YACS::valuetypeParser Struct Reference
Class for XML-RPC value parser. More...
#include <xmlrpcParsers.hxx>
Inheritance diagram for YACS::valuetypeParser:
Collaboration diagram for YACS::valuetypeParser:
virtual void pre ()
virtual void int_ (const int &d)
virtual void boolean (const bool &d)
virtual void double_ (const double &d)
virtual void string (const std::string &d)
virtual void objref (const std::string &d)
virtual void array (const std::string &d)
virtual void struct_ (const std::string &d)
virtual std::string post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _data
std::vector< std::string > _v
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static valuetypeParser valueParser
static parser main_parser
This class is used to parse XML data that describes a sequence in XML-RPC format
Its XML schema is:
  <xsd:complexType name="ValueType">
    <xsd:choice >
      <xsd:element name="int" type="IntType"/>
      <xsd:element name="boolean" type="BooleanType"/>
      <xsd:element name="double" type="DoubleType"/>
      <xsd:element name="string" type="StringType"/>
      <xsd:element name="objref" type="ObjrefType"/>
      <xsd:element name="array" type="ArrayType"/>
      <xsd:element name="struct" type="StructType"/>
    </xsd:choice>
  </xsd:complexType>
Definition at line 49 of file xmlrpcParsers.hxx.
◆ array()
void YACS::valuetypeParser::array ( const std::string &  d)
Definition at line 68 of file xmlrpcParsers.cxx.
69 {
70 _v.push_back(d);
71 }
References _v.
Referenced by onEnd().
◆ boolean()
void YACS::valuetypeParser::boolean ( const bool &  d)
Definition at line 44 of file xmlrpcParsers.cxx.
45 {
46 std::ostringstream os;
47 os << "<boolean>" << d<< "</boolean>";
48 _data=os.str();
49 _v.push_back(_data);
50 }
References _data, and _v.
◆ double_()
void YACS::valuetypeParser::double_ ( const double &  d)
Definition at line 51 of file xmlrpcParsers.cxx.
52 {
53 std::ostringstream os;
54 os << "<double>"<< std::setprecision(16) << d<< "</double>";
55 _data=os.str();
56 _v.push_back(_data);
57 }
◆ int_()
void YACS::valuetypeParser::int_ ( const int &  d)
Definition at line 37 of file xmlrpcParsers.cxx.
38 {
39 std::ostringstream os;
40 os << "<int>" << d<< "</int>";
41 _data=os.str();
42 _v.push_back(_data);
43 }
◆ objref()
void YACS::valuetypeParser::objref ( const std::string &  d)
Definition at line 63 of file xmlrpcParsers.cxx.
64 {
65 _data="<objref>"+ d+ "</objref>";
66 _v.push_back(_data);
67 }
◆ onEnd()
void YACS::valuetypeParser::onEnd ( const char *  el,
parser *  child
Definition at line 244 of file xmlrpcParsers.cxx.
245{
246 std::string element(el);
247 if(element == "string")string(((stringtypeParser*)child)->post());
248 else if(element == "objref")objref(((stringtypeParser*)child)->post());
249 else if(element == "double")double_(((doubletypeParser*)child)->post());
250 else if(element == "int")int_(((inttypeParser*)child)->post());
251 else if(element == "boolean")boolean(((booltypeParser*)child)->post());
252 else if(element == "array")array(((arraytypeParser*)child)->post());
253 else if(element == "struct")struct_(((structdatatypeParser*)child)->post());
254}
virtual void struct_(const std::string &d)
virtual void string(const std::string &d)
virtual std::string post()
virtual void objref(const std::string &d)
virtual void double_(const double &d)
virtual void int_(const int &d)
virtual void boolean(const bool &d)
virtual void array(const std::string &d)
References array(), boolean(), double_(), int_(), objref(), post(), string(), and struct_().
◆ onStart()
void YACS::valuetypeParser::onStart ( const XML_Char *  el,
const XML_Char **  attr
Definition at line 219 of file xmlrpcParsers.cxx.
220{
221 std::string element(el);
223 this->maxcount("string",1,element);
224 this->maxcount("objref",1,element);
225 this->maxcount("double",1,element);
226 this->maxcount("int",1,element);
227 this->maxcount("boolean",1,element);
228 this->maxcount("array",1,element);
229 this->maxcount("struct",1,element);
230 this->maxchoice(t4,1,element);
231 if(element == "string")pp=&stringtypeParser::stringParser;
232 else if(element == "objref")pp=&stringtypeParser::stringParser;
233 else if(element == "double")pp=&doubletypeParser::doubleParser;
234 else if(element == "int")pp=&inttypeParser::intParser;
235 else if(element == "boolean")pp=&booltypeParser::boolParser;
236 else if(element == "array")pp=&arraytypeParser::arrayParser;
237 else if(element == "struct")pp=&structdatatypeParser::structdataParser;
239 pp->init();
240 pp->pre();
241 pp->buildAttr(attr);
242}
static std::string t4[]
static arraytypeParser arrayParser
static booltypeParser boolParser
Definition: dataParsers.hxx:63
static doubletypeParser doubleParser
Definition: dataParsers.hxx:43
static inttypeParser intParser
Definition: dataParsers.hxx:53
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
virtual void maxchoice(std::string *names, int max, std::string &el)
Definition: parserBase.cxx:145
Definition: dataParsers.hxx:33
static structdatatypeParser structdataParser
References YACS::arraytypeParser::arrayParser, YACS::booltypeParser::boolParser, YACS::parser::buildAttr(), YACS::doubletypeParser::doubleParser, YACS::parser::init(), YACS::inttypeParser::intParser, YACS::parser::main_parser, YACS::parser::maxchoice(), YACS::parser::maxcount(), YACS::parser::pre(), YACS::parser::SetUserDataAndPush(), YACS::stringtypeParser::stringParser, and YACS::structdatatypeParser::structdataParser.
◆ post()
std::string YACS::valuetypeParser::post ( )
Definition at line 76 of file xmlrpcParsers.cxx.
77 {
78 minchoice(t4,1);
79 std::string value="<value>"+_v.back()+"</value>\n";
80 _v.pop_back();
81 return value;
82 }
virtual void minchoice(std::string *names, int min)
Definition: parserBase.cxx:162
References _v, YACS::parser::minchoice(), and YACS::t4.
◆ pre()
void YACS::valuetypeParser::pre ( )
Definition at line 36 of file xmlrpcParsers.cxx.
36{ }
◆ string()
void YACS::valuetypeParser::string ( const std::string &  d)
Definition at line 58 of file xmlrpcParsers.cxx.
59 {
60 _data="<string>"+ d+ "</string>";
61 _v.push_back(_data);
62 }
◆ struct_()
void YACS::valuetypeParser::struct_ ( const std::string &  d)
Definition at line 72 of file xmlrpcParsers.cxx.
73 {
74 _v.push_back(d);
75 }
References _v.
◆ _data
std::string YACS::valuetypeParser::_data
Definition at line 63 of file xmlrpcParsers.hxx.
Referenced by boolean(), double_(), int_(), objref(), and string().
◆ _v
std::vector<std::string> YACS::valuetypeParser::_v
Definition at line 64 of file xmlrpcParsers.hxx.
Referenced by array(), boolean(), double_(), int_(), objref(), post(), string(), and struct_().
◆ valueParser
