YACS::ENGINE::Executor Class Reference
Threaded Executor. More...
#include <Executor.hxx>
Collaboration diagram for YACS::ENGINE::Executor:
 Executor ()
virtual ~Executor ()
void RunA (Scheduler *graph, int debug=0, bool fromScratch=true)
 Execute a graph waiting for completion. More...
void RunW (Scheduler *graph, int debug=0, bool fromScratch=true)
void RunB (Scheduler *graph, int debug=0, bool fromScratch=true)
 Execute a graph with breakpoints or step by step. More...
void runWlm (Scheduler *graph, int debug=0, bool fromScratch=true)
void setKeepGoingProperty (bool newVal)
bool getKeepGoingProperty () const
void setDPLScopeSensitive (bool newVal)
bool getDPLScopeSensitive () const
YACS::ExecutionMode getCurrentExecMode ()
YACS::ExecutorState getExecutorState ()
void setExecMode (YACS::ExecutionMode mode)
 Dynamically set the current mode of execution. More...
void setListOfBreakPoints (std::list< std::string > listOfBreakPoints)
 define a list of nodes names as breakpoints in the graph More...
std::list< std::string > getTasksToLoad ()
 Get the list of tasks to load, to define a subset to execute in step by step mode. More...
bool setStepsToExecute (std::list< std::string > listToExecute)
 Define a subset of task to execute in step by step mode. More...
bool resumeCurrentBreakPoint ()
 wake up executor when in pause More...
bool isNotFinished ()
void stopExecution ()
 stops the execution as soon as possible More...
bool saveState (const std::string &xmlFile)
 save the current state of execution in an xml file More...
bool loadState ()
 not yet implemented More...
int getMaxNbOfThreads () const
void setMaxNbOfThreads (int maxNbThreads)
int getNbOfThreads ()
int getNumberOfRunningTasks ()
 number of running tasks More...
void displayDot (Scheduler *graph)
 Display the graph state as a dot display, public method. More...
void setStopOnError (bool dumpRequested=false, std::string xmlFile="")
 ask to stop execution on the first node found in error More...
void unsetStopOnError ()
 ask to do not stop execution on nodes found in error More...
void waitPause ()
 suspend pilot execution until Executor is in pause or waiting tasks completion mode. More...
bool suspendASAP ()
void resume (bool suspended)
YACS::BASES::Mutex & getTheMutexForSchedulerUpdate ()
void loadTask (Task *task, const WorkloadManager::RunInfo &runInfo)
YACS::Event runTask (Task *task)
void makeDatastreamConnections (Task *task)
void beginTask (Task *task)
void endTask (Task *task, YACS::Event ev)
void failTask (Task *task, const std::string &message)
Static Public Attributes
static int _maxThreads
static size_t _threadStackSize
bool checkBreakPoints ()
 Wait reactivation in modes Step By step or with BreakPoints. More...
void waitResume ()
 in modes Step By step or with BreakPoint, wait until pilot resumes the execution More...
void loadTask (Task *task, const Executor *execInst)
 Perform loading of a Task. More...
void loadParallelTasks (const std::vector< Task * > &tasks, const Executor *execInst)
void launchTasks (const std::vector< Task * > &tasks)
 Execute a list of tasks possibly connected through datastream links. More...
void launchTask (Task *task)
 Execute a Task in a thread. More...
void wakeUp ()
 must be used protected by _mutexForSchedulerUpdate! More...
void sleepWhileNoEventsFromAnyRunningTask ()
 wait until a running task ends More...
void traceExec (Task *task, const std::string &message, const std::string &placement)
void _displayDot (Scheduler *graph)
 Display the graph state as a dot display. More...
void filterTasksConsideringContainers (std::vector< Task * > &tsks)
static std::string ComputePlacement (Task *zeTask)
static void * functionForTaskLoad (void *)
static void * functionForTaskExecution (void *)
 Function to perform execution of a task in a thread. More...
Scheduler * _mainSched
ComposedNode * _root
int _nbOfConcurrentThreads
YACS::BASES::Mutex _mutexForNbOfConcurrentThreads
YACS::BASES::Condition _condForNewTasksToPerform
YACS::BASES::Semaphore _semForMaxThreads
YACS::BASES::Condition _condForStepByStep
YACS::BASES::Condition _condForPilot
YACS::BASES::Mutex _mutexForSchedulerUpdate
YACS::BASES::Mutex _mutexForTrace
std::uint32_t _maxNbThreads = 10000
bool _toContinue
bool _isOKToEnd
bool _stopOnErrorRequested
bool _dumpOnErrorRequested
bool _errorDetected
bool _isRunningunderExternalControl
bool _isWaitingEventsFromRunningTasks
int _numberOfRunningTasks
std::set< Task * > _runningTasks
int _numberOfEndedTasks
int _semThreadCnt
YACS::ExecutorState _executorState
YACS::ExecutionMode _execMode
std::list< std::string > _listOfBreakPoints
std::list< std::string > _listOfTasksToLoad
std::vector< Task * > _tasks
std::vector< Task * > _tasksSave
std::ofstream _trace
std::string _dumpErrorFile
bool _keepGoingOnFail
bool _DPLScopeSensitive
 specifies if scope DynParaLoop is active or not. False by default. More...
std::chrono::steady_clock::time_point _start
Threaded Executor.
Definition at line 62 of file Executor.hxx.
◆ Executor()
Executor::Executor ( )
Definition at line 82 of file Executor.cxx.
83{
84 _root=0;
85 _toContinue = true;
86 _isOKToEnd = false;
89 _errorDetected = false;
96 DEBTRACE("Executor initialized with max threads = " << _maxThreads);
97}
Definition: Executor.hxx:82
Definition: Executor.hxx:81
Definition: Executor.hxx:97
Definition: Executor.hxx:88
Definition: Executor.hxx:131
Definition: Executor.hxx:70
Definition: Executor.hxx:87
Definition: Executor.hxx:66
Definition: Executor.hxx:65
@ CONTINUE
Definition: define.hxx:76
@ NOTYETINITIALIZED
Definition: define.hxx:65
References _dumpOnErrorRequested, _errorDetected, _execMode, _executorState, _isOKToEnd, _isRunningunderExternalControl, _maxThreads, _numberOfEndedTasks, _numberOfRunningTasks, _root, _semThreadCnt, _stopOnErrorRequested, _toContinue, YACS::CONTINUE, DEBTRACE, and YACS::NOTYETINITIALIZED.
◆ ~Executor()
Executor::~Executor ( )
Definition at line 99 of file Executor.cxx.
100{
101}
◆ _displayDot()
void Executor::_displayDot ( Scheduler *  graph)
graph: the node to display
Definition at line 729 of file Executor.cxx.
730{
731 std::ofstream g("titi");
732 ((ComposedNode*)graph)->writeDot(g);
733 g.close();
734 const char displayScript[]="display.sh";
735 if(isfile(displayScript))
736 system("sh display.sh");
737 else
738 system("dot -Tpng titi|display -delay 5");
739}
static int isfile(const char *filename)
Definition: Executor.cxx:706
References isfile().
Referenced by displayDot(), RunA(), RunB(), and runWlm().
◆ beginTask()
void Executor::beginTask ( Task *  task)
Definition at line 1464 of file Executor.cxx.
1465{
1466 // --- Critical section
1469 _runningTasks.insert(task);
1470 // --- End of critical section
1471}
Definition: Executor.hxx:84
Definition: Executor.hxx:73
References _mutexForSchedulerUpdate, _numberOfRunningTasks, and _runningTasks.
Referenced by runWlm().
◆ checkBreakPoints()
bool Executor::checkBreakPoints ( )
Check mode of execution (set by main thread):
Definition at line 752 of file Executor.cxx.
753{
754 DEBTRACE("Executor::checkBreakPoints()");
755 vector<Task *>::iterator iter;
756 bool endRequested = false;
757
758 switch (_execMode)
759 {
760 case YACS::CONTINUE:
761 {
762 break;
763 }
765 {
766 bool stop = false;
767 { // --- Critical section
770 for (iter=_tasks.begin(); iter!=_tasks.end(); iter++)
771 {
772 string nodeToLoad = _mainSched->getTaskName(*iter);
773 if (find(_listOfBreakPoints.begin(), _listOfBreakPoints.end(), nodeToLoad)
774 != _listOfBreakPoints.end())
775 {
776 stop = true;
777 break;
778 }
779 }
780 if (stop)
781 {
782 _listOfTasksToLoad.clear();
783 for (iter=_tasks.begin(); iter!=_tasks.end(); iter++)
784 {
785 string nodeToLoad = _mainSched->getTaskName(*iter);
786 _listOfTasksToLoad.push_back(nodeToLoad);
787 }
788 if (getNbOfThreads())
789 _executorState = YACS::WAITINGTASKS; // will be paused after completion of running tasks
790 else
792 sendEvent("executor");
793 _condForPilot.notify_all();
794 }
795 if (stop && !_isOKToEnd) waitResume(); // wait until pilot calls resumeCurrentBreakPoint(), mutex released during wait
796 if (_isOKToEnd) endRequested = true;
797 } // --- End of critical section
798 if (stop) DEBTRACE("wake up from waitResume");
799 break;
800 }
801 default:
802 case YACS::STEPBYSTEP:
803 {
804 { // --- Critical section
807 _listOfTasksToLoad.clear();
808 for (iter=_tasks.begin(); iter!=_tasks.end(); iter++)
809 {
810 string nodeToLoad = _mainSched->getTaskName(*iter);
811 _listOfTasksToLoad.push_back(nodeToLoad);
812 }
813 if (getNbOfThreads())
814 _executorState = YACS::WAITINGTASKS; // will be paused after completion of running tasks
815 else
817 sendEvent("executor");
818 _condForPilot.notify_all();
819 if (!_isOKToEnd)
820 waitResume(); // wait until pilot calls resumeCurrentBreakPoint(), mutex released during wait
821 // or, if no pilot, wait until no more running tasks (stop on error)
822 if (_isOKToEnd) endRequested = true;
823 } // --- End of critical section
824 DEBTRACE("wake up from waitResume");
825 break;
826 }
827 }
828 DEBTRACE("endRequested: " << endRequested);
829 return endRequested;
830}
Definition: Executor.hxx:90
virtual void sendEvent(const std::string &event)
emit notification to all observers registered with the dispatcher
Definition: Executor.cxx:1324
Definition: Executor.hxx:91
Definition: Executor.hxx:92
Definition: Executor.hxx:89
Definition: Executor.hxx:72
void waitResume()
Definition: Executor.cxx:840
virtual std::string getTaskName(Task *task) const =0
@ STEPBYSTEP
Definition: define.hxx:77
@ STOPBEFORENODES
Definition: define.hxx:78
@ PAUSED
Definition: define.hxx:69
@ WAITINGTASKS
Definition: define.hxx:68
References _condForPilot, _execMode, _executorState, _isOKToEnd, _listOfBreakPoints, _listOfTasksToLoad, _mainSched, _mutexForSchedulerUpdate, _tasks, _tasksSave, YACS::CONTINUE, DEBTRACE, getNbOfThreads(), YACS::ENGINE::Scheduler::getTaskName(), YACS::PAUSED, sendEvent(), YACS::STEPBYSTEP, YACS::STOPBEFORENODES, YACS::WAITINGTASKS, and waitResume().
Referenced by RunB(), and runWlm().
◆ ComputePlacement()
std::string Executor::ComputePlacement ( Task *  zeTask)
staticprotected
Definition at line 1412 of file Executor.cxx.
1413{
1414 std::string placement("---");
1415 if(!zeTask)
1416 return placement;
1417 if(zeTask->getContainer())
1418 placement=zeTask->getContainer()->getFullPlacementId(zeTask);
1419 return placement;
1420}
virtual std::string getFullPlacementId(const Task *askingNode) const =0
virtual Container * getContainer()=0
References YACS::ENGINE::Task::getContainer(), and YACS::ENGINE::Container::getFullPlacementId().
Referenced by functionForTaskExecution(), launchTask(), launchTasks(), loadTask(), makeDatastreamConnections(), and runTask().
◆ displayDot()
void Executor::displayDot ( Scheduler *  graph)
Definition at line 718 of file Executor.cxx.
719{
721 _displayDot(graph);
722}
void _displayDot(Scheduler *graph)
Definition: Executor.cxx:729
References _displayDot(), and _isRunningunderExternalControl.
Referenced by main().
◆ endTask()
void Executor::endTask ( Task *  task,
YACS::Event  ev
Definition at line 1473 of file Executor.cxx.
1474{
1476 try
1477 {
1478 if (ev == YACS::FINISH) task->finished();
1479 if (ev == YACS::ABORT)
1480 {
1481 _errorDetected = true;
1483 {
1485 _isOKToEnd = true;
1486 }
1487 task->aborted();
1488 }
1489 //traceExec(task, "state:"+Node::getStateName(task->getState()),placement);
1490 _mainSched->notifyFrom(task,ev,this);
1491 }
1492 catch(Exception& ex)
1493 {
1494 //notify has failed : it is supposed to have set state
1495 //so no need to do anything
1496 std::cerr << "Error during notification" << std::endl;
1497 std::cerr << ex.what() << std::endl;
1498 }
1499 catch(...)
1500 {
1501 //notify has failed : it is supposed to have set state
1502 //so no need to do anything
1503 std::cerr << "Notification failed" << std::endl;
1504 }
1506 _runningTasks.erase(task);
1507 if ((_numberOfRunningTasks == 0) && (_execMode != YACS::CONTINUE)) // no more running tasks
1508 {
1510 {
1512 sendEvent("executor");
1513 _condForPilot.notify_all();
1514 if (_errorDetected &&
1517 _condForStepByStep.notify_all(); // exec thread may be on waitResume
1518 }
1519 }
1521 wakeUp();
1522}
void wakeUp()
Definition: Executor.cxx:1099
Definition: Executor.hxx:71
virtual void notifyFrom(const Task *sender, YACS::Event event, const Executor *execInst)=0
virtual void aborted()=0
virtual void finished()=0
@ ABORT
Definition: define.hxx:60
@ FINISH
Definition: define.hxx:59
References _condForPilot, _condForStepByStep, _errorDetected, _execMode, _executorState, _isOKToEnd, _isRunningunderExternalControl, _mainSched, _mutexForSchedulerUpdate, _numberOfRunningTasks, _runningTasks, _stopOnErrorRequested, YACS::ABORT, YACS::ENGINE::Task::aborted(), YACS::CONTINUE, testCppPluginInvokation::ex, YACS::FINISH, YACS::ENGINE::Task::finished(), YACS::ENGINE::Scheduler::notifyFrom(), YACS::PAUSED, sendEvent(), YACS::STEPBYSTEP, YACS::WAITINGTASKS, and wakeUp().
Referenced by failTask(), and YACS::ENGINE::WlmTask::run().
◆ failTask()
void Executor::failTask ( Task *  task,
const std::string &  message
Definition at line 1524 of file Executor.cxx.
1525{
1526 ElementaryNode* elemNode = dynamic_cast<ElementaryNode*>(task);
1527 if(elemNode != nullptr)
1528 {
1529 StateLoader(elemNode, YACS::ERROR);
1530 elemNode->setErrorDetails(message);
1531 }
1532 endTask(task, YACS::ABORT);
1533}
void endTask(Task *task, YACS::Event ev)
Definition: Executor.cxx:1473
virtual void setErrorDetails(const std::string &error)
Definition: Node.hxx:191
void YACSLIBENGINE_EXPORT StateLoader(Node *node, YACS::StatesForNode state)
Definition: Node.cxx:719
@ ERROR
Definition: define.hxx:52
References YACS::ABORT, endTask(), YACS::ERROR, YACS::ENGINE::Node::setErrorDetails(), and YACS::ENGINE::StateLoader().
Referenced by YACS::ENGINE::WlmTask::run().
◆ filterTasksConsideringContainers()
void Executor::filterTasksConsideringContainers ( std::vector< Task * > &  tsks)
This method takes in input a list of tasks and selects from that lists a part of it considering only the containers. If tasks have no container instance subclass of HomogeneousPoolContainer this method will let the tsks untouched.
[in,out]tsks- list of tasks to be
Definition at line 1352 of file Executor.cxx.
1353{
1354 std::map<HomogeneousPoolContainer *, std::vector<Task *>, HPCCompare > m;
1355 for(auto cur : tsks)
1356 {
1357 if(!cur)
1358 continue;
1359 Container *cont(cur->getContainer());
1360 if(!cont)
1361 {
1362 m[nullptr].push_back(cur);
1363 continue;
1364 }
1365 HomogeneousPoolContainer *contC(dynamic_cast<HomogeneousPoolContainer *>(cont));
1366 if(!contC)
1367 {
1368 m[nullptr].push_back(cur);
1369 continue;
1370 }
1371 m[contC].push_back(cur);
1372 }
1373 //
1374 std::vector<Task *> ret;
1375 for(auto it : m)
1376 {
1377 HomogeneousPoolContainer *curhpc(it.first);
1378 const std::vector<Task *>& curtsks(it.second);
1379 if(!curhpc)
1380 {
1381 std::uint32_t nbThreadsRunning = _runningTasks.size();
1382 std::uint32_t nbOfFreeSpace = _maxNbThreads - min(_maxNbThreads,nbThreadsRunning);
1383 std::uint32_t nbOfCandidates = static_cast<std::uint32_t>( curtsks.size() );
1384 std::uint32_t nbOfCandidatesToBeLaunched = std::min(nbOfCandidates,nbOfFreeSpace);
1385 DEBTRACE("nb threads running: " << nbThreadsRunning);
1386 DEBTRACE("MaxNbThreads: " << _maxNbThreads);
1387 DEBTRACE("nbOfFreeSpace: " << nbOfFreeSpace);
1388 DEBTRACE("nbOfCandidates: " << nbOfCandidates);
1389 DEBTRACE("nbOfCandidatesToBeLaunched: " << nbOfCandidatesToBeLaunched);
1390 ret.insert(ret.end(),curtsks.begin(),curtsks.begin() + nbOfCandidatesToBeLaunched);
1391 }
1392 else
1393 {
1394 // start of critical section for container curhpc
1395 std::lock_guard<std::mutex> alckCont(curhpc->getLocker());
1396 std::vector<const Task *> vecOfTaskSharingSameHPContToBeRunSimutaneously;
1397 std::size_t sz(curhpc->getNumberOfFreePlace());
1398 std::vector<Task *>::const_iterator it2(curtsks.begin());
1399 for(std::size_t i=0;i<sz && it2!=curtsks.end();i++,it2++)
1400 {
1401 vecOfTaskSharingSameHPContToBeRunSimutaneously.push_back(*it2);
1402 ret.push_back(*it2);
1403 }
1404 curhpc->allocateFor(vecOfTaskSharingSameHPContToBeRunSimutaneously);
1405 //end of critical section
1406 }
1407 }
1408 //
1409 tsks=ret;
1410}
Definition: Executor.hxx:75
References _maxNbThreads, _runningTasks, YACS::ENGINE::HomogeneousPoolContainer::allocateFor(), DEBTRACE, YACS::ENGINE::HomogeneousPoolContainer::getLocker(), YACS::ENGINE::HomogeneousPoolContainer::getNumberOfFreePlace(), yacsorb.CORBAEngineTest::i, and gui.GraphViewer::m.
◆ functionForTaskExecution()
void * Executor::functionForTaskExecution ( void *  arg)
staticprotected
arg: 3 elements (a Task, a Scheduler, an Executor)
Calls Task::execute
Calls Task::finished when the task is finished
Calls (notify with event YACS::FINISH) Scheduler::notifyFrom when the task is finished
Calls Executor::wakeUp and Executor::notifyEndOfThread
Definition at line 1165 of file Executor.cxx.
1166{
1167 DEBTRACE("Executor::functionForTaskExecution(void *arg)");
1168
1169 struct threadargs *args = (struct threadargs *) arg;
1170 Task *task=args->task;
1171 Scheduler *sched=args->sched;
1172 Executor *execInst=args->execInst;
1173 delete args;
1175
1176 Thread::detach();
1177
1178 // Execute task
1179
1181 {
1182 Node *node(dynamic_cast<Node *>(task));
1183 ComposedNode *gfn(dynamic_cast<ComposedNode *>(sched));
1184 if(node!=0 && gfn!=0)
1185 node->applyDPLScope(gfn);
1186 }
1187
1189 try
1190 {
1191 execInst->traceExec(task, "start execution",ComputePlacement(task));
1192 task->execute();
1193 execInst->traceExec(task, "end execution OK",ComputePlacement(task));
1194 }
1195 catch(Exception& ex)
1196 {
1197 std::cerr << "YACS Exception during execute" << std::endl;
1198 std::cerr << ex.what() << std::endl;
1199 ev=YACS::ABORT;
1200 string message = "end execution ABORT, ";
1201 message += ex.what();
1203 }
1204 catch(...)
1205 {
1206 // Execution has failed
1207 std::cerr << "Execution has failed: unknown reason" << std::endl;
1208 ev=YACS::ABORT;
1209 execInst->traceExec(task, "end execution ABORT, unknown reason",ComputePlacement(task));
1210 }
1211
1212 // Disconnect task
1213 try
1214 {
1215 DEBTRACE("task->disconnectService()");
1217 execInst->traceExec(task, "disconnectService",ComputePlacement(task));
1218 }
1219 catch(...)
1220 {
1221 // Disconnect has failed
1222 std::cerr << "disconnect has failed" << std::endl;
1223 ev=YACS::ABORT;
1224 execInst->traceExec(task, "disconnectService failed, ABORT",ComputePlacement(task));
1225 }
1226 //
1227
1228 std::string placement(ComputePlacement(task));
1229
1230 // container management for HomogeneousPoolOfContainer
1231
1233 if(contC)
1234 {
1235 std::lock_guard<std::mutex> alckCont(contC->getLocker());
1236 contC->release(task);
1237 }
1238
1239 DEBTRACE("End task->execute()");
1240 { // --- Critical section
1242 try
1243 {
1244 if (ev == YACS::FINISH) task->finished();
1245 if (ev == YACS::ABORT)
1246 {
1247 execInst->_errorDetected = true;
1249 {
1251 execInst->_isOKToEnd = true;
1252 }
1253 task->aborted();
1254 }
1255 execInst->traceExec(task, "state:"+Node::getStateName(task->getState()),placement);
1257 }
1258 catch(Exception& ex)
1259 {
1260 //notify has failed : it is supposed to have set state
1261 //so no need to do anything
1262 std::cerr << "Error during notification" << std::endl;
1263 std::cerr << ex.what() << std::endl;
1264 }
1265 catch(...)
1266 {
1267 //notify has failed : it is supposed to have set state
1268 //so no need to do anything
1269 std::cerr << "Notification failed" << std::endl;
1270 }
1272 execInst->_runningTasks.erase(task);
1273 DEBTRACE("_numberOfRunningTasks: " << execInst->_numberOfRunningTasks
1274 << " _execMode: " << execInst->_execMode
1275 << " _executorState: " << execInst->_executorState);
1276 if ((execInst->_numberOfRunningTasks == 0) && (execInst->_execMode != YACS::CONTINUE)) // no more running tasks
1277 {
1279 {
1281 execInst->sendEvent("executor");
1282 execInst->_condForPilot.notify_all();
1283 if (execInst->_errorDetected &&
1286 execInst->_condForStepByStep.notify_all(); // exec thread may be on waitResume
1287 }
1288 }
1289 DEBTRACE("before _semForMaxThreads.post " << execInst->_semThreadCnt);
1291 execInst->_semThreadCnt += 1;
1292 DEBTRACE("after _semForMaxThreads.post " << execInst->_semThreadCnt);
1294
1295 } // --- End of critical section (change state)
1296
1297 Thread::exit(0);
1298 return 0;
1299}
Threaded Executor.
Definition: Executor.hxx:63
bool getDPLScopeSensitive() const
Definition: Executor.hxx:109
static std::string ComputePlacement(Task *zeTask)
Definition: Executor.cxx:1412
void traceExec(Task *task, const std::string &message, const std::string &placement)
Definition: Executor.cxx:1301
Base class for all nodes.
Definition: Node.hxx:70
static std::string getStateName(YACS::StatesForNode state)
Return the name of a state.
Definition: Node.cxx:827
virtual void disconnectService()=0
virtual void execute()=0
virtual YACS::StatesForNode getState() const =0
Event
Definition: define.hxx:56
Scheduler * sched
Definition: Executor.cxx:895
Task * task
Definition: Executor.cxx:894
Executor * execInst
Definition: Executor.cxx:896
References _condForPilot, _condForStepByStep, _errorDetected, _execMode, _executorState, _isOKToEnd, _isRunningunderExternalControl, _mutexForSchedulerUpdate, _numberOfRunningTasks, _runningTasks, _semForMaxThreads, _semThreadCnt, _stopOnErrorRequested, YACS::ABORT, YACS::ENGINE::Task::aborted(), YACS::ENGINE::Node::applyDPLScope(), driver_internal::args, ComputePlacement(), YACS::CONTINUE, DEBTRACE, YACS::ENGINE::Task::disconnectService(), testCppPluginInvokation::ex, threadargs::execInst, YACS::ENGINE::Task::execute(), YACS::FINISH, YACS::ENGINE::Task::finished(), YACS::ENGINE::Task::getContainer(), getDPLScopeSensitive(), YACS::ENGINE::HomogeneousPoolContainer::getLocker(), YACS::ENGINE::Task::getState(), YACS::ENGINE::Node::getStateName(), YACS::ENGINE::Scheduler::notifyFrom(), YACS::PAUSED, YACS::ENGINE::HomogeneousPoolContainer::release(), threadargs::sched, sendEvent(), YACS::STEPBYSTEP, threadargs::task, traceExec(), YACS::WAITINGTASKS, and wakeUp().
Referenced by launchTask().
◆ functionForTaskLoad()
void * Executor::functionForTaskLoad ( void *  arg)
staticprotected
This thread is NOT supposed to be detached !
Definition at line 1140 of file Executor.cxx.
1141{
1142 DEBTRACE("Executor::functionForTaskLoad(void *arg)");
1143 struct threadargs *args = (struct threadargs *) arg;
1144 Task *task=args->task;
1145 Scheduler *sched=args->sched;
1146 Executor *execInst=args->execInst;
1147 delete args;
1148 execInst->loadTask(task,execInst);// no throw of this method - all throw are catched !
1149 return 0;
1150}
void loadTask(Task *task, const WorkloadManager::RunInfo &runInfo)
Definition: Executor.cxx:1423
References driver_internal::args, DEBTRACE, threadargs::execInst, loadTask(), threadargs::sched, and threadargs::task.
Referenced by loadParallelTasks().
◆ getCurrentExecMode()
YACS::ExecutionMode Executor::getCurrentExecMode ( )
Definition at line 373 of file Executor.cxx.
374{
376 return _execMode;
377}
References _execMode, and _isRunningunderExternalControl.
◆ getDPLScopeSensitive()
bool YACS::ENGINE::Executor::getDPLScopeSensitive ( ) const
Definition at line 109 of file Executor.hxx.
109{ return _DPLScopeSensitive; }
Referenced by functionForTaskExecution(), and runTask().
◆ getExecutorState()
YACS::ExecutorState Executor::getExecutorState ( )
Definition at line 380 of file Executor.cxx.
381{
383 return _executorState;
384}
References _executorState, and _isRunningunderExternalControl.
◆ getKeepGoingProperty()
bool YACS::ENGINE::Executor::getKeepGoingProperty ( ) const
Definition at line 107 of file Executor.hxx.
107{ return _keepGoingOnFail; }
Referenced by YACS::ENGINE::ForEachLoopGen::updateStateOnFailedEventFrom().
◆ getMaxNbOfThreads()
int Executor::getMaxNbOfThreads ( ) const
Definition at line 1111 of file Executor.cxx.
1112{
1113 return (int)_maxNbThreads;
1114}
References _maxNbThreads.
◆ getNbOfThreads()
int Executor::getNbOfThreads ( )
Definition at line 1121 of file Executor.cxx.
1122{
1123 int ret = 0;
1126 return ret;
1127}
Definition: Executor.hxx:68
References _isRunningunderExternalControl, and _mutexForNbOfConcurrentThreads.
Referenced by checkBreakPoints().
◆ getNumberOfRunningTasks()
int Executor::getNumberOfRunningTasks ( )
◆ getTasksToLoad()
std::list< std::string > Executor::getTasksToLoad ( )
If the executor is not in mode YACS::WAITINGTASKS nor YACS::PAUSED, the list is empty. Use Executor::waitPause to wait.
Definition at line 507 of file Executor.cxx.
508{
509 DEBTRACE("Executor::getTasksToLoad()");
510 list<string> listOfNodesToLoad;
511 listOfNodesToLoad.clear();
512 { // --- Critical section
515 switch (_executorState)
516 {
518 case YACS::PAUSED:
519 {
520 listOfNodesToLoad = _listOfTasksToLoad;
521 break;
522 }
525 case YACS::RUNNING:
526 case YACS::FINISHED:
527 case YACS::STOPPED:
528 default:
529 {
530 break;
531 }
532 }
533 } // --- End of critical section
534 return listOfNodesToLoad;
535}
@ RUNNING
Definition: define.hxx:67
@ INITIALISED
Definition: define.hxx:66
@ FINISHED
Definition: define.hxx:70
@ STOPPED
Definition: define.hxx:71
References _executorState, _isRunningunderExternalControl, _listOfTasksToLoad, _mutexForSchedulerUpdate, DEBTRACE, YACS::FINISHED, YACS::INITIALISED, YACS::NOTYETINITIALIZED, YACS::PAUSED, YACS::RUNNING, YACS::STOPPED, and YACS::WAITINGTASKS.
◆ getTheMutexForSchedulerUpdate()
YACS::BASES::Mutex & YACS::ENGINE::Executor::getTheMutexForSchedulerUpdate ( )
◆ isNotFinished()
bool Executor::isNotFinished ( )
Definition at line 387 of file Executor.cxx.
388{
390 return _toContinue;
391}
References _isRunningunderExternalControl, and _toContinue.
◆ launchTask()
void Executor::launchTask ( Task *  task)
task: Task to execute
Calls Scheduler::notifyFrom of main node (_mainSched) to notify start
Calls Executor::functionForTaskExecution in Thread
Definition at line 1022 of file Executor.cxx.
1023{
1024 DEBTRACE("Executor::launchTask(Task *task)");
1025 struct threadargs *args;
1026 if(task->getState() != YACS::TOACTIVATE)return;
1027
1028 DEBTRACE("before _semForMaxThreads.wait " << _semThreadCnt);
1029 if(_semThreadCnt == 0)
1030 {
1031 // --- Critical section
1033 //check if we have enough threads to run
1034 std::set<Task*> tmpSet=_runningTasks;
1035 std::set<Task*>::iterator it = tmpSet.begin();
1036 std::string status="running";
1037 std::set<Task*> coupledSet;
1038 while( it != tmpSet.end() )
1039 {
1040 Task* tt=*it;
1041 coupledSet.clear();
1042 tt->getCoupledTasks(coupledSet);
1043 status="running";
1044 for (std::set<Task*>::iterator iter = coupledSet.begin(); iter != coupledSet.end(); ++iter)
1045 {
1046 if((*iter)->getState() == YACS::TOACTIVATE)status="toactivate";
1047 tmpSet.erase(*iter);
1048 }
1049 if(status=="running")break;
1050 it = tmpSet.begin();
1051 }
1052
1053 if(status=="toactivate")
1054 {
1055 std::cerr << "WARNING: maybe you need more threads to run your schema (current value="<< _maxThreads << ")" << std::endl;
1056 std::cerr << "If it is the case, set the YACS_MAX_THREADS environment variable to a bigger value (export YACS_MAX_THREADS=xxx)" << std::endl;
1057 }
1058 // --- End of critical section
1059 }
1060
1061 _semForMaxThreads.wait();
1062 _semThreadCnt -= 1;
1063
1064 args= new threadargs;
1065 args->task = task;
1066 args->sched = _mainSched;
1067 args->execInst = this;
1068
1069 traceExec(task, "launch",ComputePlacement(task));
1070
1071 { // --- Critical section
1074 _runningTasks.insert(task);
1075 task->begin(); //change state to ACTIVATED
1076 } // --- End of critical section
1078}
Definition: Executor.hxx:132
static void * functionForTaskExecution(void *)
Definition: Executor.cxx:1165
virtual void begin()=0
virtual void getCoupledTasks(std::set< Task * > &coupledSet)=0
@ TOACTIVATE
Definition: define.hxx:40
References _mainSched, _maxThreads, _mutexForSchedulerUpdate, _numberOfRunningTasks, _runningTasks, _semForMaxThreads, _semThreadCnt, _threadStackSize, driver_internal::args, YACS::ENGINE::Task::begin(), ComputePlacement(), DEBTRACE, functionForTaskExecution(), YACS::ENGINE::Task::getCoupledTasks(), YACS::ENGINE::Task::getState(), threadargs::task, YACS::TOACTIVATE, and traceExec().
Referenced by launchTasks().
◆ launchTasks()
void Executor::launchTasks ( const std::vector< Task * > &  tasks)
tasks: a list of tasks to execute
Definition at line 921 of file Executor.cxx.
922{
923 //First phase, make datastream connections
924 for(vector<Task *>::const_iterator iter=tasks.begin();iter!=tasks.end();iter++)
925 {
926 YACS::StatesForNode state=(*iter)->getState();
927 if(state != YACS::TOLOAD && state != YACS::TORECONNECT)continue;
928 try
929 {
930 (*iter)->connectService();
931 traceExec(*iter, "connectService",ComputePlacement(*iter));
932 {//Critical section
934 (*iter)->connected();
935 }//End of critical section
936 }
937 catch(Exception& ex)
938 {
939 std::cerr << ex.what() << std::endl;
940 try
941 {
942 (*iter)->disconnectService();
943 traceExec(*iter, "disconnectService",ComputePlacement(*iter));
944 }
945 catch(...)
946 {
947 // Disconnect has failed
948 traceExec(*iter, "disconnectService failed, ABORT",ComputePlacement(*iter));
949 }
950 {//Critical section
952 (*iter)->aborted();
953 _mainSched->notifyFrom(*iter,YACS::ABORT,this);
954 }//End of critical section
955 }
956 catch(...)
957 {
958 std::cerr << "Problem in connectService" << std::endl;
959 try
960 {
961 (*iter)->disconnectService();
962 traceExec(*iter, "disconnectService",ComputePlacement(*iter));
963 }
964 catch(...)
965 {
966 // Disconnect has failed
967 traceExec(*iter, "disconnectService failed, ABORT",ComputePlacement(*iter));
968 }
969 {//Critical section
971 (*iter)->aborted();
972 _mainSched->notifyFrom(*iter,YACS::ABORT,this);
973 }//End of critical section
974 }
975 if((*iter)->getState() == YACS::ERROR)
976 {
977 //try to put all coupled tasks in error
978 std::set<Task*> coupledSet;
979 (*iter)->getCoupledTasks(coupledSet);
980 for (std::set<Task*>::iterator it = coupledSet.begin(); it != coupledSet.end(); ++it)
981 {
982 Task* t=*it;
983 if(t == *iter)continue;
984 if(t->getState() == YACS::ERROR)continue;
985 try
986 {
987 t->disconnectService();
988 traceExec(t, "disconnectService",ComputePlacement(*iter));
989 }
990 catch(...)
991 {
992 // Disconnect has failed
993 traceExec(t, "disconnectService failed, ABORT",ComputePlacement(*iter));
994 }
995 {//Critical section
997 t->aborted();
999 }//End of critical section
1000 traceExec(t, "state:"+Node::getStateName(t->getState()),ComputePlacement(*iter));
1001 }
1002 }
1003 traceExec(*iter, "state:"+Node::getStateName((*iter)->getState()),ComputePlacement(*iter));
1004 }
1005
1006 //Second phase, execute each task in a thread
1007 for(vector<Task *>::const_iterator iter=tasks.begin();iter!=tasks.end();iter++)
1008 {
1009 launchTask(*iter);
1010 }
1011}
void launchTask(Task *task)
Definition: Executor.cxx:1022
StatesForNode
Definition: define.hxx:34
@ TOLOAD
Definition: define.hxx:38
@ TORECONNECT
Definition: define.hxx:48
References _mainSched, _mutexForSchedulerUpdate, YACS::ABORT, ComputePlacement(), YACS::ERROR, testCppPluginInvokation::ex, YACS::ENGINE::Node::getStateName(), launchTask(), YACS::ENGINE::Scheduler::notifyFrom(), yacsorb.CORBAEngineTest::state, gui.Appli::t, YACS::TOLOAD, YACS::TORECONNECT, and traceExec().
Referenced by RunA(), and RunB().
◆ loadParallelTasks()
void Executor::loadParallelTasks ( const std::vector< Task * > &  tasks,
const Executor *  execInst
Definition at line 899 of file Executor.cxx.
900{
901 std::vector<Thread> ths(tasks.size());
902 std::size_t ithread(0);
903 for(std::vector<Task *>::const_iterator iter = _tasks.begin(); iter != _tasks.end(); iter++, ithread++)
904 {
905 DEBTRACE("Executor::loadParallelTasks(Task *task)");
906 struct threadargs *args(new threadargs);
907 args->task = (*iter);
908 args->sched = _mainSched;
909 args->execInst = this;
910 ths[ithread].go(functionForTaskLoad, args, _threadStackSize);
911 }
912 for(ithread=0;ithread<tasks.size();ithread++)
913 ths[ithread].join();
914}
static void * functionForTaskLoad(void *)
Definition: Executor.cxx:1140
References _mainSched, _tasks, _threadStackSize, driver_internal::args, DEBTRACE, and functionForTaskLoad().
Referenced by RunB().
◆ loadState()
bool Executor::loadState ( )
not yet implemented
Definition at line 698 of file Executor.cxx.
699{
700 DEBTRACE("Executor::loadState()");
702 return true;
703}
References _isRunningunderExternalControl, and DEBTRACE.
◆ loadTask() [1/2]
void Executor::loadTask ( Task *  task,
task: Task to load
Definition at line 853 of file Executor.cxx.
854{
855 DEBTRACE("Executor::loadTask(Task *task)");
856 if(task->getState() != YACS::TOLOAD)
857 return;
858 traceExec(task, "state:TOLOAD", ComputePlacement(task));
859 {//Critical section
861 _mainSched->notifyFrom(task,YACS::START,execInst);
862 }//End of critical section
863 try
864 {
865 traceExec(task, "load", ComputePlacement(task));
866 task->load();
867 traceExec(task, "initService", ComputePlacement(task));
868 task->initService();
869 }
870 catch(Exception& ex)
871 {
872 std::cerr << ex.what() << std::endl;
873 {//Critical section
875 task->aborted();
876 _mainSched->notifyFrom(task,YACS::ABORT,execInst);
877 traceExec(task, "state:"+Node::getStateName(task->getState()), ComputePlacement(task));
878 }//End of critical section
879 }
880 catch(...)
881 {
882 std::cerr << "Load failed" << std::endl;
883 {//Critical section
885 task->aborted();
886 _mainSched->notifyFrom(task,YACS::ABORT,execInst);
887 traceExec(task, "state:"+Node::getStateName(task->getState()), ComputePlacement(task));
888 }//End of critical section
889 }
890}
virtual void initService()=0
virtual void load()=0
@ START
Definition: define.hxx:58
References _mainSched, _mutexForSchedulerUpdate, YACS::ABORT, YACS::ENGINE::Task::aborted(), ComputePlacement(), DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::Task::getState(), YACS::ENGINE::Node::getStateName(), YACS::ENGINE::Task::initService(), YACS::ENGINE::Task::load(), YACS::ENGINE::Scheduler::notifyFrom(), YACS::START, YACS::TOLOAD, and traceExec().
◆ loadTask() [2/2]
const WorkloadManager::RunInfo &  runInfo
Definition at line 1423 of file Executor.cxx.
1424{
1425 if(task->getState() != YACS::TOLOAD)
1426 return;
1427 traceExec(task, "state:TOLOAD", ComputePlacement(task));
1428 {//Critical section
1430 _mainSched->notifyFrom(task,YACS::START,this);
1431 }//End of critical section
1432 try
1433 {
1434 std::ostringstream container_name;
1435 container_name << runInfo.type.name << "-" << runInfo.index;
1436 task->imposeResource(runInfo.resource.name, container_name.str());
1437 traceExec(task, "load", ComputePlacement(task));
1438 task->load();
1439 traceExec(task, "initService", ComputePlacement(task));
1440 task->initService();
1441 }
1442 catch(Exception& ex)
1443 {
1444 std::cerr << ex.what() << std::endl;
1445 {//Critical section
1447 task->aborted();
1448 _mainSched->notifyFrom(task,YACS::ABORT, this);
1449 traceExec(task, "state:"+Node::getStateName(task->getState()), ComputePlacement(task));
1450 }//End of critical section
1451 }
1452 catch(...)
1453 {
1454 std::cerr << "Load failed" << std::endl;
1455 {//Critical section
1457 task->aborted();
1458 _mainSched->notifyFrom(task,YACS::ABORT, this);
1459 traceExec(task, "state:"+Node::getStateName(task->getState()), ComputePlacement(task));
1460 }//End of critical section
1461 }
1462}
virtual void imposeResource(const std::string &resource_name, const std::string &container_name)
Definition: Task.hxx:55
References _mainSched, _mutexForSchedulerUpdate, YACS::ABORT, YACS::ENGINE::Task::aborted(), ComputePlacement(), testCppPluginInvokation::ex, YACS::ENGINE::Task::getState(), YACS::ENGINE::Node::getStateName(), YACS::ENGINE::Task::imposeResource(), YACS::ENGINE::Task::initService(), YACS::ENGINE::Task::load(), YACS::ENGINE::Scheduler::notifyFrom(), YACS::START, YACS::TOLOAD, and traceExec().
Referenced by functionForTaskLoad(), YACS::ENGINE::WlmTask::run(), and RunA().
◆ makeDatastreamConnections()
void Executor::makeDatastreamConnections ( Task *  task)
Definition at line 1605 of file Executor.cxx.
1606{
1609 return;
1610 try
1611 {
1612 task->connectService();
1613 traceExec(task, "connectService",ComputePlacement(task));
1614 {//Critical section
1616 task->connected();
1617 }//End of critical section
1618 }
1619 catch(Exception& ex)
1620 {
1621 std::cerr << ex.what() << std::endl;
1622 try
1623 {
1624 (task)->disconnectService();
1625 traceExec(task, "disconnectService",ComputePlacement(task));
1626 }
1627 catch(...)
1628 {
1629 // Disconnect has failed
1630 traceExec(task, "disconnectService failed, ABORT",ComputePlacement(task));
1631 }
1632 {//Critical section
1634 task->aborted();
1635 _mainSched->notifyFrom(task,YACS::ABORT,this);
1636 }//End of critical section
1637 }
1638 catch(...)
1639 {
1640 std::cerr << "Problem in connectService" << std::endl;
1641 try
1642 {
1643 (task)->disconnectService();
1644 traceExec(task, "disconnectService",ComputePlacement(task));
1645 }
1646 catch(...)
1647 {
1648 // Disconnect has failed
1649 traceExec(task, "disconnectService failed, ABORT",ComputePlacement(task));
1650 }
1651 {//Critical section
1653 task->aborted();
1654 _mainSched->notifyFrom(task,YACS::ABORT,this);
1655 }//End of critical section
1656 }
1657 if(task->getState() == YACS::ERROR)
1658 {
1659 //try to put all coupled tasks in error
1660 std::set<Task*> coupledSet;
1661 task->getCoupledTasks(coupledSet);
1662 for (std::set<Task*>::iterator it = coupledSet.begin(); it != coupledSet.end(); ++it)
1663 {
1664 Task* t=*it;
1665 if(t == task)continue;
1666 if(t->getState() == YACS::ERROR)continue;
1667 try
1668 {
1669 t->disconnectService();
1670 traceExec(t, "disconnectService",ComputePlacement(task));
1671 }
1672 catch(...)
1673 {
1674 // Disconnect has failed
1675 traceExec(t, "disconnectService failed, ABORT",ComputePlacement(task));
1676 }
1677 {//Critical section
1679 t->aborted();
1681 }//End of critical section
1682 traceExec(t, "state:"+Node::getStateName(t->getState()),ComputePlacement(task));
1683 }
1684 }
1685 traceExec(task, "state:"+Node::getStateName(task->getState()),ComputePlacement(task));
1686}
virtual void connected()=0
virtual void connectService()=0
References _mainSched, _mutexForSchedulerUpdate, YACS::ABORT, YACS::ENGINE::Task::aborted(), ComputePlacement(), YACS::ENGINE::Task::connected(), YACS::ENGINE::Task::connectService(), YACS::ERROR, testCppPluginInvokation::ex, YACS::ENGINE::Task::getCoupledTasks(), YACS::ENGINE::Task::getState(), YACS::ENGINE::Node::getStateName(), YACS::ENGINE::Scheduler::notifyFrom(), yacsorb.CORBAEngineTest::state, gui.Appli::t, YACS::TOLOAD, YACS::TORECONNECT, and traceExec().
◆ resume()
void Executor::resume ( bool  suspended)
This method is expected to be called in association with suspendASAP method. Expected to be called just after suspendASAP with output of resume as input parameter
Definition at line 660 of file Executor.cxx.
661{
662 if(suspended)
664}
References _mutexForSchedulerUpdate.
Referenced by gui.Appli.Browser::run(), gui.Appli.Browser::step(), and gui.Appli.Browser::susp().
◆ resumeCurrentBreakPoint()
bool Executor::resumeCurrentBreakPoint ( )
When Executor is in state paused or waiting for task completion, the thread running loop RunB waits on condition _condForStepByStep. Thread RunB is waken up.
true when actually wakes up executor
Definition at line 448 of file Executor.cxx.
449{
450 DEBTRACE("Executor::resumeCurrentBreakPoint()");
451 bool ret = false;
452 //bool doDump = false;
453 { // --- Critical section
456 DEBTRACE("_executorState: " << _executorState);
457 switch (_executorState)
458 {
460 case YACS::PAUSED:
461 {
462 _condForStepByStep.notify_all();
464 sendEvent("executor");
465 ret = true;
466 //if (_dumpOnErrorRequested && _errorDetected) doDump =true;
467 break;
468 }
469 case YACS::FINISHED:
470 case YACS::STOPPED:
471 {
472 //if (_dumpOnErrorRequested && _errorDetected) doDump =true;
473 DEBTRACE("Graph Execution finished or stopped !");
474 break;
475 }
476 default :
477 {
478 // debug: no easy way to verify if main loop is acutally waiting on condition
479 }
480 }
481 DEBTRACE("---");
482 //if (doDump) saveState(_dumpErrorFile);
483 } // --- End of critical section
484 return ret;
485}
References _condForStepByStep, _executorState, _isRunningunderExternalControl, _mutexForSchedulerUpdate, DEBTRACE, YACS::FINISHED, YACS::PAUSED, YACS::RUNNING, sendEvent(), YACS::STOPPED, and YACS::WAITINGTASKS.
Referenced by main(), and stopExecution().
◆ RunA()
void Executor::RunA ( Scheduler *  graph,
int  debug = 0,
bool  fromScratch = true
graph: schema to execute
debug: display the graph with dot if debug == 1
fromScratch: if true the graph is reinitialized
Calls Scheduler::getNextTasks and Scheduler::selectRunnableTasks to select tasks to execute
Calls Executor::launchTask to execute a selected Task.
Completion when graph is finished (Scheduler::isFinished)
Definition at line 116 of file Executor.cxx.
117{
118 DEBTRACE("Executor::RunW debug: " << debug << " fromScratch: " << fromScratch);
119 _mainSched=graph;
120 _root = dynamic_cast<ComposedNode *>(_mainSched);
121 if (!_root) throw Exception("Executor::Run, Internal Error!");
122 bool isMore;
123 int i=0;
124 if(debug>1)_displayDot(graph);
125 if (fromScratch)
126 {
127 graph->init();
128 graph->exUpdateState();
129 }
130 if(debug>1)_displayDot(graph);
131 vector<Task *> tasks;
132 vector<Task *>::iterator iter;
133 _toContinue=true;
137 _runningTasks.clear();
139 while(_toContinue)
140 {
142
143 if(debug>2)_displayDot(graph);
144
145 {//Critical section
147 tasks=graph->getNextTasks(isMore);
148 graph->selectRunnableTasks(tasks);
149 }//End of critical section
150
151 if(debug>2)_displayDot(graph);
152
153 for(iter=tasks.begin();iter!=tasks.end();iter++)
154 loadTask(*iter,this);
155
156 if(debug>1)_displayDot(graph);
157
158 launchTasks(tasks);
159
160 if(debug>1)_displayDot(graph);
161
162 {//Critical section
164 _toContinue=!graph->isFinished();
165 }//End of critical section
166 DEBTRACE("_toContinue: " << _toContinue);
167
168 if(debug>0)_displayDot(graph);
169
170 i++;
171 }
172}
void launchTasks(const std::vector< Task * > &tasks)
Definition: Executor.cxx:921
void sleepWhileNoEventsFromAnyRunningTask()
Definition: Executor.cxx:1082
virtual std::vector< Task * > getNextTasks(bool &isMore)=0
virtual bool isFinished()=0
virtual void init(bool start=true)=0
virtual void selectRunnableTasks(std::vector< Task * > &tasks)=0
virtual void exUpdateState()=0
References _displayDot(), _execMode, _isWaitingEventsFromRunningTasks, _mainSched, _mutexForSchedulerUpdate, _numberOfEndedTasks, _numberOfRunningTasks, _root, _runningTasks, _toContinue, YACS::CONTINUE, DEBTRACE, YACS::ENGINE::Scheduler::exUpdateState(), YACS::ENGINE::Scheduler::getNextTasks(), yacsorb.CORBAEngineTest::i, YACS::ENGINE::Scheduler::init(), YACS::ENGINE::Scheduler::isFinished(), launchTasks(), loadTask(), YACS::ENGINE::Scheduler::selectRunnableTasks(), and sleepWhileNoEventsFromAnyRunningTask().
◆ RunB()
void Executor::RunB ( Scheduler *  graph,
int  debug = 0,
To be launch in a thread (main thread controls the progression).
debug: display the graph with dot if debug >0
fromScratch: if false, state from a previous partial exection is already loaded
Calls Executor::checkBreakPoints to verify if a pause is requested
States of execution:
Modes of Execution:
A breakpoint is defined by a node name. The breakpoint is reached when the node becomes ready. Step by Step means execution node by node or group of node by group of nodes. At a given step, the user decides to launch all the ready nodes or only a subset (Caution: some nodes must run in parallel). The next event (end of task) may give a new set of ready nodes, and define a new step.
The graph execution may be controled by a pilot which sends requests. Requests are asynchronous. Requests are taken into account only on certain states, otherwise return the status IgnoredRequest.
If the pilot wants to wait the state YACS::PAUSED or YACS::WAITINGTASKS, synchronisation is obtained with:
TO BE VALIDATED:
  • Pilot may connect to executor during execution, or deconnect.
  • Several Pilots may be connected at the same time (for observation...)
Definition at line 235 of file Executor.cxx.
236{
237 DEBTRACE("Executor::RunB debug: "<< graph->getName() <<" "<< debug<<" fromScratch: "<<fromScratch);
238
239 { // --- Critical section
241 _mainSched = graph;
242 _root = dynamic_cast<ComposedNode *>(_mainSched);
243 if (!_root) throw Exception("Executor::Run, Internal Error!");
245 sendEvent("executor");
246 _toContinue=true;
247 _isOKToEnd = false;
248 _errorDetected = false;
251 _runningTasks.clear();
253 string tracefile = "traceExec_";
254 tracefile += _mainSched->getName();
255 _trace.open(tracefile.c_str());
256 _start = std::chrono::steady_clock::now();
257 } // --- End of critical section
258
259 if (debug > 1) _displayDot(graph);
260
261 if (fromScratch)
262 {
263 try
264 {
265 graph->init();
266 graph->exUpdateState();
267 }
268 catch(Exception& ex)
269 {
270 DEBTRACE("exception: "<< (ex.what()));
272 sendEvent("executor");
273 throw;
274 }
275 }
277 sendEvent("executor");
278
279 if (debug > 1) _displayDot(graph);
280
281 vector<Task *>::iterator iter;
282 bool isMore;
283 int problemCount=0;
284 int numberAllTasks;
285
287 sendEvent("executor");
288 while (_toContinue)
289 {
290 DEBTRACE("--- executor main loop");
292 DEBTRACE("--- events...");
293 if (debug > 2) _displayDot(graph);
294 { // --- Critical section
296 std::vector<Task *> tasks = graph->getNextTasks(isMore);
297 graph->selectRunnableTasks(tasks);
299 _tasks = tasks;
300 numberAllTasks=_numberOfRunningTasks+_tasks.size();
301 } // --- End of critical section
302 if (debug > 2) _displayDot(graph);
304 {
305 if (checkBreakPoints()) break; // end of thread requested, OK to exit at once;
306 if (debug > 0) _displayDot(graph);
307 DEBTRACE("---");
309 if (debug > 1) _displayDot(graph);
310 DEBTRACE("---");
312 DEBTRACE("---");
313 }
314 if (debug > 1) _displayDot(graph);
315 { // --- Critical section
316 DEBTRACE("---");
318 //It is possible that the graph is finished but it remains running tasks (it's an error but we must take it into account)
319 if(_numberOfRunningTasks == 0)
320 _toContinue = !graph->isFinished();
321
322 DEBTRACE("_numberOfRunningTasks: " << _numberOfRunningTasks);
323 DEBTRACE("_numberOfEndedTasks: " << _numberOfEndedTasks);
324 DEBTRACE("_toContinue: " << _toContinue);
325 if(_toContinue && numberAllTasks==0)
326 {
327 //Problem : no running tasks and no task to launch ??
328 problemCount++;
329 std::cerr << "Problem in Executor : no running tasks and no task to launch ?? problemCount=" << problemCount << std::endl;
330 //Pause to give a chance to interrupt
331 usleep(1000);
332 if(problemCount > 25)
333 {
334 // Too much problems encountered : stop execution
335 _toContinue=false;
336 }
337 }
338
339 if (! _toContinue)
340 {
342 sendEvent("executor");
343 _condForPilot.notify_all();
344 }
345 } // --- End of critical section
346 if (debug > 0) _displayDot(graph);
347 DEBTRACE("_toContinue: " << _toContinue);
348 }
349
350 DEBTRACE("End of main Loop");
351
352 { // --- Critical section
354 if ( _toContinue) // --- break while(): request to stop detected on checkBreakPoints()
355 {
356 DEBTRACE("stop requested: End soon");
358 _toContinue = false;
359 sendEvent("executor");
360 }
361 } // --- End of critical section
363 {
365 }
366 {
368 _trace.close();
369 }
370 DEBTRACE("End of RunB thread");
371}
Definition: Executor.hxx:74
bool saveState(const std::string &xmlFile)
Definition: Executor.cxx:678
void loadParallelTasks(const std::vector< Task * > &tasks, const Executor *execInst)
Definition: Executor.cxx:899
bool checkBreakPoints()
Definition: Executor.cxx:752
Definition: Executor.hxx:94
Definition: Executor.hxx:93
void filterTasksConsideringContainers(std::vector< Task * > &tsks)
Definition: Executor.cxx:1352
Definition: Executor.hxx:98
virtual std::string getName() const =0
References _condForPilot, _displayDot(), _dumpErrorFile, _dumpOnErrorRequested, _errorDetected, _executorState, _isOKToEnd, _isWaitingEventsFromRunningTasks, _mainSched, _mutexForSchedulerUpdate, _mutexForTrace, _numberOfEndedTasks, _numberOfRunningTasks, _root, _runningTasks, _start, _tasks, _toContinue, _trace, checkBreakPoints(), DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::Scheduler::exUpdateState(), filterTasksConsideringContainers(), YACS::FINISHED, YACS::ENGINE::Scheduler::getName(), YACS::ENGINE::Scheduler::getNextTasks(), YACS::ENGINE::Scheduler::init(), YACS::INITIALISED, YACS::ENGINE::Scheduler::isFinished(), launchTasks(), loadParallelTasks(), YACS::NOTYETINITIALIZED, YACS::RUNNING, saveState(), YACS::ENGINE::Scheduler::selectRunnableTasks(), sendEvent(), sleepWhileNoEventsFromAnyRunningTask(), and YACS::STOPPED.
Referenced by executorFunc(), and RunW().
◆ runTask()
YACS::Event Executor::runTask ( Task *  task)
Definition at line 1535 of file Executor.cxx.
1536{
1537 { // --- Critical section
1539 task->begin(); //change state to ACTIVATED
1540 }
1541 traceExec(task, "state:"+Node::getStateName(task->getState()),ComputePlacement(task));
1542
1544 {
1545 Node *node(dynamic_cast<Node *>(task));
1546 ComposedNode *gfn(dynamic_cast<ComposedNode *>(_mainSched));
1547 if(node!=0 && gfn!=0)
1548 node->applyDPLScope(gfn);
1549 }
1550
1552 try
1553 {
1554 traceExec(task, "start execution",ComputePlacement(task));
1555 task->execute();
1556 traceExec(task, "end execution OK",ComputePlacement(task));
1557 }
1558 catch(Exception& ex)
1559 {
1560 std::cerr << "YACS Exception during execute" << std::endl;
1561 std::cerr << ex.what() << std::endl;
1562 ev=YACS::ABORT;
1563 string message = "end execution ABORT, ";
1564 message += ex.what();
1565 traceExec(task, message,ComputePlacement(task));
1566 }
1567 catch(...)
1568 {
1569 // Execution has failed
1570 std::cerr << "Execution has failed: unknown reason" << std::endl;
1571 ev=YACS::ABORT;
1572 traceExec(task, "end execution ABORT, unknown reason",ComputePlacement(task));
1573 }
1574
1575 // Disconnect task
1576 try
1577 {
1578 DEBTRACE("task->disconnectService()");
1579 task->disconnectService();
1580 traceExec(task, "disconnectService",ComputePlacement(task));
1581 }
1582 catch(...)
1583 {
1584 // Disconnect has failed
1585 std::cerr << "disconnect has failed" << std::endl;
1586 ev=YACS::ABORT;
1587 traceExec(task, "disconnectService failed, ABORT",ComputePlacement(task));
1588 }
1589 //
1590
1591 std::string placement(ComputePlacement(task));
1592
1593 // container management for HomogeneousPoolOfContainer
1594
1595 HomogeneousPoolContainer *contC(dynamic_cast<HomogeneousPoolContainer *>(task->getContainer()));
1596 if(contC)
1597 {
1598 std::lock_guard<std::mutex> alckCont(contC->getLocker());
1599 contC->release(task);
1600 }
1601
1602 return ev;
1603}
References _mainSched, _mutexForSchedulerUpdate, YACS::ABORT, YACS::ENGINE::Node::applyDPLScope(), YACS::ENGINE::Task::begin(), ComputePlacement(), DEBTRACE, YACS::ENGINE::Task::disconnectService(), testCppPluginInvokation::ex, YACS::ENGINE::Task::execute(), YACS::FINISH, YACS::ENGINE::Task::getContainer(), getDPLScopeSensitive(), YACS::ENGINE::HomogeneousPoolContainer::getLocker(), YACS::ENGINE::Task::getState(), YACS::ENGINE::Node::getStateName(), YACS::ENGINE::HomogeneousPoolContainer::release(), and traceExec().
◆ RunW()
void Executor::RunW ( Scheduler *  graph,
int  debug = 0,
Definition at line 1833 of file Executor.cxx.
1834{
1835 std::string str_value = graph->getProperty("executor");
1836 if(str_value == "WorkloadManager"
1837 || str_value == "WORKLOADMANAGER"
1838 || str_value == "workloadmanager"
1839 || str_value == "WorkLoadManager")
1840 runWlm(graph, debug, fromScratch);
1841 else
1842 RunB(graph, debug, fromScratch);
1843}
void RunB(Scheduler *graph, int debug=0, bool fromScratch=true)
Definition: Executor.cxx:235
void runWlm(Scheduler *graph, int debug=0, bool fromScratch=true)
Definition: Executor.cxx:1688
virtual std::string getProperty(const std::string &name)=0
References YACS::ENGINE::Scheduler::getProperty(), RunB(), and runWlm().
Referenced by driverTest(), main(), and Proc_i::RunW().
◆ runWlm()
void Executor::runWlm ( Scheduler *  graph,
int  debug = 0,
Definition at line 1688 of file Executor.cxx.
1689{
1690 DEBTRACE("Executor::runWlm debug: "<< graph->getName() <<" "<< debug<<" fromScratch: "<<fromScratch);
1691 { // --- Critical section
1693 _mainSched = graph;
1694 _root = dynamic_cast<ComposedNode *>(_mainSched);
1695 if (!_root) throw Exception("Executor::Run, Internal Error!");
1697 sendEvent("executor");
1698 _toContinue=true;
1699 _isOKToEnd = false;
1700 _errorDetected = false;
1703 _runningTasks.clear();
1705 string tracefile = "traceExec_";
1706 tracefile += _mainSched->getName();
1707 _trace.open(tracefile.c_str());
1708 _start = std::chrono::steady_clock::now();
1709 } // --- End of critical section
1710
1711 if (debug > 1) _displayDot(graph);
1712
1713 if (fromScratch)
1714 {
1715 try
1716 {
1717 graph->init();
1718 graph->exUpdateState();
1719 }
1720 catch(Exception& ex)
1721 {
1722 DEBTRACE("exception: "<< (ex.what()));
1724 sendEvent("executor");
1725 throw;
1726 }
1727 }
1729 sendEvent("executor");
1730
1731 if (debug > 1) _displayDot(graph);
1732
1733 bool isMore;
1734 int problemCount=0;
1735 int numberAllTasks;
1736
1738 sendEvent("executor");
1739
1740 WorkloadManager::DefaultAlgorithm algo;
1741 WorkloadManager::WorkloadManager wlm(algo);
1743 wlm.start();
1744
1745 while (_toContinue)
1746 {
1747 DEBTRACE("--- executor main loop");
1749 DEBTRACE("--- events...");
1750 if (debug > 2) _displayDot(graph);
1751 { // --- Critical section
1753 std::vector<Task *> readyTasks=graph->getNextTasks(isMore);
1754 graph->selectRunnableTasks(readyTasks);
1755 _tasks.clear();
1756 for(Task * t : readyTasks)
1757 if(_runningTasks.find(t) == _runningTasks.end())
1758 _tasks.push_back(t);
1759 // TODO: to be removed
1761 numberAllTasks=_numberOfRunningTasks+_tasks.size();
1762 } // --- End of critical section
1763 if (debug > 2) _displayDot(graph);
1764 DEBTRACE("--- events...");
1766 {
1767 if (checkBreakPoints()) break; // end of thread requested, OK to exit at once;
1768 for(Task * task : _tasks)
1769 {
1770 beginTask(task);
1771 WlmTask* newTask = new WlmTask(*this, task);
1772 wlm.addTask(newTask);
1773 }
1774 }
1775 if (debug > 1) _displayDot(graph);
1776 { // --- Critical section
1777 DEBTRACE("---");
1779 //It is possible that the graph is finished but it remains running tasks (it's an error but we must take it into account)
1780 _toContinue = !graph->isFinished();
1781
1782 DEBTRACE("_numberOfRunningTasks: " << _numberOfRunningTasks);
1783 DEBTRACE("_numberOfEndedTasks: " << _numberOfEndedTasks);
1784 DEBTRACE("_toContinue: " << _toContinue);
1785 if(_toContinue && numberAllTasks==0)
1786 {
1787 //Problem : no running tasks and no task to launch ??
1788 problemCount++;
1789 std::cerr << "Problem in Executor : no running tasks and no task to launch ?? problemCount=" << problemCount << std::endl;
1790 //Pause to give a chance to interrupt
1791 usleep(1000);
1792 if(problemCount > 25)
1793 {
1794 // Too much problems encountered : stop execution
1795 _toContinue=false;
1796 }
1797 }
1798
1799 if (! _toContinue)
1800 {
1802 sendEvent("executor");
1803 _condForPilot.notify_all();
1804 }
1805 } // --- End of critical section
1806 if (debug > 0) _displayDot(graph);
1807 DEBTRACE("_toContinue: " << _toContinue);
1808 }
1809
1810 wlm.stop();
1811 DEBTRACE("End of main Loop");
1812
1813 { // --- Critical section
1815 if ( _toContinue) // --- break while(): request to stop detected on checkBreakPoints()
1816 {
1817 DEBTRACE("stop requested: End soon");
1819 _toContinue = false;
1820 sendEvent("executor");
1821 }
1822 } // --- End of critical section
1824 {
1826 }
1827 {
1829 _trace.close();
1830 }
1831}
void beginTask(Task *task)
Definition: Executor.cxx:1464
static void loadResources(WorkloadManager::WorkloadManager &wm)
Definition: WlmTask.cxx:84
References _condForPilot, _displayDot(), _dumpErrorFile, _dumpOnErrorRequested, _errorDetected, _executorState, _isOKToEnd, _isWaitingEventsFromRunningTasks, _mainSched, _mutexForSchedulerUpdate, _mutexForTrace, _numberOfEndedTasks, _numberOfRunningTasks, _root, _runningTasks, _start, _tasks, _toContinue, _trace, beginTask(), checkBreakPoints(), DEBTRACE, testCppPluginInvokation::ex, YACS::ENGINE::Scheduler::exUpdateState(), filterTasksConsideringContainers(), YACS::FINISHED, YACS::ENGINE::Scheduler::getName(), YACS::ENGINE::Scheduler::getNextTasks(), YACS::ENGINE::Scheduler::init(), YACS::INITIALISED, YACS::ENGINE::Scheduler::isFinished(), YACS::ENGINE::WlmTask::loadResources(), YACS::NOTYETINITIALIZED, YACS::RUNNING, saveState(), YACS::ENGINE::Scheduler::selectRunnableTasks(), sendEvent(), sleepWhileNoEventsFromAnyRunningTask(), YACS::STOPPED, and gui.Appli::t.
Referenced by RunW().
◆ saveState()
bool Executor::saveState ( const std::string &  xmlFile)
Definition at line 678 of file Executor.cxx.
679{
680 DEBTRACE("Executor::saveState() in " << xmlFile);
681 bool result = false;
682 try {
685 vst.openFileDump(xmlFile.c_str());
686 _root->accept(&vst);
687 vst.closeFileDump();
688 result = true;
689 }
690 catch(Exception& ex) {
691 std::cerr << ex.what() << std::endl;
692 }
693 return result;
694}
void accept(Visitor *visitor)
References _mutexForSchedulerUpdate, _root, YACS::ENGINE::ComposedNode::accept(), YACS::ENGINE::VisitorSaveState::closeFileDump(), DEBTRACE, testCppPluginInvokation::ex, and YACS::ENGINE::VisitorSaveState::openFileDump().
◆ sendEvent()
void Executor::sendEvent ( const std::string &  event)
The dispatcher is unique and can be obtained by getDispatcher()
Definition at line 1324 of file Executor.cxx.
1325{
1327 YASSERT(disp);
1328 YASSERT(_root);
1329 disp->dispatch(_root,event);
1330}
#define YASSERT(val)
Definition: YacsTrace.hxx:59
Base class for dispatcher in observer pattern.
Definition: Dispatcher.hxx:74
virtual void dispatch(Node *object, const std::string &event)
Definition: Dispatcher.cxx:85
static Dispatcher * getDispatcher()
Definition: Dispatcher.cxx:55
References _root, YACS::ENGINE::Dispatcher::dispatch(), YACS::ENGINE::Dispatcher::getDispatcher(), and YASSERT.
Referenced by checkBreakPoints(), endTask(), functionForTaskExecution(), resumeCurrentBreakPoint(), RunB(), and runWlm().
◆ setDPLScopeSensitive()
void YACS::ENGINE::Executor::setDPLScopeSensitive ( bool  newVal)
Definition at line 108 of file Executor.hxx.
108{ _DPLScopeSensitive=newVal; }
◆ setExecMode()
void Executor::setExecMode ( YACS::ExecutionMode  mode)
The mode can be Continue, step by step, or stop before execution of a node defined in a list of breakpoints.
Definition at line 430 of file Executor.cxx.
431{
432 DEBTRACE("Executor::setExecMode(YACS::ExecutionMode mode) " << mode);
433 { // --- Critical section
436 _execMode = mode;
437 } // --- End of critical section
438}
References _execMode, _isRunningunderExternalControl, _mutexForSchedulerUpdate, and DEBTRACE.
◆ setKeepGoingProperty()
void YACS::ENGINE::Executor::setKeepGoingProperty ( bool  newVal)
Definition at line 106 of file Executor.hxx.
106{ _keepGoingOnFail=newVal; }
◆ setListOfBreakPoints()
void Executor::setListOfBreakPoints ( std::list< std::string >  listOfBreakPoints)
Definition at line 491 of file Executor.cxx.
492{
493 DEBTRACE("Executor::setListOfBreakPoints(std::list<std::string> listOfBreakPoints)");
494 { // --- Critical section
497 _listOfBreakPoints = listOfBreakPoints;
498 } // --- End of critical section
499}
References _isRunningunderExternalControl, _listOfBreakPoints, _mutexForSchedulerUpdate, and DEBTRACE.
◆ setMaxNbOfThreads()
void Executor::setMaxNbOfThreads ( int  maxNbThreads)
Definition at line 1116 of file Executor.cxx.
1117{
1118 _maxNbThreads = static_cast< std::uint32_t >(maxNbThreads);
1119}
◆ setStepsToExecute()
bool Executor::setStepsToExecute ( std::list< std::string >  listToExecute)
Behaviour is unpredictable if the list is not a subset of the list given by Executor::getTasksToLoad in the current step. If some nodes must run in parallel, they must stay together in the list.
Definition at line 545 of file Executor.cxx.
546{
547 DEBTRACE("Executor::setStepsToExecute(std::list<std::string> listToExecute)");
548 bool ret = true;
549 vector<Task *>::iterator iter;
550 vector<Task *> restrictedTasks;
551 { // --- Critical section
554 switch (_executorState)
555 {
557 case YACS::PAUSED:
558 {
559 for (iter=_tasksSave.begin(); iter!=_tasksSave.end(); iter++)
560 {
561 string readyNode = _mainSched->getTaskName(*iter);
562 if (find(listToExecute.begin(), listToExecute.end(), readyNode)
563 != listToExecute.end())
564 {
565 restrictedTasks.push_back(*iter);
566 DEBTRACE("node to execute " << readyNode);
567 }
568 }
569 _tasks.clear();
570 for (iter=restrictedTasks.begin(); iter!=restrictedTasks.end(); iter++)
571 {
572 _tasks.push_back(*iter);
573 }
574 break;
575 }
578 case YACS::RUNNING:
579 case YACS::FINISHED:
580 case YACS::STOPPED:
581 default:
582 {
583 break;
584 }
585 }
586 } // --- End of critical section
587
588 _tasks.clear();
589 for (iter=restrictedTasks.begin(); iter!=restrictedTasks.end(); iter++)
590 {
591 _tasks.push_back(*iter);
592 }
593 for (iter=_tasks.begin(); iter!=_tasks.end(); iter++)
594 {
595 string readyNode = _mainSched->getTaskName(*iter);
596 DEBTRACE("selected node to execute " << readyNode);
597 }
598
599 return ret;
600}
References _executorState, _isRunningunderExternalControl, _mainSched, _mutexForSchedulerUpdate, _tasks, _tasksSave, DEBTRACE, YACS::FINISHED, YACS::ENGINE::Scheduler::getTaskName(), YACS::INITIALISED, YACS::NOTYETINITIALIZED, YACS::PAUSED, YACS::RUNNING, YACS::STOPPED, and YACS::WAITINGTASKS.
◆ setStopOnError()
void Executor::setStopOnError ( bool  dumpRequested = false,
std::string  xmlFile = ""
ask to stop execution on the first node found in error
dumpRequestedproduce a state dump when an error is found
xmlFilename of file used for state dump
Definition at line 399 of file Executor.cxx.
400{
401 { // --- Critical section
403 _dumpErrorFile=xmlFile;
405 _dumpOnErrorRequested = dumpRequested;
406 if (dumpRequested && xmlFile.empty())
407 throw YACS::Exception("dump on error requested and no filename given for dump");
408 DEBTRACE("_dumpErrorFile " << _dumpErrorFile << " " << _dumpOnErrorRequested);
409 } // --- End of critical section
410}
References _dumpErrorFile, _dumpOnErrorRequested, _mutexForSchedulerUpdate, _stopOnErrorRequested, and DEBTRACE.
◆ sleepWhileNoEventsFromAnyRunningTask()
void Executor::sleepWhileNoEventsFromAnyRunningTask ( )
Definition at line 1082 of file Executor.cxx.
1083{
1084 DEBTRACE("Executor::sleepWhileNoEventsFromAnyRunningTask()");
1085// _semForNewTasksToPerform.wait(); //----utiliser pthread_cond_wait(pthread_cond_t *cond, pthread_mutex_t *mutex);
1088 {
1090 _condForNewTasksToPerform.wait(_mutexForSchedulerUpdate); // mutex released during wait
1091 }
1093 DEBTRACE("---");
1094}
Definition: Executor.hxx:69
References _condForNewTasksToPerform, _isWaitingEventsFromRunningTasks, _mutexForSchedulerUpdate, _numberOfEndedTasks, _numberOfRunningTasks, and DEBTRACE.
Referenced by RunA(), RunB(), and runWlm().
◆ stopExecution()
void Executor::stopExecution ( )
stops the execution as soon as possible
Definition at line 668 of file Executor.cxx.
669{
671 //waitPause();
672 _isOKToEnd = true;
674}
void setExecMode(YACS::ExecutionMode mode)
Dynamically set the current mode of execution.
Definition: Executor.cxx:430
bool resumeCurrentBreakPoint()
wake up executor when in pause
Definition: Executor.cxx:448
References _isOKToEnd, resumeCurrentBreakPoint(), setExecMode(), and YACS::STEPBYSTEP.
◆ suspendASAP()
bool Executor::suspendASAP ( )
This method can be called at any time simultaneously during a RunB call. This method will wait until the executor is locked in a consistent state of a running graph.
This method is expected to be called in association with resume method. The returned parameter is expected to be transfered to resume method.
Definition at line 643 of file Executor.cxx.
644{
645 // no AutoLocker here. It's not a bug.
648 {// execution is finished
650 return false;// the executor is no more running
651 }
652 //general case. Leave method with locker in locked status
653 return true;
654}
References _executorState, _mutexForSchedulerUpdate, _toContinue, and YACS::FINISHED.
◆ traceExec()
void Executor::traceExec ( Task *  task,
const std::string &  message,
const std::string &  placement
Definition at line 1301 of file Executor.cxx.
1302{
1303 string nodeName = _mainSched->getTaskName(task);
1304 Container *cont = task->getContainer();
1305 string containerName = "---";
1306 if (cont)
1307 containerName = cont->getName();
1308
1309 std::chrono::steady_clock::time_point now = std::chrono::steady_clock::now();
1310 std::chrono::milliseconds millisec;
1311 millisec = std::chrono::duration_cast<std::chrono::milliseconds>(now -_start);
1312 double elapse = double(millisec.count()) / 1000.0;
1313 {
1315 _trace << elapse << " " << containerName << " " << placement << " " << nodeName << " " << message << endl;
1316 _trace << flush;
1317 }
1318}
Definition: Container.hxx:81
References _mainSched, _mutexForTrace, _start, _trace, YACS::ENGINE::Task::getContainer(), YACS::ENGINE::Container::getName(), YACS::ENGINE::Scheduler::getTaskName(), and threadargs::task.
◆ unsetStopOnError()
void Executor::unsetStopOnError ( )
ask to do not stop execution on nodes found in error
Definition at line 416 of file Executor.cxx.
417{
418 { // --- Critical section
421 } // --- End of critical section
422}
References _mutexForSchedulerUpdate, and _stopOnErrorRequested.
◆ waitPause()
void Executor::waitPause ( )
suspend pilot execution until Executor is in pause or waiting tasks completion mode.
Do nothing if execution is finished or in pause. Wait first step if Executor is running or in initialization.
Definition at line 608 of file Executor.cxx.
609{
610 DEBTRACE("Executor::waitPause()" << _executorState);
611 { // --- Critical section
614 switch (_executorState)
615 {
616 default:
617 case YACS::STOPPED:
618 case YACS::FINISHED:
620 case YACS::PAUSED:
621 {
622 break;
623 }
626 case YACS::RUNNING:
627 {
628 _condForPilot.wait(_mutexForSchedulerUpdate); // wait until executor is PAUSED or WAITINGTASKS
629 break;
630 }
631 }
632 } // --- End of critical section
633 DEBTRACE("---");
634}
References _condForPilot, _executorState, _isRunningunderExternalControl, _mutexForSchedulerUpdate, DEBTRACE, YACS::FINISHED, YACS::INITIALISED, YACS::NOTYETINITIALIZED, YACS::PAUSED, YACS::RUNNING, YACS::STOPPED, and YACS::WAITINGTASKS.
◆ waitResume()
void Executor::waitResume ( )
in modes Step By step or with BreakPoint, wait until pilot resumes the execution
With the condition Mutex, the mutex is released atomically during the wait. Pilot calls Executor::resumeCurrentBreakPoint to resume execution. Must be called while mutex is locked.
Definition at line 840 of file Executor.cxx.
841{
842 DEBTRACE("Executor::waitResume()");
843 _condForStepByStep.wait(_mutexForSchedulerUpdate); // wait until pilot calls resumeCurrentBreakPoint()
844 DEBTRACE("---");
845}
References _condForStepByStep, _mutexForSchedulerUpdate, and DEBTRACE.
◆ wakeUp()
void Executor::wakeUp ( )
must be used protected by _mutexForSchedulerUpdate!
Definition at line 1099 of file Executor.cxx.
1100{
1101 DEBTRACE("Executor::wakeUp() " << _isWaitingEventsFromRunningTasks);
1103 {
1105 _condForNewTasksToPerform.notify_all();
1106 }
1107 else
1109}
References _condForNewTasksToPerform, _isWaitingEventsFromRunningTasks, _numberOfEndedTasks, and DEBTRACE.
Referenced by endTask(), and functionForTaskExecution().
◆ _condForNewTasksToPerform
YACS::BASES::Condition YACS::ENGINE::Executor::_condForNewTasksToPerform
Definition at line 69 of file Executor.hxx.
Referenced by sleepWhileNoEventsFromAnyRunningTask(), and wakeUp().
◆ _condForPilot
YACS::BASES::Condition YACS::ENGINE::Executor::_condForPilot
◆ _condForStepByStep
YACS::BASES::Condition YACS::ENGINE::Executor::_condForStepByStep
◆ _DPLScopeSensitive
bool YACS::ENGINE::Executor::_DPLScopeSensitive
specifies if scope DynParaLoop is active or not. False by default.
Definition at line 97 of file Executor.hxx.
◆ _dumpErrorFile
std::string YACS::ENGINE::Executor::_dumpErrorFile
Definition at line 94 of file Executor.hxx.
Referenced by RunB(), runWlm(), and setStopOnError().
◆ _dumpOnErrorRequested
bool YACS::ENGINE::Executor::_dumpOnErrorRequested
Definition at line 79 of file Executor.hxx.
Referenced by Executor(), RunB(), runWlm(), and setStopOnError().
◆ _errorDetected
bool YACS::ENGINE::Executor::_errorDetected
Definition at line 80 of file Executor.hxx.
Referenced by endTask(), Executor(), functionForTaskExecution(), RunB(), and runWlm().
◆ _execMode
YACS::ExecutionMode YACS::ENGINE::Executor::_execMode
◆ _executorState
◆ _isOKToEnd
bool YACS::ENGINE::Executor::_isOKToEnd
◆ _isRunningunderExternalControl
◆ _isWaitingEventsFromRunningTasks
bool YACS::ENGINE::Executor::_isWaitingEventsFromRunningTasks
Definition at line 82 of file Executor.hxx.
Referenced by RunA(), RunB(), runWlm(), sleepWhileNoEventsFromAnyRunningTask(), and wakeUp().
◆ _keepGoingOnFail
bool YACS::ENGINE::Executor::_keepGoingOnFail
Definition at line 95 of file Executor.hxx.
◆ _listOfBreakPoints
std::list<std::string> YACS::ENGINE::Executor::_listOfBreakPoints
Definition at line 89 of file Executor.hxx.
Referenced by checkBreakPoints(), and setListOfBreakPoints().
◆ _listOfTasksToLoad
std::list<std::string> YACS::ENGINE::Executor::_listOfTasksToLoad
Definition at line 90 of file Executor.hxx.
Referenced by checkBreakPoints(), and getTasksToLoad().
◆ _mainSched
◆ _maxNbThreads
std::uint32_t YACS::ENGINE::Executor::_maxNbThreads = 10000
◆ _maxThreads
int Executor::_maxThreads
Definition at line 131 of file Executor.hxx.
Referenced by Executor(), launchTask(), and YACS::ENGINE::Runtime::Runtime().
◆ _mutexForNbOfConcurrentThreads
YACS::BASES::Mutex YACS::ENGINE::Executor::_mutexForNbOfConcurrentThreads
Definition at line 68 of file Executor.hxx.
Referenced by getNbOfThreads().
◆ _mutexForSchedulerUpdate
◆ _mutexForTrace
YACS::BASES::Mutex YACS::ENGINE::Executor::_mutexForTrace
Definition at line 74 of file Executor.hxx.
Referenced by RunB(), runWlm(), and traceExec().
◆ _nbOfConcurrentThreads
int YACS::ENGINE::Executor::_nbOfConcurrentThreads
Definition at line 67 of file Executor.hxx.
◆ _numberOfEndedTasks
int YACS::ENGINE::Executor::_numberOfEndedTasks
Definition at line 85 of file Executor.hxx.
Referenced by Executor(), RunA(), RunB(), runWlm(), sleepWhileNoEventsFromAnyRunningTask(), and wakeUp().
◆ _numberOfRunningTasks
int YACS::ENGINE::Executor::_numberOfRunningTasks
◆ _root
ComposedNode* YACS::ENGINE::Executor::_root
Definition at line 66 of file Executor.hxx.
Referenced by Executor(), RunA(), RunB(), runWlm(), saveState(), and sendEvent().
◆ _runningTasks
std::set<Task *> YACS::ENGINE::Executor::_runningTasks
◆ _semForMaxThreads
YACS::BASES::Semaphore YACS::ENGINE::Executor::_semForMaxThreads
Definition at line 70 of file Executor.hxx.
Referenced by functionForTaskExecution(), and launchTask().
◆ _semThreadCnt
int YACS::ENGINE::Executor::_semThreadCnt
Definition at line 86 of file Executor.hxx.
Referenced by Executor(), functionForTaskExecution(), and launchTask().
◆ _start
std::chrono::steady_clock::time_point YACS::ENGINE::Executor::_start
Definition at line 98 of file Executor.hxx.
◆ _stopOnErrorRequested
bool YACS::ENGINE::Executor::_stopOnErrorRequested
◆ _tasks
std::vector<Task *> YACS::ENGINE::Executor::_tasks
Definition at line 91 of file Executor.hxx.
Referenced by checkBreakPoints(), loadParallelTasks(), RunB(), runWlm(), and setStepsToExecute().
◆ _tasksSave
std::vector<Task *> YACS::ENGINE::Executor::_tasksSave
Definition at line 92 of file Executor.hxx.
Referenced by checkBreakPoints(), and setStepsToExecute().
◆ _threadStackSize
size_t Executor::_threadStackSize
Definition at line 132 of file Executor.hxx.
Referenced by launchTask(), loadParallelTasks(), and YACS::ENGINE::Runtime::Runtime().
◆ _toContinue
bool YACS::ENGINE::Executor::_toContinue
Definition at line 76 of file Executor.hxx.
Referenced by Executor(), isNotFinished(), RunA(), RunB(), runWlm(), and suspendASAP().
◆ _trace
std::ofstream YACS::ENGINE::Executor::_trace
Definition at line 93 of file Executor.hxx.
