YACS::ENGINE::ElementaryNode Class Reference
Base class for all calculation nodes. More...
#include <ElementaryNode.hxx>
Inheritance diagram for YACS::ENGINE::ElementaryNode:
Collaboration diagram for YACS::ENGINE::ElementaryNode:
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Friends
class ComposedNode
YACS::Colour _colour
static int _total = 0
This is an abstract class that must be specialized.
Definition at line 43 of file ElementaryNode.hxx.
◆ ElementaryNode() [1/2]
ElementaryNode::ElementaryNode ( const std::string &  name)
◆ ElementaryNode() [2/2]
ElementaryNode::ElementaryNode ( const ElementaryNode &  other,
ComposedNode *  father
Definition at line 56 of file ElementaryNode.cxx.
56 :Node(other,father), _weight(other._weight)
57{
60 for(list<InputPort *>::const_iterator iter1=other._setOfInputPort.begin();iter1!=other._setOfInputPort.end();iter1++)
61 _setOfInputPort.push_back((InputPort *)(*iter1)->clone(this));
62 for(list<OutputPort *>::const_iterator iter2=other._setOfOutputPort.begin();iter2!=other._setOfOutputPort.end();iter2++)
63 _setOfOutputPort.push_back((OutputPort *)(*iter2)->clone(this));
64 for(list<InputDataStreamPort *>::const_iterator iter3=other._setOfInputDataStreamPort.begin();iter3!=other._setOfInputDataStreamPort.end();iter3++)
65 _setOfInputDataStreamPort.push_back((InputDataStreamPort *)(*iter3)->clone(this));
66 for(list<OutputDataStreamPort *>::const_iterator iter4=other._setOfOutputDataStreamPort.begin();iter4!=other._setOfOutputDataStreamPort.end();iter4++)
67 _setOfOutputDataStreamPort.push_back((OutputDataStreamPort *)(*iter4)->clone(this));
68}
std::list< OutputDataStreamPort * > _setOfOutputDataStreamPort
std::list< InputDataStreamPort * > _setOfInputDataStreamPort
Base class for Input Ports.
Definition: InputPort.hxx:44
References _createDatastreamPorts, _multi_port_node, _setOfInputDataStreamPort, _setOfInputPort, _setOfOutputDataStreamPort, and _setOfOutputPort.
◆ ~ElementaryNode()
ElementaryNode::~ElementaryNode ( )
Definition at line 78 of file ElementaryNode.cxx.
79{
80 for(list<InputPort *>::iterator iter1=_setOfInputPort.begin();iter1!=_setOfInputPort.end();iter1++)
81 delete *iter1;
82 for(list<OutputPort *>::iterator iter2=_setOfOutputPort.begin();iter2!=_setOfOutputPort.end();iter2++)
83 delete *iter2;
84 for(list<InputDataStreamPort *>::iterator iter3=_setOfInputDataStreamPort.begin();iter3!=_setOfInputDataStreamPort.end();iter3++)
85 delete *iter3;
86 for(list<OutputDataStreamPort *>::iterator iter4=_setOfOutputDataStreamPort.begin();iter4!=_setOfOutputDataStreamPort.end();iter4++)
87 delete *iter4;
88}
References _setOfInputDataStreamPort, _setOfInputPort, _setOfOutputDataStreamPort, and _setOfOutputPort.
◆ aborted()
void ElementaryNode::aborted ( )
Implements YACS::ENGINE::Task.
Reimplemented in YACS::ENGINE::FakeNodeForForEachLoop, YACS::ENGINE::FakeNodeForLoop, YACS::ENGINE::FakeNodeForOptimizerLoop, and YACS::ENGINE::FakeNodeForSwitch.
Definition at line 763 of file ElementaryNode.cxx.
764{
766}
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
@ ERROR
Definition: define.hxx:52
References YACS::ERROR, and YACS::ENGINE::Node::setState().
◆ accept()
◆ addDatastreamPortToInitMultiService()
virtual void YACS::ENGINE::ElementaryNode::addDatastreamPortToInitMultiService ( const std::string &  port_name,
int  number
Definition at line 134 of file ElementaryNode.hxx.
135 {}
Referenced by createMultiDatastreamPorts().
◆ areAllInputPortsValid()
bool ElementaryNode::areAllInputPortsValid ( ) const
checks if all input ports contains a valid data. Used at execution to change the state of the node for activation.
Definition at line 274 of file ElementaryNode.cxx.
275{
276 bool ret=true;
277 for(list<InputPort *>::const_iterator iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
278 {
279 ret=!(*iter)->isEmpty();
280 if (!ret) break;
281 }
282 return ret;
283}
References _setOfInputPort.
Referenced by connected(), and exUpdateState().
◆ begin()
void ElementaryNode::begin ( )
Definition at line 749 of file ElementaryNode.cxx.
750{
752}
@ ACTIVATED
Definition: define.hxx:41
References YACS::ACTIVATED, and YACS::ENGINE::Node::setState().
Referenced by YACS::HMI::SubjectNode::registerUndoDestroy().
◆ checkBasicConsistency()
void ElementaryNode::checkBasicConsistency ( ) const
Reimplemented in YACS::ENGINE::InlineFuncNode, YACS::ENGINE::OutNode, YACS::ENGINE::PresetNode, YACS::ENGINE::PythonNode, YACS::ENGINE::PyFuncNode, YACS::ENGINE::StudyInNode, and YACS::ENGINE::StudyOutNode.
Definition at line 577 of file ElementaryNode.cxx.
578{
579 DEBTRACE("ElementaryNode::checkBasicConsistency");
580 list<InputPort *>::const_iterator iter;
581 for(iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
582 (*iter)->checkBasicConsistency();
583}
References _setOfInputPort, and DEBTRACE.
Referenced by YACS::ENGINE::InlineFuncNode::checkBasicConsistency(), YACS::ENGINE::PythonNode::checkBasicConsistency(), and edUpdateState().
◆ connected()
void ElementaryNode::connected ( )
Notify this node that it is connected.
When an elementary node has been connected it goes to TOACTIVATE state It is then ready to be executed
Definition at line 784 of file ElementaryNode.cxx.
785{
786 if(_inGate.exIsReady())
788 {
790 return;
791 }
793}
bool exIsReady() const
Definition: InGate.cxx:126
InGate _inGate
Definition: Node.hxx:86
@ LOADED
Definition: define.hxx:39
@ TOACTIVATE
Definition: define.hxx:40
References YACS::ENGINE::Node::_inGate, areAllInputPortsValid(), YACS::ENGINE::InGate::exIsReady(), YACS::LOADED, YACS::ENGINE::Node::setState(), and YACS::TOACTIVATE.
◆ connectService()
virtual void YACS::ENGINE::ElementaryNode::connectService ( )
Definition at line 125 of file ElementaryNode.hxx.
125{ }
◆ createInputDataStreamPort()
InputDataStreamPort * ElementaryNode::createInputDataStreamPort ( const std::string &  inputPortDSName,
TypeCode *  type
Definition at line 689 of file ElementaryNode.cxx.
690{
691 return getRuntime()->createInputDataStreamPort(inputPortDSName, this, type);
692}
virtual InputDataStreamPort * createInputDataStreamPort(const std::string &name, Node *node, TypeCode *type)
Definition: Runtime.cxx:269
Definition: Runtime.cxx:61
References YACS::ENGINE::Runtime::createInputDataStreamPort(), and YACS::ENGINE::getRuntime().
Referenced by edAddInputDataStreamPort().
◆ createInputPort()
InputPort * ElementaryNode::createInputPort ( const std::string &  inputPortName,
TypeCode *  type
Reimplemented in YACS::ENGINE::OutNode, and YACS::ENGINE::StudyOutNode.
Definition at line 593 of file ElementaryNode.cxx.
594{
595 return getRuntime()->createInputPort(inputPortName, _implementation, this, type);
596}
Definition: Node.hxx:97
virtual InputPort * createInputPort(const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
References YACS::ENGINE::Node::_implementation, YACS::ENGINE::Runtime::createInputPort(), and YACS::ENGINE::getRuntime().
Referenced by edAddInputPort().
◆ createMultiDatastreamPorts()
void ElementaryNode::createMultiDatastreamPorts ( )
Definition at line 290 of file ElementaryNode.cxx.
291{
293 {
295 for(list<InputDataStreamPort *>::const_iterator iter3 = _setOfInputDataStreamPort.begin(); iter3!=_setOfInputDataStreamPort.end();iter3++)
296 {
297 InputDataStreamPort * port = *iter3;
298 std::string port_name = port->getName();
299 std::map<std::string,std::string>::iterator it=_propertyMap.find(port_name);
300 int multi = 1;
301 if(it != _propertyMap.end())
302 {
303 std::string multi_str = it->second;
304 std::istringstream iss(multi_str);
305 if (!(iss >> multi))
306 throw Exception("Property multi port should be set with a stringified int not an: " + multi_str);
307 }
308
309 if (multi > 1)
310 {
311 addDatastreamPortToInitMultiService(port_name, multi);
312 // Change name of first port
313 port->setName(port_name + "_0");
314 for (int i = 2; i <= multi; i++)
315 {
316 InputDataStreamPort * new_port = port->clone(this);
317 std::ostringstream number;
318 number << i-1;
319 new_port->setName(port_name + "_" + number.str());
320 _setOfInputDataStreamPort.push_back(new_port);
321 _multi_port_node = true;
322 }
323 }
324 }
325 for(list<OutputDataStreamPort *>::const_iterator iter4 = _setOfOutputDataStreamPort.begin(); iter4!=_setOfOutputDataStreamPort.end();iter4++)
326 {
327 OutputDataStreamPort * port = *iter4;
328 std::string port_name = port->getName();
329 std::map<std::string,std::string>::iterator it=_propertyMap.find(port_name);
330 int multi = 1;
331 if(it != _propertyMap.end())
332 {
333 std::string multi_str = it->second;
334 std::istringstream iss(multi_str);
335 if (!(iss >> multi))
336 throw Exception("Property multi port should be set with a stringified int not an: " + multi_str);
337 }
338
339 if (multi > 1)
340 {
341 addDatastreamPortToInitMultiService(port_name, multi);
342 // Change name of first port
343 port->setName(port_name + "_0");
344 for (int i = 2; i <= multi; i++)
345 {
346 OutputDataStreamPort * new_port = port->clone(this);
347 std::ostringstream number;
348 number << i-1;
349 new_port->setName(port_name + "_" + number.str());
350 _setOfOutputDataStreamPort.push_back(new_port);
351 _multi_port_node = true;
352 }
353 }
354 }
355 }
356}
void setName(std::string theName)
Definition: DataPort.hxx:56
std::string getName() const
Definition: DataPort.hxx:55
virtual void addDatastreamPortToInitMultiService(const std::string &port_name, int number)
virtual InputDataStreamPort * clone(Node *newHelder) const
std::map< std::string, std::string > _propertyMap
Definition: Node.hxx:98
virtual OutputDataStreamPort * clone(Node *newHelder) const
References _createDatastreamPorts, _multi_port_node, YACS::ENGINE::Node::_propertyMap, _setOfInputDataStreamPort, _setOfOutputDataStreamPort, addDatastreamPortToInitMultiService(), YACS::ENGINE::InputDataStreamPort::clone(), YACS::ENGINE::OutputDataStreamPort::clone(), YACS::ENGINE::DataPort::getName(), yacsorb.CORBAEngineTest::i, and YACS::ENGINE::DataPort::setName().
Referenced by getReadyTasks().
◆ createOutputDataStreamPort()
OutputDataStreamPort * ElementaryNode::createOutputDataStreamPort ( const std::string &  outputPortDSName,
TypeCode *  type
Definition at line 706 of file ElementaryNode.cxx.
707{
708 return getRuntime()->createOutputDataStreamPort(outputPortDSName, this, type);
709}
virtual OutputDataStreamPort * createOutputDataStreamPort(const std::string &name, Node *node, TypeCode *type)
Definition: Runtime.cxx:274
References YACS::ENGINE::Runtime::createOutputDataStreamPort(), and YACS::ENGINE::getRuntime().
Referenced by edAddOutputDataStreamPort().
◆ createOutputPort()
OutputPort * ElementaryNode::createOutputPort ( const std::string &  outputPortName,
TypeCode *  type
Reimplemented in YACS::ENGINE::PresetNode, and YACS::ENGINE::StudyInNode.
Definition at line 662 of file ElementaryNode.cxx.
663{
664 return getRuntime()->createOutputPort(outputPortName, _implementation, this, type);
665}
virtual OutputPort * createOutputPort(const std::string &name, const std::string &impl, Node *node, TypeCode *type)=0
References YACS::ENGINE::Node::_implementation, YACS::ENGINE::Runtime::createOutputPort(), and YACS::ENGINE::getRuntime().
Referenced by edAddOutputPort().
◆ disconnectService()
virtual void YACS::ENGINE::ElementaryNode::disconnectService ( )
Definition at line 126 of file ElementaryNode.hxx.
126{ }
◆ edAddInputDataStreamPort()
InputDataStreamPort * ElementaryNode::edAddInputDataStreamPort ( const std::string &  inputPortDSName,
TypeCode *  type
Definition at line 694 of file ElementaryNode.cxx.
695{
696 InputDataStreamPort *ret = 0;
697 if (edCheckAddPort<InputDataStreamPort, TypeCode*>(inputPortDSName,_setOfInputDataStreamPort,type))
698 {
699 ret = createInputDataStreamPort(inputPortDSName, type);
700 _setOfInputDataStreamPort.push_back(ret);
701 modified();
702 }
703 return ret;
704}
virtual InputDataStreamPort * createInputDataStreamPort(const std::string &inputPortDSName, TypeCode *type)
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References _setOfInputDataStreamPort, createInputDataStreamPort(), and YACS::ENGINE::Node::modified().
Referenced by YACS::ENGINE::SessionCataLoader::importComponent(), YACS::servertypeParser< T >::instream(), YACS::servicetypeParser< T >::instream(), and YACS::HMI::CommandAddIDSPortFromCatalog::localExecute().
◆ edAddInputPort()
InputPort * ElementaryNode::edAddInputPort ( const std::string &  inputPortName,
TypeCode *  type
the input port is also published recursively in ancestors because it may be visible from everywhere. WARNING: CHECK CASE OF BLOC: ONLY INPUT PORTS NOT INTERNALLY CONNECTED MUST BE VISIBLE.
Definition at line 603 of file ElementaryNode.cxx.
604{
605
606 // Cannot create an InputPort defined with InPropertyPort name.
607 if (inputPortName == "__InPropertyPort__Node__YACS_")
608 {
609 string what("ElementaryNode::edAddInputPort: it is forbidden to add an InputPort with the name __InPropertyPort__Node__YACS_\"");
610 throw Exception(what);
611 }
612
613 InputPort *ret = 0;
614 if (edCheckAddPort<InputPort, TypeCode*>(inputPortName,_setOfInputPort,type))
615 {
616 ret = createInputPort(inputPortName, type);
617 _setOfInputPort.push_back(ret);
618 modified();
619 /*
620 ComposedNode *iter=_father;
621 while(iter)
622 iter=iter->_father;
623 */
624 }
625 return ret;
626}
virtual InputPort * createInputPort(const std::string &inputPortName, TypeCode *type)
References _setOfInputPort, createInputPort(), and YACS::ENGINE::Node::modified().
Referenced by YACS::ENGINE::SessionCataLoader::importComponent(), YACS::inlinetypeParser< T >::inport(), and YACS::HMI::CommandAddInputPortFromCatalog::localExecute().
◆ edAddOutputDataStreamPort()
OutputDataStreamPort * ElementaryNode::edAddOutputDataStreamPort ( const std::string &  outputPortDSName,
TypeCode *  type
Definition at line 711 of file ElementaryNode.cxx.
712{
713 OutputDataStreamPort *ret = 0;
714 if (edCheckAddPort<OutputDataStreamPort, TypeCode*>(outputPortDSName,_setOfOutputDataStreamPort,type))
715 {
716 ret = createOutputDataStreamPort(outputPortDSName, type);
717 _setOfOutputDataStreamPort.push_back(ret);
718 modified();
719 }
720 return ret;
721}
virtual OutputDataStreamPort * createOutputDataStreamPort(const std::string &outputPortDSName, TypeCode *type)
References _setOfOutputDataStreamPort, createOutputDataStreamPort(), and YACS::ENGINE::Node::modified().
Referenced by YACS::ENGINE::SessionCataLoader::importComponent(), YACS::HMI::CommandAddODSPortFromCatalog::localExecute(), YACS::servertypeParser< T >::outstream(), and YACS::servicetypeParser< T >::outstream().
◆ edAddOutputPort()
OutputPort * ElementaryNode::edAddOutputPort ( const std::string &  outputPortName,
TypeCode *  type
TO SOLVE : The output port is not published in father. Father must create an output port. for now, publication is done the same way as input ports
Definition at line 672 of file ElementaryNode.cxx.
673{
674 OutputPort *ret =0;
675 if (edCheckAddPort<OutputPort, TypeCode*>(outputPortName,_setOfOutputPort,type))
676 {
677 ret = createOutputPort(outputPortName, type);
678 _setOfOutputPort.push_back(ret);
679 modified();
680 /*
681 ComposedNode *iter=_father;
682 while(iter)
683 iter=iter->_father;
684 */
685 }
686 return ret;
687}
virtual OutputPort * createOutputPort(const std::string &outputPortName, TypeCode *type)
References _setOfOutputPort, createOutputPort(), and YACS::ENGINE::Node::modified().
Referenced by YACS::ENGINE::SessionCataLoader::importComponent(), YACS::HMI::CommandAddOutputPortFromCatalog::localExecute(), and YACS::inlinetypeParser< T >::outport().
◆ edAddPort()
PORT * YACS::ENGINE::ElementaryNode::edAddPort ( const std::string &  portName,
std::list< PORT * > &  setOfPorts,
ENUMTYPE  type
protected: add a port given it's name and type, in a given list of ports WHY TEMPLATE PARAMETER ENUMTYPE?
Definition at line 179 of file ElementaryNode.hxx.
180 {
181 checkValidityOfPortName(portName);
182 if(isPortNameAlreadyExist<PORT>(portName, setOfPorts))
183 {
184 std::string what="Port of type "; what+=PORT::NAME; what += " with name : "; what+=portName; what+=" already exists";
185 throw Exception(what);
186 }
187 PORT *ret=new PORT(portName,this,type);
188 setOfPorts.push_back(ret);
189 return ret;
190 }
static void checkValidityOfPortName(const std::string &name)
Definition: Node.cxx:446
References YACS::ENGINE::Node::checkValidityOfPortName().
◆ edCheckAddPort()
bool YACS::ENGINE::ElementaryNode::edCheckAddPort ( const std::string &  portName,
ENUMTYPE  type
Definition at line 193 of file ElementaryNode.hxx.
194 {
195 checkValidityOfPortName(portName);
196 if(isPortNameAlreadyExist<PORT>(portName, setOfPorts))
197 {
198 std::string what="Port of type "; what+=PORT::NAME; what += " with name : "; what+=portName; what+=" already exists";
199 throw Exception(what);
200 }
201 return true;
202 }
◆ edDisconnectAllLinksWithMe()
void ElementaryNode::edDisconnectAllLinksWithMe ( )
Called typically by ComposedNode to correctly update DF/CF/DS links
Reimplemented from YACS::ENGINE::Node.
Definition at line 249 of file ElementaryNode.cxx.
250{
251 //CF
253 //Leaving part
254 // - DF
255 for(list<InputPort *>::iterator iter=_setOfInputPort.begin();iter!=_setOfInputPort.end();iter++)
256 (*iter)->edRemoveAllLinksLinkedWithMe();
257 // - DS
258 for(list<InputDataStreamPort *>::iterator iter2=_setOfInputDataStreamPort.begin();iter2!=_setOfInputDataStreamPort.end();iter2++)
259 (*iter2)->edRemoveAllLinksLinkedWithMe();
260 //Arriving part
261 // - DF
262 for(list<OutputPort *>::iterator iter=_setOfOutputPort.begin();iter!=_setOfOutputPort.end();iter++)
263 (*iter)->edRemoveAllLinksLinkedWithMe();
264 // - DS
265 for(list<OutputDataStreamPort *>::iterator iter2=_setOfOutputDataStreamPort.begin();iter2!=_setOfOutputDataStreamPort.end();iter2++)
266 (*iter2)->edRemoveAllLinksLinkedWithMe();
267}
virtual void edDisconnectAllLinksWithMe()
Definition: Node.cxx:395
References _setOfInputDataStreamPort, _setOfInputPort, _setOfOutputDataStreamPort, _setOfOutputPort, and YACS::ENGINE::Node::edDisconnectAllLinksWithMe().
Referenced by YACS::ENGINE::DFToDSForLoop::~DFToDSForLoop(), and YACS::ENGINE::DSToDFForLoop::~DSToDFForLoop().
◆ edOrderInputPorts()
void ElementaryNode::edOrderInputPorts ( const std::list< InputPort * > &  ports)
Definition at line 628 of file ElementaryNode.cxx.
629{
630 std::set<InputPort *> s1;
631 std::set<InputPort *> s2;
632 for(list<InputPort *>::const_iterator it=_setOfInputPort.begin();it != _setOfInputPort.end();it++)
633 s1.insert(*it);
634 for(list<InputPort *>::const_iterator it=ports.begin();it != ports.end();it++)
635 s2.insert(*it);
636
637 if(s1 != s2)
638 throw Exception("ElementaryNode::edOrderInputPorts : port list must contain same ports as existing ones");
639
640 _setOfInputPort.clear();
641 for(list<InputPort *>::const_iterator it=ports.begin();it != ports.end();it++)
642 _setOfInputPort.push_back(*it);
643}
Referenced by YACS::HMI::CommandOrderInputPorts::localExecute(), and YACS::HMI::CommandOrderInputPorts::localReverse().
◆ edOrderOutputPorts()
void ElementaryNode::edOrderOutputPorts ( const std::list< OutputPort * > &  ports)
Definition at line 645 of file ElementaryNode.cxx.
646{
647 std::set<OutputPort *> s1;
648 std::set<OutputPort *> s2;
649 for(list<OutputPort *>::const_iterator it=_setOfOutputPort.begin();it != _setOfOutputPort.end();it++)
650 s1.insert(*it);
651 for(list<OutputPort *>::const_iterator it=ports.begin();it != ports.end();it++)
652 s2.insert(*it);
653
654 if(s1 != s2)
655 throw Exception("ElementaryNode::edOrderOutputPorts : port list must contain same ports as existing ones");
656
657 _setOfOutputPort.clear();
658 for(list<OutputPort *>::const_iterator it=ports.begin();it != ports.end();it++)
659 _setOfOutputPort.push_back(*it);
660}
References _setOfOutputPort.
Referenced by YACS::HMI::CommandOrderOutputPorts::localExecute(), and YACS::HMI::CommandOrderOutputPorts::localReverse().
◆ edRemovePort()
void ElementaryNode::edRemovePort ( Port *  port)
remove port from node at edition. Ports are typed.
Definition at line 523 of file ElementaryNode.cxx.
524{
525 DEBTRACE("ElementaryNode::edRemovePort ");
526 if(port->getNode()!=this)
527 throw Exception("ElementaryNode::edRemovePort : Port is not held by this node");
528 if(InputPort *p=dynamic_cast<InputPort *>(port))
529 edRemovePortTypedFromSet<InputPort>(p,_setOfInputPort);
530 else if(OutputPort *p=dynamic_cast<OutputPort *>(port))
531 edRemovePortTypedFromSet<OutputPort>(p,_setOfOutputPort);
532 else if(InputDataStreamPort *p=dynamic_cast<InputDataStreamPort *>(port))
533 edRemovePortTypedFromSet<InputDataStreamPort>(p,_setOfInputDataStreamPort);
534 else if(OutputDataStreamPort *p=dynamic_cast<OutputDataStreamPort *>(port))
535 edRemovePortTypedFromSet<OutputDataStreamPort>(p,_setOfOutputDataStreamPort);
536 else
537 throw Exception("ElementaryNode::edRemovePort : unknown port type");
538 delete port;
539 modified();
540}
Node * getNode() const
Definition: Port.hxx:46
Proc * p
Definition: driver.cxx:216
References _setOfInputDataStreamPort, _setOfInputPort, _setOfOutputDataStreamPort, _setOfOutputPort, DEBTRACE, YACS::ENGINE::Port::getNode(), YACS::ENGINE::Node::modified(), and p.
Referenced by YACS::HMI::SubjectDataPort::~SubjectDataPort().
◆ edRemovePortTypedFromSet()
void YACS::ENGINE::ElementaryNode::edRemovePortTypedFromSet ( PORT *  port,
staticprotected
protected: remove a port from a given list
Definition at line 209 of file ElementaryNode.hxx.
210 {
211 if(!isPortNameAlreadyExist<PORT>(port->getName(), setOfPorts))
212 throw Exception("Port is not part of the list : unable to remove it");
213 typename std::list<PORT *>::iterator iter=std::find(setOfPorts.begin(),setOfPorts.end(),port);
214 if(iter!=setOfPorts.end())
215 {
216 (*iter)->edRemoveAllLinksLinkedWithMe();
217 setOfPorts.erase(iter);
218 }
219 }
◆ edUpdateState()
void ElementaryNode::edUpdateState ( )
update the status of the node
Only useful when editing a schema Do nothing in base Node : to implement in derived classes
Definition at line 809 of file ElementaryNode.cxx.
810{
811 DEBTRACE("ElementaryNode::edUpdateState: " << getName());
813 try
814 {
816 _errorDetails="";
817 }
818 catch(Exception& e)
819 {
821 _errorDetails=e.what();
822 }
823 DEBTRACE("ElementaryNode::edUpdateState: " << _errorDetails);
824 if(state != _state)
826 _modified=0;
827}
Definition: Node.hxx:125
Definition: Node.hxx:93
Definition: Node.hxx:91
StatesForNode
Definition: define.hxx:34
@ INVALID
Definition: define.hxx:36
@ READY
Definition: define.hxx:37
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_modified, YACS::ENGINE::Node::_state, checkBasicConsistency(), DEBTRACE, YACS::ENGINE::Node::getName(), YACS::INVALID, YACS::READY, YACS::ENGINE::Node::setState(), yacsorb.CORBAEngineTest::state, and YACS::Exception::what().
◆ ensureLoading()
void ElementaryNode::ensureLoading ( )
Put this node into TOLOAD state when possible.
Can be called by another ElementaryNode that is connected to this one by a datastream link These 2 nodes must be loaded at the same time as they are coupled It's the other node which requests this node loading
Definition at line 835 of file ElementaryNode.cxx.
836{
837 DEBTRACE("ElementaryNode::ensureLoading: " << getName());
838 if(_state != YACS::READY)
839 return;
841
842 // request loading for all nodes connected to this one by datastream link
843 // Be careful that nodes can be connected in a loop. Put first this node in TOLOAD state to break the loop
844 std::list<OutputDataStreamPort *>::iterator iterout;
845 for(iterout = _setOfOutputDataStreamPort.begin(); iterout != _setOfOutputDataStreamPort.end(); iterout++)
846 {
848 std::set<InPort *> ports=port->edSetInPort();
849 std::set<InPort *>::iterator iter;
850 for(iter=ports.begin();iter != ports.end(); iter++)
851 {
852 Node* node= (*iter)->getNode();
853 node->ensureLoading();
854 }
855 }
856 std::list<InputDataStreamPort *>::iterator iterin;
857 for(iterin = _setOfInputDataStreamPort.begin(); iterin != _setOfInputDataStreamPort.end(); iterin++)
858 {
860 std::set<OutPort *> ports=port->edSetOutPort();
861 std::set<OutPort *>::iterator iter;
862 for(iter=ports.begin();iter != ports.end(); iter++)
863 {
864 Node* node= (*iter)->getNode();
865 node->ensureLoading();
866 }
867 }
868}
virtual std::set< OutPort * > edSetOutPort() const
Returns physical backlinks NOT user backlinks.
Definition: InPort.cxx:65
Base class for all nodes.
Definition: Node.hxx:70
virtual void ensureLoading()
Definition: Node.cxx:817
std::set< InPort * > edSetInPort() const
@ TOLOAD
Definition: define.hxx:38
References _setOfInputDataStreamPort, _setOfOutputDataStreamPort, YACS::ENGINE::Node::_state, DEBTRACE, YACS::ENGINE::OutputDataStreamPort::edSetInPort(), YACS::ENGINE::InPort::edSetOutPort(), YACS::ENGINE::Node::ensureLoading(), YACS::ENGINE::Node::getName(), YACS::READY, YACS::ENGINE::Node::setState(), and YACS::TOLOAD.
Referenced by exUpdateState().
◆ exUpdateState()
void ElementaryNode::exUpdateState ( )
Update the node state.
: Update the '_state' attribute. Typically called by 'this->_inGate' when 'this->_inGate' is ready.
Called by InGate::exNotifyFromPrecursor
Definition at line 136 of file ElementaryNode.cxx.
137{
138 DEBTRACE("ElementaryNode::exUpdateState: " << getName() << " " << _state );
139 if(_state==YACS::DISABLED)return;
140 if(_inGate.exIsReady())
142 {
143 if(_state == YACS::READY)
145 else if(_state == YACS::LOADED)
147 }
148 else
149 {
150 string what("ElementaryNode::exUpdateState : Invalid graph given : Node with name \"");
151 what+=_name; what+="\" ready to run whereas some inputports are not set correctly\nCheck coherence DF/CF";
153 _errorDetails=what;
154 throw Exception(what);
155 }
156}
std::string _name
Definition: Node.hxx:89
@ INTERNALERR
Definition: define.hxx:49
@ DISABLED
Definition: define.hxx:50
References YACS::ENGINE::Node::_errorDetails, YACS::ENGINE::Node::_inGate, YACS::ENGINE::Node::_name, YACS::ENGINE::Node::_state, areAllInputPortsValid(), DEBTRACE, YACS::DISABLED, ensureLoading(), YACS::ENGINE::InGate::exIsReady(), YACS::ENGINE::Node::getName(), YACS::INTERNALERR, YACS::LOADED, YACS::READY, YACS::ENGINE::Node::setState(), and YACS::TOACTIVATE.
◆ finished()
void ElementaryNode::finished ( )
◆ getAllInPortsComingFromOutsideOfCurrentScope()
std::set< InPort * > ElementaryNode::getAllInPortsComingFromOutsideOfCurrentScope ( ) const
Definition at line 195 of file ElementaryNode.cxx.
196{
197 set<InPort *> ret;
198 list<InPort *> temp=getSetOfInPort();
199 for(list<InPort *>::iterator iter2=temp.begin();iter2!=temp.end();iter2++)
200 {
201 set<OutPort *> temp2=(*iter2)->edSetOutPort();
202 if(temp2.size()!=0)
203 ret.insert(*iter2);
204 }
205 return ret;
206}
std::list< InPort * > getSetOfInPort() const
Definition: Node.cxx:289
References YACS::ENGINE::Node::getSetOfInPort().
Referenced by getSetOfLinksComingInCurrentScope().
◆ getAllOutPortsLeavingCurrentScope()
std::set< OutPort * > ElementaryNode::getAllOutPortsLeavingCurrentScope ( ) const
Definition at line 182 of file ElementaryNode.cxx.
183{
184 set<OutPort *> ret;
185 list<OutPort *> temp=getSetOfOutPort();
186 for(list<OutPort *>::iterator iter2=temp.begin();iter2!=temp.end();iter2++)
187 {
188 set<InPort *> temp2=(*iter2)->edSetInPort();
189 if(temp2.size()!=0)
190 ret.insert(*iter2);
191 }
192 return ret;
193}
std::list< OutPort * > getSetOfOutPort() const
Definition: Node.cxx:299
References YACS::ENGINE::Node::getSetOfOutPort().
Referenced by getSetOfLinksLeavingCurrentScope().
◆ getChildByName()
Node * ElementaryNode::getChildByName ( const std::string &  name) const
Definition at line 571 of file ElementaryNode.cxx.
572{
573 string what("ElementaryNode does not agregate any nodes particullary node with name "); what+=name;
574 throw Exception(what);
575}
◆ getComponent() [1/2]
ComponentInstance * ElementaryNode::getComponent ( )
Reimplemented in YACS::ENGINE::ServiceNode.
Definition at line 116 of file ElementaryNode.cxx.
117{
118 return 0;
119}
Referenced by YACS::servertypeParser< T >::post().
◆ getComponent() [2/2]
const ComponentInstance * ElementaryNode::getComponent ( ) const
Definition at line 121 of file ElementaryNode.cxx.
122{
123 return 0;
124}
◆ getContainer()
Container * ElementaryNode::getContainer ( )
Reimplemented in YACS::ENGINE::InlineNode, and YACS::ENGINE::ServiceNode.
Definition at line 126 of file ElementaryNode.cxx.
127{
128 return 0;
129}
◆ getCoupledNodes()
void ElementaryNode::getCoupledNodes ( std::set< Task * > &  coupledSet)
Put all nodes that are coupled to this node in coupledSet.
Definition at line 877 of file ElementaryNode.cxx.
878{
879 if(coupledSet.find(this) != coupledSet.end())return;
880
881 coupledSet.insert(this);
882
883 std::list<OutputDataStreamPort *>::iterator iterout;
884 for(iterout = _setOfOutputDataStreamPort.begin(); iterout != _setOfOutputDataStreamPort.end(); iterout++)
885 {
887 std::set<InPort *> ports=port->edSetInPort();
888 std::set<InPort *>::iterator iter;
889 for(iter=ports.begin();iter != ports.end(); iter++)
890 {
891 Node* node= (*iter)->getNode();
892 node->getCoupledNodes(coupledSet);
893 }
894 }
895}
virtual void getCoupledNodes(std::set< Task * > &coupledNodes)
Definition: Node.hxx:199
References _setOfOutputDataStreamPort, YACS::ENGINE::OutputDataStreamPort::edSetInPort(), and YACS::ENGINE::Node::getCoupledNodes().
Referenced by getCoupledTasks().
◆ getCoupledTasks()
void ElementaryNode::getCoupledTasks ( std::set< Task * > &  coupledSet)
Calls getCoupledNodes for Task interface.
Definition at line 871 of file ElementaryNode.cxx.
872{
873 getCoupledNodes(coupledSet);
874}
virtual void getCoupledNodes(std::set< Task * > &coupledSet)
References getCoupledNodes().
◆ getDynClonerIfExists()
ComposedNode * ElementaryNode::getDynClonerIfExists ( const ComposedNode *  levelToStop) const
Definition at line 585 of file ElementaryNode.cxx.
586{
587 for(ComposedNode *iter=_father;iter!=levelToStop && iter!=0; iter=iter->_father)
588 if(!iter->isPlacementPredictableB4Run())
589 return iter;
590 return 0;
591}
Definition: Node.hxx:90
References YACS::ENGINE::Node::_father.
◆ getErrorDetails()
std::string ElementaryNode::getErrorDetails ( )
Give a description of error when node status is ERROR.
Definition at line 804 of file ElementaryNode.cxx.
805{
806 return _errorDetails;
807}
References YACS::ENGINE::Node::_errorDetails.
Referenced by YACS::ENGINE::DistributedPythonNode::dealException(), and YACS::ENGINE::SalomeNode::execute().
◆ getInPortName()
string ElementaryNode::getInPortName ( const InPort *  inPort) const
get the input port name used by the current node (see composed nodes)
Definition at line 727 of file ElementaryNode.cxx.
728{
729 Node *node = inPort->getNode();
730 if ( node != this )
731 {
732 string what("InputPort "); what += inPort->getName(); what += " does not belong to node "; what += node->getName();
733 throw Exception(what);
734 }
735 return inPort->getName();
736}
References YACS::ENGINE::DataPort::getName(), YACS::ENGINE::Node::getName(), and YACS::ENGINE::Port::getNode().
◆ getInputDataStreamPort()
InputDataStreamPort * ElementaryNode::getInputDataStreamPort ( const std::string &  name) const
Reimplemented in YACS::ENGINE::DSToDFForLoop.
Definition at line 239 of file ElementaryNode.cxx.
240{
241 return getPort<InputDataStreamPort>(name,_setOfInputDataStreamPort);
242}
References _setOfInputDataStreamPort.
Referenced by getReadyTasks(), and YACS::HMI::CommandAddIDSPortFromCatalog::localReverse().
◆ getInputPort()
InputPort * ElementaryNode::getInputPort ( const std::string &  name) const
◆ getLocalInputPorts()
std::list< InputPort * > YACS::ENGINE::ElementaryNode::getLocalInputPorts ( ) const
Definition at line 85 of file ElementaryNode.hxx.
85{ return _setOfInputPort; }
Referenced by YACS::HMI::SubjectElementaryNode::loadChildren().
◆ getLocalOutputPorts()
std::list< OutputPort * > YACS::ENGINE::ElementaryNode::getLocalOutputPorts ( ) const
Definition at line 86 of file ElementaryNode.hxx.
86{ return _setOfOutputPort; }
◆ getMaxLevelOfParallelism()
int YACS::ENGINE::ElementaryNode::getMaxLevelOfParallelism ( ) const
Reimplemented in YACS::ENGINE::InlineNode.
Definition at line 110 of file ElementaryNode.hxx.
110{ return 1; }
◆ getNumberOfInputPorts()
int ElementaryNode::getNumberOfInputPorts ( ) const
◆ getNumberOfOutputPorts()
◆ getOutPortName()
string ElementaryNode::getOutPortName ( const OutPort *  outPort) const
Definition at line 738 of file ElementaryNode.cxx.
739{
740 Node *node = outPort->getNode();
741 if ( node != this )
742 {
743 string what("OutputPort "); what += outPort->getName(); what += " does not belong to node "; what += node->getName();
744 throw Exception(what);
745 }
746 return outPort->getName();
747}
◆ getOutputDataStreamPort()
OutputDataStreamPort * ElementaryNode::getOutputDataStreamPort ( const std::string &  name) const
Reimplemented in YACS::ENGINE::DFToDSForLoop.
Definition at line 244 of file ElementaryNode.cxx.
245{
246 return getPort<OutputDataStreamPort>(name,_setOfOutputDataStreamPort);
247}
References _setOfOutputDataStreamPort.
Referenced by getReadyTasks(), and YACS::HMI::CommandAddODSPortFromCatalog::localReverse().
◆ getOutputPort()
OutputPort * ElementaryNode::getOutputPort ( const std::string &  name) const
◆ getPort()
PORT * YACS::ENGINE::ElementaryNode::getPort ( const std::string &  name,
const std::list< PORT * > &  setOfPorts
protected: get a port in a list given it's name
Definition at line 160 of file ElementaryNode.hxx.
161 {
162 for(typename std::list<PORT *>::const_iterator iter=setOfPorts.begin();iter!=setOfPorts.end();iter++)
163 {
164 if((*iter)->getName()==name)
165 return *iter;
166 }
167 std::string what="ElementaryNode::getPort : unexisting "; what+=PORT::NAME;
168 what+=" with name ";
169 what+=name;
170 throw Exception(what);
171 }
◆ getProgressWeight()
list< ProgressWeight > ElementaryNode::getProgressWeight ( ) const
Get the progress weight for all elementary nodes.
Only elementary nodes have weight. At this stage weight is 0 or 1 (it can be modified later following the kind of father)
Definition at line 558 of file ElementaryNode.cxx.
559{
560 list<ProgressWeight> ret;
561 ProgressWeight myWeight;
562 myWeight.weightTotal=1;
563 if (getState() == YACS::DONE)
564 myWeight.weightDone=1;
565 else
566 myWeight.weightDone=0;
567 ret.push_back(myWeight);
568 return ret;
569}
YACS::StatesForNode getState() const
References YACS::DONE, getState(), YACS::ENGINE::ProgressWeight::weightDone, and YACS::ENGINE::ProgressWeight::weightTotal.
◆ getReadyTasks()
void ElementaryNode::getReadyTasks ( std::vector< Task * > &  tasks)
add this node task to a given set of ready tasks, if this task is ready to activate
Reimplemented in YACS::ENGINE::DFToDSForLoop, and YACS::ENGINE::DSToDFForLoop.
Definition at line 362 of file ElementaryNode.cxx.
363{
364 DEBTRACE("ElementaryNode::getReadyTasks: " << getName() << " " << _state);
365
366 int multi = 1;
367 std::map<std::string,std::string>::iterator it=_propertyMap.find("multi");
368 if(it != _propertyMap.end())
369 {
370 std::string multi_str = it->second;
371 std::istringstream iss(multi_str);
372 if (!(iss >> multi))
373 throw Exception("Property multi should be set with a stringified int not an: " + multi_str);
374 }
375
377 {
378 if (multi == 1)
379 {
380 std::map<std::string,std::string>::iterator it=_propertyMap.find("multi_working_dir");
381 if(it != _propertyMap.end())
382 {
383 std::string working_dir_base = it->second;
384 std::ostringstream working_dir_stream;
385 working_dir_stream << working_dir_base;
386 working_dir_stream << 1;
387 this->getContainer()->setProperty("workingdir", working_dir_stream.str());
388 }
389 tasks.push_back(this);
390 }
391 else
392 {
393
394 // Check output port -> cannot clone an Elementary Node with Output Ports connected
395 std::list<OutputPort *>::iterator it_output = _setOfOutputPort.begin();
396 for (;it_output != _setOfOutputPort.end(); it_output++)
397 {
398 if ((*it_output)->isConnected())
399 {
400 throw Exception("Property multi cannot be set on nodes with dataflow output ports connected");
401 }
402 }
403
404 // Add my instance
405 std::map<std::string,std::string>::iterator it=_propertyMap.find("multi_working_dir");
406 if(it != _propertyMap.end())
407 {
408 std::string working_dir_base = it->second;
409 std::ostringstream working_dir_stream;
410 working_dir_stream << working_dir_base;
411 working_dir_stream << 1;
412 this->getContainer()->setProperty("workingdir", working_dir_stream.str());
413 }
414 tasks.push_back(this);
415
416 // Step 1: Create clones
417 for (int i = 1; i < multi; i++)
418 {
419 // Clone
420 YACS::ENGINE::ElementaryNode * new_node = static_cast<YACS::ENGINE::ElementaryNode *>(clone(_father, false));
421 new_node->createMultiDatastreamPorts();
422
423 // Change name
424 std::string iname;
425 std::stringstream inamess;
426 inamess << getName() << "_" << i;
427 iname=inamess.str();
428 DEBTRACE("Create clone "<< iname << " of node " << getName());
429 new_node->setName(iname);
430
431 // For each input port connect it with the original output port
432 std::list<InputPort *> clone_list_inputPorts = new_node->getSetOfInputPort();
433 for(list<InputPort *>::const_iterator iter1=clone_list_inputPorts.begin(); iter1!=clone_list_inputPorts.end(); iter1++)
434 {
435 std::string input_port_name = (*iter1)->getName();
436 // Get Port Name in master node
437 InputPort * master_port = getInputPort(input_port_name);
438 for (auto itt : master_port->_backLinks)
439 {
440 // Connect dataflow
441 getProc()->edAddDFLink(itt.first,(*iter1));
442 }
443 }
444
445 // InputDataStreamPort connections
446 std::list<InputDataStreamPort *> clone_list_inputDatastreamPorts = new_node->getSetOfInputDataStreamPort();
447 for(list<InputDataStreamPort *>::iterator iter = clone_list_inputDatastreamPorts.begin(); iter != clone_list_inputDatastreamPorts.end(); iter++)
448 {
449 std::string port_name = (*iter)->getName();
450 InputDataStreamPort * orig_port = getInputDataStreamPort(port_name);
451
452 std::set<OutputDataStreamPort *> connected_ports = orig_port->getConnectedOutputDataStreamPort();
453
454 // Create datastream ports if not created
455 std::set<OutputDataStreamPort *>::const_iterator iter3;
456 for(iter3=connected_ports.begin();iter3!=connected_ports.end();iter3++)
457 {
458 ElementaryNode * node = (ElementaryNode *) (*iter3)->getNode();
460
461 std::string good_port_name;
462 std::stringstream temp_name;
463 std::string out_name = (*iter3)->getName();
464 out_name.erase(out_name.end()-1);
465 temp_name << out_name << i;
466 good_port_name = temp_name.str();
467 getProc()->edAddLink(node->getOutputDataStreamPort(good_port_name), (*iter));
468 }
469 }
470
471 // OutputDataStreamPort connections
472 std::list<OutputDataStreamPort *> clone_list_outputDatastreamPorts = new_node->getSetOfOutputDataStreamPort();
473 for(list<OutputDataStreamPort *>::iterator iter = clone_list_outputDatastreamPorts.begin(); iter != clone_list_outputDatastreamPorts.end(); iter++)
474 {
475 std::string port_name = (*iter)->getName();
476 OutputDataStreamPort * orig_port = getOutputDataStreamPort(port_name);
477 std::set<InputDataStreamPort *> dest_input_port = orig_port->_setOfInputDataStreamPort;
478 for(set<InputDataStreamPort *>::iterator dest_port = dest_input_port.begin(); dest_port != dest_input_port.end(); dest_port++)
479 {
480 ElementaryNode * dest_node = (ElementaryNode *)(*dest_port)->getNode();
481 // Add InputPort to dest node
482 dest_node->createMultiDatastreamPorts();
483
484 std::string good_port_name;
485 std::stringstream temp_name;
486 std::string in_name = (*dest_port)->getName();
487 in_name.erase(in_name.end()-1);
488 temp_name << in_name << i;
489 good_port_name = temp_name.str();
490 getProc()->edAddLink((*iter), dest_node->getInputDataStreamPort(good_port_name));
491 }
492 }
493
494 // Init node
495 new_node->init(false);
496 new_node->exUpdateState();
497
498 // Set Control Link to done
499 std::list<OutGate *> clone_cl_back = new_node->getInGate()->getBackLinks();
500 for(std::list<OutGate *>::const_iterator iter=clone_cl_back.begin(); iter!=clone_cl_back.end(); iter++)
501 new_node->getInGate()->exNotifyFromPrecursor((*iter));
502
503 // Add clone
504 std::map<std::string,std::string>::iterator it=_propertyMap.find("multi_working_dir");
505 if(it != _propertyMap.end())
506 {
507 std::string working_dir_base = it->second;
508 std::ostringstream working_dir_stream;
509 working_dir_stream << working_dir_base;
510 working_dir_stream << i+1;
511 new_node->getContainer()->setProperty("workingdir", working_dir_stream.str());
512 }
513 tasks.push_back(new_node);
514 }
515 }
516 }
517}
virtual bool edAddDFLink(OutPort *start, InPort *end)
Connect an OutPort to an InPort and add the necessary control link.
bool edAddLink(OutPort *start, InPort *end)
Add a dataflow link between two data ports.
virtual void setProperty(const std::string &name, const std::string &value)=0
InputPort * getInputPort(const std::string &name) const
OutputDataStreamPort * getOutputDataStreamPort(const std::string &name) const
std::list< OutputDataStreamPort * > getSetOfOutputDataStreamPort() const
void init(bool start=true)
InputDataStreamPort * getInputDataStreamPort(const std::string &name) const
virtual void createMultiDatastreamPorts()
std::list< InputDataStreamPort * > getSetOfInputDataStreamPort() const
void exUpdateState()
std::list< OutGate * > getBackLinks()
Definition: InGate.cxx:134
void exNotifyFromPrecursor(OutGate *fromgate)
Notify this port that an upstream node connected by a control flow link is finished.
Definition: InGate.cxx:68
std::set< std::pair< OutPort *, bool > > _backLinks
Definition: InPort.hxx:78
std::set< OutputDataStreamPort * > getConnectedOutputDataStreamPort()
Change the name of the node.
Definition: Node.cxx:162
Node * clone(ComposedNode *father, bool editionOnly=true) const
This method MUST NEVER BE VIRTUAL
Definition: Node.cxx:131
InGate * getInGate()
Definition: Node.hxx:123
virtual Proc * getProc()
Definition: Node.cxx:401
std::set< InputDataStreamPort * > _setOfInputDataStreamPort
@ TORECONNECT
Definition: define.hxx:48
References YACS::ENGINE::InPort::_backLinks, YACS::ENGINE::Node::_father, YACS::ENGINE::Node::_propertyMap, YACS::ENGINE::OutputDataStreamPort::_setOfInputDataStreamPort, _setOfOutputPort, YACS::ENGINE::Node::_state, YACS::ENGINE::Node::clone(), createMultiDatastreamPorts(), DEBTRACE, YACS::ENGINE::ComposedNode::edAddDFLink(), YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::InGate::exNotifyFromPrecursor(), exUpdateState(), YACS::ENGINE::InGate::getBackLinks(), YACS::ENGINE::InputDataStreamPort::getConnectedOutputDataStreamPort(), getContainer(), YACS::ENGINE::Node::getInGate(), getInputDataStreamPort(), getInputPort(), YACS::ENGINE::Node::getName(), getOutputDataStreamPort(), YACS::ENGINE::Node::getProc(), getSetOfInputDataStreamPort(), getSetOfInputPort(), getSetOfOutputDataStreamPort(), yacsorb.CORBAEngineTest::i, init(), YACS::ENGINE::Node::setName(), YACS::ENGINE::Container::setProperty(), YACS::TOACTIVATE, YACS::TOLOAD, and YACS::TORECONNECT.
Referenced by YACS::ENGINE::ForEachLoopGen::getReadyTasks(), YACS::ENGINE::Loop::getReadyTasks(), YACS::ENGINE::OptimizerLoop::getReadyTasks(), and YACS::ENGINE::Switch::getReadyTasks().
◆ getRecursiveConstituents()
list< ElementaryNode * > ElementaryNode::getRecursiveConstituents ( ) const
a set with only this node. (Same method in composed nodes)
Definition at line 546 of file ElementaryNode.cxx.
547{
548 list<ElementaryNode *> ret;
549 ret.push_back((ElementaryNode *)this);
550 return ret;
551}
◆ getSetOfInputDataStreamPort()
std::list< InputDataStreamPort * > YACS::ENGINE::ElementaryNode::getSetOfInputDataStreamPort ( ) const
◆ getSetOfInputPort()
◆ getSetOfLinksComingInCurrentScope()
std::vector< std::pair< InPort *, OutPort * > > ElementaryNode::getSetOfLinksComingInCurrentScope ( ) const
Definition at line 221 of file ElementaryNode.cxx.
222{
223 vector< pair<InPort *, OutPort *> > ret;
225 for(set<InPort *>::iterator iter2=ports.begin();iter2!=ports.end();iter2++)
226 {
227 set<OutPort *> temp2=(*iter2)->edSetOutPort();
228 for(set<OutPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
229 {
230 std::set<OutPort *> trueOutPorts;
231 (*iter3)->getAllRepresented(trueOutPorts);
232 for(std::set<OutPort *>::iterator iter4=trueOutPorts.begin();iter4!=trueOutPorts.end();++iter4)
233 ret.push_back(pair<InPort *, OutPort *>(*iter2,*iter4));
234 }
235 }
236 return ret;
237}
std::set< InPort * > getAllInPortsComingFromOutsideOfCurrentScope() const
References getAllInPortsComingFromOutsideOfCurrentScope().
◆ getSetOfLinksLeavingCurrentScope()
std::vector< std::pair< OutPort *, InPort * > > ElementaryNode::getSetOfLinksLeavingCurrentScope ( ) const
Definition at line 208 of file ElementaryNode.cxx.
209{
210 vector< pair<OutPort *, InPort *> > ret;
211 std::set<OutPort *> ports=getAllOutPortsLeavingCurrentScope();
212 for(set<OutPort *>::iterator iter2=ports.begin();iter2!=ports.end();iter2++)
213 {
214 set<InPort *> temp2=(*iter2)->edSetInPort();
215 for(set<InPort *>::iterator iter3=temp2.begin();iter3!=temp2.end();iter3++)
216 ret.push_back(pair<OutPort *, InPort *>(*iter2,*iter3));
217 }
218 return ret;
219}
std::set< OutPort * > getAllOutPortsLeavingCurrentScope() const
References getAllOutPortsLeavingCurrentScope().
◆ getSetOfOutputDataStreamPort()
std::list< OutputDataStreamPort * > YACS::ENGINE::ElementaryNode::getSetOfOutputDataStreamPort ( ) const
◆ getSetOfOutputPort()
◆ getState()
◆ getWeight()
ComplexWeight * YACS::ENGINE::ElementaryNode::getWeight ( )
◆ getWeightRegardingDPL()
void YACS::ENGINE::ElementaryNode::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 113 of file ElementaryNode.hxx.
113{ weight->addWeight(getWeight()); }
References YACS::ENGINE::ComplexWeight::addWeight().
◆ init()
void ElementaryNode::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Reimplemented in YACS::ENGINE::SplitterNode, and YACS::ENGINE::PyFuncNode.
Definition at line 99 of file ElementaryNode.cxx.
100{
101 DEBTRACE("ElementaryNode::init " << getName() << " " << start << " " << _state);
104 {
105 exDisabledState(); // to refresh propagation of DISABLED state
106 return ;
107 }
109}
void initCommonPartWithoutStateManagement(bool start)
virtual void exDisabledState()
Notify this node that it has been disabled.
Definition: Node.cxx:232
References YACS::ENGINE::Node::_state, DEBTRACE, YACS::DISABLED, YACS::ENGINE::Node::exDisabledState(), YACS::ENGINE::Node::getName(), initCommonPartWithoutStateManagement(), YACS::READY, and YACS::ENGINE::Node::setState().
Referenced by getReadyTasks(), and YACS::ENGINE::SplitterNode::init().
◆ initCommonPartWithoutStateManagement()
void ElementaryNode::initCommonPartWithoutStateManagement ( bool  start)
Definition at line 90 of file ElementaryNode.cxx.
91{
92 for(list<OutputPort *>::iterator iter=_setOfOutputPort.begin();iter!=_setOfOutputPort.end();iter++)
93 (*iter)->exInit();
94 for(list<InputPort *>::iterator iter2=_setOfInputPort.begin();iter2!=_setOfInputPort.end();iter2++)
95 (*iter2)->exInit(start);
97}
References YACS::ENGINE::Node::_inGate, _setOfInputPort, _setOfOutputPort, and YACS::ENGINE::InGate::exReset().
Referenced by init(), and YACS::ENGINE::PyFuncNode::init().
◆ initService()
virtual void YACS::ENGINE::ElementaryNode::initService ( )
Definition at line 124 of file ElementaryNode.hxx.
124{ }
◆ isDeployable()
bool ElementaryNode::isDeployable ( ) const
Reimplemented in YACS::ENGINE::InlineNode, YACS::ENGINE::ServerNode, and YACS::ENGINE::ServiceNode.
Definition at line 111 of file ElementaryNode.cxx.
112{
113 return false;
114}
◆ isPortNameAlreadyExist()
bool YACS::ENGINE::ElementaryNode::isPortNameAlreadyExist ( const std::string &  portName,
staticprotected
protected: checks existence of a port, given it's name, in a list
Definition at line 226 of file ElementaryNode.hxx.
227 {
228 for(typename std::list<PORT *>::const_iterator iter=setOfPorts.begin();iter!=setOfPorts.end();iter++)
229 {
230 if((*iter)->getName()==portName)
231 return true;
232 }
233 return false;
234 }
◆ isReady()
bool ElementaryNode::isReady ( )
Definition at line 754 of file ElementaryNode.cxx.
755{
756 return _state==TOACTIVATE;
757}
References YACS::ENGINE::Node::_state, and YACS::TOACTIVATE.
◆ load()
◆ loaded()
void ElementaryNode::loaded ( )
Notify this node that it is loaded.
When an elementary node has been loaded It is ready to be connected
Definition at line 774 of file ElementaryNode.cxx.
775{
776}
◆ partitionRegardingDPL()
void YACS::ENGINE::ElementaryNode::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 114 of file ElementaryNode.hxx.
114{ }
◆ performDuplicationOfPlacement()
void ElementaryNode::performDuplicationOfPlacement ( const Node &  other)
performs a duplication of placement using clone method of containers and components. clone behaviour is driven by attachOnCloning attribute.
Definition at line 70 of file ElementaryNode.cxx.
71{
72}
◆ performShallowDuplicationOfPlacement()
void ElementaryNode::performShallowDuplicationOfPlacement ( const Node &  other)
performs a also duplication of placement but here containers and components are not copied at all whatever the value of attachedOnCloning.
Definition at line 74 of file ElementaryNode.cxx.
75{
76}
◆ setWeight()
void ElementaryNode::setWeight ( double  elementaryWeight)
Definition at line 897 of file ElementaryNode.cxx.
898{
899 if(elementaryWeight<=0.)
900 throw Exception("ElementaryNode::setWeight : invalid input value !");
901 _weight.setElementaryWeight(elementaryWeight);
902}
void setElementaryWeight(double elementaryWeight)
References _weight, and YACS::ENGINE::ComplexWeight::setElementaryWeight().
Referenced by YACS::inlinetypeParser< T >::function(), YACS::remotetypeParser< T >::function(), and YACS::remotetypeParser< T >::script().
◆ typeName()
◆ ComposedNode
friend class ComposedNode
friend
Definition at line 45 of file ElementaryNode.hxx.
◆ _createDatastreamPorts
bool YACS::ENGINE::ElementaryNode::_createDatastreamPorts
Definition at line 54 of file ElementaryNode.hxx.
Referenced by createMultiDatastreamPorts(), and ElementaryNode().
◆ _multi_port_node
bool YACS::ENGINE::ElementaryNode::_multi_port_node
Definition at line 55 of file ElementaryNode.hxx.
◆ _setOfInputDataStreamPort
◆ _setOfInputPort
◆ _setOfOutputDataStreamPort
◆ _setOfOutputPort
◆ _weight
ComplexWeight YACS::ENGINE::ElementaryNode::_weight
Definition at line 51 of file ElementaryNode.hxx.
Referenced by ElementaryNode(), and setWeight().
