YACS::parser Struct Reference
#include <parserBase.hxx>
Inheritance diagram for YACS::parser:
Collaboration diagram for YACS::parser:
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static parser main_parser
Definition at line 39 of file parserBase.hxx.
◆ parser()
YACS::parser::parser ( )
Definition at line 44 of file parserBase.hxx.
45 {
46 _counts=new std::map<std::string,int>;
47 }
std::map< std::string, int > * _counts
Definition: parserBase.hxx:98
std::map< std::string, parser * > * _defaultParsersMap
Definition: parserBase.hxx:107
◆ ~parser()
YACS::parser::~parser ( )
Definition at line 38 of file parserBase.cxx.
39{
40 if(_level==0)
41 {
42 delete _counts;
43 }
44 else
45 {
46 DEBTRACE("Problem with parser: final stack level should be 0 and not " << _level);
47 }
48}
References _counts, _level, and DEBTRACE.
◆ buildAttr()
void YACS::parser::buildAttr ( const XML_Char **  attr)
Reimplemented in YACS::HMI::presentationtype_parser, YACS::bloctypeParser< T >, YACS::bloctypeParser< YACS::ENGINE::Proc * >, YACS::functypeParser, YACS::componentinstancetypeParser, YACS::machinetypeParser, YACS::containertypeParser, YACS::loadtypeParser, YACS::inlinetypeParser< T >, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServerNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::linktypeParser< T >, YACS::linktypeParser< mystream >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::DynParaLoop * >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::ForLoop * >, YACS::looptypeParser< ENGINE::OptimizerLoop * >, YACS::looptypeParser< PseudoComposedNode * >, YACS::looptypeParser< ENGINE::WhileLoop * >, YACS::forlooptypeParser< T >, YACS::pseudocomposednodetypeParser< T >, YACS::foreachlooptypeParser< T >, YACS::optimizerlooptypeParser< T >, YACS::nodetypeParser< T >, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >, YACS::nodetypeParser< ENGINE::DataNode * >, YACS::nodetypeParser< YACS::ENGINE::ServerNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::outputdatatypeParser, YACS::outnodetypeParser< T >, YACS::inporttypeParser< T >, YACS::inporttypeParser< myoutport >, YACS::presetdatatypeParser, YACS::presettypeParser< T >, YACS::proctypeParser< T >, YACS::propertytypeParser, YACS::casetypeParser, YACS::defaultcasetypeParser, YACS::switchtypeParser, YACS::typetypeParser, YACS::seqtypeParser, YACS::objtypeParser, YACS::membertypeParser, and YACS::structtypeParser.
Definition at line 195 of file parserBase.cxx.
196{
197 if (!attr)
198 return;
199 for (int i = 0; attr[i]; i += 2)
200 {
201 DEBTRACE(attr[i] << "=" << attr[i + 1]);
202 }
203}
References DEBTRACE, and yacsorb.CORBAEngineTest::i.
Referenced by YACS::HMI::presentationtype_parser::onStart(), YACS::bloctypeParser< T >::onStart(), YACS::codetypeParser::onStart(), YACS::componentinstancetypeParser::onStart(), YACS::containertypeParser::onStart(), YACS::inlinetypeParser< T >::onStart(), YACS::controltypeParser< T >::onStart(), YACS::linktypeParser< T >::onStart(), YACS::looptypeParser< T >::onStart(), YACS::dynparalooptypeParser< T >::onStart(), YACS::nodetypeParser< T >::onStart(), YACS::outputdatatypeParser::onStart(), YACS::outnodetypeParser< T >::onStart(), onStart(), YACS::inporttypeParser< T >::onStart(), YACS::presetdatatypeParser::onStart(), YACS::presettypeParser< T >::onStart(), YACS::proctypeParser< T >::onStart(), YACS::remotetypeParser< T >::onStart(), YACS::roottypeParser::onStart(), YACS::servertypeParser< T >::onStart(), YACS::servicetypeParser< T >::onStart(), YACS::sinlinetypeParser< T >::onStart(), YACS::casetypeParser::onStart(), YACS::switchtypeParser::onStart(), YACS::seqtypeParser::onStart(), YACS::objtypeParser::onStart(), YACS::structtypeParser::onStart(), YACS::valuetypeParser::onStart(), YACS::datatypeParser::onStart(), YACS::memberdatatypeParser::onStart(), YACS::structdatatypeParser::onStart(), YACS::arraytypeParser::onStart(), and YACS::parametertypeParser::onStart().
◆ cdata_block()
void XMLCALL YACS::parser::cdata_block ( void *  data,
const xmlChar *  value,
int  len
Definition at line 275 of file parserBase.cxx.
278{
279 DEBTRACE("parser::cdata_block");
280 parser *currentParser = static_cast<parser *> (data);
281 currentParser->charData((const XML_Char*) value, len);
282}
char XML_Char
Definition: parserBase.hxx:37
References charData(), and DEBTRACE.
Referenced by YACS::YACSLoader::load().
◆ characters()
void XMLCALL YACS::parser::characters ( void *  data,
const xmlChar *  ch,
int  len
Definition at line 259 of file parserBase.cxx.
262{
263 DEBTRACE("parser::characters " << len);
264 parser *currentParser = (parser *) (data);
265 currentParser->charData((const XML_Char*) ch, len);
266}
◆ charData()
void YACS::parser::charData ( const XML_Char *  s,
int  len
Definition at line 67 of file parserBase.cxx.
68{
69 _content=_content+std::string(s,len);
70}
Definition: parserBase.hxx:97
References _content.
Referenced by cdata_block(), and characters().
◆ checkOrder()
void YACS::parser::checkOrder ( std::string &  el)
Definition at line 108 of file parserBase.cxx.
109{
110 if(_orders.count(el)==0)return;
111 if(_orders[el] < _orderState)
112 {
113 std::string msg="unexpected "+el+" element (wrong order)";
114 throw YACS::Exception(msg);
115 }
116 else if(_orders[el] > _orderState)
117 {
119 }
120}
std::map< std::string, int > _orders
Definition: parserBase.hxx:99
References _orders, and _orderState.
◆ comment()
void XMLCALL YACS::parser::comment ( void *  data,
Definition at line 268 of file parserBase.cxx.
270{
271 DEBTRACE("parser::comment");
272 parser *currentParser = static_cast<parser *> (data);
273}
References DEBTRACE.
◆ end_document()
void XMLCALL YACS::parser::end_document ( void *  data)
Definition at line 231 of file parserBase.cxx.
232{
233 DEBTRACE("parser::end_document");
234 parser *currentParser = static_cast<parser *> (data);
235}
◆ end_element()
void XMLCALL YACS::parser::end_element ( void *  data,
const xmlChar *  name
Definition at line 247 of file parserBase.cxx.
249{
250 DEBTRACE("parser::end_element");
251 parser *childParser = static_cast<parser *> (data);
252 _stackParser.pop();
253 parser* pp=_stackParser.top();
255 pp->onEnd((const XML_Char *)name, childParser);
256 childParser->endParser();
257 }
_xmlParserCtxt * saxContext
Definition: parserBase.cxx:31
static std::stack< parser * > _stackParser
Definition: parserBase.hxx:42
static void XML_SetUserData(_xmlParserCtxt *ctxt, parser *par)
Definition: parserBase.cxx:219
References _stackParser, DEBTRACE, endParser(), onEnd(), saxContext, and XML_SetUserData().
◆ endParser()
void YACS::parser::endParser ( )
Definition at line 72 of file parserBase.cxx.
73{
74 DEBTRACE("parser::endParser, level: " <<_level);
75 _level=_level-1;
76 if(_level>0)
77 {
78 delete _counts;
79 _counts=_stackCount.top();
81 _stackCount.pop();
82 _stackOrder.pop();
83 }
84}
std::stack< std::map< std::string, int > * > _stackCount
Definition: parserBase.hxx:102
Definition: parserBase.hxx:103
References _counts, _level, _orderState, _stackCount, _stackOrder, and DEBTRACE.
Referenced by end_element().
◆ error()
void XMLCALL YACS::parser::error ( void *  data,
const char *  fmt,
Definition at line 303 of file parserBase.cxx.
305{
306 DEBTRACE("parser::error");
307 parser *currentParser = static_cast<parser *> (data);
308 va_list args;
309 va_start(args, fmt);
310 std::string format = "%s";
311 if (format == fmt)
312 {
313 char* parv;
314 parv = va_arg(args, char*);
315 std::cerr << parv ;
316 }
317 else std::cerr << __FILE__ << " [" << __LINE__ << "] : "
318 << "error format not taken into account: " << fmt << std::endl;
319 va_end(args);
320}
References driver_internal::args, and DEBTRACE.
◆ fatal_error()
void XMLCALL YACS::parser::fatal_error ( void *  data,
const char *  fmt,
Definition at line 322 of file parserBase.cxx.
324{
325 DEBTRACE("parser::fatal_error");
326 parser *currentParser = static_cast<parser *> (data);
327 va_list args;
328 va_start(args, fmt);
329 std::string format = "%s";
330 if (format == fmt)
331 {
332 char* parv;
333 parv = va_arg(args, char*);
334 std::cerr << parv ;
335 }
336 else std::cerr << __FILE__ << " [" << __LINE__ << "] : "
337 << "error format not taken into account: " << fmt << std::endl;
338 va_end(args);
339}
◆ getStack()
std::stack< parser * > & YACS::parser::getStack ( )
Definition at line 50 of file parserBase.cxx.
51{
52 return _stackParser;
53}
References _stackParser.
◆ incrCount()
void YACS::parser::incrCount ( const XML_Char *  elem)
Definition at line 100 of file parserBase.cxx.
101{
102 if((*_counts).find(el)==(*_counts).end())
103 (*_counts)[el]=1;
104 else
105 (*_counts)[el]=(*_counts)[el]+1;
106}
References _counts.
Referenced by start_element().
◆ init()
void YACS::parser::init ( )
Definition at line 86 of file parserBase.cxx.
87{
88 DEBTRACE("parser::init, level: " <<_level);
89 if(_level>0)
90 {
91 _stackCount.push(_counts);
93 _counts=new std::map<std::string,int>;
94 }
95 _level=_level+1;
96 _counts->clear();
98}
Referenced by YACS::YACSLoader::load(), YACS::HMI::presentationtype_parser::onStart(), YACS::bloctypeParser< T >::onStart(), YACS::codetypeParser::onStart(), YACS::componentinstancetypeParser::onStart(), YACS::containertypeParser::onStart(), YACS::inlinetypeParser< T >::onStart(), YACS::controltypeParser< T >::onStart(), YACS::linktypeParser< T >::onStart(), YACS::looptypeParser< T >::onStart(), YACS::dynparalooptypeParser< T >::onStart(), YACS::nodetypeParser< T >::onStart(), YACS::outputdatatypeParser::onStart(), YACS::outnodetypeParser< T >::onStart(), onStart(), YACS::inporttypeParser< T >::onStart(), YACS::presetdatatypeParser::onStart(), YACS::presettypeParser< T >::onStart(), YACS::proctypeParser< T >::onStart(), YACS::remotetypeParser< T >::onStart(), YACS::roottypeParser::onStart(), YACS::servertypeParser< T >::onStart(), YACS::servicetypeParser< T >::onStart(), YACS::sinlinetypeParser< T >::onStart(), YACS::casetypeParser::onStart(), YACS::switchtypeParser::onStart(), YACS::seqtypeParser::onStart(), YACS::objtypeParser::onStart(), YACS::structtypeParser::onStart(), YACS::valuetypeParser::onStart(), YACS::datatypeParser::onStart(), YACS::memberdatatypeParser::onStart(), YACS::structdatatypeParser::onStart(), YACS::arraytypeParser::onStart(), YACS::parametertypeParser::onStart(), outputParser::onStart(), YACS::ENGINE::stateParser::onStart(), YACS::ENGINE::graphParser::onStart(), YACS::ENGINE::nodeParser::onStart(), YACS::ENGINE::portParser::onStart(), YACS::ENGINE::valueParser::onStart(), YACS::ENGINE::arrayParser::onStart(), YACS::ENGINE::dataParser::onStart(), YACS::ENGINE::loopPortParser::onStart(), and YACS::ENGINE::sampleParser::onStart().
◆ logError()
void YACS::parser::logError ( const std::string &  reason)
Definition at line 214 of file parserBase.cxx.
215{
216 DEBTRACE( "parser::logError: " << _file );
217 currentProc->getLogger("parser")->error(reason,main_parser._file.c_str(),saxContext->input->line);
218}
virtual void error(const std::string &message, const char *filename, int line)
Definition: Logger.cxx:50
virtual Logger * getLogger(const std::string &name)
Definition: Proc.cxx:431
Definition: parserBase.cxx:30
Definition: parserBase.hxx:41
std::string _file
Definition: parserBase.hxx:96
References _file, currentProc, DEBTRACE, YACS::ENGINE::Logger::error(), YACS::ENGINE::Proc::getLogger(), main_parser, and saxContext.
Referenced by YACS::bloctypeParser< T >::control(), YACS::bloctypeParser< T >::datalink(), YACS::servertypeParser< T >::method(), YACS::servicetypeParser< T >::method(), YACS::bloctypeParser< T >::parameter(), and YACS::bloctypeParser< T >::stream().
◆ maxchoice()
void YACS::parser::maxchoice ( std::string *  names,
int  max,
std::string &  el
Definition at line 145 of file parserBase.cxx.
146{
147 int i=0;
148 int ncount=0;
149 while (names[i]!= "")
150 {
151 ncount=ncount+(*_counts)[names[i]];
152 ++i;
153 }
154 if(ncount>max)
155 {
156 std::stringstream msg;
157 msg<<"unexpected "+el+" element (choice count="<<ncount<<" > maxOccurs=" << max << ")";
158 throw YACS::Exception(msg.str());
159 }
160}
References yacsorb.CORBAEngineTest::i, and yacsorb.CORBAEngineTest::names.
Referenced by YACS::casetypeParser::onStart(), and YACS::valuetypeParser::onStart().
◆ maxcount()
void YACS::parser::maxcount ( std::string  name,
int  max,
std::string &  el
Definition at line 122 of file parserBase.cxx.
123{
124 if(el!=name)return;
125 if((*_counts)[name]>max)
126 {
127 std::stringstream msg;
128 msg <<"unexpected "+name+" element (count="<<(*_counts)[name];
129 msg <<" > maxOccurs=" << max << ")";
130 throw YACS::Exception(msg.str());
131 }
132}
References _counts.
Referenced by YACS::memberdatatypeParser::onEnd(), YACS::componentinstancetypeParser::onStart(), YACS::controltypeParser< T >::onStart(), YACS::linktypeParser< T >::onStart(), YACS::dynparalooptypeParser< T >::onStart(), YACS::presetdatatypeParser::onStart(), YACS::casetypeParser::onStart(), YACS::switchtypeParser::onStart(), YACS::valuetypeParser::onStart(), YACS::arraytypeParser::onStart(), and YACS::parametertypeParser::onStart().
◆ minchoice()
void YACS::parser::minchoice ( std::string *  names,
int  min
Definition at line 162 of file parserBase.cxx.
163{
164 int i=0;
165 int ncount=0;
166 while (names[i]!= "")
167 {
168 ncount=ncount+(*_counts)[names[i]];
169 ++i;
170 }
171 if(ncount<min)
172 {
173 std::stringstream msg;
174 msg << "expected element ";
175 i=0;
176 while (names[i]!= "")
177 {
178 msg << names[i] << ",";
179 ++i;
180 }
181 msg << "(choice count="<<ncount<<" < minOccurs=" << min << ")";
182 throw YACS::Exception(msg.str());
183 }
184}
Referenced by YACS::casetypeParser::post(), and YACS::valuetypeParser::post().
◆ mincount()
void YACS::parser::mincount ( std::string  name,
int  min
Definition at line 134 of file parserBase.cxx.
135{
136 if((*_counts)[name]<min)
137 {
138 std::stringstream msg;
139 msg<<"expected "+name+" element (count="<<(*_counts)[name];
140 msg << " < minOccurs=" << min << ")";
141 throw YACS::Exception(msg.str());
142 }
143}
References _counts.
Referenced by YACS::componentinstancetypeParser::post(), YACS::controltypeParser< T >::post(), YACS::linktypeParser< T >::post(), YACS::presetdatatypeParser::post(), YACS::servertypeParser< T >::post(), YACS::servicetypeParser< T >::post(), YACS::memberdatatypeParser::post(), YACS::arraytypeParser::post(), and YACS::parametertypeParser::post().
◆ onEnd()
void YACS::parser::onEnd ( const XML_Char *  el,
parser *  child
Reimplemented in YACS::bloctypeParser< T >, YACS::bloctypeParser< YACS::ENGINE::Proc * >, YACS::codetypeParser, YACS::componentinstancetypeParser, YACS::containertypeParser, YACS::inlinetypeParser< T >, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServerNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::controltypeParser< T >, YACS::controltypeParser< mylink >, YACS::controltypeParser< mystream >, YACS::linktypeParser< T >, YACS::linktypeParser< mystream >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::DynParaLoop * >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::ForLoop * >, YACS::looptypeParser< ENGINE::OptimizerLoop * >, YACS::looptypeParser< PseudoComposedNode * >, YACS::looptypeParser< ENGINE::WhileLoop * >, YACS::dynparalooptypeParser< T >, YACS::dynparalooptypeParser< T >, YACS::dynparalooptypeParser< ENGINE::OptimizerLoop * >, YACS::nodetypeParser< T >, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >, YACS::nodetypeParser< ENGINE::DataNode * >, YACS::nodetypeParser< YACS::ENGINE::ServerNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::outputdatatypeParser, YACS::outnodetypeParser< T >, YACS::inporttypeParser< T >, YACS::inporttypeParser< myoutport >, YACS::presetdatatypeParser, YACS::presettypeParser< T >, YACS::proctypeParser< T >, YACS::remotetypeParser< T >, YACS::roottypeParser, YACS::servertypeParser< T >, YACS::servicetypeParser< T >, YACS::sinlinetypeParser< T >, YACS::casetypeParser, YACS::switchtypeParser, YACS::seqtypeParser, YACS::objtypeParser, YACS::structtypeParser, YACS::valuetypeParser, YACS::datatypeParser, YACS::memberdatatypeParser, YACS::structdatatypeParser, YACS::arraytypeParser, and YACS::parametertypeParser.
Definition at line 62 of file parserBase.cxx.
63{
64 DEBTRACE("parser::onEnd: " << el)
65}
◆ onStart()
void YACS::parser::onStart ( const XML_Char *  el,
Reimplemented in YACS::HMI::presentationtype_parser, YACS::bloctypeParser< T >, YACS::bloctypeParser< YACS::ENGINE::Proc * >, YACS::codetypeParser, YACS::componentinstancetypeParser, YACS::containertypeParser, YACS::inlinetypeParser< T >, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServerNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::controltypeParser< T >, YACS::controltypeParser< mylink >, YACS::controltypeParser< mystream >, YACS::linktypeParser< T >, YACS::linktypeParser< mystream >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::DynParaLoop * >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::ForLoop * >, YACS::looptypeParser< ENGINE::OptimizerLoop * >, YACS::looptypeParser< PseudoComposedNode * >, YACS::looptypeParser< ENGINE::WhileLoop * >, YACS::dynparalooptypeParser< T >, YACS::dynparalooptypeParser< T >, YACS::dynparalooptypeParser< ENGINE::OptimizerLoop * >, YACS::nodetypeParser< T >, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >, YACS::nodetypeParser< ENGINE::DataNode * >, YACS::nodetypeParser< YACS::ENGINE::ServerNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::outputdatatypeParser, YACS::outnodetypeParser< T >, YACS::inporttypeParser< T >, YACS::inporttypeParser< myoutport >, YACS::presetdatatypeParser, YACS::presettypeParser< T >, YACS::proctypeParser< T >, YACS::remotetypeParser< T >, YACS::roottypeParser, YACS::servertypeParser< T >, YACS::servicetypeParser< T >, YACS::sinlinetypeParser< T >, YACS::casetypeParser, YACS::switchtypeParser, YACS::seqtypeParser, YACS::objtypeParser, YACS::structtypeParser, YACS::valuetypeParser, YACS::datatypeParser, YACS::memberdatatypeParser, YACS::structdatatypeParser, YACS::arraytypeParser, and YACS::parametertypeParser.
Definition at line 205 of file parserBase.cxx.
206{
207 DEBTRACE( "parser::onStart: " << el );
212}
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
Definition: parserBase.cxx:55
Definition: parserBase.cxx:195
References buildAttr(), DEBTRACE, init(), main_parser, pre(), and SetUserDataAndPush().
◆ post()
template<class T >
T YACS::parser::post ( )
Definition at line 92 of file parserBase.hxx.
92{ }
Referenced by YACS::dynparalooptypeParser< T >::onEnd(), and YACS::roottypeParser::onEnd().
◆ pre()
virtual void YACS::parser::pre ( )
Reimplemented in YACS::HMI::presentationtype_parser, YACS::codetypeParser, YACS::componentinstancetypeParser, YACS::machinetypeParser, YACS::containertypeParser, YACS::loadtypeParser, YACS::inlinetypeParser< T >, YACS::inlinetypeParser< YACS::ENGINE::InlineNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServerNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceNode * >, YACS::inlinetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::controltypeParser< T >, YACS::controltypeParser< mylink >, YACS::controltypeParser< mystream >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::DynParaLoop * >, YACS::looptypeParser< T >, YACS::looptypeParser< ENGINE::ForLoop * >, YACS::looptypeParser< ENGINE::OptimizerLoop * >, YACS::looptypeParser< PseudoComposedNode * >, YACS::looptypeParser< ENGINE::WhileLoop * >, YACS::foreachlooptypeParser< T >, YACS::optimizerlooptypeParser< T >, YACS::nodetypeParser< T >, YACS::nodetypeParser< YACS::ENGINE::InlineNode * >, YACS::nodetypeParser< ENGINE::DataNode * >, YACS::nodetypeParser< YACS::ENGINE::ServerNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceNode * >, YACS::nodetypeParser< YACS::ENGINE::ServiceInlineNode * >, YACS::outputdatatypeParser, YACS::outnodetypeParser< T >, YACS::inporttypeParser< T >, YACS::inporttypeParser< myoutport >, YACS::presetdatatypeParser, YACS::presettypeParser< T >, YACS::proctypeParser< T >, YACS::casetypeParser, YACS::defaultcasetypeParser, YACS::switchtypeParser, YACS::typetypeParser, YACS::objtypeParser, YACS::structtypeParser, YACS::valuetypeParser, YACS::datatypeParser, YACS::memberdatatypeParser, YACS::structdatatypeParser, YACS::arraytypeParser, and YACS::parametertypeParser.
Definition at line 61 of file parserBase.hxx.
61{_content="";};
◆ required()
◆ SetUserDataAndPush()
◆ start_document()
void XMLCALL YACS::parser::start_document ( void *  data)
Definition at line 225 of file parserBase.cxx.
226{
227 DEBTRACE("parser::start_document");
228 parser *currentParser = static_cast<parser *> (data);
229}
◆ start_element()
void XMLCALL YACS::parser::start_element ( void *  data,
const xmlChar *  name,
const xmlChar **  p
Definition at line 237 of file parserBase.cxx.
240{
241 DEBTRACE("parser::start_element " << name);
242 parser *currentParser = static_cast<parser *> (data);
243 currentParser->incrCount((const XML_Char *)name);
244 currentParser->onStart((const XML_Char *)name, (const XML_Char **)p);
245}
Proc * p
Definition: driver.cxx:216
References DEBTRACE, incrCount(), onStart(), and p.
◆ warning()
void XMLCALL YACS::parser::warning ( void *  data,
const char *  fmt,
Definition at line 284 of file parserBase.cxx.
286{
287 DEBTRACE("parser::warning");
288 parser *currentParser = static_cast<parser *> (data);
289 va_list args;
290 va_start(args, fmt);
291 std::string format = "%s";
292 if (format == fmt)
293 {
294 char* parv;
295 parv = va_arg(args, char*);
296 std::cerr << parv ;
297 }
298 else std::cerr << __FILE__ << " [" << __LINE__ << "] : "
299 << "error format not taken into account: " << fmt << std::endl;
300 va_end(args);
301}
◆ XML_SetUserData()
void YACS::parser::XML_SetUserData ( _xmlParserCtxt *  ctxt,
parser *  par
Definition at line 219 of file parserBase.cxx.
221{
222 ctxt->userData = par;
223}
Referenced by end_element(), and SetUserDataAndPush().
◆ _content
std::string YACS::parser::_content
◆ _counts
std::map<std::string,int>* YACS::parser::_counts
Definition at line 98 of file parserBase.hxx.
Referenced by endParser(), incrCount(), init(), maxcount(), mincount(), and ~parser().
◆ _defaultParsersMap
std::map<std::string,parser*>* YACS::parser::_defaultParsersMap
Definition at line 107 of file parserBase.hxx.
Referenced by YACS::roottypeParser::setDefaultMap().
◆ _file
std::string YACS::parser::_file
Definition at line 96 of file parserBase.hxx.
Referenced by YACS::YACSLoader::load(), and logError().
◆ _level
int YACS::parser::_level
Definition at line 101 of file parserBase.hxx.
Referenced by endParser(), init(), SetUserDataAndPush(), and ~parser().
◆ _orders
std::map<std::string,int> YACS::parser::_orders
◆ _orderState
int YACS::parser::_orderState
Definition at line 100 of file parserBase.hxx.
Referenced by checkOrder(), endParser(), and init().
◆ _stackCount
std::stack<std::map<std::string,int>*> YACS::parser::_stackCount
Definition at line 102 of file parserBase.hxx.
Referenced by endParser(), and init().
◆ _stackOrder
std::stack<int> YACS::parser::_stackOrder
Definition at line 103 of file parserBase.hxx.
◆ _stackParser
std::stack< parser * > YACS::parser::_stackParser
Definition at line 42 of file parserBase.hxx.
Referenced by end_element(), getStack(), YACS::YACSLoader::load(), and SetUserDataAndPush().
◆ main_parser
