YACS::datatypeParser Struct Reference
Class for XML-RPC data parser. More...
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::datatypeParser:
Collaboration diagram for YACS::datatypeParser:
virtual void pre ()
virtual void value (const std::string &v)
virtual std::string post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _data
std::vector< std::string > _datas
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static datatypeParser dataParser
static parser main_parser
This class is used to parse XML data that describes a sequence in XML-RPC format
Its XML schema is:
  <xsd:complexType name="DataType">
    <xsd:element name="value" type="ValueType"/>
  </xsd:complexType>
Definition at line 78 of file xmlrpcParsers.hxx.
◆ onEnd()
void YACS::datatypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 94 of file xmlrpcParsers.cxx.
95 {
96 std::string element(el);
97 if(element == "value")value(((valuetypeParser*)child)->post());
98 }
virtual void value(const std::string &v)
virtual std::string post()
References post(), and value().
◆ onStart()
void YACS::datatypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 84 of file xmlrpcParsers.cxx.
85 {
86 std::string element(el);
88 if(element == "value")pp=&valuetypeParser::valueParser;
90 pp->init();
91 pp->pre();
92 pp->buildAttr(attr);
93 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
static valuetypeParser valueParser
References YACS::parser::buildAttr(), YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), and YACS::valuetypeParser::valueParser.
◆ post()
std::string YACS::datatypeParser::post ( )
Definition at line 107 of file xmlrpcParsers.cxx.
108 {
109 std::string d="<data>\n"+_data+"</data>";
110 _data=_datas.back();
111 _datas.pop_back();
112 return d;
113 }
References _data, and _datas.
Referenced by onEnd().
◆ pre()
void YACS::datatypeParser::pre ( )
Definition at line 99 of file xmlrpcParsers.cxx.
100 {
101 _datas.push_back(_data);
102 _data="";
103 }
◆ value()
void YACS::datatypeParser::value ( const std::string &  v)
◆ _data
std::string YACS::datatypeParser::_data
Definition at line 86 of file xmlrpcParsers.hxx.
Referenced by post(), pre(), and value().
◆ _datas
std::vector<std::string> YACS::datatypeParser::_datas
Definition at line 87 of file xmlrpcParsers.hxx.
Referenced by post(), and pre().
◆ dataParser
datatypeParser YACS::datatypeParser::dataParser
Definition at line 80 of file xmlrpcParsers.hxx.
Referenced by YACS::arraytypeParser::onStart().
