YACS::ENGINE::VisitorSaveState Class Reference
#include <VisitorSaveState.hxx>
Inheritance diagram for YACS::ENGINE::VisitorSaveState:
Collaboration diagram for YACS::ENGINE::VisitorSaveState:
 VisitorSaveState (ComposedNode *root)
virtual ~VisitorSaveState ()
void openFileDump (const std::string &xmlDump)
void closeFileDump ()
virtual void visitBloc (Bloc *node)
virtual void visitElementaryNode (ElementaryNode *node)
void visitForEachLoop (ForEachLoop *node) override
void visitForEachLoopDyn (ForEachLoopDyn *node) override
virtual void visitOptimizerLoop (OptimizerLoop *node)
virtual void visitDynParaLoop (DynParaLoop *node)
virtual void visitForLoop (ForLoop *node)
virtual void visitInlineNode (InlineNode *node)
virtual void visitInlineFuncNode (InlineFuncNode *node)
virtual void visitLoop (Loop *node)
virtual void visitProc (Proc *node)
virtual void visitServiceNode (ServiceNode *node)
virtual void visitServerNode (ServerNode *node)
virtual void visitServiceInlineNode (ServiceInlineNode *node)
virtual void visitSwitch (Switch *node)
virtual void visitWhileLoop (WhileLoop *node)
virtual void visitPresetNode (DataNode *node)
virtual void visitOutNode (DataNode *node)
virtual void visitStudyInNode (DataNode *node)
virtual void visitStudyOutNode (DataNode *node)
- Public Member Functions inherited from YACS::ENGINE::Visitor
 Visitor (ComposedNode *root)
virtual void visitBloc (Bloc *node)=0
virtual void visitElementaryNode (ElementaryNode *node)=0
virtual void visitForEachLoop (ForEachLoop *node)=0
virtual void visitForEachLoopDyn (ForEachLoopDyn *node)=0
virtual void visitOptimizerLoop (OptimizerLoop *node)=0
virtual void visitDynParaLoop (DynParaLoop *node)=0
virtual void visitForLoop (ForLoop *node)=0
virtual void visitInlineNode (InlineNode *node)=0
virtual void visitInlineFuncNode (InlineFuncNode *node)=0
virtual void visitLoop (Loop *node)=0
virtual void visitProc (Proc *node)=0
virtual void visitServiceNode (ServiceNode *node)=0
virtual void visitServerNode (ServerNode *node)=0
virtual void visitServiceInlineNode (ServiceInlineNode *node)=0
virtual void visitSwitch (Switch *node)=0
virtual void visitWhileLoop (WhileLoop *node)=0
virtual void visitPresetNode (DataNode *node)=0
virtual void visitOutNode (DataNode *node)=0
virtual void visitStudyInNode (DataNode *node)=0
virtual void visitStudyOutNode (DataNode *node)=0
std::ofstream _out
std::map< int, std::string > _nodeStateName
- Protected Attributes inherited from YACS::ENGINE::Visitor
ComposedNode * _root
- Protected Member Functions inherited from YACS::ENGINE::Visitor
std::map< std::string, std::string > getNodeProperties (Node *node)
std::map< std::string, TypeCode * > getTypeCodeMap (Proc *proc)
std::map< std::string, Container * > getContainerMap (Proc *proc)
std::list< TypeCodeObjref * > getListOfBases (TypeCodeObjref *objref)
Definition at line 35 of file VisitorSaveState.hxx.
◆ VisitorSaveState()
VisitorSaveState::VisitorSaveState ( ComposedNode *  root)
Definition at line 47 of file VisitorSaveState.cxx.
47 : Visitor(root)
48{
52 _nodeStateName[YACS::TOACTIVATE] ="TOACTIVATE";
53 _nodeStateName[YACS::ACTIVATED] ="ACTIVATED";
54 _nodeStateName[YACS::DESACTIVATED] ="DESACTIVATED";
56 _nodeStateName[YACS::SUSPENDED] ="SUSPENDED";
57 _nodeStateName[YACS::LOADFAILED] ="LOADFAILED";
58 _nodeStateName[YACS::EXECFAILED] ="EXECFAILED";
60 _nodeStateName[YACS::INTERNALERR] ="INTERNALERR";
61 _nodeStateName[YACS::DISABLED] ="DISABLED";
64}
Visitor(ComposedNode *root)
Definition: Visitor.cxx:28
@ FAILED
Definition: define.hxx:51
@ DESACTIVATED
Definition: define.hxx:42
@ EXECFAILED
Definition: define.hxx:46
@ TOLOAD
Definition: define.hxx:38
@ LOADED
Definition: define.hxx:39
@ READY
Definition: define.hxx:37
@ ACTIVATED
Definition: define.hxx:41
@ INTERNALERR
Definition: define.hxx:49
@ DONE
Definition: define.hxx:43
@ TOACTIVATE
Definition: define.hxx:40
@ SUSPENDED
Definition: define.hxx:44
@ PAUSE
Definition: define.hxx:47
@ DISABLED
Definition: define.hxx:50
@ LOADFAILED
Definition: define.hxx:45
@ ERROR
Definition: define.hxx:52
References _nodeStateName, YACS::ACTIVATED, YACS::DESACTIVATED, YACS::DISABLED, YACS::DONE, YACS::ERROR, YACS::EXECFAILED, YACS::FAILED, YACS::INTERNALERR, YACS::LOADED, YACS::LOADFAILED, YACS::PAUSE, YACS::READY, YACS::SUSPENDED, YACS::TOACTIVATE, and YACS::TOLOAD.
◆ ~VisitorSaveState()
VisitorSaveState::~VisitorSaveState ( )
Definition at line 66 of file VisitorSaveState.cxx.
67{
68 if (_out)
69 {
70 _out << "</graphState>" << endl;
71 _out.close();
72 }
73}
References _out.
◆ closeFileDump()
void VisitorSaveState::closeFileDump ( )
Definition at line 87 of file VisitorSaveState.cxx.
88{
89 if (!_out) throw Exception("No file open for dump state");
90 _out << "</graphState>" << endl;
91 _out.close();
92}
References _out.
Referenced by dumpState(), Handler(), main(), YACS::ENGINE::Executor::saveState(), YACS::ENGINE::Proc::saveState(), and YACS::ENGINE::schemaSaveStateUnsafe().
◆ openFileDump()
void VisitorSaveState::openFileDump ( const std::string &  xmlDump)
Definition at line 75 of file VisitorSaveState.cxx.
76{
77 _out.open(xmlDump.c_str(), ios::out);
78 if (!_out)
79 {
80 string what = "Impossible to open file for writing: " + xmlDump;
81 throw Exception(what);
82 }
83 _out << "<?xml version='1.0'?>" << endl;
84 _out << "<graphState>" << endl;
85}
References _out.
◆ visitBloc()
void VisitorSaveState::visitBloc ( Bloc *  node)
Implements YACS::ENGINE::Visitor.
Definition at line 145 of file VisitorSaveState.cxx.
146{
147 node->ComposedNode::accept(this);
148 if (!_out) throw Exception("No file open for dump state");
149 string name = _root->getName();
150 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
151 DEBTRACE("VisitorSaveState::visitBloc ------------- " << name);
152 _out << " <node type='bloc'>" << endl;
153 _out << " <name>" << name << "</name>" << endl;
154 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
155
156 _out << " </node>" << endl;
157}
std::string getName() const
virtual YACS::StatesForNode getState() const
Definition: Node.hxx:118
Definition: Visitor.hxx:85
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), and YACS::ENGINE::Node::getState().
◆ visitDynParaLoop()
void VisitorSaveState::visitDynParaLoop ( DynParaLoop *  node)
Definition at line 214 of file VisitorSaveState.cxx.
215{
216 node->ComposedNode::accept(this);
217}
◆ visitElementaryNode()
void VisitorSaveState::visitElementaryNode ( ElementaryNode *  node)
Definition at line 94 of file VisitorSaveState.cxx.
95{
96 if (!_out) throw Exception("No file open for dump state");
97 string name = _root->getChildName(node);
98 DEBTRACE("VisitorSaveState::visitElementaryNode --- " << name);
99 _out << " <node type='elementaryNode'>" << endl;
100 _out << " <name>" << name << "</name>" << endl;
101 int nodeState = node->getState();
102 _out << " <state>" << _nodeStateName[nodeState] << "</state>" << endl;
103
104 list<InputPort *> setOfInputPort = node->getSetOfInputPort();
105 list<InputPort *>::iterator iter;
106 for(iter = setOfInputPort.begin(); iter != setOfInputPort.end(); iter++)
107 {
108 _out << " <inputPort>" << endl;
109 _out << " <name>" << (*iter)->getName() << "</name>" << endl;
110 try
111 {
112 _out << " ";
113 _out << (*iter)->dump();
114 }
115 catch (YACS::Exception &e)
116 {
117 DEBTRACE("caught YACS:Exception: " << e.what());
118 _out << "<value><error><![CDATA[" << e.what() << "]]></error></value>" << endl;
119 }
120 _out << " </inputPort>" << endl;
121 }
122
123 list<OutputPort *> setOfOutputPort = node->getSetOfOutputPort();
124 list<OutputPort *>::iterator oiter;
125 for(oiter = setOfOutputPort.begin(); oiter != setOfOutputPort.end(); oiter++)
126 {
127 _out << " <outputPort>" << endl;
128 _out << " <name>" << (*oiter)->getName() << "</name>" << endl;
129 try
130 {
131 _out << " ";
132 _out << (*oiter)->dump();
133 }
134 catch (YACS::Exception &e)
135 {
136 DEBTRACE("caught YACS:Exception: " << e.what());
137 _out << "<value><error><![CDATA[" << e.what() << "]]></error></value>" << endl;
138 }
139 _out << " </outputPort>" << endl;
140 }
141
142 _out << " </node>" << endl;
143}
std::list< OutputPort * > getSetOfOutputPort() const
const char * what(void) const noexcept
Definition: Exception.cxx:50
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ElementaryNode::getSetOfInputPort(), YACS::ENGINE::ElementaryNode::getSetOfOutputPort(), YACS::ENGINE::ElementaryNode::getState(), and YACS::Exception::what().
Referenced by visitInlineFuncNode(), visitInlineNode(), visitOutNode(), visitPresetNode(), visitServerNode(), visitServiceInlineNode(), visitServiceNode(), visitStudyInNode(), and visitStudyOutNode().
◆ visitForEachLoop()
void VisitorSaveState::visitForEachLoop ( ForEachLoop *  node)
overridevirtual
Reimplemented in YACS::ENGINE::VisitorSalomeSaveState.
Definition at line 173 of file VisitorSaveState.cxx.
174{
175 node->ComposedNode::accept(this);
176 if (!_out) throw Exception("No file open for dump state");
177 string name = _root->getName();
178 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
179 DEBTRACE("VisitorSaveState::visitForEachLoop ------ " << name);
180 _out << " <node type='forEachLoop'>" << endl;
181 _out << " <name>" << name << "</name>" << endl;
182 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
183
184 _out << " </node>" << endl;
185}
◆ visitForEachLoopDyn()
void VisitorSaveState::visitForEachLoopDyn ( ForEachLoopDyn *  node)
overridevirtual
Definition at line 187 of file VisitorSaveState.cxx.
188{
189 node->ComposedNode::accept(this);
190 if (!_out) throw Exception("No file open for dump state");
191 string name = _root->getName();
192 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
193 DEBTRACE("VisitorSaveState::visitForEachLoopDyn ------ " << name);
194 _out << " <node type='forEachLoopDyn'>" << endl;
195 _out << " <name>" << name << "</name>" << endl;
196 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
197 _out << " </node>" << endl;
198}
◆ visitForLoop()
void VisitorSaveState::visitForLoop ( ForLoop *  node)
Definition at line 234 of file VisitorSaveState.cxx.
235{
236 node->ComposedNode::accept(this);
237 if (!_out) throw Exception("No file open for dump state");
238 string name = _root->getName();
239 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
240 DEBTRACE("VisitorSaveState::visitForLoop ---------- " << name);
241 _out << " <node type='forLoop'>" << endl;
242 _out << " <name>" << name << "</name>" << endl;
243 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
244 _out << " <nbdone>" << node->getNbOfTurns() << "</nbdone>" << endl;
245 InputPort * ip = node->edGetNbOfTimesInputPort();
246 if (ip->isEmpty())
247 throw Exception("NbOfTimesInputPort in forLoop empty, case not handled yet...");
248 Any *val = static_cast<Any*>(ip->get());
249 int nsteps = val->getIntValue();
250 _out << " <nsteps>" << nsteps << "</nsteps>" << endl;
251
252 _out << " </node>" << endl;
253}
Definition: Any.hxx:79
virtual int getIntValue() const =0
InputPort * edGetNbOfTimesInputPort()
Definition: ForLoop.hxx:45
Base class for Input Ports.
Definition: InputPort.hxx:44
virtual void * get() const =0
virtual bool isEmpty()
Definition: InputPort.cxx:70
int getNbOfTurns() const
Definition: Loop.hxx:162
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::ForLoop::edGetNbOfTimesInputPort(), YACS::ENGINE::InputPort::get(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Any::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Loop::getNbOfTurns(), YACS::ENGINE::Node::getState(), and YACS::ENGINE::InputPort::isEmpty().
◆ visitInlineFuncNode()
void VisitorSaveState::visitInlineFuncNode ( InlineFuncNode *  node)
Definition at line 303 of file VisitorSaveState.cxx.
304{
306}
virtual void visitElementaryNode(ElementaryNode *node)
References visitElementaryNode().
◆ visitInlineNode()
void VisitorSaveState::visitInlineNode ( InlineNode *  node)
Definition at line 298 of file VisitorSaveState.cxx.
299{
301}
◆ visitLoop()
void VisitorSaveState::visitLoop ( Loop *  node)
Definition at line 219 of file VisitorSaveState.cxx.
220{
221 node->ComposedNode::accept(this);
222 if (!_out) throw Exception("No file open for dump state");
223 string name = _root->getName();
224 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
225 DEBTRACE("VisitorSaveState::visitLoop ------------- " << name);
226 _out << " <node type ='loop'>" << endl;
227 _out << " <name>" << name << "</name>" << endl;
228 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
229 _out << " <nbdone>" << node->getNbOfTurns() << "</nbdone>" << endl;
230
231 _out << " </node>" << endl;
232}
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Loop::getNbOfTurns(), and YACS::ENGINE::Node::getState().
◆ visitOptimizerLoop()
void VisitorSaveState::visitOptimizerLoop ( OptimizerLoop *  node)
Definition at line 200 of file VisitorSaveState.cxx.
201{
202 node->ComposedNode::accept(this);
203 if (!_out) throw Exception("No file open for dump state");
204 string name = _root->getName();
205 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
206 DEBTRACE("VisitorSaveState::visitOptimizerLoop ------ " << name);
207 _out << " <node type='optimizerLoop'>" << endl;
208 _out << " <name>" << name << "</name>" << endl;
209 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
210
211 _out << " </node>" << endl;
212}
◆ visitOutNode()
void VisitorSaveState::visitOutNode ( DataNode *  node)
Definition at line 328 of file VisitorSaveState.cxx.
329{
331}
◆ visitPresetNode()
void VisitorSaveState::visitPresetNode ( DataNode *  node)
Definition at line 323 of file VisitorSaveState.cxx.
324{
326}
◆ visitProc()
void VisitorSaveState::visitProc ( Proc *  node)
Definition at line 159 of file VisitorSaveState.cxx.
160{
161 node->ComposedNode::accept(this);
162 if (!_out) throw Exception("No file open for dump state");
163 string name = _root->getName();
164 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
165 DEBTRACE("VisitorSaveState::visitProc ------------- " << name);
166 _out << " <node type='proc'>" << endl;
167 _out << " <name>" << name << "</name>" << endl;
168 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
169
170 _out << " </node>" << endl;
171}
◆ visitServerNode()
void VisitorSaveState::visitServerNode ( ServerNode *  node)
Definition at line 313 of file VisitorSaveState.cxx.
314{
316}
◆ visitServiceInlineNode()
void VisitorSaveState::visitServiceInlineNode ( ServiceInlineNode *  node)
Definition at line 318 of file VisitorSaveState.cxx.
319{
321}
◆ visitServiceNode()
void VisitorSaveState::visitServiceNode ( ServiceNode *  node)
Definition at line 308 of file VisitorSaveState.cxx.
309{
311}
◆ visitStudyInNode()
void VisitorSaveState::visitStudyInNode ( DataNode *  node)
Definition at line 333 of file VisitorSaveState.cxx.
334{
336}
◆ visitStudyOutNode()
void VisitorSaveState::visitStudyOutNode ( DataNode *  node)
Definition at line 338 of file VisitorSaveState.cxx.
339{
341}
◆ visitSwitch()
void VisitorSaveState::visitSwitch ( Switch *  node)
Definition at line 278 of file VisitorSaveState.cxx.
279{
280 node->ComposedNode::accept(this);
281 if (!_out) throw Exception("No file open for dump state");
282 string name = _root->getName();
283 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
284 DEBTRACE("VisitorSaveState::visitSwitch ----------- " << name);
285 _out << " <node type='switch'>" << endl;
286 _out << " <name>" << name << "</name>" << endl;
287 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
288 InputPort * ip = node->edGetConditionPort();
289 if (ip->isEmpty())
290 throw Exception("condition in switch empty, case not handled yet...");
291 Any *val = static_cast<Any*>(ip->get());
292 int condition = val->getIntValue();
293 _out << " <condition>" << condition << "</condition>" << endl;
294
295 _out << " </node>" << endl;
296}
InputPort * edGetConditionPort()
Definition: Switch.hxx:115
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::Switch::edGetConditionPort(), YACS::ENGINE::InputPort::get(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::Any::getIntValue(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Node::getState(), and YACS::ENGINE::InputPort::isEmpty().
◆ visitWhileLoop()
void VisitorSaveState::visitWhileLoop ( WhileLoop *  node)
Definition at line 255 of file VisitorSaveState.cxx.
256{
257 node->ComposedNode::accept(this);
258 if (!_out) throw Exception("No file open for dump state");
259 string name = _root->getName();
260 if (static_cast<ComposedNode*>(node) != _root) name = _root->getChildName(node);
261 DEBTRACE("VisitorSaveState::visitWhileLoop -------- " << name);
262 _out << " <node type='whileLoop'>" << endl;
263 _out << " <name>" << name << "</name>" << endl;
264 _out << " <state>" << _nodeStateName[node->getState()] << "</state>" << endl;
265 _out << " <nbdone>" << node->getNbOfTurns() << "</nbdone>" << endl;
266 InputPort * ip = node->edGetConditionPort();
267 if (ip->isEmpty())
268 throw Exception("condition in WhileLoop empty, case not handled yet...");
269 if ( ConditionInputPort* cip = dynamic_cast<ConditionInputPort*>(ip) )
270 {
271 bool condition = cip->getValue();
272 _out << " <condition>" << condition << "</condition>" << endl;
273 }
274
275 _out << " </node>" << endl;
276}
Definition: WhileLoop.hxx:48
References _nodeStateName, _out, YACS::ENGINE::Visitor::_root, DEBTRACE, YACS::ENGINE::WhileLoop::edGetConditionPort(), YACS::ENGINE::ComposedNode::getChildName(), YACS::ENGINE::ComposedNode::getName(), YACS::ENGINE::Loop::getNbOfTurns(), YACS::ENGINE::Node::getState(), and YACS::ENGINE::InputPort::isEmpty().
◆ _nodeStateName
◆ _out
