YACS::ENGINE::StaticDefinedComposedNode Class Reference
#include <StaticDefinedComposedNode.hxx>
Inheritance diagram for YACS::ENGINE::StaticDefinedComposedNode:
Collaboration diagram for YACS::ENGINE::StaticDefinedComposedNode:
bool isPlacementPredictableB4Run () const
bool isMultiplicitySpecified (unsigned &value) const
void forceMultiplicity (unsigned value)
void selectRunnableTasks (std::vector< Task * > &tasks)
- Public Member Functions inherited from YACS::ENGINE::ComposedNode
virtual ~ComposedNode ()
bool isFinished ()
void init (bool start=true)
 Stop all pending activities of the composed node. More...
 Reset the state of the node and its children depending on the parameter level. More...
std::string getName () const
std::string getTaskName (Task *task) const
DeploymentTree getDeploymentTree () const
 Essentially for test. Use checkDeploymentTree instead to be sure that returned DeploymentTree is consistent. More...
DeploymentTree checkDeploymentTree (bool deep) const
 Perform check of deployment consistency of the current graph. More...
std::vector< Task * > getNextTasks (bool &isMore)
virtual bool isPlacementPredictableB4Run () const =0
void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)
 Notify the node a task has emitted an event. More...
bool edAddLink (OutPort *start, InPort *end)
 Add a dataflow link between two data ports. More...
virtual bool edAddDFLink (OutPort *start, InPort *end)
 Connect an OutPort to an InPort and add the necessary control link. More...
virtual bool edAddChild (Node *DISOWNnode)
virtual void edRemoveChild (Node *node)
 Remove a child node. More...
bool edAddLink (OutGate *start, InGate *end)
 Add a controlflow link between two control ports. More...
bool edAddCFLink (Node *nodeS, Node *nodeE)
 Add a controlflow link between two nodes. More...
void edRemoveCFLink (Node *nodeS, Node *nodeE)
 Remove a controlflow link. More...
void edRemoveLink (OutPort *start, InPort *end)
 Remove a dataflow link. More...
void edRemoveLink (OutGate *start, InGate *end)
virtual bool isRepeatedUnpredictablySeveralTimes () const
virtual bool isLoop () const
virtual std::list< Node * > edGetDirectDescendants () const =0
virtual void removeRecursivelyRedundantCL ()
std::list< Node * > getAllRecursiveNodes ()
 Get all children nodes elementary and composed including this node. More...
virtual std::list< Node * > getAllRecursiveConstituents ()
 Idem getAllRecursiveNodes, but this node is NOT included. More...
 Get the input port name. More...
 redefined on derived class of ComposedNode. by default a ComposedNode has no port by itself More...
 List all output ports of children nodes that are linked to out of scope input ports. More...
 List all input ports that are linked to out of scope ports. More...
OutPort * getOutPort (const std::string &name) const
 Get an input port given its name. More...
 Get an output port given its name. More...
std::vector< std::pair< OutPort *, InPort * > > getSetOfInternalLinks () const
void checkConsistency (LinkInfo &info) const
virtual void edUpdateState ()
ComposedNode * getRootNode () const
bool isNodeAlreadyAggregated (const Node *node) const
 Check that Node 'node' is already a direct son of this. More...
virtual bool isNameAlreadyUsed (const std::string &name) const
Node * isInMyDescendance (Node *nodeToTest) const
 Returns the parent of a node that is the direct child of this node. More...
std::string getChildName (const Node *node) const
virtual std::string getMyQualifiedName (const Node *directSon) const
void loaded ()
void connected ()
virtual void cleanNodes ()
 Clean the composed node in case of not clean exit. More...
virtual std::string getProgress () const
void setProperty (const std::string &name, const std::string &value) override
std::string getProperty (const std::string &name) override
virtual ~Node ()
InGate * getInGate ()
OutGate * getOutGate ()
virtual void exUpdateState ()
virtual void exFailedState ()
virtual Proc * getProc ()
int getNumId ()
virtual void modified ()
virtual int isModified ()
virtual int isValid ()
virtual void ensureLoading ()
- Public Member Functions inherited from YACS::ENGINE::Scheduler
virtual void init (bool start=true)=0
virtual bool isFinished ()=0
virtual void exUpdateState ()=0
virtual std::string getName () const =0
virtual std::string getTaskName (Task *task) const =0
virtual std::vector< Task * > getNextTasks (bool &isMore)=0
virtual void selectRunnableTasks (std::vector< Task * > &tasks)=0
virtual void notifyFrom (const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual DeploymentTree getDeploymentTree () const =0
virtual bool isMultiplicitySpecified (unsigned &value) const =0
virtual void forceMultiplicity (unsigned value)=0
virtual void setProperty (const std::string &name, const std::string &value)=0
virtual std::string getProperty (const std::string &name)=0
virtual ~Scheduler ()
 StaticDefinedComposedNode (const std::string &name)
 StaticDefinedComposedNode (const StaticDefinedComposedNode &other, ComposedNode *father)
void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const
- Protected Member Functions inherited from YACS::ENGINE::ComposedNode
 ComposedNode (const ComposedNode &other, ComposedNode *father)
virtual Node * getChildByShortName (const std::string &name) const =0
YACS::Event updateStateFrom (Node *node, YACS::Event event, const Executor *execInst)
 Update node state on receiving event from a node. More...
virtual YACS::Event updateStateOnStartEventFrom (Node *node)
 Method used to notify the node that a child node has started. More...
virtual YACS::Event updateStateOnFinishedEventFrom (Node *node)=0
virtual YACS::Event updateStateOnFailedEventFrom (Node *node, const Executor *execInst)
 Method used to notify the node that a child node has failed. More...
virtual void checkLinkPossibility (OutPort *start, const std::list< ComposedNode * > &pointsOfViewStart, InPort *end, const std::list< ComposedNode * > &pointsOfViewEnd)
virtual void buildDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void buildDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void getDelegateOf (std::pair< OutPort *, OutPort * > &port, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (InPort *&port, OutPort *initialStart, const std::list< ComposedNode * > &pointsOfView)
virtual void releaseDelegateOf (OutPort *portDwn, OutPort *portUp, InPort *finalTarget, const std::list< ComposedNode * > &pointsOfView)
virtual void checkNoCyclePassingThrough (Node *node)=0
void checkInMyDescendance (Node *nodeToTest) const
 Check if a node is in the descendance of this node. More...
template<class PORT >
std::string getPortName (const PORT *port) const
void checkNoCrossHierachyWith (Node *node) const
virtual void performCFComputations (LinkInfo &info) const
 perform recursively all CF computations. More...
virtual void destructCFComputations (LinkInfo &info) const
 destroy recursively all results of initial computations. More...
Node * getLowestNodeDealingAll (const std::list< OutPort * > &ports) const
void checkLinksCoherenceRegardingControl (const std::vector< OutPort * > &starts, InputPort *end, LinkInfo &info) const
virtual void checkControlDependancy (OutPort *start, InPort *end, bool cross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &fw, std::vector< OutPort * > &fwCross, std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &bw, LinkInfo &info) const =0
void solveObviousOrDelegateCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
virtual void checkCFLinks (const std::list< OutPort * > &starts, InputPort *end, unsigned char &alreadyFed, bool direction, LinkInfo &info) const
 check control flow links More...
- Static Public Member Functions inherited from YACS::ENGINE::ComposedNode
static ComposedNode * getLowestCommonAncestor (Node *node1, Node *node2)
 Retrieves the lowest common ancestor of 2 nodes. More...
static std::string getLowestCommonAncestorStr (const std::string &node1, const std::string &node2)
YACS::Colour _colour
- Static Public Attributes inherited from YACS::ENGINE::ComposedNode
static const char SEP_CHAR_BTW_LEVEL [] ="."
- Static Protected Member Functions inherited from YACS::ENGINE::ComposedNode
static bool splitNamesBySep (const std::string &globalName, const char separator[], std::string &firstPart, std::string &lastPart, bool priority)
 Splits name globalName in 2 parts using separator. More...
InGate _inGate
OutGate _outGate
ComposedNode * _father
YACS::StatesForNode _state
int _modified
std::string _errorDetails
int _numId
std::string _implementation
- Static Protected Attributes inherited from YACS::ENGINE::ComposedNode
static const unsigned char FED_ST = 2
static const unsigned char FREE_ST = 0
static const unsigned char FED_DS_ST = 1
static int _total = 0
Abstract class, that factorizes all the treatments relative to resource management for ComposedNode that have their connectivity fully defined before launching ; which is not always the case for classes inheriting from DynParaLoop.
Definition at line 34 of file StaticDefinedComposedNode.hxx.
◆ StaticDefinedComposedNode() [1/2]
StaticDefinedComposedNode::StaticDefinedComposedNode ( const std::string &  name)
Definition at line 27 of file StaticDefinedComposedNode.cxx.
27 :ComposedNode(name)
28{
29}
friend class ComposedNode
Definition: Node.hxx:79
◆ StaticDefinedComposedNode() [2/2]
StaticDefinedComposedNode::StaticDefinedComposedNode ( const StaticDefinedComposedNode &  other,
ComposedNode *  father
Definition at line 31 of file StaticDefinedComposedNode.cxx.
31 :ComposedNode(other,father)
32{
33}
◆ checkControlDependancy()
void StaticDefinedComposedNode::checkControlDependancy ( OutPort *  start,
InPort *  end,
bool  cross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  fw,
std::vector< OutPort * > &  fwCross,
std::map< ComposedNode *, std::list< OutPort * >, SortHierarc > &  bw,
LinkInfo &  info
Implements YACS::ENGINE::ComposedNode.
Definition at line 55 of file StaticDefinedComposedNode.cxx.
60{
61 if(start->getNode()==end->getNode())
62 bw[(ComposedNode *)this].push_back(start);
63 else
64 throw Exception("Internal error occured - dealing an unexpected link !");
65}
Node * getNode() const
Definition: Port.hxx:46
References YACS::ENGINE::Port::getNode().
Referenced by YACS::ENGINE::ForLoop::checkControlDependancy(), and YACS::ENGINE::Loop::checkControlDependancy().
◆ forceMultiplicity()
void StaticDefinedComposedNode::forceMultiplicity ( unsigned  value)
Implements YACS::ENGINE::Scheduler.
Definition at line 46 of file StaticDefinedComposedNode.cxx.
47{
48 //no sense for this class
49}
◆ isMultiplicitySpecified()
bool StaticDefinedComposedNode::isMultiplicitySpecified ( unsigned &  value) const
Definition at line 40 of file StaticDefinedComposedNode.cxx.
41{
42 value=1;
43 return true;
44}
◆ isPlacementPredictableB4Run()
bool StaticDefinedComposedNode::isPlacementPredictableB4Run ( ) const
Definition at line 35 of file StaticDefinedComposedNode.cxx.
36{
37 return true;
38}
◆ selectRunnableTasks()
void StaticDefinedComposedNode::selectRunnableTasks ( std::vector< Task * > &  tasks)
Definition at line 51 of file StaticDefinedComposedNode.cxx.
52{
53}
