YACS::ENGINE::FakeNodeForLoop Class Reference
#include <Loop.hxx>
Inheritance diagram for YACS::ENGINE::FakeNodeForLoop:
Collaboration diagram for YACS::ENGINE::FakeNodeForLoop:
 FakeNodeForLoop (Loop *loop, bool normalFinish, bool internalError=false)
 FakeNodeForLoop (const FakeNodeForLoop &other)
Node * simpleClone (ComposedNode *father, bool editionOnly) const
void exForwardFailed ()
void exForwardFinished ()
void execute ()
void aborted ()
void finished ()
Loop * _loop
bool _normalFinish
bool _internalError
Friends
class ForLoop
class WhileLoop
virtual ~ElementaryNode ()
void exUpdateState ()
void init (bool start=true)
bool isDeployable () const
Container * getContainer ()
virtual void edUpdateState ()
virtual void ensureLoading ()
ComplexWeight * getWeight ()
void begin ()
bool isReady ()
void finished ()
void aborted ()
void loaded ()
void connected ()
virtual void initService ()
virtual void load ()
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void cleanNodes ()
virtual void begin ()=0
virtual bool isReady ()=0
virtual void execute ()=0
virtual void load ()=0
virtual void loaded ()=0
virtual void connected ()=0
virtual void initService ()=0
virtual void finished ()=0
virtual void aborted ()=0
virtual ~Task ()
YACS::Colour _colour
template<class PORT >
ComplexWeight _weight
bool _createDatastreamPorts
bool _multi_port_node
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
static int _total = 0
Definition at line 120 of file Loop.hxx.
◆ FakeNodeForLoop() [1/2]
FakeNodeForLoop::FakeNodeForLoop ( Loop *  loop,
bool  normalFinish,
bool  internalError = false
Definition at line 251 of file Loop.cxx.
251 :ElementaryNode("thisIsAFakeNode"),
252 _loop(loop),
253 _normalFinish(normalFinish),
254 _internalError(internalError)
255{
258}
Definition: Node.hxx:90
friend class ElementaryNode
Definition: Node.hxx:80
ComposedNode * getFather() const
Definition: Node.hxx:127
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
@ TOACTIVATE
Definition: define.hxx:40
References YACS::ENGINE::Node::_father, _loop, YACS::ENGINE::Node::getFather(), YACS::ENGINE::Node::setState(), and YACS::TOACTIVATE.
Referenced by simpleClone().
◆ FakeNodeForLoop() [2/2]
FakeNodeForLoop::FakeNodeForLoop ( const FakeNodeForLoop &  other)
Definition at line 260 of file Loop.cxx.
260 :ElementaryNode(other),_loop(0),
261 _normalFinish(false),_internalError(true)
262{
263}
◆ aborted()
void FakeNodeForLoop::aborted ( )
privatevirtual
Reimplemented from YACS::ENGINE::ElementaryNode.
Definition at line 286 of file Loop.cxx.
287{
290 else
292}
@ INTERNALERR
Definition: define.hxx:49
@ ERROR
Definition: define.hxx:52
References _internalError, _loop, YACS::ERROR, YACS::INTERNALERR, and YACS::ENGINE::Node::setState().
◆ execute()
void FakeNodeForLoop::execute ( )
privatevirtual
Implements YACS::ENGINE::Task.
Definition at line 280 of file Loop.cxx.
281{
282 if(!_normalFinish)
283 throw Exception("");//only to trigger ABORT on Executor
284}
References _normalFinish.
◆ exForwardFailed()
void FakeNodeForLoop::exForwardFailed ( )
privatevirtual
Called typically by Bloc to notify failure on potentially next nodes on the same scope of 'this'
Reimplemented from YACS::ENGINE::Node.
Definition at line 270 of file Loop.cxx.
271{
273}
virtual void exForwardFailed()
Definition: Node.cxx:378
References _loop, and YACS::ENGINE::Node::exForwardFailed().
◆ exForwardFinished()
void FakeNodeForLoop::exForwardFinished ( )
privatevirtual
Called typically by Bloc to activate potentially next nodes on the same scope of 'this'
Definition at line 275 of file Loop.cxx.
276{
278}
virtual void exForwardFinished()
Definition: Node.cxx:386
References _loop, and YACS::ENGINE::Node::exForwardFinished().
◆ finished()
void FakeNodeForLoop::finished ( )
privatevirtual
Definition at line 294 of file Loop.cxx.
295{
297}
@ DONE
Definition: define.hxx:43
References _loop, YACS::DONE, and YACS::ENGINE::Node::setState().
◆ simpleClone()
Node * FakeNodeForLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly
privatevirtual
Definition at line 265 of file Loop.cxx.
266{
267 return new FakeNodeForLoop(*this);
268}
FakeNodeForLoop(Loop *loop, bool normalFinish, bool internalError=false)
Definition: Loop.cxx:251
References FakeNodeForLoop().
◆ ForLoop
friend class ForLoop
friend
Definition at line 122 of file Loop.hxx.
◆ WhileLoop
friend class WhileLoop
friend
Definition at line 123 of file Loop.hxx.
◆ _internalError
bool YACS::ENGINE::FakeNodeForLoop::_internalError
Definition at line 127 of file Loop.hxx.
Referenced by aborted().
◆ _loop
Loop* YACS::ENGINE::FakeNodeForLoop::_loop
Definition at line 125 of file Loop.hxx.
Referenced by aborted(), exForwardFailed(), exForwardFinished(), FakeNodeForLoop(), and finished().
◆ _normalFinish
bool YACS::ENGINE::FakeNodeForLoop::_normalFinish
Definition at line 126 of file Loop.hxx.
Referenced by execute().
