.SalomeNode, Item.Item, adapt_ServiceNode_to_Item)
573 #adapt.registerAdapterFactory(pilot.ServiceNodeNode, Item.Item, adapt_Node_to_Item)
574 adapt.registerAdapterFactory(pilot.InlineNode, Item.Item, adapt_InlineScriptNode_to_Item)
575 adapt.registerAdapterFactory(SALOMERuntime.PythonNode, Item.Item, adapt_InlineScriptNode_to_Item)
576 adapt.registerAdapterFactory(pilot.InlineFuncNode, Item.Item, adapt_InlineFuncNode_to_Item)
577 adapt.registerAdapterFactory(SALOMERuntime.PyFuncNode, Item.Item, adapt_InlineFuncNode_to_Item)
578 adapt.registerAdapterFactory(pilot.Node, Item.Item, adapt_Node_to_Item)
579
580 adapt.registerAdapterFactory(pilot.OutputPort, Item.Item, adapt_OutPort_to_Item)
581 adapt.registerAdapterFactory(SALOMERuntime.OutputPyPort, Item.Item, adapt_OutPort_to_Item)
582 adapt.registerAdapterFactory(SALOMERuntime.OutputCorbaPort, Item.Item, adapt_OutPort_to_Item)
583 adapt.registerAdapterFactory(pilot.InputPort, Item.Item, adapt_InPort_to_Item)
584 adapt.registerAdapterFactory(SALOMERuntime.InputPyPort, Item.Item, adapt_InPort_to_Item)
585 adapt.registerAdapterFactory(SALOMERuntime.InputCorbaPort, Item.Item, adapt_InPort_to_Item)
586 adapt.registerAdapterFactory(pilot.OutputDataStreamPort, Item.Item, adapt_OutStream_to_Item)
587 adapt.registerAdapterFactory(pilot.InputDataStreamPort, Item.Item, adapt_InStream_to_Item)
588 adapt.registerAdapterFactory(pilot.OutGate, Item.Item, adapt_OutGate_to_Item)
589 adapt.registerAdapterFactory(pilot.InGate, Item.Item, adapt_InGate_to_Item)
590
591 pilot_InputDataStreamPort=pilot.InputDataStreamPort
def father(self)
Definition: Item.py:35
def __init__(self, nodeup, nodedown)
Definition: Items.py:56
Definition: Items.py:62
Definition: Items.py:77
def __init__(self, item)
Definition: Items.py:67
def addLink(self, link)
Definition: Items.py:84
Definition: Items.py:72
Definition: Items.py:74
def __init__(self, pin, pout)
Definition: Items.py:36
Definition: Items.py:42
Definition: Items.py:96
Definition: Items.py:99
Definition: Items.py:114
Definition: Items.py:89
Definition: Items.py:94
def layout(self, rankdir)
Definition: Items.py:192
def __init__(self, node)
Definition: Items.py:120
def panel1(self, parent)
Definition: Items.py:187
def panel(self, parent)
Definition: Items.py:169
Definition: Items.py:198
def addNode(self, service)
Definition: Items.py:176
Definition: Items.py:129
def box(self, parent)
Definition: Items.py:209
Definition: Items.py:212
Definition: Items.py:422
def FuncChanged(self, newText)
Definition: Items.py:425
Definition: Items.py:417
def __init__(self, port)
Definition: Items.py:350
Definition: Items.py:289
Definition: Items.py:286
Definition: Items.py:326
Definition: Items.py:398
Definition: Items.py:383
Definition: Items.py:365
Definition: Items.py:386
def selected(self)
Definition: Items.py:371
Definition: Items.py:355
Definition: Items.py:298
Definition: Items.py:295
def link(self, other)
Definition: Items.py:303
Definition: Items.py:333
Definition: Items.py:330
Definition: Items.py:278
def __init__(self, port, root=None)
Definition: Items.py:246
Definition: Items.py:270
def connect(self)
Definition: Items.py:281
def selected(self)
Definition: Items.py:258
Definition: Items.py:267
def connecting(self, item)
Definition: Items.py:239
Definition: Items.py:408
Definition: Items.py:413
def NameChanged(self, newText)
Definition: Items.py:467
Definition: Items.py:479
Definition: Items.py:429
Definition: Items.py:473
Definition: Items.py:476
Definition: Items.py:470
Definition: Items.py:234
Definition: Items.py:52
Definition: Items.py:517
Definition: Items.py:514
Definition: Items.py:508
Definition: Items.py:523
Definition: Items.py:493
Definition: Items.py:505
Definition: Items.py:532
Definition: Items.py:502
Definition: Items.py:520
Definition: Items.py:496
Definition: Items.py:526
Definition: Items.py:511
Definition: Items.py:499
Definition: Items.py:484
Definition: Items.py:529
Definition: Items.py:490
Definition: Items.py:487
