YACS::ENGINE::WhileLoop Member List
This is the complete list of members for YACS::ENGINE::WhileLoop, including all inherited members.
_colourYACS::ENGINE::Nodemutable
_conditionPortYACS::ENGINE::WhileLoopprotected
_errorDetailsYACS::ENGINE::Nodeprotected
_eventReceiverYACS::ENGINE::Nodeprotected
_fatherYACS::ENGINE::Nodeprotected
_implementationYACS::ENGINE::Nodeprotected
_inGateYACS::ENGINE::Nodeprotected
_inPropertyPortYACS::ENGINE::Nodeprotected
_inputsTraducerYACS::ENGINE::Loopprotected
_modifiedYACS::ENGINE::Nodeprotected
_nameYACS::ENGINE::Nodeprotected
_nbOfTurnsYACS::ENGINE::Loopprotected
_nodeYACS::ENGINE::Loopprotected
_nodeForNullTurnOfLoopsYACS::ENGINE::Loopprotected
_numIdYACS::ENGINE::Nodeprotected
_outGateYACS::ENGINE::Nodeprotected
_outputsTraducerYACS::ENGINE::Loopprotected
_propertyMapYACS::ENGINE::Nodeprotected
_stateYACS::ENGINE::Nodeprotected
_totalYACS::ENGINE::Nodeprotectedstatic
accept(Visitor *visitor)YACS::ENGINE::WhileLoopvirtual
applyDPLScope(ComposedNode *gfn)YACS::ENGINE::Nodevirtual
buildDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
buildDelegateOf(std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
checkBasicConsistency() constYACS::ENGINE::Loopvirtual
checkCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) constYACS::ENGINE::Loopprotectedvirtual
checkConsistency(LinkInfo &info) constYACS::ENGINE::ComposedNode
checkControlDependancy(OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) constYACS::ENGINE::Loopprotectedvirtual
checkDeploymentTree(bool deep) constYACS::ENGINE::ComposedNode
checkHavingCommonFather(Node *node1, Node *node2)YACS::ENGINE::Nodeprotectedstatic
checkInMyDescendance(Node *nodeToTest) constYACS::ENGINE::ComposedNodeprotected
checkLinkPossibility(OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)YACS::ENGINE::WhileLoopprotectedvirtual
checkLinksCoherenceRegardingControl(const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) constYACS::ENGINE::ComposedNodeprotected
checkNoCrossHierachyWith(Node *node) constYACS::ENGINE::ComposedNodeprotected
checkNoCyclePassingThrough(Node *node)YACS::ENGINE::Loopprotectedvirtual
checkValidityOfNodeName(const std::string &name)YACS::ENGINE::Nodestatic
checkValidityOfPortName(const std::string &name)YACS::ENGINE::Nodeprotectedstatic
cleanNodes()YACS::ENGINE::ComposedNodevirtual
clone(ComposedNode *father, bool editionOnly=true) constYACS::ENGINE::Node
cloneWithoutCompAndContDeepCpy(ComposedNode *father, bool editionOnly=true) constYACS::ENGINE::Node
ComposedNode(const std::string &name)YACS::ENGINE::ComposedNodeprotected
ComposedNode(const ComposedNode &other, ComposedNode *father)YACS::ENGINE::ComposedNodeprotected
connected()YACS::ENGINE::ComposedNode
destructCFComputations(LinkInfo &info) constYACS::ENGINE::ComposedNodeprotectedvirtual
edAddCFLink(Node *nodeS, Node *nodeE)YACS::ENGINE::ComposedNode
edAddChild(Node *DISOWNnode)YACS::ENGINE::Loopvirtual
edAddDFLink(OutPort *start, InPort *end)YACS::ENGINE::Loopvirtual
edAddLink(OutPort *start, InPort *end)YACS::ENGINE::ComposedNode
edAddLink(OutGate *start, InGate *end)YACS::ENGINE::ComposedNode
edAreAllInputPortInitialized() constYACS::ENGINE::Nodevirtual
edDisconnectAllLinksWithMe()YACS::ENGINE::ComposedNodeprotectedvirtual
edGetConditionPort()YACS::ENGINE::WhileLoopinline
edGetDirectDescendants() constYACS::ENGINE::Loopvirtual
edGetSetOfUnitializedInputPort() constYACS::ENGINE::Nodevirtual
edRemoveCFLink(Node *nodeS, Node *nodeE)YACS::ENGINE::ComposedNode
edRemoveChild(Node *node)YACS::ENGINE::Loopvirtual
edRemoveLink(OutPort *start, InPort *end)YACS::ENGINE::ComposedNode
edRemoveLink(OutGate *start, InGate *end)YACS::ENGINE::ComposedNode
edRemoveNode()YACS::ENGINE::Loop
edSetNode(Node *DISOWNnode)YACS::ENGINE::Loop
edUpdateState()YACS::ENGINE::ComposedNodevirtual
ensureLoading()YACS::ENGINE::Nodevirtual
exDisabledState()YACS::ENGINE::Nodevirtual
exFailedState()YACS::ENGINE::Nodevirtual
exForwardFailed()YACS::ENGINE::Nodeprotectedvirtual
exForwardFinished()YACS::ENGINE::Nodeprotectedvirtual
exIsControlReady() constYACS::ENGINE::Node
exUpdateState()YACS::ENGINE::WhileLoopvirtual
FED_DS_STYACS::ENGINE::ComposedNodeprotectedstatic
FED_STYACS::ENGINE::ComposedNodeprotectedstatic
forceMultiplicity(unsigned value)YACS::ENGINE::StaticDefinedComposedNodevirtual
FREE_STYACS::ENGINE::ComposedNodeprotectedstatic
getAllAscendanceOf(ComposedNode *levelToStop=0) constYACS::ENGINE::Node
getAllInPortsComingFromOutsideOfCurrentScope() constYACS::ENGINE::ComposedNodevirtual
getAllOutPortsLeavingCurrentScope() constYACS::ENGINE::ComposedNodevirtual
getAllRecursiveConstituents()YACS::ENGINE::ComposedNodevirtual
getAllRecursiveNodes()YACS::ENGINE::ComposedNode
getChildByName(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
getChildByShortName(const std::string &name) constYACS::ENGINE::Loopvirtual
getChildName(const Node *node) constYACS::ENGINE::ComposedNode
getClosestDPLAmongAncestors() constYACS::ENGINE::Node
getColorState(YACS::StatesForNode state) constYACS::ENGINE::Node
getContainerLog()YACS::ENGINE::Nodevirtual
getCoupledNodes(std::set< Task * > &coupledNodes)YACS::ENGINE::Nodeinlinevirtual
getDecisionPort() constYACS::ENGINE::WhileLoopinlinevirtual
getDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
getDelegateOf(std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
getDeploymentTree() constYACS::ENGINE::ComposedNodevirtual
getDPLScopeInfo(ComposedNode *gfn)YACS::ENGINE::Node
getEffectiveState() constYACS::ENGINE::Nodevirtual
getEffectiveState(const Node *) constYACS::ENGINE::Nodevirtual
getErrorDetails() constYACS::ENGINE::Nodeinlinevirtual
getErrorReport()YACS::ENGINE::ComposedNodevirtual
getFather() constYACS::ENGINE::Nodeinline
getId() constYACS::ENGINE::Node
getImplementation() constYACS::ENGINE::Node
getInGate()YACS::ENGINE::Nodeinline
getInPort(const std::string &name) constYACS::ENGINE::Node
getInPortName(const InPort *) constYACS::ENGINE::ComposedNodevirtual
getInPropertyPort() constYACS::ENGINE::Node
getInputDataStreamPort(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
getInputPort(const std::string &name) constYACS::ENGINE::WhileLoopvirtual
getLocalInputPorts() constYACS::ENGINE::WhileLoopvirtual
getLocalOutputPorts() constYACS::ENGINE::ComposedNodevirtual
getLowestCommonAncestor(Node *node1, Node *node2)YACS::ENGINE::ComposedNodestatic
getLowestCommonAncestorStr(const std::string &node1, const std::string &node2)YACS::ENGINE::ComposedNodestatic
getLowestNodeDealingAll(const std::list< OutPort * > &ports) constYACS::ENGINE::ComposedNodeprotected
getMaxLevelOfParallelism() constYACS::ENGINE::Loopvirtual
getMyQualifiedName(const Node *directSon) constYACS::ENGINE::ComposedNodevirtual
getName() constYACS::ENGINE::ComposedNodevirtual
getNbOfTurns() constYACS::ENGINE::Loopinline
getNextTasks(bool &isMore)YACS::ENGINE::ComposedNodevirtual
getNumberOfInputPorts() constYACS::ENGINE::Loopvirtual
getNumberOfOutputPorts() constYACS::ENGINE::ComposedNodevirtual
getNumId()YACS::ENGINE::Node
getOutGate()YACS::ENGINE::Nodeinline
getOutNodes() constYACS::ENGINE::Node
getOutPort(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
getOutPortName(const OutPort *) constYACS::ENGINE::ComposedNodevirtual
getOutputDataStreamPort(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
getOutputPort(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
getPortName(const PORT *port) constYACS::ENGINE::ComposedNodeprotected
getProc()YACS::ENGINE::Nodevirtual
getProc() constYACS::ENGINE::Nodevirtual
getProgress() constYACS::ENGINE::ComposedNodeinlinevirtual
getProgressWeight() constYACS::ENGINE::ComposedNodevirtual
getProperties()YACS::ENGINE::Node
getProperty(const std::string &name) overrideYACS::ENGINE::ComposedNodevirtual
getPropertyMap()YACS::ENGINE::Nodeinline
getQualifiedName() constYACS::ENGINE::Node
getReadyTasks(std::vector< Task * > &tasks)YACS::ENGINE::Loopvirtual
getRecursiveConstituents() constYACS::ENGINE::ComposedNodevirtual
getRootNode() constYACS::ENGINE::ComposedNodevirtual
getSetOfInPort() constYACS::ENGINE::Node
getSetOfInputDataStreamPort() constYACS::ENGINE::ComposedNodevirtual
getSetOfInputPort() constYACS::ENGINE::Loopvirtual
getSetOfInternalLinks() constYACS::ENGINE::ComposedNode
getSetOfLinksComingInCurrentScope() constYACS::ENGINE::ComposedNodevirtual
getSetOfLinksLeavingCurrentScope() constYACS::ENGINE::ComposedNodevirtual
getSetOfOutPort() constYACS::ENGINE::Node
getSetOfOutputDataStreamPort() constYACS::ENGINE::ComposedNodevirtual
getSetOfOutputPort() constYACS::ENGINE::ComposedNodevirtual
getState() constYACS::ENGINE::Nodeinlinevirtual
getStateName(YACS::StatesForNode state)YACS::ENGINE::Nodestatic
getTaskName(Task *task) constYACS::ENGINE::ComposedNodevirtual
getWeightRegardingDPL(ComplexWeight *weight)YACS::ENGINE::Loopvirtual
idMapYACS::ENGINE::Nodestatic
init(bool start=true)YACS::ENGINE::WhileLoopvirtual
isFinished()YACS::ENGINE::ComposedNodevirtual
isInMyDescendance(Node *nodeToTest) constYACS::ENGINE::ComposedNode
isLoop() const overrideYACS::ENGINE::Loopinlinevirtual
isModified()YACS::ENGINE::Nodeinlinevirtual
isMultiplicitySpecified(unsigned &value) constYACS::ENGINE::StaticDefinedComposedNodevirtual
isNameAlreadyUsed(const std::string &name) constYACS::ENGINE::ComposedNodevirtual
isNecessaryToBuildSpecificDelegateDF2DS(const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedstatic
isNodeAlreadyAggregated(const Node *node) constYACS::ENGINE::ComposedNode
isPlacementPredictableB4Run() constYACS::ENGINE::StaticDefinedComposedNodevirtual
isRepeatedUnpredictablySeveralTimes() constYACS::ENGINE::Loopinlinevirtual
isValid()YACS::ENGINE::Nodevirtual
loaded()YACS::ENGINE::ComposedNode
Loop(const Loop &other, ComposedNode *father, bool editionOnly)YACS::ENGINE::Loop
Loop(const std::string &name)YACS::ENGINE::Loop
MappingDF2DS(TypeCode *type)YACS::ENGINE::Loopstatic
MappingDS2DF(TypeCode *type)YACS::ENGINE::Loopstatic
modified()YACS::ENGINE::Nodevirtual
NAME_OF_INPUT_CONDITIONYACS::ENGINE::WhileLoopprotectedstatic
Node(const std::string &name)YACS::ENGINE::Nodeprotected
Node(const Node &other, ComposedNode *father)YACS::ENGINE::Nodeprotected
notifyFrom(const Task *sender, YACS::Event event, const Executor *execInst)YACS::ENGINE::ComposedNodevirtual
operator<(const Node &other) constYACS::ENGINE::Node
operator>(const Node &other) constYACS::ENGINE::Node
partitionRegardingDPL(const PartDefinition *pd, std::map< ComposedNode *, YACS::BASES::AutoRefCnt< PartDefinition > > &zeMap)YACS::ENGINE::Loopvirtual
performCFComputations(LinkInfo &info) constYACS::ENGINE::ComposedNodeprotectedvirtual
performDuplicationOfPlacement(const Node &other)YACS::ENGINE::ComposedNodeprotectedvirtual
performShallowDuplicationOfPlacement(const Node &other)YACS::ENGINE::ComposedNodeprotectedvirtual
releaseDelegateOf(InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
releaseDelegateOf(OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)YACS::ENGINE::Loopprotectedvirtual
removeRecursivelyRedundantCL()YACS::ENGINE::ComposedNodevirtual
resetState(int level)YACS::ENGINE::ComposedNodevirtual
selectRunnableTasks(std::vector< Task * > &tasks)YACS::ENGINE::StaticDefinedComposedNodevirtual
sendEvent(const std::string &event)YACS::ENGINE::Nodevirtual
sendEvent2(const std::string &event, void *something)YACS::ENGINE::Nodevirtual
SEP_CHAR_BTW_LEVELYACS::ENGINE::ComposedNodestatic
SEP_CHAR_IN_PORTYACS::ENGINE::Nodeprotectedstatic
setErrorDetails(const std::string &error)YACS::ENGINE::Nodeinlinevirtual
setName(const std::string &name)YACS::ENGINE::Node
setProperties(std::map< std::string, std::string > properties)YACS::ENGINE::Nodevirtual
setProperty(const std::string &name, const std::string &value) overrideYACS::ENGINE::ComposedNodevirtual
setState(YACS::StatesForNode theState)YACS::ENGINE::Node
shutdown(int level)YACS::ENGINE::ComposedNodevirtual
simpleClone(ComposedNode *father, bool editionOnly=true) constYACS::ENGINE::WhileLoopprotectedvirtual
solveObviousOrDelegateCFLinks(const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) constYACS::ENGINE::ComposedNodeprotected
splitNamesBySep(const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)YACS::ENGINE::ComposedNodeprotectedstatic
StaticDefinedComposedNode(const std::string &name)YACS::ENGINE::StaticDefinedComposedNodeprotected
StaticDefinedComposedNode(const StaticDefinedComposedNode &other, ComposedNode *father)YACS::ENGINE::StaticDefinedComposedNodeprotected
typeName()YACS::ENGINE::WhileLoopinlinevirtual
updateStateFrom(Node *node, YACS::Event event, const Executor *execInst)YACS::ENGINE::ComposedNodeprotected
updateStateOnFailedEventFrom(Node *node, const Executor *execInst)YACS::ENGINE::ComposedNodeprotectedvirtual
updateStateOnFinishedEventFrom(Node *node)YACS::ENGINE::WhileLoopprotectedvirtual
updateStateOnStartEventFrom(Node *node)YACS::ENGINE::ComposedNodeprotectedvirtual
WhileLoop(const WhileLoop &other, ComposedNode *father, bool editionOnly)YACS::ENGINE::WhileLoop
WhileLoop(const std::string &name)YACS::ENGINE::WhileLoop
writeDot(std::ostream &os) constYACS::ENGINE::Loopvirtual
writeDotInFile(const std::string &fileName) constYACS::ENGINE::Node
~ComposedNode()YACS::ENGINE::ComposedNodevirtual
~Loop()YACS::ENGINE::Loop
~Node()YACS::ENGINE::Nodevirtual
~Scheduler()YACS::ENGINE::Schedulervirtual
