YACS::ENGINE::LogRecord Class Reference
Class for logging record. More...
#include <LogRecord.hxx>
Collaboration diagram for YACS::ENGINE::LogRecord:
typedef int LogLevel
 LogRecord (const std::string &name, int level, const std::string &message, const std::string &file, int line)
virtual ~LogRecord ()
virtual std::string getLevelName (int level)
virtual std::string getStr ()
Public Attributes
const std::string _loggerName
const std::string _message
int _level
std::string _fileName
int _line
Static Public Attributes
static const LogLevel FATAL = 50
static const LogLevel ERROR = 40
static const LogLevel WARNING = 30
static const LogLevel INFO = 20
static const LogLevel DEBUG = 10
static const LogLevel NOTSET = 0
Definition at line 32 of file LogRecord.hxx.
◆ LogLevel
Definition at line 35 of file LogRecord.hxx.
◆ LogRecord()
LogRecord::LogRecord ( const std::string &  name,
int  level,
const std::string &  message,
const std::string &  file,
int  line
Definition at line 30 of file LogRecord.cxx.
31 :_loggerName(name),_level(level),_message(message),_fileName(file),_line(line)
32{
33}
Definition: LogRecord.hxx:48
Definition: LogRecord.hxx:46
◆ ~LogRecord()
LogRecord::~LogRecord ( )
Definition at line 35 of file LogRecord.cxx.
36{
37}
◆ getLevelName()
std::string LogRecord::getLevelName ( int  level)
Definition at line 39 of file LogRecord.cxx.
40{
41 switch(level)
42 {
43 case FATAL:
44 return "FATAL";
45 case ERROR:
46 return "ERROR";
47 case WARNING:
48 return "WARNING";
49 case INFO:
50 return "INFO";
51 case DEBUG:
52 return "DEBUG";
53 default:
54 return "NOTSET";
55 }
56}
Definition: LogRecord.hxx:36
Definition: LogRecord.hxx:38
Definition: LogRecord.hxx:40
Definition: LogRecord.hxx:37
Definition: LogRecord.hxx:39
References DEBUG, ERROR, FATAL, INFO, and WARNING.
Referenced by getStr().
◆ getStr()
std::string LogRecord::getStr ( )
Definition at line 58 of file LogRecord.cxx.
59{
60 std::stringstream msg;
61 msg << "LogRecord: " << _loggerName << ":" << getLevelName(_level) << ":" << _message;
62 if(_fileName != "")
63 msg << " (" << _fileName << ":" << _line << ")";
64 return msg.str();
65}
virtual std::string getLevelName(int level)
Definition: LogRecord.cxx:39
References _fileName, _level, _line, _loggerName, _message, and getLevelName().
◆ _fileName
std::string YACS::ENGINE::LogRecord::_fileName
filename of logging record
Definition at line 52 of file LogRecord.hxx.
◆ _level
int YACS::ENGINE::LogRecord::_level
Level of logging record
Definition at line 50 of file LogRecord.hxx.
◆ _line
int YACS::ENGINE::LogRecord::_line
line number of logging record
Definition at line 54 of file LogRecord.hxx.
◆ _loggerName
const std::string YACS::ENGINE::LogRecord::_loggerName
The logger name.
Definition at line 46 of file LogRecord.hxx.
◆ _message
const std::string YACS::ENGINE::LogRecord::_message
The message of logging record
Definition at line 48 of file LogRecord.hxx.
◆ DEBUG
const LogLevel YACS::ENGINE::LogRecord::DEBUG = 10
Definition at line 40 of file LogRecord.hxx.
Referenced by getLevelName().
◆ ERROR
const LogLevel YACS::ENGINE::LogRecord::ERROR = 40
Definition at line 37 of file LogRecord.hxx.
Referenced by YACS::ENGINE::Logger::error(), and getLevelName().
◆ FATAL
const LogLevel YACS::ENGINE::LogRecord::FATAL = 50
Definition at line 36 of file LogRecord.hxx.
Referenced by YACS::ENGINE::Logger::fatal(), and getLevelName().
◆ INFO
const LogLevel YACS::ENGINE::LogRecord::INFO = 20
Definition at line 39 of file LogRecord.hxx.
◆ NOTSET
const LogLevel YACS::ENGINE::LogRecord::NOTSET = 0
Definition at line 41 of file LogRecord.hxx.
◆ WARNING
const LogLevel YACS::ENGINE::LogRecord::WARNING = 30
