YACS::ENGINE::Loop Class Referenceabstract
Base class for loop node. More...
#include <Loop.hxx>
Inheritance diagram for YACS::ENGINE::Loop:
Collaboration diagram for YACS::ENGINE::Loop:
 Loop (const Loop &other, ComposedNode *father, bool editionOnly)
 Loop (const std::string &name)
 ~Loop ()
void init (bool start=true)
int getNbOfTurns () const
Node * edSetNode (Node *DISOWNnode)
virtual bool edAddChild (Node *DISOWNnode)
bool isLoop () const override
Node * edRemoveNode ()
virtual InputPort * getDecisionPort () const =0
 Returns the port which value is used to take decision about the continuation of the loop. More...
 Collect all the child nodes that are ready. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isRepeatedUnpredictablySeveralTimes () const
std::list< Node * > edGetDirectDescendants () const
Node * getChildByShortName (const std::string &name) const
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
void writeDot (std::ostream &os) const
 Dump the node state to a stream. More...
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
static TypeCode * MappingDF2DS (TypeCode *type)
static TypeCode * MappingDS2DF (TypeCode *type)
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkNoCyclePassingThrough (Node *node)
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
static bool isNecessaryToBuildSpecificDelegateDF2DS (const std::list< ComposedNode * > &pointsOfView)
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
Node * _node
int _nbOfTurns
FakeNodeForLoop * _nodeForNullTurnOfLoops
std::set< DSToDFForLoop * > _inputsTraducer
std::set< DFToDSForLoop * > _outputsTraducer
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Friends
class DSToDFForLoop
class FakeNodeForLoop
void NbDoneLoader (Loop *node, int val)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
See also
ForLoop
WhileLoop
Definition at line 146 of file Loop.hxx.
◆ Loop() [1/2]
Loop::Loop ( const Loop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 299 of file Loop.cxx.
300{
301 if(other._node)
302 _node=other._node->simpleClone(this,editionOnly);
303}
Definition: Loop.hxx:154
virtual Node * simpleClone(ComposedNode *father, bool editionOnly=true) const =0
References _node, and YACS::ENGINE::Node::simpleClone().
◆ Loop() [2/2]
Loop::Loop ( const std::string &  name)
Definition at line 305 of file Loop.cxx.
◆ ~Loop()
Loop::~Loop ( )
Definition at line 309 of file Loop.cxx.
310{
311 delete _node;
313 for(set<DSToDFForLoop *>::iterator iter1=_inputsTraducer.begin();iter1!=_inputsTraducer.end();iter1++)
314 delete (*iter1);
315 for(set<DFToDSForLoop *>::iterator iter2=_outputsTraducer.begin();iter2!=_outputsTraducer.end();iter2++)
316 delete (*iter2);
317}
Definition: Loop.hxx:155
Definition: Loop.hxx:156
References _inputsTraducer, _node, _nodeForNullTurnOfLoops, and _outputsTraducer.
◆ accept()
void Loop::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::ComposedNode.
Reimplemented in YACS::ENGINE::ForLoop, and YACS::ENGINE::WhileLoop.
Definition at line 674 of file Loop.cxx.
675{
676 visitor->visitLoop(this);
677}
virtual void visitLoop(Loop *node)=0
References YACS::ENGINE::Visitor::visitLoop().
◆ buildDelegateOf() [1/2]
void Loop::buildDelegateOf ( InPort *&  port,
OutPort *  initialStart,
const std::list< ComposedNode * > &  pointsOfView
Definition at line 459 of file Loop.cxx.
460{
461 string typeOfPortInstance=port->getNameOfTypeOfCurrentInstance();
462 if(typeOfPortInstance!=InputPort::NAME ||
463 (typeOfPortInstance == InputPort::NAME &&
466 return ;
467 InputPort *portCasted=(InputPort *)port;
468 set<DSToDFForLoop*>::iterator iter;
469 //Determinig if a DSToDFForLoop node has already been created for delegation of 'port'
470 for(iter=_inputsTraducer.begin();iter!=_inputsTraducer.end();iter++)
471 if((*iter)->getOutputPort("")->isAlreadyInSet(portCasted))
472 break;
473 if(iter==_inputsTraducer.end())
474 {//first time that 'port' is delegated on higher level
475 pair<set<DSToDFForLoop*>::iterator, bool> iter2=_inputsTraducer.insert(new DSToDFForLoop(this,portCasted->getName(),Loop::MappingDF2DS(portCasted->edGetType())));
476 iter=iter2.first;
477 (*iter)->getOutputPort("")->addInPort(portCasted);
478 }
479 else
480 (*iter)->loopHasOneMoreRef();
481 port=(*iter)->getInputDataStreamPort("");
482}
TypeCode * edGetType() const
Definition: DataPort.hxx:53
Definition: DataPort.cxx:56
std::string getName() const
Definition: DataPort.hxx:55
Base class for Input Ports.
Definition: InputPort.hxx:44
static const char NAME[]
Definition: InputPort.hxx:48
friend class DSToDFForLoop
Definition: Loop.hxx:148
static TypeCode * MappingDF2DS(TypeCode *type)
Definition: Loop.cxx:449
static bool isNecessaryToBuildSpecificDelegateDF2DS(const std::list< ComposedNode * > &pointsOfView)
Definition: Loop.cxx:630
Definition: OutputPort.hxx:79
References _inputsTraducer, DSToDFForLoop, YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), isNecessaryToBuildSpecificDelegateDF2DS(), MappingDF2DS(), YACS::ENGINE::InputPort::NAME, and YACS::ENGINE::OutputPort::NAME.
◆ buildDelegateOf() [2/2]
void Loop::buildDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
InPort *  finalTarget,
Definition at line 484 of file Loop.cxx.
485{
486 string typeOfPortInstance=(port.first)->getNameOfTypeOfCurrentInstance();
487 if(typeOfPortInstance!=OutputPort::NAME ||
488 ( typeOfPortInstance == OutputPort::NAME &&
491 return ;
492 OutPort *portCasted=port.first;
493 set<DFToDSForLoop*>::iterator iter;
494 //Determinig if a DFToDSForLoop node has already been created for delegation of 'port'
495 for(iter=_outputsTraducer.begin();iter!=_outputsTraducer.end();iter++)
496 if(portCasted->isAlreadyLinkedWith((*iter)->getInputPort("")))
497 break;
498 DFToDSForLoop *kl;
499 if(iter==_outputsTraducer.end())
500 {//first time that 'port' is delegated on higher level
501 //_outputsTraducer.insert(new DFToDSForLoop(this,portCasted->getName(),portCasted->edGetType()));
502 kl=new DFToDSForLoop(this,portCasted->getName(),portCasted->edGetType());
503 pair<set<DFToDSForLoop*>::iterator, bool> iter2=_outputsTraducer.insert(kl);
504 iter=iter2.first;
505 portCasted->addInPort((*iter)->getInputPort(""));
506 }
507 else
508 {
509 kl=*iter;
510 kl->loopHasOneMoreRef();
511 }
512 edAddLink(isInMyDescendance((port.first)->getNode())->getOutGate(),kl->getInGate());
513 port.first=(*iter)->getOutputDataStreamPort("");
514}
bool edAddLink(OutPort *start, InPort *end)
Node * isInMyDescendance(Node *nodeToTest) const
OutGate * getOutGate()
Definition: Node.hxx:124
InGate * getInGate()
Definition: Node.hxx:123
virtual bool isAlreadyLinkedWith(InPort *withp) const =0
virtual bool addInPort(InPort *inPort)=0
References _outputsTraducer, YACS::ENGINE::OutPort::addInPort(), YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::DataPort::edGetType(), YACS::ENGINE::Node::getInGate(), YACS::ENGINE::DataPort::getName(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::Node::getOutGate(), YACS::ENGINE::OutPort::isAlreadyLinkedWith(), YACS::ENGINE::ComposedNode::isInMyDescendance(), isNecessaryToBuildSpecificDelegateDF2DS(), YACS::ENGINE::DFToDSForLoop::loopHasOneMoreRef(), YACS::ENGINE::InputPort::NAME, and YACS::ENGINE::OutputPort::NAME.
◆ checkBasicConsistency()
void Loop::checkBasicConsistency ( ) const
Definition at line 693 of file Loop.cxx.
694{
695 DEBTRACE("Loop::checkBasicConsistency");
697 if(!_node)
698 throw Exception("For a loop, internal node is mandatory");
699}
References _node, YACS::ENGINE::ComposedNode::checkBasicConsistency(), and DEBTRACE.
◆ checkCFLinks()
void Loop::checkCFLinks ( const std::list< OutPort * > &  starts,
InputPort *  end,
unsigned char &  alreadyFed,
bool  direction,
LinkInfo &  info
startsIf different of 0, must aggregate at leat 1 element.
end:
alreadyFedin/out parameter. Indicates if 'end' ports is already and surely set or fed by an another port.
directionIf true : forward direction else backward direction.
info: informations collectedduring the check
Definition at line 612 of file Loop.cxx.
613{
614 Node *nodeEnd=end->getNode();
615 if(nodeEnd==this)
616 {//In this case 'end' port is a special port of this (for exemple ForLoop::_nbOfTimesPort)
617 //ASSERT(!direction) see Loop::checkControlDependancy (bw only)
618 solveObviousOrDelegateCFLinks(starts,end,alreadyFed,direction,info);
619 }
620 else
621 StaticDefinedComposedNode::checkCFLinks(starts,end,alreadyFed,direction,info);
622}
void solveObviousOrDelegateCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
Base class for all nodes.
Definition: Node.hxx:70
Node * getNode() const
Definition: Port.hxx:46
References YACS::ENGINE::ComposedNode::checkCFLinks(), YACS::ENGINE::Port::getNode(), and YACS::ENGINE::ComposedNode::solveObviousOrDelegateCFLinks().
◆ checkControlDependancy()
void Loop::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  bw,
LinkInfo &  info
Implements YACS::ENGINE::ComposedNode.
Definition at line 679 of file Loop.cxx.
684{
685 //First testing if end==getDecisionPort. This is the only case possible in theory.
686 if(end!=getDecisionPort())
687 return StaticDefinedComposedNode::checkControlDependancy(start,end,cross,fw,fwCross,bw,info);
688 if(cross)
689 throw Exception("Internal error occured - cross type link detected on decision port of a loop. Forbidden !");
690 fw[(ComposedNode *)this].push_back(start);
691}
virtual InputPort * getDecisionPort() const =0
void checkControlDependancy(OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
References YACS::ENGINE::StaticDefinedComposedNode::checkControlDependancy(), and getDecisionPort().
◆ checkNoCyclePassingThrough()
void Loop::checkNoCyclePassingThrough ( Node *  node)
Definition at line 607 of file Loop.cxx.
608{
609 //throw Exception("Loop::checkNoCyclePassingThrough : Internal error occured");
610}
◆ edAddChild()
bool Loop::edAddChild ( Node *  DISOWNnode)
Definition at line 353 of file Loop.cxx.
354{
355 return edSetNode(node);
356}
Node * edSetNode(Node *DISOWNnode)
Definition: Loop.cxx:331
References edSetNode().
◆ edAddDFLink()
bool Loop::edAddDFLink ( OutPort *  start,
InPort *  end
Connect the ports with a data link (edAddLink) In a Loop don't add control flow link : use this only to add data back links
start: the OutPort to connect
end: the InPort to connect
true if a new link has been created, false otherwise.
Definition at line 647 of file Loop.cxx.
648{
649 return edAddLink(start,end);
650}
References YACS::ENGINE::ComposedNode::edAddLink().
◆ edGetDirectDescendants()
std::list< Node * > Loop::edGetDirectDescendants ( ) const
Definition at line 401 of file Loop.cxx.
402{
403 list<Node *> ret;
404 if(_node)
405 ret.push_back(_node);
406 return ret;
407}
References _node.
Referenced by YACS::ENGINE::ForLoop::getProgressWeight().
◆ edRemoveChild()
void Loop::edRemoveChild ( Node *  node)
Definition at line 393 of file Loop.cxx.
394{
396 if(_node==node)
397 _node=0;
398 modified();
399}
virtual void edRemoveChild(Node *node)
virtual void modified()
Sets Node in modified state and its father if it exists.
Definition: Node.cxx:805
References _node, YACS::ENGINE::ComposedNode::edRemoveChild(), and YACS::ENGINE::Node::modified().
◆ edRemoveNode()
Node * Loop::edRemoveNode ( )
Definition at line 358 of file Loop.cxx.
359{
361 Node *ret=_node;
362 _node=0;
363 modified();
364 return ret;
365}
◆ edSetNode()
Node * Loop::edSetNode ( Node *  DISOWNnode)
Definition at line 331 of file Loop.cxx.
332{
333 if(_node==node)
334 return 0;
335 if(node)
336 {
337 if(node->_father)
338 {
339 string what = "Loop::edSetNode: node "; what += node->getName(); what += " is not orphan ! ";
340 throw Exception(what);
341 }
342 }
345 Node *ret=_node;
346 _node=node;
347 _node->_father=this;
348 //set _modified flag so that edUpdateState() can refresh state
349 modified();
350 return ret;
351}
void checkNoCrossHierachyWith(Node *node) const
Definition: Node.hxx:90
References YACS::ENGINE::Node::_father, _node, YACS::ENGINE::ComposedNode::checkNoCrossHierachyWith(), YACS::ENGINE::ComposedNode::edRemoveChild(), YACS::ENGINE::Node::getName(), and YACS::ENGINE::Node::modified().
Referenced by edAddChild().
◆ getChildByShortName()
Node * Loop::getChildByShortName ( const std::string &  name) const
Definition at line 440 of file Loop.cxx.
441{
442 if (_node)
443 if(name==_node->getName())
444 return _node;
445 string what("node "); what+= name ; what+=" is not a child of loop node "; what += getName();
446 throw Exception(what);
447}
Definition: Node.hxx:125
References _node, YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::Node::getName().
◆ getDecisionPort()
virtual InputPort * YACS::ENGINE::Loop::getDecisionPort ( ) const
pure virtual
Implemented in YACS::ENGINE::ForLoop, and YACS::ENGINE::WhileLoop.
Referenced by checkControlDependancy(), and getSetOfInputPort().
◆ getDelegateOf() [1/2]
void Loop::getDelegateOf ( InPort *&  port,
Definition at line 516 of file Loop.cxx.
517{
518 string typeOfPortInstance=port->getNameOfTypeOfCurrentInstance();
519 if(typeOfPortInstance!=InputPort::NAME ||
520 (typeOfPortInstance == InputPort::NAME &&
523 return ;
524 InputPort *portCasted=(InputPort *)port;
525 set<DSToDFForLoop*>::iterator iter;
526 for(iter=_inputsTraducer.begin();iter!=_inputsTraducer.end();iter++)
527 if((*iter)->getOutputPort("")->isAlreadyInSet(portCasted))
528 break;
529 if(iter==_inputsTraducer.end())
530 {
531 string what("Loop::getDelegateOf : Port with name "); what+=portCasted->getName(); what+=" not exported by loop "; what+=_name;
532 throw Exception(what);
533 }
534 else
535 port=(*iter)->getInputDataStreamPort("");
536}
std::string _name
Definition: Node.hxx:89
References _inputsTraducer, YACS::ENGINE::Node::_name, YACS::ENGINE::DataPort::getName(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), isNecessaryToBuildSpecificDelegateDF2DS(), YACS::ENGINE::InputPort::NAME, and YACS::ENGINE::OutputPort::NAME.
◆ getDelegateOf() [2/2]
void Loop::getDelegateOf ( std::pair< OutPort *, OutPort * > &  port,
Definition at line 538 of file Loop.cxx.
540{
541 string typeOfPortInstance=(port.first)->getNameOfTypeOfCurrentInstance();
542 if(typeOfPortInstance!=OutputPort::NAME ||
543 ( typeOfPortInstance == OutputPort::NAME &&
546 return ;
547 OutPort *portCasted=port.first;
548 set<DFToDSForLoop*>::iterator iter;
549 for(iter=_outputsTraducer.begin();iter!=_outputsTraducer.end();iter++)
550 if(portCasted->isAlreadyLinkedWith((*iter)->getInputPort("")))
551 break;
552 if(iter==_outputsTraducer.end())
553 {
554 string what("Loop::getDelegateOf : Port with name "); what+=portCasted->getName(); what+=" not exported by loop "; what+=_name;
555 throw Exception(what);
556 }
557 else
558 port.first=(*iter)->getOutputDataStreamPort("");
559}
References YACS::ENGINE::Node::_name, _outputsTraducer, YACS::ENGINE::DataPort::getName(), YACS::ENGINE::DataPort::getNameOfTypeOfCurrentInstance(), YACS::ENGINE::OutPort::isAlreadyLinkedWith(), isNecessaryToBuildSpecificDelegateDF2DS(), YACS::ENGINE::InputPort::NAME, and YACS::ENGINE::OutputPort::NAME.
◆ getMaxLevelOfParallelism()
int Loop::getMaxLevelOfParallelism ( ) const
Definition at line 421 of file Loop.cxx.
422{
423 if(!_node)
424 return 0;
426}
virtual int getMaxLevelOfParallelism() const =0
References _node, and YACS::ENGINE::Node::getMaxLevelOfParallelism().
◆ getNbOfTurns()
◆ getNumberOfInputPorts()
int Loop::getNumberOfInputPorts ( ) const
Definition at line 416 of file Loop.cxx.
References YACS::ENGINE::ComposedNode::getNumberOfInputPorts().
◆ getReadyTasks()
void Loop::getReadyTasks ( std::vector< Task * > &  tasks)
tasks: vector of tasks to collect ready nodes
Definition at line 371 of file Loop.cxx.
372{
373 if(!_node)
374 return;
375 /*
376 * To change the way ComposedNode state is handled, uncomment the following line
377 * see Bloc::getReadyTasks
378 */
383 else
384 {
385 _node->getReadyTasks(tasks);
386 for(set<DSToDFForLoop *>::iterator iter1=_inputsTraducer.begin();iter1!=_inputsTraducer.end();iter1++)
387 (*iter1)->getReadyTasks(tasks);
388 for(set<DFToDSForLoop *>::iterator iter2=_outputsTraducer.begin();iter2!=_outputsTraducer.end();iter2++)
389 (*iter2)->getReadyTasks(tasks);
390 }
391}
void getReadyTasks(std::vector< Task * > &tasks)
virtual void getReadyTasks(std::vector< Task * > &tasks)=0
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
Definition: Node.hxx:91
@ ACTIVATED
Definition: define.hxx:41
@ TOACTIVATE
Definition: define.hxx:40
References _inputsTraducer, _node, _nodeForNullTurnOfLoops, _outputsTraducer, YACS::ENGINE::Node::_state, YACS::ACTIVATED, YACS::ENGINE::ElementaryNode::getReadyTasks(), YACS::ENGINE::Node::getReadyTasks(), YACS::ENGINE::Node::setState(), and YACS::TOACTIVATE.
◆ getSetOfInputPort()
std::list< InputPort * > Loop::getSetOfInputPort ( ) const
Definition at line 409 of file Loop.cxx.
410{
411 list<InputPort *> ret=StaticDefinedComposedNode::getSetOfInputPort();
412 ret.push_back(getDecisionPort());
413 return ret;
414}
References getDecisionPort(), and YACS::ENGINE::ComposedNode::getSetOfInputPort().
◆ getWeightRegardingDPL()
void Loop::getWeightRegardingDPL ( ComplexWeight *  weight)
Definition at line 428 of file Loop.cxx.
429{
430 if(_node)
432}
virtual void getWeightRegardingDPL(ComplexWeight *weight)=0
References _node, and YACS::ENGINE::Node::getWeightRegardingDPL().
◆ init()
void Loop::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Reimplemented in YACS::ENGINE::WhileLoop.
Definition at line 319 of file Loop.cxx.
320{
322 _nbOfTurns=0;
323 if(_node)
324 _node->init(start); // if start is true, refresh the internal node
325 else
326 throw Exception("Loop::initLoop : no nodes specifies to be repeated ");
329}
void init(bool start=true)
virtual void init(bool start=true)
Definition: Node.cxx:102
References _nbOfTurns, _node, _nodeForNullTurnOfLoops, YACS::ENGINE::ComposedNode::init(), and YACS::ENGINE::Node::init().
Referenced by YACS::ENGINE::ForLoop::init(), and YACS::ENGINE::WhileLoop::init().
◆ isLoop()
bool YACS::ENGINE::Loop::isLoop ( ) const
inlineoverridevirtual
Definition at line 166 of file Loop.hxx.
166{ return true; }
◆ isNecessaryToBuildSpecificDelegateDF2DS()
bool Loop::isNecessaryToBuildSpecificDelegateDF2DS ( const std::list< ComposedNode * > &  pointsOfView)
staticprotected
: States if a DF port must be considered on an upper level in hierarchy as a DS port or not from 'pointsOfView' observers.
  • True : a traduction DF->DS has to be done
  • False : no traduction needed
Definition at line 630 of file Loop.cxx.
631{
632 bool ret=false;
633 for(list<ComposedNode *>::const_iterator iter=pointsOfView.begin();iter!=pointsOfView.end() && !ret;iter++)
634 ret=(*iter)->isRepeatedUnpredictablySeveralTimes();
635 return ret;
636}
Referenced by buildDelegateOf(), getDelegateOf(), and releaseDelegateOf().
◆ isRepeatedUnpredictablySeveralTimes()
bool YACS::ENGINE::Loop::isRepeatedUnpredictablySeveralTimes ( ) const
Definition at line 173 of file Loop.hxx.
173{ return true; }
◆ MappingDF2DS()
TypeCode * Loop::MappingDF2DS ( TypeCode *  type)
Definition at line 449 of file Loop.cxx.
450{
451 return type;
452}
Referenced by buildDelegateOf(), and YACS::ENGINE::DFToDSForLoop::DFToDSForLoop().
◆ MappingDS2DF()
TypeCode * Loop::MappingDS2DF ( TypeCode *  type)
Definition at line 454 of file Loop.cxx.
455{
456 return type;
457}
◆ partitionRegardingDPL()
void Loop::partitionRegardingDPL ( const PartDefinition *  pd,
std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &  zeMap
Definition at line 434 of file Loop.cxx.
435{
436 if(_node)
437 _node->partitionRegardingDPL(pd,zeMap);
438}
virtual void partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)=0
References _node, and YACS::ENGINE::Node::partitionRegardingDPL().
◆ releaseDelegateOf() [1/2]
void Loop::releaseDelegateOf ( InPort *&  port,
Definition at line 561 of file Loop.cxx.
562{
563 string typeOfPortInstance=port->getNameOfTypeOfCurrentInstance();
564 if(typeOfPortInstance!=InputPort::NAME ||
565 ( typeOfPortInstance == InputPort::NAME &&
568 return ;
569 InputPort *portCasted=(InputPort *)port;
570 set<DSToDFForLoop*>::iterator iter;
571 for(iter=_inputsTraducer.begin();iter!=_inputsTraducer.end();iter++)
572 if((*iter)->getOutputPort("")->isAlreadyInSet(portCasted))
573 break;
574 if(iter==_inputsTraducer.end())
575 {
576 string what("Loop::releaseDelegateOf Port with name "); what+=portCasted->getName(); what+=" not exported by loop "; what+=_name;
577 throw Exception(what);
578 }
579 else
580 {
581 port=(*iter)->getInputDataStreamPort("");
582 if((*iter)->loopHasOneLessRef())
583 {
584 (*iter)->getOutputPort("")->removeInPort(portCasted,false);
585 delete (*iter);
586 _inputsTraducer.erase(iter);
587 }
588 }
589}
◆ releaseDelegateOf() [2/2]
void Loop::releaseDelegateOf ( OutPort *  portDwn,
OutPort *  portUp,
Definition at line 591 of file Loop.cxx.
592{
593 if(portDwn==portUp)
594 return ;
595 set<DFToDSForLoop*>::iterator iter;
596 for(iter=_outputsTraducer.begin();iter!=_outputsTraducer.end();iter++)
597 if((*iter)->getOutputDataStreamPort("")==portUp)
598 break;
599 if((*iter)->loopHasOneLessRef())
600 {
601 portDwn->removeInPort((*iter)->getInputPort(""),false);
602 delete (*iter);
603 _outputsTraducer.erase(iter);
604 }
605}
virtual int removeInPort(InPort *inPort, bool forward)=0
References _outputsTraducer, and YACS::ENGINE::OutPort::removeInPort().
◆ typeName()
virtual std::string YACS::ENGINE::Loop::typeName ( )
Definition at line 186 of file Loop.hxx.
186{return "YACS__ENGINE__Loop";}
◆ writeDot()
void Loop::writeDot ( std::ostream &  os) const
os: the output stream
Reimplemented from YACS::ENGINE::Node.
Definition at line 656 of file Loop.cxx.
657{
658 os << " subgraph cluster_" << getId() << " {\n" ;
659 //only one node in a loop
660 if(_node)
661 {
662 _node->writeDot(os);
663 os << getId() << " -> " << _node->getId() << ";\n";
664 }
665 os << "}\n" ;
666 os << getId() << "[fillcolor=\"" ;
668 os << getColorState(state);
669 os << "\" label=\"" << "Loop:" ;
670 os << getQualifiedName() <<"\"];\n";
671}
std::string getColorState(YACS::StatesForNode state) const
Return the color associated to a state.
Definition: Node.cxx:578
std::string getQualifiedName() const
same as Node::getName() in most cases, but differs for children of switch
Definition: Node.cxx:632
const std::string getId() const
Definition: Node.cxx:478
virtual void writeDot(std::ostream &os) const
Dump to the input stream a dot representation of the node.
Definition: Node.cxx:611
virtual YACS::StatesForNode getEffectiveState() const
Return the node state in the context of its father.
Definition: Node.cxx:538
StatesForNode
Definition: define.hxx:34
References _node, YACS::ENGINE::Node::getColorState(), YACS::ENGINE::Node::getEffectiveState(), YACS::ENGINE::Node::getId(), YACS::ENGINE::Node::getQualifiedName(), yacsorb.CORBAEngineTest::state, and YACS::ENGINE::Node::writeDot().
◆ DSToDFForLoop
friend
Definition at line 148 of file Loop.hxx.
Referenced by buildDelegateOf().
◆ FakeNodeForLoop
friend class FakeNodeForLoop
friend
◆ NbDoneLoader
void NbDoneLoader ( Loop *  node,
int  val
friend
◆ _inputsTraducer
std::set<DSToDFForLoop *> YACS::ENGINE::Loop::_inputsTraducer
Definition at line 155 of file Loop.hxx.
Referenced by buildDelegateOf(), getDelegateOf(), getReadyTasks(), releaseDelegateOf(), and ~Loop().
◆ _nbOfTurns
◆ _node
◆ _nodeForNullTurnOfLoops
FakeNodeForLoop* YACS::ENGINE::Loop::_nodeForNullTurnOfLoops
◆ _outputsTraducer
std::set<DFToDSForLoop *> YACS::ENGINE::Loop::_outputsTraducer
Definition at line 156 of file Loop.hxx.
