20#ifndef __VISITOR_SAVESTATE_HXX__
21#define __VISITOR_SAVESTATE_HXX__
40 void openFileDump(
const std::string& xmlDump) ;
42 virtual void visitBloc(
Bloc *node);
48 virtual void visitForLoop(
ForLoop *node);
49 virtual void visitInlineNode(
InlineNode *node);
51 virtual void visitLoop(
Loop *node);
52 virtual void visitProc(
Proc *node);
54 virtual void visitServerNode(
ServerNode *node);
56 virtual void visitSwitch(
Switch *node);
57 virtual void visitWhileLoop(
WhileLoop *node);
58 virtual void visitPresetNode(
DataNode *node);
59 virtual void visitOutNode(
DataNode *node);
60 virtual void visitStudyInNode(
DataNode *node);
61 virtual void visitStudyOutNode(
DataNode *node);
#define YACSLIBENGINE_EXPORT
Base class for dynamically (fully or semifully) built graphs.
Loop node for parametric calculation.
Base class for loop node.
std::map< int, std::string > _nodeStateName
