YACS::presettypeParser< T > Struct Template Reference
Class for PresetNode parser. More...
#include <presetParsers.hxx>
Inheritance diagram for YACS::presettypeParser< T >:
Collaboration diagram for YACS::presettypeParser< T >:
virtual void create ()
virtual void pre ()
virtual void kind (const std::string &kind)
virtual void parameter (myoutport &p)
- Public Member Functions inherited from YACS::nodetypeParser< ENGINE::DataNode * >
virtual void pre ()
virtual void type (const std::string &name)
virtual ENGINE::DataNode * post ()
YACS::ENGINE::InlineNode * post ()
 parser ()
virtual ~parser ()
virtual void endParser ()
virtual void init ()
virtual void pre ()
template<class T >
T post ()
Public Attributes
std::string _kind
- Public Attributes inherited from YACS::nodetypeParser< ENGINE::DataNode * >
std::string _type
std::string _state
std::string _container
ENGINE::DataNode * _node
std::string _file
std::string _content
int _orderState
int _level
std::stack< int > _stackOrder
Static Public Attributes
static presettypeParser< T > presetParser
- Static Public Attributes inherited from YACS::nodetypeParser< ENGINE::DataNode * >
static nodetypeParser< ENGINE::DataNode * > nodeParser
static parser main_parser
template<class T = ENGINE::DataNode*>
struct YACS::presettypeParser< T >
Its XML schema is:
    <xsd:complexType name="PresetType">
      <xsd:attribute name="name" type="xsd:string" use="required"/>
      <xsd:element name="parameter" type="ParameterType"/>
    </xsd:complexType>
Definition at line 135 of file presetParsers.hxx.
◆ buildAttr()
template<class T >
void YACS::presettypeParser< T >::buildAttr ( const XML_Char **  attr)
Reimplemented from YACS::nodetypeParser< ENGINE::DataNode * >.
Definition at line 177 of file presetParsers.hxx.
178 {
179 if (!attr)
180 return;
181 DEBTRACE("presettypeParser::buildAttr");
182 this->required("name",attr);
183 for (int i = 0; attr[i]; i += 2)
184 {
185 if(std::string(attr[i]) == "name")name(attr[i+1]);
186 if(std::string(attr[i]) == "kind")kind(attr[i+1]);
187 }
188 create();
189 }
virtual void kind(const std::string &kind)
References DEBTRACE, and yacsorb.CORBAEngineTest::i.
◆ create()
template<class T >
void YACS::presettypeParser< T >::create
Definition at line 210 of file presetParsers.hxx.
211{
213}
Definition: parsers.cxx:40
virtual DataNode * createInDataNode(const std::string &kind, const std::string &name)
Definition: Runtime.cxx:180
References YACS::ENGINE::Runtime::createInDataNode(), and theRuntime.
◆ kind()
template<class T >
void YACS::presettypeParser< T >::kind ( const std::string &  kind)
Definition at line 204 of file presetParsers.hxx.
205{
206 _kind=kind;
207}
template<class T >
void YACS::presettypeParser< T >::name ( const std::string &  name)
Definition at line 198 of file presetParsers.hxx.
199{
200 _name=name;
201}
◆ onEnd()
template<class T >
void YACS::presettypeParser< T >::onEnd ( const char *  el,
parser *  child
Definition at line 168 of file presetParsers.hxx.
169 {
170 DEBTRACE("presettypeParser::onEnd");
171 std::string element(el);
172 if(element == "parameter")parameter(((presetdatatypeParser*)child)->post());
173 if(element == "property")this->property(((propertytypeParser*)child)->post());
174 }
virtual ENGINE::DataNode * post()
virtual void parameter(myoutport &p)
References DEBTRACE.
◆ onStart()
template<class T >
void YACS::presettypeParser< T >::onStart ( const XML_Char *  el,
Definition at line 154 of file presetParsers.hxx.
155 {
156 DEBTRACE("presettypeParser::onStart");
157 std::string element(el);
159 if(element == "parameter")pp=&presetdatatypeParser::presetdataParser;
160 if(element == "property")pp=&propertytypeParser::propertyParser;
161 this->SetUserDataAndPush(pp);
162 pp->init();
163 pp->pre();
164 pp->buildAttr(attr);
165 }
Definition: parserBase.cxx:55
Definition: parserBase.hxx:41
static presetdatatypeParser presetdataParser
References YACS::parser::buildAttr(), DEBTRACE, YACS::parser::init(), YACS::parser::main_parser, YACS::parser::pre(), YACS::presetdatatypeParser::presetdataParser, and YACS::propertytypeParser::propertyParser.
◆ parameter()
template<class T >
void YACS::presettypeParser< T >::parameter ( myoutport &  p)
Definition at line 216 of file presetParsers.hxx.
217{
218 DEBTRACE("presettypeParser::parameter");
219 if(currentProc->typeMap.count(p._type)==0)
220 {
221 //Check if the typecode is defined in the runtime
223 if(t==0)
224 {
225 std::string msg="Unknown Type: ";
226 msg=msg+p._type+" for node: "+this->_node->getName()+" port name: "+p._name;
227 this->logError(msg);
228 return;
229 }
230 else
231 {
232 currentProc->typeMap[p._type]=t;
233 t->incrRef();
234 }
235 }
236 ENGINE::OutputPort *port = this->_node->edAddOutputPort(p._name,currentProc->typeMap[p._type]);
237 this->_node->setData(port,p._props["value"]);
238}
Definition: parserBase.cxx:30
virtual void setData(InputPort *port, const std::string &data)
Definition: DataNode.cxx:29
virtual OutputPort * edAddOutputPort(const std::string &outputPortName, TypeCode *type)
Definition: Node.hxx:125
Definition: Proc.hxx:90
Definition: Runtime.cxx:333
Definition: TypeCode.hxx:68
Proc * p
Definition: driver.cxx:216
void logError(const std::string &reason)
Definition: parserBase.cxx:214
std::string _name
Definition: factory.hxx:80
References currentProc, DEBTRACE, YACS::ENGINE::Runtime::getTypeCode(), p, gui.Appli::t, theRuntime, and YACS::ENGINE::Proc::typeMap.
◆ pre()
template<class T >
void YACS::presettypeParser< T >::pre
Definition at line 192 of file presetParsers.hxx.
193{
194 _kind="";
195}
◆ _kind
std::string YACS::presettypeParser< T >::_kind
Definition at line 147 of file presetParsers.hxx.
◆ _name
std::string YACS::presettypeParser< T >::_name
Definition at line 146 of file presetParsers.hxx.
◆ presetParser
template<class T >
presettypeParser< T > YACS::presettypeParser< T >::presetParser
Definition at line 137 of file presetParsers.hxx.
