YACS::ENGINE::WhileLoop Class Reference
Class for a while loop. More...
#include <WhileLoop.hxx>
Inheritance diagram for YACS::ENGINE::WhileLoop:
Collaboration diagram for YACS::ENGINE::WhileLoop:
 WhileLoop (const WhileLoop &other, ComposedNode *father, bool editionOnly)
 WhileLoop (const std::string &name)
void exUpdateState ()
void init (bool start=true)
InputPort * edGetConditionPort ()
 Get an input port given its name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
InputPort * getDecisionPort () const
 Returns the port which value is used to take decision about the continuation of the loop. More...
- Public Member Functions inherited from YACS::ENGINE::Loop
 Loop (const Loop &other, ComposedNode *father, bool editionOnly)
 ~Loop ()
int getNbOfTurns () const
Node * edSetNode (Node *DISOWNnode)
virtual bool edAddChild (Node *DISOWNnode)
bool isLoop () const override
Node * edRemoveNode ()
virtual InputPort * getDecisionPort () const =0
 Collect all the child nodes that are ready. More...
void edRemoveChild (Node *node)
 Remove a child node. More...
bool isRepeatedUnpredictablySeveralTimes () const
std::list< Node * > edGetDirectDescendants () const
Node * getChildByShortName (const std::string &name) const
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add control link if necessary. More...
void writeDot (std::ostream &os) const
 Dump the node state to a stream. More...
- Public Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual void edRemoveChild (Node *node)
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
Node * simpleClone (ComposedNode *father, bool editionOnly=true) const
void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
YACS::Event updateStateOnFinishedEventFrom (Node *node)
 Method used to notify the node that a child node has ended. More...
- Protected Member Functions inherited from YACS::ENGINE::Loop
void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
void checkNoCyclePassingThrough (Node *node)
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
- Protected Member Functions inherited from YACS::ENGINE::StaticDefinedComposedNode
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
ConditionInputPort _conditionPort
- Protected Attributes inherited from YACS::ENGINE::Loop
Node * _node
int _nbOfTurns
FakeNodeForLoop * _nodeForNullTurnOfLoops
std::set< DSToDFForLoop * > _inputsTraducer
std::set< DFToDSForLoop * > _outputsTraducer
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
Static Protected Attributes
static const char NAME_OF_INPUT_CONDITION [] ="condition"
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
- Static Public Member Functions inherited from YACS::ENGINE::Loop
static TypeCode * MappingDF2DS (TypeCode *type)
static TypeCode * MappingDS2DF (TypeCode *type)
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Member Functions inherited from YACS::ENGINE::Loop
static bool isNecessaryToBuildSpecificDelegateDF2DS (const std::list< ComposedNode * > &pointsOfView)
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
This node makes steps while the condition is true
Definition at line 38 of file WhileLoop.hxx.
◆ WhileLoop() [1/2]
WhileLoop::WhileLoop ( const WhileLoop &  other,
ComposedNode *  father,
bool  editionOnly
Definition at line 38 of file WhileLoop.cxx.
38 :Loop(other,father,editionOnly),
40{
41 //Copy Data linking
42 std::vector< std::pair<OutPort *, InPort *> > linksToReproduce=other.getSetOfInternalLinks();
43 std::vector< std::pair<OutPort *, InPort *> >::iterator iter=linksToReproduce.begin();
44 for(;iter!=linksToReproduce.end();++iter)
45 {
46 OutPort* pout = iter->first;
47 InPort* pin = iter->second;
48 edAddLink(getOutPort(other.getPortName(pout)),getInPort(other.getPortName(pin)));
49 }
50}
OutPort * getOutPort(const std::string &name) const
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks() const
std::string getPortName(const PORT *port) const
bool edAddLink(OutPort *start, InPort *end)
InPort * getInPort(const std::string &name) const
Definition: Node.cxx:239
Definition: WhileLoop.hxx:42
References YACS::ENGINE::ComposedNode::edAddLink(), YACS::ENGINE::Node::getInPort(), YACS::ENGINE::ComposedNode::getOutPort(), YACS::ENGINE::ComposedNode::getPortName(), and YACS::ENGINE::ComposedNode::getSetOfInternalLinks().
Referenced by simpleClone().
◆ WhileLoop() [2/2]
WhileLoop::WhileLoop ( const std::string &  name)
Definition at line 34 of file WhileLoop.cxx.
35{
36}
static const char NAME_OF_INPUT_CONDITION[]
Definition: WhileLoop.hxx:41
◆ accept()
void WhileLoop::accept ( Visitor *  visitor)
Reimplemented from YACS::ENGINE::Loop.
Definition at line 130 of file WhileLoop.cxx.
131{
132 visitor->visitWhileLoop(this);
133}
virtual void visitWhileLoop(WhileLoop *node)=0
References YACS::ENGINE::Visitor::visitWhileLoop().
◆ checkLinkPossibility()
void WhileLoop::checkLinkPossibility ( OutPort *  start,
const std::list< ComposedNode * > &  pointsOfViewStart,
InPort *  end,
const std::list< ComposedNode * > &  pointsOfViewEnd
Reimplemented from YACS::ENGINE::ComposedNode.
Definition at line 122 of file WhileLoop.cxx.
126{
127 DEBTRACE("WhileLoop::checkLinkPossibility");
128}
References DEBTRACE.
◆ edGetConditionPort()
◆ exUpdateState()
void WhileLoop::exUpdateState ( )
Update the node state.
: Update the '_state' attribute. Typically called by 'this->_inGate' when 'this->_inGate' is ready.
Called by InGate::exNotifyFromPrecursor
Reimplemented from YACS::ENGINE::Node.
Definition at line 58 of file WhileLoop.cxx.
59{
61 return;
62 if(_inGate.exIsReady())
63 {
68 {
70 _nodeForNullTurnOfLoops=new FakeNodeForLoop(this,false,true);
71 }
72 else
74 {
75 bool normalFinish=getAllOutPortsLeavingCurrentScope().empty();
77 _nodeForNullTurnOfLoops=new FakeNodeForLoop(this,normalFinish);
78 }
79 else
80 {
83 }
84 }
85}
std::set< OutPort * > getAllOutPortsLeavingCurrentScope() const
bool exIsReady() const
Definition: InGate.cxx:126
virtual bool isEmpty()
Definition: InputPort.cxx:70
friend class FakeNodeForLoop
Definition: Loop.hxx:149
Definition: Loop.hxx:154
InGate _inGate
Definition: Node.hxx:86
virtual void exUpdateState()
Definition: Node.cxx:206
void setState(YACS::StatesForNode theState)
Sets the given state for node.
Definition: Node.cxx:652
Definition: Node.hxx:91
@ ACTIVATED
Definition: define.hxx:41
@ DISABLED
Definition: define.hxx:50
References _conditionPort, YACS::ENGINE::Node::_inGate, YACS::ENGINE::Loop::_node, YACS::ENGINE::Loop::_nodeForNullTurnOfLoops, YACS::ENGINE::Node::_state, YACS::ACTIVATED, YACS::DISABLED, YACS::ENGINE::InGate::exIsReady(), YACS::ENGINE::Node::exUpdateState(), YACS::ENGINE::Loop::FakeNodeForLoop, YACS::ENGINE::ComposedNode::getAllOutPortsLeavingCurrentScope(), YACS::ENGINE::ConditionInputPort::getValue(), YACS::ENGINE::InputPort::isEmpty(), YACS::ENGINE::ConditionInputPort::isLinkedOutOfScope(), and YACS::ENGINE::Node::setState().
◆ getDecisionPort()
InputPort * YACS::ENGINE::WhileLoop::getDecisionPort ( ) const
Implements YACS::ENGINE::Loop.
Definition at line 52 of file WhileLoop.hxx.
52{ return (InputPort *)&_conditionPort; }
friend class InputPort
Definition: Node.hxx:74
◆ getInputPort()
InputPort * WhileLoop::getInputPort ( const std::string &  name) const
Contrary to YACS::ENGINE::ComposedNode::getOutputPort, this method is NOT recursive and so the leaf of type ElementaryNode aggregating this InputPort is directly invoked.
Definition at line 92 of file WhileLoop.cxx.
93{
95 return (InputPort*)&_conditionPort;
96 return Loop::getInputPort(name);
97}
InputPort * getInputPort(const std::string &name) const
Base class for Input Ports.
Definition: InputPort.hxx:44
References _conditionPort, YACS::ENGINE::ComposedNode::getInputPort(), and NAME_OF_INPUT_CONDITION.
◆ getLocalInputPorts()
std::list< InputPort * > WhileLoop::getLocalInputPorts ( ) const
Definition at line 135 of file WhileLoop.cxx.
136{
137 list<InputPort *> ret;
138 ret.push_back((InputPort *)&_conditionPort);
139 return ret;
140}
References _conditionPort.
◆ init()
void WhileLoop::init ( bool  start = true)
initialisation of all input and output ports and gates, for execution
Definition at line 52 of file WhileLoop.cxx.
53{
54 Loop::init(start);
56}
virtual void exInit(bool start)
Definition: InputPort.cxx:63
void init(bool start=true)
Definition: Loop.cxx:319
References _conditionPort, YACS::ENGINE::InputPort::exInit(), and YACS::ENGINE::Loop::init().
◆ simpleClone()
Node * WhileLoop::simpleClone ( ComposedNode *  father,
bool  editionOnly = true
Definition at line 87 of file WhileLoop.cxx.
88{
89 return new WhileLoop(*this,father,editionOnly);
90}
WhileLoop(const WhileLoop &other, ComposedNode *father, bool editionOnly)
Definition: WhileLoop.cxx:38
References WhileLoop().
◆ typeName()
virtual std::string YACS::ENGINE::WhileLoop::typeName ( )
Definition at line 53 of file WhileLoop.hxx.
53{return "YACS__ENGINE__WhileLoop";}
◆ updateStateOnFinishedEventFrom()
YACS::Event WhileLoop::updateStateOnFinishedEventFrom ( Node *  node)
Update the loop state and return the loop change state
node: the child node that has ended
the loop state change
Implements YACS::ENGINE::ComposedNode.
Definition at line 106 of file WhileLoop.cxx.
107{
108 _nbOfTurns++;
110 {
112 return YACS::FINISH;
113 }
114 else
115 {
116 node->init(false);
117 node->exUpdateState();
118 }
119 return YACS::NOEVENT;
120}
virtual void init(bool start=true)
Definition: Node.cxx:102
@ NOEVENT
Definition: define.hxx:57
@ FINISH
Definition: define.hxx:59
@ DONE
Definition: define.hxx:43
References _conditionPort, YACS::ENGINE::Loop::_nbOfTurns, YACS::DONE, YACS::ENGINE::Node::exUpdateState(), YACS::FINISH, YACS::ENGINE::ConditionInputPort::getValue(), YACS::ENGINE::Node::init(), YACS::NOEVENT, and YACS::ENGINE::Node::setState().
◆ _conditionPort
ConditionInputPort YACS::ENGINE::WhileLoop::_conditionPort
◆ NAME_OF_INPUT_CONDITION
const char WhileLoop::NAME_OF_INPUT_CONDITION ="condition"
staticprotected
Definition at line 41 of file WhileLoop.hxx.
Referenced by getInputPort().
