panels.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20from qt import *
21import traceback
22from . import Editor
23from . import Item
24
26 def __init__(self,parent,item):
27 QVBox.__init__(self,parent)
28 self.item=item
29 self.setSpacing( 5 )
30
31 row0=QHBox(self)
32 label=QLabel("Name: ",row0)
33 self.lined0 = QLineEdit(item.node.getName(),row0)
34
35 label=QLabel("Script: ",self)
36 self.mle=Editor.Editor(self,"multiLineEdit" )
37 self.mle.setText(item.node.getScript())
38
39 row2=QHBox(self)
40 but1=QPushButton( "Save", row2 )
41 but1.setFixedSize( but1.sizeHint())
42 but2=QPushButton( "Cancel", row2 )
43 but2.setFixedSize( but2.sizeHint())
44 self.connect( but1, SIGNAL("clicked()"), self.handleSave )
45 self.connect( but2, SIGNAL("clicked()"), self.handleCancel )
46
47 def handleSave(self):
48 self.item.node.setScript(str(self.mle.text()))
49
50 def handleCancel(self):
51 self.lined0.setText(self.item.node.getName())
52 self.mle.setText(self.item.node.getScript())
53
55 def __init__(self,parent,item):
56 QVBox.__init__(self,parent)
57 self.item=item
58 self.setSpacing( 5 )
59
60 row0=QHBox(self)
61 label=QLabel("Name: ",row0)
62 self.lined0 = QLineEdit(self.item.node.getName(),row0)
63
64 row1=QHBox(self)
65 label=QLabel("Fname: ",row1)
66 self.lined1 = QLineEdit(self.item.node.getFname(),row1)
67
68 label=QLabel("Function: ",self)
69 self.mle=Editor.Editor(self,"multiLineEdit" )
70 self.mle.setText(self.item.node.getScript())
71
72 row2=QHBox(self)
73 but1=QPushButton( "Save", row2 )
74 but1.setFixedSize( but1.sizeHint())
75 but2=QPushButton( "Cancel", row2 )
76 but2.setFixedSize( but2.sizeHint())
77 self.connect( but1, SIGNAL("clicked()"), self.handleSave )
78 self.connect( but2, SIGNAL("clicked()"), self.handleCancel )
79
80 def handleSave(self):
81 self.item.node.setFname(str(self.lined1.text()))
82 self.item.node.setScript(str(self.mle.text()))
83
84 def handleCancel(self):
85 self.lined0.setText(self.item.node.getName())
86 self.lined1.setText(self.item.node.getFname())
87 self.mle.setText(self.item.node.getScript())
88
90 def __init__(self,parent,item):
91 QVBox.__init__(self,parent)
92 self.item=item
93 vsplit=QSplitter(Qt.Vertical,self,"VSplitter")
94 vbox=QVBox(vsplit)
95 vbox.layout().setAlignment(Qt.AlignTop|Qt.AlignLeft)
96
97 row0=QHBox(vbox)
98 label=QLabel("Name: ",row0)
99 self.lined0 = QLineEdit(item.node.getName(),row0)
100
101 #row1=QVBox(self)
102 #self.setStretchFactor(row1,10)
103
104 row2=QHBox(vbox)
105 but1=QPushButton( "Save", row2 )
106 but1.setFixedSize( but1.sizeHint())
107 but2=QPushButton( "Cancel", row2 )
108 but2.setFixedSize( but2.sizeHint())
109 self.connect( but1, SIGNAL("clicked()"), self.handleSave )
110 self.connect( but2, SIGNAL("clicked()"), self.handleCancel )
111
112 nodes= item.node.edGetDirectDescendants()
113 if nodes:
114 node=nodes[0]
115 subitem=Item.adapt(node)
116 panel=subitem.box(vsplit)
117
118 def handleSave(self):
119 return
120 def handleCancel(self):
121 return
122
123class PanelInPort(QVBox):
124 def __init__(self,parent,item):
125 QVBox.__init__(self,parent)
126 self.item=item
127 self.layout().setAlignment(Qt.AlignTop|Qt.AlignLeft)
128 self.setSpacing( 5 )
129 row0=QHBox(self)
130 label=QLabel("Name: ",row0)
131 lined0 = QLineEdit(self.item.port.getName(),row0)
132 label=QLabel("Type: ",row0)
133 QLineEdit(self.item.port.edGetType().name(),row0)
134
135 label=QLabel("Value: ",self)
136 self.value=QTextEdit(self)
137 self.value.setText("Empty")
138 self.handleRestore()
139
140 row3=QHBox(self)
141 but1=QPushButton( "Save", row3 )
142 but1.setFixedSize( but1.sizeHint())
143 self.connect( but1, SIGNAL("clicked()"), self.handleSave )
144 but2=QPushButton( "Restore", row3 )
145 but2.setFixedSize( but2.sizeHint())
146 self.connect( but2, SIGNAL("clicked()"), self.handleRestore )
147
148 def handleSave(self):
149 try:
150 self.item.port.edInitXML(str(self.value.text()))
151 except:
152 traceback.print_exc()
153 self.value.setText(self.item.port.dump())
154
155 def handleRestore(self):
156 if not self.item.port.isEmpty():
157 self.value.setText(self.item.port.dump())
158
160 def handleRestore(self):
161 try:
162 self.value.setText(self.item.port.dump())
163 except:
164 traceback.print_exc()
Definition: panels.py:120
Definition: panels.py:118
def __init__(self, parent, item)
Definition: panels.py:90
Definition: panels.py:84
Definition: panels.py:55
Definition: panels.py:80
Definition: panels.py:148
Definition: panels.py:155
Definition: panels.py:124
Definition: panels.py:160
Definition: panels.py:50
Definition: panels.py:26
Definition: panels.py:47
