LogRecord.cxx
20#include "LogRecord.hxx"
21
22#include <sstream>
23#include <iostream>
24
25//#define _DEVDEBUG_
26#include "YacsTrace.hxx"
27
28using namespace YACS::ENGINE;
30LogRecord::LogRecord(const std::string& name,int level,const std::string& message, const std::string& file, int line)
31 :_loggerName(name),_level(level),_message(message),_fileName(file),_line(line)
32{
33}
34
36{
37}
38
39std::string LogRecord::getLevelName(int level)
40{
41 switch(level)
42 {
43 case FATAL:
44 return "FATAL";
45 case ERROR:
46 return "ERROR";
47 case WARNING:
48 return "WARNING";
49 case INFO:
50 return "INFO";
51 case DEBUG:
52 return "DEBUG";
53 default:
54 return "NOTSET";
55 }
56}
57
58std::string LogRecord::getStr()
59{
60 std::stringstream msg;
61 msg << "LogRecord: " << _loggerName << ":" << getLevelName(_level) << ":" << _message;
62 if(_fileName != "")
63 msg << " (" << _fileName << ":" << _line << ")";
64 return msg.str();
65}
66
const std::string _message
Definition: LogRecord.hxx:48
virtual std::string getStr()
Definition: LogRecord.cxx:58
static const LogLevel FATAL
Definition: LogRecord.hxx:36
static const LogLevel WARNING
Definition: LogRecord.hxx:38
virtual std::string getLevelName(int level)
Definition: LogRecord.cxx:39
static const LogLevel DEBUG
Definition: LogRecord.hxx:40
static const LogLevel ERROR
Definition: LogRecord.hxx:37
static const LogLevel INFO
Definition: LogRecord.hxx:39
const std::string _loggerName
Definition: LogRecord.hxx:46
