presetParsers.hxx
20#ifndef _PRESETPARSERS_HXX_
21#define _PRESETPARSERS_HXX_
23#include "nodeParsers.hxx"
24
25#include "factory.hxx"
26
27#include "DataNode.hxx"
28
29namespace YACS
30{
31
44{
46
47 virtual void onStart(const XML_Char* el, const XML_Char** attr)
48 {
49 DEBTRACE("presetdatatypeParser::onStart");
50 std::string element(el);
51 this->maxcount("value",1,element);
53 if(element == "value")pp=&valuetypeParser::valueParser;
55 pp->init();
56 pp->pre();
57 pp->buildAttr(attr);
58 }
59 virtual void onEnd(const char *el,parser* child)
60 {
61 DEBTRACE("presetdatatypeParser::onEnd");
62 std::string element(el);
63 if(element == "value")value(((valuetypeParser*)child)->post());
64 }
65 virtual void buildAttr(const XML_Char** attr)
66 {
67 if (!attr)
68 return;
69 DEBTRACE("presetdatatypeParser::buildAttr");
70 required("name",attr);
71 required("type",attr);
72 for (int i = 0; attr[i]; i += 2)
73 {
74 if(std::string(attr[i]) == "name")name(attr[i+1]);
75 if(std::string(attr[i]) == "type")type(attr[i+1]);
76 if(std::string(attr[i]) == "ref")ref(attr[i+1]);
77 }
78 }
79 virtual void name (const std::string& name)
80 {
81 DEBTRACE("presetdatatypeParser::name");
83 _name=name;
84 }
85 virtual void type (const std::string& type)
86 {
87 DEBTRACE("presetdatatypeParser::type");
89 _type=type;
90 }
91
92 virtual void ref (const std::string& ref)
93 {
94 _ref=ref;
95 }
96
97 virtual void pre ()
98 {
99 DEBTRACE("presetdatatypeParser::pre");
100 _ref="undef";
101 _param.clear();
102 }
103 virtual void value (const std::string& value)
104 {
105 DEBTRACE("presetdatatypeParser::value " << value);
106 _param.setProperty("value",value);
107 }
108 virtual myoutport& post()
109 {
110 DEBTRACE("presetdatatypeParser::post");
111 //a parameter can have a ref attribute OR one value element
112 if(_ref == "undef")
113 mincount("value",1);
114 else
115 _param.setProperty("value",_ref);
116 return _param;
117 }
119 std::string _name;
120 std::string _type;
121 std::string _ref;
122};
123
134template <class T=ENGINE::DataNode*>
136{
138 virtual void onStart(const XML_Char* el, const XML_Char** attr);
139 virtual void onEnd(const char *el,parser* child);
140 virtual void buildAttr(const XML_Char** attr);
141 virtual void create ();
142 virtual void pre ();
143 virtual void name (const std::string& name);
144 virtual void kind (const std::string& kind);
145 virtual void parameter (myoutport& p);
146 std::string _name;
147 std::string _kind;
148};
149
151
152
153template <class T>
154void presettypeParser<T>::onStart(const XML_Char* el, const XML_Char** attr)
155 {
156 DEBTRACE("presettypeParser::onStart");
157 std::string element(el);
159 if(element == "parameter")pp=&presetdatatypeParser::presetdataParser;
160 if(element == "property")pp=&propertytypeParser::propertyParser;
161 this->SetUserDataAndPush(pp);
162 pp->init();
163 pp->pre();
164 pp->buildAttr(attr);
165 }
166
167template <class T>
168void presettypeParser<T>::onEnd(const char *el,parser* child)
169 {
170 DEBTRACE("presettypeParser::onEnd");
171 std::string element(el);
172 if(element == "parameter")parameter(((presetdatatypeParser*)child)->post());
173 if(element == "property")this->property(((propertytypeParser*)child)->post());
174 }
175
176template <class T>
178 {
179 if (!attr)
180 return;
181 DEBTRACE("presettypeParser::buildAttr");
182 this->required("name",attr);
183 for (int i = 0; attr[i]; i += 2)
184 {
185 if(std::string(attr[i]) == "name")name(attr[i+1]);
186 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
187 }
188 create();
189 }
190
191template <class T>
193{
194 _kind="";
195}
196
197template <class T>
198void presettypeParser<T>::name (const std::string& name)
199{
200 _name=name;
201}
202
203template <class T>
204void presettypeParser<T>::kind (const std::string& kind)
205{
206 _kind=kind;
207}
208
209template <class T>
211{
212 this->_node = theRuntime->createInDataNode(_kind,_name);
213}
214
215template <class T>
217{
218 DEBTRACE("presettypeParser::parameter");
219 if(currentProc->typeMap.count(p._type)==0)
220 {
221 //Check if the typecode is defined in the runtime
223 if(t==0)
224 {
225 std::string msg="Unknown Type: ";
226 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
227 this->logError(msg);
228 return;
229 }
230 else
231 {
232 currentProc->typeMap[p._type]=t;
233 t->incrRef();
234 }
235 }
236 ENGINE::OutputPort *port = this->_node->edAddOutputPort(p._name,currentProc->typeMap[p._type]);
237 this->_node->setData(port,p._props["value"]);
238}
239
240}
241#endif
Definition: parsers.cxx:40
Definition: parserBase.cxx:30
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
virtual DataNode * createInDataNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:180
Definition: TypeCode.hxx:68
Proc * p
Definition: driver.cxx:216
char XML_Char
Definition: parserBase.hxx:37
Class for node parser.
Definition: nodeParsers.hxx:54
virtual void init()
Definition: parserBase.cxx:86
virtual void pre()
Definition: parserBase.hxx:61
Definition: parserBase.cxx:55
virtual void mincount(std::string name, int min)
Definition: parserBase.cxx:134
Definition: parserBase.cxx:195
static parser main_parser
Definition: parserBase.hxx:41
Class for presetdata parser.
virtual void ref(const std::string &ref)
virtual void type(const std::string &type)
virtual void value(const std::string &value)
static presetdatatypeParser presetdataParser
virtual myoutport & post()
Class for PresetNode parser.
virtual void parameter(myoutport &p)
virtual void kind(const std::string &kind)
static presettypeParser< T > presetParser
Class for property parser.
Class for XML-RPC value parser.
static valuetypeParser valueParser
std::string _name
Definition: factory.hxx:80
std::string _type
Definition: factory.hxx:81
void setProperty(const std::string &name, const std::string &value)
Definition: factory.hxx:87
void clear()
Definition: factory.hxx:83
